標(biāo)題: 基于51單片機(jī)的簡(jiǎn)易電子琴_[brightbell] [打印本頁(yè)]
作者: BrightBell    時(shí)間: 2016-1-4 13:45
      學(xué)習(xí)51單片機(jī)不久后,自己設(shè)計(jì)制作了這個(gè)簡(jiǎn)易電子琴,這是我單片機(jī)DIY的第一個(gè)作品,從構(gòu)思設(shè)計(jì)-購(gòu)買(mǎi)元件-布局焊接-程序編寫(xiě),系統(tǒng)地體驗(yàn)了整個(gè)開(kāi)發(fā)流程,也是一邊學(xué)一邊做,還好有網(wǎng)絡(luò)。      在2015年3月底焊接的,那段時(shí)間也參考網(wǎng)上的程序?qū)懥藗€(gè)程序,實(shí)現(xiàn)的功能跟現(xiàn)在這個(gè)是一樣的,只不過(guò)程序結(jié)構(gòu)不好,還有延時(shí)有點(diǎn)問(wèn)題,所以在2016年1月1日重寫(xiě)了一下,功能不變,沒(méi)加沒(méi)減。
      沒(méi)什么技術(shù)含量,但是是我的第一個(gè)DIY成品,很有紀(jì)念價(jià)值啊,現(xiàn)在分享一下。
     有演示視頻,有圖片,有程序,不過(guò)沒(méi)有元件清單,沒(méi)有電路圖,也沒(méi)有必要吧,大家看看就都明白。
視頻:
http://player.youku.com/player.php/sid/XMTQzNDcyNjAyNA==/v.swf
源代碼:
  1. #include <reg52.h>
  2. sbit BUZZ=P1^6;//蜂鳴器連續(xù)的IO口
  3. unsigned char T1TH=0,T1TL=0;
  4. unsigned char code song1[]={                  //兩只老虎
  5.     0x14,0x14,0x24,0x34,0x14,0x14,0x24,0x34,0x14,
  6.         0x34,0x44,0x58,0x34,0x44,0x58,
  7.         0x53,0x61,0x53,0x41,0x34,0x14,
  8.         0x53,0x61,0x53,0x41,0x34,0x14,
  9.         0x14,0x54,0x18,
  10.         0x14,0x54,0x18,
  11.         0xFF          //歌曲結(jié)束標(biāo)志
  12. };
  13. unsigned char code song2[]={                  //送別
  14.     0x54,0x54,0x32,0x52,0x88,0x64,0x84,0x58,
  15.         0x54,0x12,0x22,0x34,0x22,0x12,0x28,0x04,0x04,
  16.         0x54,0x32,0x52,0x86,0x72,0x64,0x84,0x58,
  17.         0x54,0x22,0x32,0x46,0xB2,0x18,0x04,0x04,
  18.         0x64,0x84,0x88,0x74,0x62,0x72,0x88,
  19.         0x62,0x72,0x82,0x62,0x62,0x52,0x32,0x12,0x28,0x04,0x04,
  20.         0x54,0x32,0x52,0x86,0x72,0x64,0x84,0x58,
  21.         0x54,0x22,0x32,0x46,0xB2,0x18,0x04,0x04,
  22.         0xFF
  23. };
  24. unsigned char code cuzhi[]={
  25.     0xFF,0xFF,                //                          low                mid             high
  26.         0xFC,0x44,                //1      ##  5 6 7  1 2 3 4 5 6 7  1 2 3
  27.         0xFC,0xAC,                //2                 ##         D C B  1 2 3 4 5 6 7  8 9 A
  28.         0xFD,0x09,                //3
  29.         0xFD,0x34,                //4
  30.         0xFD,0x82,                //5
  31.         0xFD,0xC8,                //6
  32.         0xFE,0x06,                //7
  33.         0xFE,0x2A,                //8 --high 1         N = 470;
  34.         0xFE,0x48,                //9 --hign 2         N = 440;
  35.         0xFE,0x66,      //A --hign 3         N = 410;
  36.         0xFC,0x0C                //B---low  7         N = 1012
  37. };
  38. void delay1ms(unsigned char z);        //延時(shí)1MS
  39. void delay125ms(unsigned char z);        //延時(shí)165MS,即十六分音符
  40. void sing();
  41. main()
  42. {
  43.         EA=1;//開(kāi)總中斷
  44.     TMOD=0x10;//定時(shí)器1工作在方式1
  45.         TH1=0;
  46.         TL1=0;
  47.         ET1=1;
  48.         while(1)
  49.         {
  50.                 sing();
  51.             delay1ms(1000);
  52.         }
  53. }
  54. void sing()
  55. {
  56.     unsigned char temp;
  57.         unsigned char jianpu;
  58.         unsigned int i = 0;
  59.         static unsigned char thesong = 0;
  60.         while(1)
  61.         {
  62.                 switch(thesong)
  63.                 {
  64.                    case 0:temp = song1[i];break;
  65.                    case 1:temp = song2[i];break;
  66.                    default:break;
  67.                 }
  68.                 if(temp == 0xFF)
  69.                   break;
  70.                 jianpu = (temp>>4); //取數(shù)的高4位
  71.                 if(jianpu != 0)                //不是休止符
  72.                 {
  73.                   T1TH = cuzhi[jianpu*2];
  74.                   T1TL = cuzhi[jianpu*2+1];
  75.                 }               //查表找初值
  76.                 else                        //jp = 0,休止符
  77.                   { TR1 = 0;BUZZ = 1; }        //關(guān)蜂鳴器
  78.                 delay125ms( temp & 0x0F ); //取數(shù)的低4位
  79.                 TR1 = 0;         //唱完一個(gè)音停10MS
  80.                 BUZZ = 1;
  81.                 delay1ms(10);
  82.                 TR1 = 1;
  83.                 i++;
  84.         }
  85.         TR1 = 0;
  86.         BUZZ = 1;
  87.         thesong++;
  88.         if(thesong >=2)
  89.            thesong = 0;
  90. }
  91. void delay125ms(unsigned char z)        //延時(shí)165MS,即十六分音符
  92. {
  93.     unsigned int x,y;
  94.         for(x=z;x>0;x--)
  95.                  for(y=15000;y>0;y--);
  96. }
  97. void delay1ms(unsigned char z)        //延時(shí)1MS
  98. {
  99.     unsigned int x,y;
  100.         for(x=z;x>0;x--)
  101.                  for(y=112;y>0;y--);
  102. }
  103. void timer1() interrupt 3         //用于產(chǎn)生各種音調(diào)
  104. {
  105.         TH1=T1TH;
  106.         TL1=T1TL;
  107.     BUZZ = ~BUZZ;
  108. }
制作資料下載:
【BrightBell】基于51單片機(jī)的簡(jiǎn)易電子琴.rar (9.67 MB, 下載次數(shù): 331)
為大家省點(diǎn)黑幣,上百度云。。。
鏈接:http://pan.baidu.com/s/1skoeFkp 密碼:x9v5
作者: lc喝酒的魚(yú)    時(shí)間: 2016-5-14 17:26
謝謝大哥!!
作者: 越快樂(lè)越墮落    時(shí)間: 2016-6-7 16:40
樓主,你這里貼的程序和資料包里的不一樣,哪個(gè)是你現(xiàn)在視頻里用的?
作者: 越快樂(lè)越墮落    時(shí)間: 2016-6-7 17:10
假設(shè)定義左邊第一個(gè)音的按鍵為K1,然后以此類(lèi)推,K1是接的單片機(jī)的1腳???然后以此類(lèi)推?
作者: BrightBell    時(shí)間: 2016-6-8 07:54
越快樂(lè)越墮落 發(fā)表于 2016-6-7 16:40
一樣的哦,資料包里的是全部的,貼出來(lái)的只是其中一小部分
作者: BrightBell    時(shí)間: 2016-6-8 08:03
越快樂(lè)越墮落 發(fā)表于 2016-6-7 17:10
是的,那時(shí)候是這樣定義的:
                 定義各口
sbit BUZZ = P2^0;      //蜂鳴器連續(xù)的IO口
sbit led0 = P0^0;                   //各LED小燈
sbit led1 = P0^1;
sbit led2 = P0^2;
sbit led3 = P0^3;
sbit led4 = P0^4;
sbit led5 = P0^5;
sbit led6 = P0^6;
sbit led7 = P0^7;
sbit ledF = P3^7;     //功能指示燈(處于演奏狀態(tài)時(shí)亮
sbit key0 = P1^0;                        //各按鍵
sbit key1 = P1^1;
sbit key2 = P1^2;
sbit key3 = P1^3;
sbit key4 = P1^4;
sbit key5 = P1^5;
sbit key6 = P1^6;
sbit key7 = P1^7;
sbit keyF = P3^2;                        //功能切換鍵——外中斷0端口
作者: 陌文    時(shí)間: 2016-6-8 17:20
電阻都是多大的,求解
作者: BrightBell    時(shí)間: 2016-6-8 19:27
陌文 發(fā)表于 2016-6-8 17:20
電阻都是多大的,求解
都是常規(guī)的,,,,,,不好細(xì)說(shuō),找個(gè)最小系統(tǒng)類(lèi)比一下就成
作者: 越快樂(lè)越墮落    時(shí)間: 2016-6-8 21:46
電阻都是多大的,求解
10K 1K 4K7 10K排阻
作者: 陌文    時(shí)間: 2016-7-25 13:03
越快樂(lè)越墮落 發(fā)表于 2016-6-8 21:46
10K 1K 4K7 10K排阻
好的,謝謝了
作者: Contana    時(shí)間: 2016-10-10 17:56
就是可以問(wèn)一下,為什么制作資料上面的程序和您上面的不太對(duì)應(yīng)吧?可以告知一下嗎??
作者: faridzled    時(shí)間: 2017-1-13 22:42
thanks. i like it
作者: c1971264164    時(shí)間: 2017-12-3 17:10
最近也做了一個(gè)   不知道那邊出問(wèn)題了  先看看  無(wú)奈  其次謝謝
作者: 姬宮涅    時(shí)間: 2017-12-10 23:33
大佬能私發(fā)你一下嗎?我郵箱859197408@qq.com
作者: 一笙    時(shí)間: 2017-12-12 13:10
謝謝主樓分享
作者: lxb    時(shí)間: 2017-12-12 15:14
樓主那個(gè)蜂鳴器用的是有源的還是無(wú)源的?
作者: ljy棉花糖    時(shí)間: 2017-12-22 15:52
老哥   你是用的什么譜曲軟件?     我用名為樂(lè)譜編輯這個(gè)軟件編出來(lái)的音樂(lè)代碼放在你就一通亂響。。。
作者: ljy棉花糖    時(shí)間: 2017-12-22 15:54
老哥  你是用的什么譜曲軟件?   我用名為樂(lè)譜編輯的軟件編出來(lái)的音樂(lè)代碼放在你這程序行不通,就一通亂響。。。
作者: 214shiyanshi    時(shí)間: 2017-12-25 17:42
資料上的程序也不全吧?、
作者: qq69296154    時(shí)間: 2017-12-25 20:35
感謝,擼主很棒
作者: tieq1952    時(shí)間: 2017-12-26 14:55
這是真正的學(xué)習(xí)成果。支持。
作者: 記憶鎏金    時(shí)間: 2017-12-26 16:29
樓主好人啊
作者: ljy棉花糖    時(shí)間: 2017-12-27 11:11
214shiyanshi 發(fā)表于 2017-12-25 17:42
資料上的程序也不全吧?、
全啊    不過(guò)要自己發(fā)現(xiàn)如何去編寫(xiě)音樂(lè)代碼    我已經(jīng)發(fā)現(xiàn)了   哈哈    現(xiàn)在編了一首超級(jí)瑪麗的背景音樂(lè)   超動(dòng)感
作者: a5168    時(shí)間: 2017-12-28 12:29
可以!很給力!!
作者: 她很荔枝    時(shí)間: 2018-5-18 21:46
大佬,百度云沒(méi)了餒,資料可以私發(fā)我郵箱一下嗎?935662325@qq.com   非常感謝噠
作者: lemon666    時(shí)間: 2018-5-28 14:23
一笙 發(fā)表于 2017-12-12 13:10
謝謝主樓分享
能私發(fā)一下嗎?我郵箱2388549835@qq.com
作者: lemon666    時(shí)間: 2018-5-28 14:24
大佬,百度云沒(méi)了餒,資料可以私發(fā)我郵箱一下嗎?2399549835@qq.com   非常感謝噠
作者: 2429958788    時(shí)間: 2018-5-29 08:47
大佬百度鏈接過(guò)期了
作者: 2429958788    時(shí)間: 2018-5-29 08:53
大佬能發(fā)我一下嗎?2429958788@qq.com
作者: 2429958788    時(shí)間: 2018-5-29 08:59
大佬,6666666
作者: t1769024410    時(shí)間: 2018-5-30 16:50
大佬,百度云鏈接過(guò)期了,能否發(fā)給我一下,1769024410@qq.com
作者: t1769024410    時(shí)間: 2018-5-30 16:52
大佬,百度云失效了,資料可以私發(fā)我郵箱一下嗎?1769024410@qq.com   非常感謝噠
作者: liuhuayang2    時(shí)間: 2018-6-1 20:55
謝謝樓主
作者: 圖南    時(shí)間: 2018-6-4 21:56
大佬,能不能私發(fā)一下,1972411722@qq.com  ,謝謝樓主!
作者: 1015425521    時(shí)間: 2018-6-5 13:06
用了幾個(gè)中斷呀
作者: libby妖怪吧    時(shí)間: 2018-6-7 13:01
厲害了,圍觀一下
作者: 點(diǎn)點(diǎn)天地心    時(shí)間: 2018-6-8 13:26
作者還有鏈接分享嗎,我急需呀
作者: 點(diǎn)點(diǎn)天地心    時(shí)間: 2018-6-8 15:36
大佬,能不能私發(fā)一下,1142844609@foxmail.com  ,謝謝樓主!
作者: 隨夢(mèng)b    時(shí)間: 2018-6-10 08:22
大佬還有鏈接嗎??,,511889585@qq.com  謝謝!
作者: 陳良坤    時(shí)間: 2018-6-19 12:31
百度云已經(jīng)失效  能不能發(fā)到我郵箱樓主:2388799017@qq.com
作者: zyzain    時(shí)間: 2018-6-21 16:19
大佬,百度云沒(méi)了,可以私發(fā)一下嗎?501680355@qq.com謝謝了
作者: 單片機(jī)@    時(shí)間: 2018-6-25 23:03
厲害啦,去大神分享!
作者: 釋你    時(shí)間: 2018-8-18 16:11
大佬,能不能私發(fā)一下,1638078283@qq.com  ,謝謝樓主!
作者: 去幼兒園的車(chē)    時(shí)間: 2018-9-14 18:50
樓主大佬可以發(fā)我一份嗎?  lijianhong94k@qq.com  謝謝!!
作者: 劉永    時(shí)間: 2018-9-22 11:04
好厲害啊,我最近才開(kāi)始學(xué)單片機(jī),也想做一個(gè)自己的東西出來(lái)。
作者: Smiletiger    時(shí)間: 2018-10-7 20:38
老哥,穩(wěn)!
作者: lljmini    時(shí)間: 2019-5-8 21:30
樓主,百度云已經(jīng)失效,私發(fā)郵箱765972616@qq.com 謝謝!!
作者: 849498175a    時(shí)間: 2019-11-28 14:41
大佬還在嗎? 849498175@qq.com 可以發(fā)一下嗎?
作者: CandyCandy123    時(shí)間: 2019-12-10 09:25
大佬,能分享一下百度云么,謝謝782549158@qq.com
作者: 2488311295    時(shí)間: 2019-12-15 13:50
剛剛學(xué)單片機(jī),正好想做一個(gè)這個(gè),感謝樓主大大的分享。嘻嘻
作者: 且聽(tīng)且吟    時(shí)間: 2019-12-20 21:57
感謝樓主分享
作者: 七淮    時(shí)間: 2020-3-18 13:23
學(xué)到了,謝謝樓主
作者: 奶粉丷給你揚(yáng)了    時(shí)間: 2020-4-29 16:58
哈哈最后一句好評(píng)
作者: 有被嚇得    時(shí)間: 2020-5-4 23:38
謝謝大佬
作者: 有被嚇得    時(shí)間: 2020-5-4 23:39
大佬能問(wèn)一下這個(gè)還有改進(jìn)空間嗎,如果我想給它加個(gè)回放功能,不用外加芯片用數(shù)組能實(shí)現(xiàn)嗎
作者: shirayuki_lumi    時(shí)間: 2020-5-7 10:48
謝謝!很有用
作者: 電控2001    時(shí)間: 2020-5-26 15:05
下來(lái)研究一下
主站蜘蛛池模板: 午夜免费av | 四虎黄色片 | 亚洲一区中文 | 日韩在线观看中文字幕 | 国产农村妇女aaaaa视频 | 国产理论片 | 一级片黄色 | 成人精品福利 | 中文精品一区 | 一二三区视频 | 毛片在线免费播放 | 一级黄片毛片 | 成人一区二区视频 | 国产在线观看免费 | 另类ts人妖一区二区三区 | 免费网站观看www在线观看 | 99精品久久久久久中文字幕 | 91片黄在线观看 | 成人精品免费视频 | 国产免费网址 | 成人免费福利视频 | 伊人国产女 | 天天操天天舔 | 在线观看国产黄色 | 日韩福利视频 | www.一区| 国产欧美综合一区二区三区 | 成人免费毛片网站 | 日日夜夜天天干 | 在线观看国产一区二区 | 美国特色黄a大片 | 欧美日韩中文字幕在线观看 | 秋霞福利视频 | 国产黄色免费 | 中文一区二区 | 日韩网站免费观看 | 日韩午夜在线观看 | 国产日韩欧美日韩大片 | 欧美日韩四区 | 免费视频一区二区 | 久久精品国产一区 |
