標題: STMicroelectronics STM32F0 Microcontrollers with Cortex-M0 Core [打印本頁]
作者: heila    時間: 2015-12-9 02:39
STMicroelectronics has introduced the STMicroelectronics STM32F0, a new family of microcontrollers based on the ARM Cortex-M0 core. The new STM32F0 family runs at 48MHz.
STMicroelectronics STM32F0 Features
Features of the new Cortex-M0 microcontrollers include:
  Cortex-M0 core @ 48MHz
  Single Supply: 1.8V to 3.6V Vcc
  5?0?8A Stop mode
  2?0?8A Standby mode
  430nA Vbat mode with only RTC running and 20 RAM registers kept alive
  Up to 64 KBytes Flash
  Up to 8 KBytes RAM
  Hardware RAM Parity check
  CRC module
  Two Watchdog Timers (for Class B certification)
  One watchdog timer uses the low-speed internal clock and triggers if the main oscillator fails
  Calendar RTC
  One 32-bit Timer
  Up to six 16-bit Timers
  16-bit 3-phase Motor Control Timer
  Five channel DMA
  12-bit ADC ±2LSB
  12-bit DAC
  Two comparators
  I2C/SPI @ 1Mbps
  HDMI Consumer Electronics Control (CEC)
The STM32F0 series integrates hardware support for the HDMI Consumer Electronics Control (CEC) interface. This protocol is used in home multimedia devices and allows connections based on the latest industry-standard protocols while leaving the microcontroller's CPU, memory and peripherals free to perform other tasks. The CEC kernel can be independently clocked by a low-speed 32kHz external clock or internal 8MHz clock.
STMicroelectronics STM32F0 Performance
The 48MHz STM32F0 is rated at 38DMIPS and 68 CoreMark. Interrupts on the Cortex-M0 require 12 cycles. All peripherals are compatible with existing STM32 devices and all STM32 devices are pin-compatible.
ST is targeting the STM32F0 at the low-power, low-performance, interrupt conscious 8-bit and 16-bit microcontroller market.
STM32F0 Price and Availability
From ST: "STM32 F0 microcontrollers are sampling now at the resale price of $0.95 for quantities of 1000 pieces to lead customers. Full production is scheduled for the beginning of Q2 2012, and the devices will be available in 32-pin UFQFPN32, 48-pin LQFP48 and 64-pin LQFP64 package options with 20-pin and 100-pin extensions soon to follow."
主站蜘蛛池模板: 成人免费毛片aaaaaa片 | 久久精品视频网 | 中文在线观看免费网站 | 黄色片网站免费 | 午夜激情视频 | 精东影业一区二区三区 | 成人在线免费视频观看 | 中文字幕亚洲精品 | 久草网在线观看 | 日韩精品在线免费观看 | 亚洲一区国产精品 | 中文字幕偷拍 | 国产精品国产精品国产专区不片 | 欧洲一级片 | 国产一区二区三区久久 | 国产精品久久久久久99 | 在线亚洲天堂 | 国产欧美视频在线观看 | 日韩av资源 | 谁有毛片网站 | 人人澡人人爽 | 免费看一级黄色片 | 国产精品成人一区二区三区 | 可以在线观看的av | 91精品成人 | 亚洲成人免费网站 | 国产成人精品一区二区三区福利 | 日韩精品视频在线免费观看 | 国产精品欧美精品 | 欧美日韩在线视频观看 | a视频| www久久久久| 91av在线免费观看 | 亚洲欧美日韩一区二区 | 成年女人毛片 | 国产精品视频久久久 | 久在线| 久久精品在线观看 | 成人免费毛片嘿嘿连载视频 | 日韩精品一二三 | 日韩福利片|
