標(biāo)題:
requires ANSI-style prototype c語言程序有個(gè)錯(cuò)誤找不出來,附加了程序,求大神看看
mxl111
時(shí)間:
2016-1-7 09:30
標(biāo)題:
compiling 11.c...
11.c(4): warning C318: can't open file 'lcd_1602.h'
11.c(5): warning C318: can't open file 'key.h'
11.c(6): warning C318: can't open file 'IIC_24C04.h'
11.C(55): warning C206: 'lcd_init': missing function-prototype
11.C(56): warning C206: 'IIC_24C04_Init': missing function-prototype
11.C(62): warning C206: 'keys_scan': missing function-prototype
11.C(120): warning C206: 'sendstring': missing function-prototype
11.C(120): error C267: 'sendstring': requires ANSI-style prototype
11.c(360): warning C316: unterminated conditionals
11.c - 1 Error(s), 8 Warning(s).
有一個(gè)錯(cuò)誤怎么都看不出來,求大神幫下忙 啊
#include<reg52.h>
#include<string.h>
#include<intrins.h>
#include<lcd_1602.h>
#include<key.h>
#include<IIC_24C04.h>
#define uchar unsigned char
#define uint unsigned int
uchar pre_keyno=16,keyno=16;
uchar code Title_Text[]="your password...";
uchar DSY_BUFFER[16]=" ";
uchar userpassword[7]=" ";
uchar IIC_Password[7];
uchar lS_Valid_User=0;
uchar i=0;
void display_string(uchar *str,uchar lineno);
void beep();
uchar Clear_Password();
sbit LED_OPEN=P2^0;
sbit BEEP=P3^7;
void delay(uint x)
uchar i;
while (x--)
for(i=0;i<120;i++);
void beep()
uchar i;
for(i=0;i<100;i++)
BEEP=~BEEP;
BEEP=0;
void clear_password()
uchar i;
for(i=0;i<6;i++)
userpassword[ i]=' ';
DSY_BUFFER[ i]=' ';
void init_main()
P0=0xFF;
P1=0xFF;
P2=0xFF;
TMOD=0x02;
TH0=175;
TL0=175;
TR0=1;
delay(10);
lcd_init();
IIC_24C04_Init();
void key_main()
P1=0xF0;
if(P1!=0xF0) keyno=keys_scan();
if(pre_keyno!=keyno)
if(i<=6)
switch(keyno)
case 0: case 1: case 2: case 3: case 4:
case 5: case 6: case 7: case 8: case 9:
if(i<=6)
if(i==0)display_string(" ",0x40);
userpassword[ i]=keyno+'0';
userpassword[i+1]=' ';
DSY_BUFFER[ i]='*';
DSY_BUFFER[i+1]=' ';
display_string(DSY_BUFFER,0x40);
i++;
case 10:
if(strcmp(userpassword,IIC_Password)==0)
LED_OPEN=0;
Clear_Password();
display_string("Unlock ok! ",0x40);
lS_Valid_User=1;
LED_OPEN=1;
Clear_Password();
display_string("ERROR! ",0x40);
lS_Valid_User=0;
i=0;
case 11:
LED_OPEN=1;
Clear_Password();
display_string(Title_Text,0x00);
i=0;
lS_Valid_User=0;
case 12:
if(!lS_Valid_User)display_string("No rights !",0x40);
i=0;
display_string("New Password: ",0x00);
case 13:
sendstring(0xa0,0,userpassword,6);
recstring(0xa0,0,IIC_Password,6);
IIC_Password[6]='';
i=0;
display_string("Password Saved! ",0x40);
case 14:
i=0;
Clear_Password();
燈 }
beep();
pre_keyno=keyno;
}鳴器
beep();
delay(100)
P1=0xF0;
while(P1==0xF0);
init_main();
IIC_Password[6]='\0';
while(l)
key_main();
P1=0xF0;
while(P1!=0xF0);
while(P1==0xF0);
#ifndef _LCD1602_H_
#define _LCD1602_H_
#include<reg52.h>
sbit rs=P2^1;
sbit rw=P2^2;
sbit eq=P2^3;
void delay_lcd(uchar n)
uchar i;
while(n--)
for(i=0;i<250;i++)
_nop_(); _nop_(); _nop_(); _nop_();
bit lcd_bz()
bit result;
rs=0;
rw=1;
eq=1;
_nop_(); _nop_();_nop_(); _nop_();
result=(bit)(P0&0x80);
eq=0;
return result;
void lcd_wcmd(uchar cmd)
rs=0;
rw=0;
eq=0;
P0=cmd;
eq=1;
delay_lcd(1);
eq=0;
void lcd_wdat(uchar dat)
while(lcd_bz());
rs=1;
rw=0;
P0=dat;
delay_lcd(1);
eq=1;
eq=0;
void lcd_init()
lcd_wcmd(0x38);
while(lcd_bz());
lcd_wcmd(0x0c);
lcd_wcmd(0x06);
lcd_wcmd(0x01);
uchar i;
lcd_wcmd(0x80+lineno);
for (i=0;i<16;i++)
lcd_wdat(str[ i]);
#endif
#ifndef _key_H_
#define _key_H_
#include<reg52.h>
void delay_key(uint x)
uchar i;
while (x--)
for(i=0;i<120;i++);
uchar keys_scan()
uchar temp,k;
P1=0x0F;
delay_key(2);
temp=P1^0x0F;
switch(temp)
case 1: k=0;break;
case 2: k=1;break;
case 4: k=2;break;
case 8: k=3;break;
default: break;
P1=0xF0;
delay_key(2);
temp=(P1>>4)^0x0F;
switch(temp)
case 1: k+=0;break;
case 2: k+=4;break;
case 4: k+=8;break;
case 8: k+=12;break;
default: break;
return k;
#ifndef _IIC_24C04_H_
#define _IIC_24C04_H_
#include<reg52.h>
#include<string.h>
#include<intrins.h>
#define delay4us();
sbit SCL=P3^2;
sbit SDA=P3^3;
void start()
SDA=1;SCL=1;delay4us();
SDA=0;delay4us();SCL=0;
void stop()
SDA=0;SCL=1;delay4us();
SDA=1;delay4us();SCL=0;
void IIC_24C04_Init()
SCL=0;stop();
void ACK()
SDA=1;SCL=0;
void no_ACK()
SDA=0;SCL=0;
uchar recbyte()
uchar i;rd;
rd=0x00;
SDA=1;
for(i=0;i<8;i++)
SCL=1;rd<<=1;rd|=SDA; delay4us(); SCL=0;delay4us();
SCL=0;
delay4us();
return rd;
uchar sendbyte(uchar wd)
uchar i;
bit ACK0;
for(i=0;i<8;i++)
SDA=(bit)(wd&0x80);
_nop_();_nop_();SCL=1;delay4us();SCL=0;wd<<=1;
delay4us();
SDA=1;
SCL=1;
delay4us();
ACK0=!SDA;
SCL=0;
delay4us();
return ACK0;
uchar sendstring(uchar slave,uchar subaddr,uchar *buffer,uchar N);
uchar i;
start();
if(!sendbyte(slave))
return 0;
if(!sendbyte(subaddr))
return 0;
for(i=0;i<N-1;i++)
if(!sendbyte(buffer[ i])) return 0;
stop();
return 1;
uchar recstring(uchar slave,uchar subaddr,ucahr *buffer,uchar N);
uchar i;
start();
if(!sendbyte(slave)) return 0;
if(!sendbyte(subaddr)) return 0;
start();
if(!sendbyte(slave+1)) return 0;
for(i=0;i<N-1;i++)
buffer[ i]=recbyte();
ACK();
buffer[N-1]=recbyte();
no_ACK();
stop();
return 1;
admin
時(shí)間:
2016-1-10 01:36
11.C(120): error C267: 'sendstring': requires ANSI-style prototype 是說sendstring可能沒有定義,你應(yīng)該上傳完整的壓縮包,才能方便查找呢.
av中文字幕在线
亚洲国产精品一区二区www
一区二区三区四区在线播放
日本不卡一区
精品视频免费在线
不用播放器看的av
羞羞的视频在线观看
四虎影视
国产免费视频在线
亚洲精品国产一区
成人欧美一区二区
亚洲成人一区二区
亚洲欧洲激情
一级久久久久久
欧美舔穴
亚洲国产成人在线
一级片在线免费播放
国产精品夜夜春夜夜爽久久电影
久久av综合
日韩一区在线播放
日韩欧美精品在线播放
欧美日韩大陆
午夜视频在线免费观看
亚洲传媒在线
中文字幕一区二区三区精彩视频
免费高清av
欧美中文字幕一区二区三区亚洲
一区二区三区国产
av在线一区二区三区
欧美一区在线看
国产成人精品一区二区三区
日韩中文字幕在线播放
亚洲人va欧美va人人爽
精品福利在线视频
亚洲视频二区
国产精品中文在线
黄色亚洲网站
中文在线一区二区
成人欧美一区二区三区白人
日日夜夜天天久久
日韩在线观看精品
