system_stm32f10x.c文件內容分析
piaolin
2015-9-30 13:22
這個文件完成了寫聲明配置,他和對應的頭文件的關系,頭文件里做了些什么工作,為什么要這樣
完成系統時鐘的配置。
#include "stm32f10x.h"
#if defined (STM32F10X_LD_VL) || (defined STM32F10X_MD_VL) || (defined STM32F10X_HD_VL)
#define SYSCLK_FREQ_24MHz 24000000
#else
#define SYSCLK_FREQ_72MHz 72000000
#endif
#if defined (STM32F10X_HD) || (defined STM32F10X_XL) || (defined STM32F10X_HD_VL)
#endif
#define VECT_TAB_OFFSET 0x0
#ifdef SYSCLK_FREQ_HSE
uint32_t SystemCoreClock = SYSCLK_FREQ_HSE;
#elif defined SYSCLK_FREQ_24MHz
uint32_t SystemCoreClock = SYSCLK_FREQ_24MHz;
#elif defined SYSCLK_FREQ_36MHz
uint32_t SystemCoreClock = SYSCLK_FREQ_36MHz;
#elif defined SYSCLK_FREQ_48MHz
uint32_t SystemCoreClock = SYSCLK_FREQ_48MHz;
#elif defined SYSCLK_FREQ_56MHz
uint32_t SystemCoreClock = SYSCLK_FREQ_56MHz;
#elif defined SYSCLK_FREQ_72MHz
uint32_t SystemCoreClock = SYSCLK_FREQ_72MHz;
#else
uint32_t SystemCoreClock = HSI_VALUE;
#endif
__I uint8_t AHBPrescTable[16] = {0, 0, 0, 0, 0, 0, 0, 0, 1, 2, 3, 4, 6, 7, 8, 9};
static void SetSysClock(void);
static void SetSysClockToHSE(void);
static void SetSysClockTo24(void);
static void SetSysClockTo36(void);
static void SetSysClockTo48(void);
static void SetSysClockTo56(void);
static void SetSysClockTo72(void);
#endif
#ifdef DATA_IN_ExtSRAM
static void SystemInit_ExtMemCtl(void);
#endif
void SystemInit (void)
RCC->CR |= (uint32_t)0x00000001;
#ifndef STM32F10X_CL
RCC->CFGR &= (uint32_t)0xF8FF0000;
#else
RCC->CFGR &= (uint32_t)0xF0FF0000;
#endif
RCC->CR &= (uint32_t)0xFEF6FFFF;
RCC->CR &= (uint32_t)0xFFFBFFFF;
RCC->CFGR &= (uint32_t)0xFF80FFFF;
#ifdef STM32F10X_CL
RCC->CR &= (uint32_t)0xEBFFFFFF;
RCC->CIR = 0x00FF0000;
RCC->CFGR2 = 0x00000000;
#elif defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || (defined STM32F10X_HD_VL)
RCC->CIR = 0x009F0000;
#else
#endif
SystemInit_ExtMemCtl();
#endif
#endif
SetSysClock();
#ifdef VECT_TAB_SRAM
SCB->VTOR = SRAM_BASE | VECT_TAB_OFFSET;
#else
SCB->VTOR = FLASH_BASE | VECT_TAB_OFFSET;
#endif
void SystemCoreClockUpdate (void)
uint32_t tmp = 0, pllmull = 0, pllsource = 0;
#ifdef STM32F10X_CL
uint32_t prediv1source = 0, prediv1factor = 0, prediv2factor = 0, pll2mull = 0;
#endif
#if defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || (defined STM32F10X_HD_VL)
uint32_t prediv1factor = 0;
#endif
tmp = RCC->CFGR & RCC_CFGR_SWS;
switch (tmp)
case 0x00:
case 0x04:
SystemCoreClock = HSE_VALUE;
case 0x08:
pllmull = RCC->CFGR & RCC_CFGR_PLLMULL;
pllsource = RCC->CFGR & RCC_CFGR_PLLSRC;
pllmull = ( pllmull >> 18) + 2;
if (pllsource == 0x00)
SystemCoreClock = (HSI_VALUE >> 1) * pllmull;
prediv1factor = (RCC->CFGR2 & RCC_CFGR2_PREDIV1) + 1;
SystemCoreClock = (HSE_VALUE / prediv1factor) * pllmull;
#else
if ((RCC->CFGR & RCC_CFGR_PLLXTPRE) != (uint32_t)RESET)
SystemCoreClock = (HSE_VALUE >> 1) * pllmull;
SystemCoreClock = HSE_VALUE * pllmull;
#endif
#else
pllmull = pllmull >> 18;
if (pllmull != 0x0D)
pllmull += 2;
pllmull = 13 / 2;
prediv1source = RCC->CFGR2 & RCC_CFGR2_PREDIV1SRC;
if (prediv1source == 0)
prediv2factor = ((RCC->CFGR2 & RCC_CFGR2_PREDIV2) >> 4) + 1;
pll2mull = ((RCC->CFGR2 & RCC_CFGR2_PLL2MUL) >> 8 ) + 2;
SystemCoreClock = (((HSE_VALUE / prediv2factor) * pll2mull) / prediv1factor) * pllmull;
#endif
default:
tmp = AHBPrescTable[((RCC->CFGR & RCC_CFGR_HPRE) >> 4)];
SystemCoreClock >>= tmp;
SetSysClockToHSE();
SetSysClockTo24();
SetSysClockTo36();
SetSysClockTo48();
SetSysClockTo56();
SetSysClockTo72();
#endif
RCC->AHBENR = 0x00000114;
RCC->APB2ENR = 0x000001E0;
GPIOD->CRL = 0x44BB44BB;
GPIOD->CRH = 0xBBBBBBBB;
GPIOE->CRL = 0xB44444BB;
GPIOE->CRH = 0xBBBBBBBB;
GPIOF->CRL = 0x44BBBBBB;
GPIOF->CRH = 0xBBBB4444;
GPIOG->CRL = 0x44BBBBBB;
GPIOG->CRH = 0x44444B44;
FSMC_Bank1->BTCR[4] = 0x00001011;
FSMC_Bank1->BTCR[5] = 0x00000200;
#endif
__IO uint32_t StartUpCounter = 0, HSEStatus = 0;
RCC->CR |= ((uint32_t)RCC_CR_HSEON);
do
HSEStatus = RCC->CR & RCC_CR_HSERDY;
StartUpCounter++;
} while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
if ((RCC->CR & RCC_CR_HSERDY) != RESET)
HSEStatus = (uint32_t)0x01;
HSEStatus = (uint32_t)0x00;
if (HSEStatus == (uint32_t)0x01)
#if !defined STM32F10X_LD_VL && !defined STM32F10X_MD_VL && !defined STM32F10X_HD_VL
FLASH->ACR |= FLASH_ACR_PRFTBE;
FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);
FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_0;
#else
if (HSE_VALUE <= 24000000)
FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_1;
#endif
#endif
RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;
RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV1;
RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
RCC->CFGR |= (uint32_t)RCC_CFGR_SW_HSE;
while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x04)
do
StartUpCounter++;
#endif
#ifdef STM32F10X_CL
RCC->CFGR &= (uint32_t)~(RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL);
RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLSRC_PREDIV1 |
RCC_CFGR_PLLMULL6);
RCC->CFGR2 &= (uint32_t)~(RCC_CFGR2_PREDIV2 | RCC_CFGR2_PLL2MUL |
RCC_CFGR2_PREDIV1 | RCC_CFGR2_PREDIV1SRC);
RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV5 | RCC_CFGR2_PLL2MUL8 |
RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV10);
RCC->CR |= RCC_CR_PLL2ON;
while((RCC->CR & RCC_CR_PLL2RDY) == 0)
#elif defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || defined (STM32F10X_HD_VL)
RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_PREDIV1 | RCC_CFGR_PLLXTPRE_PREDIV1_Div2 | RCC_CFGR_PLLMULL6);
#else
RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLXTPRE_HSE_Div2 | RCC_CFGR_PLLMULL6);
#endif
RCC->CR |= RCC_CR_PLLON;
while((RCC->CR & RCC_CR_PLLRDY) == 0)
RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)
do
StartUpCounter++;
#ifdef STM32F10X_CL
RCC_CFGR_PLLMULL9);
#else
RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLXTPRE_HSE_Div2 | RCC_CFGR_PLLMULL9);
#endif
do
StartUpCounter++;
RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV2;
#ifdef STM32F10X_CL
RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV5);
RCC_CFGR_PLLMULL6);
#else
RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL6);
#endif
do
StartUpCounter++;
FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_2;
#ifdef STM32F10X_CL
RCC_CFGR_PLLMULL7);
#else
RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL7);
#endif
do
StartUpCounter++;
#ifdef STM32F10X_CL
RCC_CFGR_PLLMULL9);
#else
RCC_CFGR_PLLMULL));
RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL9);
#endif
#endif
天天干狠狠操
国产一区二区在线视频
久久国产精品一区二区三区
精品国产乱码久久久久久蜜臀网站
久久久夜色精品
成人免费视频视频
国产午夜精品久久久
国产免费一级
欧美亚洲一区二区三区
男人午夜影院
亚洲精品久久久久久久久久久
可以看毛片的网站
久久综合爱
亚洲精品91
黄色大片av
欧美一区二区三区成人
精品国产欧美一区二区三区成人
欧美日韩一
老司机午夜视频
欧美三级三级三级爽爽爽
日韩免费高清
天堂网在线资源
国产片一区二区
欧美日本精品
在线国产一区
在线视频亚洲
久热精品视频在线观看
在线a视频
日韩无遮挡
99av
国产黄视频在线观看
久草青青草
日本伊人久久
www.在线播放
国产高清视频
伊人久久av
欧美综合一区二区
亚洲国产伦理
成人免费在线
成人自拍视频在线观看
黄色片网站在线观看
