標(biāo)題: stm32產(chǎn)生spwm波的pwm寄存器配置與教程工具等 [打印本頁(yè)]
作者: hushao    時(shí)間: 2016-1-4 18:08
有很多種方案可以選擇,我現(xiàn)在你解決的方案是用定時(shí)器和DMA來(lái)做的,還可以有其他很多方法我還沒(méi)有去試,如果有其他方法成功了的期待分享,不多說(shuō)了,直接上程序:
  1. #include "stm32f10x.h"
  2. #define TIM1_CCR3_Address    0x40012C3C
  3. TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  4. TIM_OCInitTypeDef  TIM_OCInitStructure;
  5. uint16_t SRC_Buffer[3] = {500, 500, 500};
  6. ErrorStatus HSEStartUpStatus;
  7. /* Private function prototypes -----------------------------------------------*/
  8. void RCC_Configuration(void);
  9. void GPIO_Configuration(void);
  10. void DMA_Configuration(void);
  11. int main(void)
  12. {
  13.   RCC_Configuration();
  14.   GPIO_Configuration();
  15.   DMA_Configuration();
  16.   /* TIM1 Peripheral Configuration --------------------------------------------*/
  17.   /* Time Base configuration */
  18.   TIM_TimeBaseStructure.TIM_Prescaler = 0;
  19.   TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  20.   TIM_TimeBaseStructure.TIM_Period = 1000-1;//72M/x=frq
  21.   TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  22.   TIM_TimeBaseStructure.TIM_RepetitionCounter = 2;
  23.   TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
  24.   /* Channel 3 Configuration in PWM mode */
  25.   TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
  26.   TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  27.   TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
  28.   TIM_OCInitStructure.TIM_Pulse = 127;
  29.   TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  30.   TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;
  31.   TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
  32.   TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
  33.   TIM_OC3Init(TIM1, &TIM_OCInitStructure);
  34.   /* TIM1 Update DMA Request enable */
  35.   TIM_DMACmd(TIM1, TIM_DMA_Update, ENABLE);
  36.   /* TIM1 counter enable */
  37.   TIM_Cmd(TIM1, ENABLE);
  38.   /* Main Output Enable */
  39.   TIM_CtrlPWMOutputs(TIM1, ENABLE);
  40.   while (1)
  41.   {}
  42. }
  43. void RCC_Configuration(void)
  44. {
  45.   SystemInit();
  46.   /* TIM1, GPIOA and GPIOB clock enable */
  47.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1 | RCC_APB2Periph_GPIOA |
  48.                          RCC_APB2Periph_GPIOB, ENABLE);
  49.   /* DMA clock enable */
  50.   RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
  51. }
  52. void GPIO_Configuration(void)
  53. {
  54.   GPIO_InitTypeDef GPIO_InitStructure;
  55.   /* GPIOA Configuration: Channel 3 as alternate function push-pull */
  56.   GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_10;
  57.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  58.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  59.   GPIO_Init(GPIOA, &GPIO_InitStructure);
  60.   /* GPIOB Configuration: Channel 3N as alternate function push-pull */
  61.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
  62.   GPIO_Init(GPIOB, &GPIO_InitStructure);
  63. }
  64. void DMA_Configuration(void)
  65. {
  66.   DMA_InitTypeDef DMA_InitStructure;
  67.   /* DMA1 Channel5 Config */
  68.   DMA_DeInit(DMA1_Channel5);
  69.   DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)TIM1_CCR3_Address;
  70.   DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)SRC_Buffer;
  71.   DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
  72.   DMA_InitStructure.DMA_BufferSize = 3;
  73.   DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  74.   DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  75.   DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  76.   DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  77.   DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  78.   DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  79.   DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  80.   DMA_Init(DMA1_Channel5, &DMA_InitStructure);
  81.   /* DMA1 Channel5 enable */
  82.   DMA_Cmd(DMA1_Channel5, ENABLE);
  83. }
上面的數(shù)組SRC_Buffer[3] = {100, 200, 500};
是作為SPWM波的產(chǎn)生數(shù)組,需要自己去取碼表,還有就是用一些軟件取出來(lái)的碼表可能有負(fù)值,所以需要將這樣的碼表整體抬升成正值。
關(guān)鍵的問(wèn)題來(lái)了,就是這數(shù)組怎么取出來(lái)的這是關(guān)鍵的,lz說(shuō)說(shuō)你怎么取得數(shù)組
本來(lái)想在上面說(shuō)明一下,我以為大家都知道,很簡(jiǎn)單,有一個(gè)SPWM碼表產(chǎn)生的軟件,網(wǎng)上應(yīng)該能找到,只是取出來(lái)的數(shù)應(yīng)該有負(fù)數(shù),所以需要抬升,至于抬升的辦法就看自己了。可以用EXCEL來(lái)做,也可以自己寫一個(gè)簡(jiǎn)單的c程序。上面的SPWM碼表的產(chǎn)生其實(shí)也可以自己寫一個(gè)簡(jiǎn)單的C程序來(lái)完成,這就需要自己想一點(diǎn)算法了。
我就好人做到底把SPWM波碼表的產(chǎn)生軟件和我自己寫的一個(gè)碼表的抬升程序都上傳了吧。抬升程序解壓之后在碼表抬升軟件文件夾下的debug文件夾下,直接運(yùn)行daydayup。exe就可以了,第一次提醒輸入抬升的碼表的碼值個(gè)數(shù),然后提醒輸入碼表(可以直接粘貼上去),然后會(huì)提醒輸入要抬升多少,最后會(huì)以一定的格式輸出,自己再?gòu)?fù)制出來(lái)就可以了。
SPWM波產(chǎn)生軟件.rar (159.56 KB, 下載次數(shù): 83)
只是產(chǎn)生PWM波其實(shí)不需要DMA模塊完全可以的,DMA主要是我用來(lái)產(chǎn)生SPWM波的。你可以試一下,上個(gè)碼表就行了
作者: 橘沐希    時(shí)間: 2016-4-20 17:07
謝謝樓主
作者: 橘沐希    時(shí)間: 2016-4-20 17:08
謝謝樓主
作者: K.S    時(shí)間: 2017-10-8 16:42
可以可以
作者: jmjack    時(shí)間: 2018-8-10 16:35
謝謝樓主
主站蜘蛛池模板: 神马福利视频 | 日韩视频免费看 | 欧美国产综合 | 91狠狠干 | www.九色 | 天天干天天操天天 | 风间由美一区二区三区 | 久久久久久久影院 | 久久国产亚洲 | 九九热在线视频 | 欧美日韩一区二区在线 | 婷婷伊人网 | 精品影院 | 日韩av免费看 | www久久久久| 香蕉视频一区二区 | 国产欧美另类 | 日本黄色三级视频 | 免费一级全黄少妇性色生活片 | 欧美日韩在线视频观看 | 日本成人中文字幕 | 97自拍视频 | 黄色片在线播放 | 国产一区二区在线看 | 日韩av在线免费播放 | 黄色一级大片在线免费看国产一 | 五月婷婷激情 | 日韩在线中文字幕 | 精品免费 | 青青草视频网站 | 欧美一级片 | 精品免费国产一区二区三区四区 | www.国产精品.com | 日韩精品在线一区 | 亚洲黄色天堂 | 成人免费小视频 | 日韩欧美在线播放 | 国产成人免费在线 | 国产精品久久视频 | 黄色一级片黄色一级片 | 久久久久久久免费视频 |
