AVR單片機驅動二相步進電機(單極驅動)簡易程序,帶串口控制
das
2015-4-8 21:15
AVR單片機驅動二相步進電機(單極驅動)簡易程序,帶串口控制。
編譯器為ICC6.31A;
#include"iom16v.h"
#include"macros.h"
#define uint unsigned int
#define uchar unsigned char
#pragma interrupt_handler usart:14
uchar i;
uchar const *p;
uchar zf=1; //電機正反轉標志;
uchar k1=5;
//uchar const timer2dath[10]={};
//uchar const timer2datl[10]={};
unsigned char const suzhu1[16]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,
0x77,0x7c,0x39,0x5e,0x79,0x71};
uchar const bjdjdat[48]={0x80,0xa0,0x20,0x60,0x40,0x50,0x10,0x90,
0x80,0x90,0x10,0x50,0x40,0x60,0x20,0xa0,
0x80,0x20,0x40,0x10,0x80,0x20,0x40,0x10,
0x80,0x10,0x40,0x20,0x80,0x10,0x40,0x20,
0xa0,0x60,0x50,0x90,0xa0,0x60,0x50,0x90,
0xa0,0x90,0x50,0x60,0xa0,0x90,0x50,0x60
};//設置單片機IO口高低電平數據組,用以驅動步進電機的各相按需通電;
uint const timer1dat[11]={36000,23000,13000,7000,4300,3000,2500,2100,1800,1700,0};//定時器1定時數據,用于控制電機的轉速,定時越短轉速越快;
uchar uartdat[4]={0,0,0,0}; //劃出串行通信時所需的寄存器;
uchar add,open,jslopen;
void siansi(unsigned int dat,unsigned char bit,unsigned int time)//數碼管顯示函數
//PORTA&=~BIT(4);
PORTC&=~BIT(7);
PORTA&=~0x17;
PORTB=suzhu1[dat];
PORTA|=bit ;
PORTA|=BIT(4);
PORTC|=BIT(7);
while(time--);
void ioinit()//IO口初始化;
DDRB=0XFF;
DDRD=0XF3;
DDRA|=0X17;
DDRC|=0X80;
PORTD|=0X0f;
void usart()//串行接收中斷處理;
uchar a;
a=UDR;
if(a==168)
open=1;
add=0;
if(a==138&&open)
open=0;
uartdat[add]=a;
jslopen=1;
if(open)
uartdat[add]=a;
add++;
void jsl()//一幀數據處理;
uchar j;
jslopen=0;
switch(uartdat[1])
case 1:
if(uartdat[2])TIMSK|=0X04;
else TIMSK&=~0X04;
case 2:
if(uartdat[2]>0)
k1=uartdat[2]-1;
else k1=10;
case 3:
if(uartdat[2]&&!zf)p=p-8,zf=1;
if(!uartdat[2]&&zf)p=p+8,zf=0;
case 4:
if(uartdat[2]==1&&zf)p=bjdjdat;
if(uartdat[2]==1&&!zf)p=bjdjdat+8;
if(uartdat[2]==2&&zf)p=bjdjdat+16;
if(uartdat[2]==2&&!zf)p=bjdjdat+24;
if(uartdat[2]==3&&zf)p=bjdjdat+32;
if(uartdat[2]==3&&!zf)p=bjdjdat+40;
for(j=0;j<4;j++)
/* 等待發送緩沖器為空 */
while ( !( UCSRA & (1<<UDRE)) )
/* 將數據放入緩沖器,發送數據 */
UDR=uartdat[j];
void uartinit()//串行口初始化;
UCSRA=0X00;
UCSRB=0X98;
UCSRC=0X86;
UBRRH=0X00;
UBRRL=71;
SREG|=0X80;
#pragma interrupt_handler timer1:9
void timer1() //定時器1中斷處理;
TCNT1=65536-timer1dat[k1];
i++;
if(i>7)i=0;
PORTD&=0X0F;
if(k1==10)return;
PORTD|=p[i];
void timer1init()
TCCR1A=0X00;
TCCR1B=0X02;
TIMSK|=0X04;
void main(void)//主程序;
p=bjdjdat;
uartinit();
ioinit();
timer1init();
siansi(timer1dat[k1]%10,7,1000);
siansi(timer1dat[k1]%100/10,6,1000);
siansi(timer1dat[k1]%1000/100,5,1000);
siansi(timer1dat[k1]%10000/1000,4,1000);
siansi(timer1dat[k1]/10000,3,1000);
if(zf)siansi(14,2,1000);
else siansi(15,2,1000);
if(jslopen)jsl();
欧美区在线
在线观看h视频
色在线播放
黄色直接看
欧美一级特黄视频
国产传媒av
在线亚洲精品
国产手机在线视频
一区二区不卡视频
欧美在线视频免费
亚洲最大网站
久久免费网
一区二区三区四区精品
婷婷视频网
4438成人网
日韩资源在线
亚洲黄色一级
av网站免费看
午夜性影院
日韩色黄大片
99爱视频
黄色大片免费在线观看
中文字幕在线看片
亚洲性猛交
www.黄色网
成人av影视
a天堂在线视频
国产一级一片免费播放放a 国产黄色大片
日本www视频
国产一区二区三区免费视频
天天综合色
亚洲毛片av
欧美黄色一区
日韩欧美黄色
色一情一乱一伦一区二区三区
视频一区二区三区在线观看
国产区在线
亚洲欧美日韩另类
欧美日韩一区二区三区
成人精品一区二区三区
免费网站观看www在线观看
