標(biāo)題:
辛苦找到的三星S3C2440A處理器正確的初始化文件-具備CPSR寄存器相關(guān)功能位開啟
51heisex
2016-1-24 02:34
標(biāo)題:
; NAME: 2440INIT.S
; DESC: C start up codes
; Configure memory, ISR ,stacks
; Initialize C-variables
; HISTORY:
; 2002.02.25:kwtark: ver 0.0
; 2002.03.20:purnnamu: Add some functions for testing STOP,Sleep mode
; 2003.03.14:DonGo: Modified for 2440.
GET option.inc
GET memcfg.inc
GET 2440addr.inc
BIT_SELFREFRESH EQU (1<<22)
;Pre-defined constants
USERMODE EQU 0x10
FIQMODE EQU 0x11
IRQMODE EQU 0x12
SVCMODE EQU 0x13
ABORTMODE EQU 0x17
UNDEFMODE EQU 0x1b
MODEMASK EQU 0x1f
NOINT EQU 0xc0
;The location of stacks
UserStack EQU (_STACK_BASEADDRESS-0x3800) ;0x33ff4800 ~
SVCStack EQU (_STACK_BASEADDRESS-0x2800) ;0x33ff5800 ~
UndefStack EQU (_STACK_BASEADDRESS-0x2400) ;0x33ff5c00 ~
AbortStack EQU (_STACK_BASEADDRESS-0x2000) ;0x33ff6000 ~
IRQStack EQU (_STACK_BASEADDRESS-0x1000) ;0x33ff7000 ~
FIQStack EQU (_STACK_BASEADDRESS-0x0) ;0x33ff8000 ~
;Check if tasm.exe(armasm -16 ...@ADS 1.0) is used.
GBLL THUMBCODE
[ {CONFIG} = 16
THUMBCODE SETL {TRUE}
CODE32
THUMBCODE SETL {FALSE}
MACRO
MOV_PC_LR
[ THUMBCODE
bx lr
mov pc,lr
MEND
MACRO
MOVEQ_PC_LR
[ THUMBCODE
bxeq lr
moveq pc,lr
MEND
MACRO
$HandlerLabel HANDLER $HandleLabel
$HandlerLabel
sub sp,sp,#4 ;decrement sp(to store jump address)
stmfd sp!,{r0} ;PUSH the work register to stack(lr does not push because it return to original address)
ldr r0,=$HandleLabel;load the address of HandleXXX to r0
ldr r0,[r0] ;load the contents(service routine start address) of HandleXXX
str r0,[sp,#4] ;store the contents(ISR) of HandleXXX to stack
ldmfd sp!,{r0,pc} ;POP the work register and pc(jump to ISR)
MEND
IMPORT |Image$RO$Base| ; Base of ROM code
IMPORT |Image$RO$Limit| ; End of ROM code (=start of ROM data)
IMPORT |Image$RW$Base| ; Base of RAM to initialise
IMPORT |Image$ZI$Base| ; Base and limit of area
IMPORT |Image$ZI$Limit| ; to zero initialise
IMPORT MMU_SetAsyncBusMode
IMPORT MMU_SetFastBusMode ;
IMPORT Main ; The main entry of mon program
AREA Init,CODE,READONLY
ENTRY
EXPORT __ENTRY
__ENTRY
ResetEntry
;1)The code, which converts to Big-endian, should be in little endian code.
;2)The following little endian code will be compiled in Big-Endian mode.
; The code byte order should be changed as the memory bus width.
;3)The pseudo instruction,DCD can not be used here because the linker generates error.
ASSERT :DEF:ENDIAN_CHANGE
[ ENDIAN_CHANGE
ASSERT :DEF:ENTRY_BUS_WIDTH
[ ENTRY_BUS_WIDTH=32
b ChangeBigEndian ;DCD 0xea000007
[ ENTRY_BUS_WIDTH=16
andeq r14,r7,r0,lsl #20 ;DCD 0x0007ea00
[ ENTRY_BUS_WIDTH=8
streq r0,[r0,-r10,ror #1] ;DCD 0x070000ea
b ResetHandler
b HandlerUndef ;handler for Undefined mode
b HandlerSWI ;handler for SWI interrupt
b HandlerPabort ;handler for PAbort
b HandlerDabort ;handler for DAbort
b . ;reserved
b HandlerIRQ ;handler for IRQ interrupt
b HandlerFIQ ;handler for FIQ interrupt
;@0x20
b EnterPWDN ; Must be @0x20.
ChangeBigEndian
;@0x24
DCD 0xee110f10 ;0xee110f10 => mrc p15,0,r0,c1,c0,0
DCD 0xe3800080 ;0xe3800080 => orr r0,r0,#0x80; //Big-endian
DCD 0xee010f10 ;0xee010f10 => mcr p15,0,r0,c1,c0,0
DCD 0x0f10ee11
DCD 0x0080e380
DCD 0x0f10ee01
[ ENTRY_BUS_WIDTH=8
DCD 0x100f11ee
DCD 0x800080e3
DCD 0x100f01ee
DCD 0xffffffff ;swinv 0xffffff is similar with NOP and run well in both endian mode.
DCD 0xffffffff
DCD 0xffffffff
DCD 0xffffffff
DCD 0xffffffff
b ResetHandler
HandlerFIQ HANDLER HandleFIQ
HandlerIRQ HANDLER HandleIRQ
HandlerUndef HANDLER HandleUndef
HandlerSWI HANDLER HandleSWI
HandlerDabort HANDLER HandleDabort
HandlerPabort HANDLER HandlePabort
IsrIRQ
sub sp,sp,#4 ;reserved for PC
stmfd sp!,{r8-r9}
ldr r9,=INTOFFSET
ldr r9,[r9]
ldr r8,=HandleEINT0
add r8,r8,r9,lsl #2
ldr r8,[r8]
str r8,[sp,#8]
ldmfd sp!,{r8-r9,pc}
LTORG
; ENTRY
ResetHandler
ldr r0,=WTCON ;watch dog disable
ldr r1,=0x0
str r1,[r0]
ldr r0,=INTMSK
ldr r1,=0xffffffff ;all interrupt disable
str r1,[r0]
ldr r0,=INTSUBMSK
ldr r1,=0x7fff ;all sub interrupt disable
str r1,[r0]
[ {TRUE}
;rGPFDAT = (rGPFDAT & ~(0xf<<4)) | ((~data & 0xf)<<4);
; Led_Display
ldr r0,=GPBCON
ldr r1,=0x00555555
str r1,[r0]
ldr r0,=GPBDAT
ldr r1,=0x07fe
str r1,[r0]
;To reduce PLL lock time, adjust the LOCKTIME register.
ldr r0,=LOCKTIME
ldr r1,=0xffffff
str r1,[r0]
[ PLL_ON_START
; Added for confirm clock divide. for 2440.
; Setting value Fclk:Hclk:Pclk
ldr r0,=CLKDIVN
ldr r1,=CLKDIV_VAL ; 0=1:1:1, 1=1:1:2, 2=1:2:2, 3=1:2:4, 4=1:4:4, 5=1:4:8, 6=1:3:3, 7=1:3:6.
str r1,[r0]
; MMU_SetAsyncBusMode and MMU_SetFastBusMode over 4K, so do not call here
; call it after copy
; [ CLKDIV_VAL>1 ; means Fclk:Hclk is not 1:1.
; bl MMU_SetAsyncBusMode
; bl MMU_SetFastBusMode ; default value.
;program has not been copied, so use these directly
orr r0,r0,#0xc0000000;R1_nF:OR:R1_iA
bic r0,r0,#0xc0000000;R1_iA:OR:R1_nF
;Configure UPLL
ldr r0,=UPLLCON
ldr r1,=((U_MDIV<<12)+(U_PDIV<<4)+U_SDIV)
str r1,[r0]
nop ; Caution: After UPLL setting, at least 7-clocks delay must be inserted for setting hardware be completed.
nop
nop
nop
nop
nop
nop
;Configure MPLL
ldr r0,=MPLLCON
ldr r1,=((M_MDIV<<12)+(M_PDIV<<4)+M_SDIV) ;Fin=16.9344MHz
str r1,[r0]
;Check if the boot is caused by the wake-up from SLEEP mode.
ldr r1,=GSTATUS2
ldr r0,[r1]
tst r0,#0x2
;In case of the wake-up from SLEEP mode, go to SLEEP_WAKEUP handler.
bne WAKEUP_SLEEP
EXPORT StartPointAfterSleepWakeUp
;Set memory control registers
;ldr r0,=SMRDATA
adrl r0, SMRDATA ;be careful!
ldr r1,=BWSCON ;BWSCON Address
add r2, r0, #52 ;End address of SMRDATA
0
ldr r3, [r0], #4
str r3, [r1], #4
cmp r2, r0
bne %B0
;;;;;;;;;;;;; When EINT0 is pressed, Clear SDRAM
; check if EIN0 button is pressed
ldr r0,=GPFCON
ldr r1,=0x0
str r1,[r0]
ldr r0,=GPFUP
ldr r1,=0xff
str r1,[r0]
ldr r1,=GPFDAT
ldr r0,[r1]
bic r0,r0,#(0x1e<<1) ; bit clear
tst r0,#0x1
bne %F1
; Clear SDRAM Start
ldr r0,=GPFCON
ldr r1,=0x55aa
str r1,[r0]
; ldr r0,=GPFUP
; ldr r1,=0xff
; str r1,[r0]
ldr r0,=GPFDAT
ldr r1,=0x0
str r1,[r0] ;LED=****
mov r1,#0
mov r2,#0
mov r3,#0
mov r4,#0
mov r5,#0
mov r6,#0
mov r7,#0
mov r8,#0
ldr r9,=0x4000000 ;64MB
ldr r0,=0x30000000
0
stmia r0!,{r1-r8}
subs r9,r9,#32
bne %B0
;Clear SDRAM End
1
;Initialize stacks
bl InitStacks
ldr r0, =BWSCON
ldr r0, [r0]
ands r0, r0, #6 ;OM[1:0] != 0, NOR FLash boot
bne copy_proc_beg ;do not read nand flash
adr r0, ResetEntry ;OM[1:0] == 0, NAND FLash boot
cmp r0, #0 ;if use Multi-ice,
bne copy_proc_beg ;do not read nand flash for boot
;nop
nand_boot_beg
mov r5, #NFCONF
;set timing value
ldr r0, =(7<<12)|(7<<8)|(7<<4)
str r0, [r5]
;enable control
ldr r0, =(0<<13)|(0<<12)|(0<<10)|(0<<9)|(0<<8)|(1<<6)|(1<<5)|(1<<4)|(1<<1)|(1<<0)
str r0, [r5, #4]
bl ReadNandID
mov r6, #0
ldr r0, =0xec73
cmp r5, r0
beq %F1
ldr r0, =0xec75
cmp r5, r0
beq %F1
mov r6, #1
1
bl ReadNandStatus
mov r8, #0
ldr r9, =ResetEntry
2
ands r0, r8, #0x1f
bne %F3
mov r0, r8
bl CheckBadBlk
cmp r0, #0
addne r8, r8, #32
bne %F4
3
mov r0, r8
mov r1, r9
bl ReadNandPage
add r9, r9, #512
add r8, r8, #1
4
cmp r8, #5120
bcc %B2
mov r5, #NFCONF ;DsNandFlash
ldr r0, [r5, #4]
bic r0, r0, #1
str r0, [r5, #4]
ldr pc, =copy_proc_beg
copy_proc_beg
adr r0, ResetEntry
ldr r2, BaseOfROM
cmp r0, r2
ldreq r0, TopOfROM
beq InitRam
ldr r3, TopOfROM
0
ldmia r0!, {r4-r7}
stmia r2!, {r4-r7}
cmp r2, r3
bcc %B0
sub r2, r2, r3
sub r0, r0, r2
InitRam
ldr r2, BaseOfBSS
ldr r3, BaseOfZero
0
cmp r2, r3
ldrcc r1, [r0], #4
strcc r1, [r2], #4
bcc %B0
mov r0, #0
ldr r3, EndOfBSS
1
cmp r2, r3
strcc r0, [r2], #4
bcc %B1
ldr pc, =%F2 ;goto compiler address
2
;bl Led_Test
; Setup IRQ handler
ldr r0,=HandleIRQ ;This routine is needed
ldr r1,=IsrIRQ ;if there is not 'subs pc,lr,#4' at 0x18, 0x1c
str r1,[r0]
; ;Copy and paste RW data/zero initialized data
; ldr r0, =|Image$RO$Limit| ; Get pointer to ROM data
; ldr r1, =|Image$RW$Base| ; and RAM copy
; ldr r3, =|Image$ZI$Base|
; ;Zero init base => top of initialised data
; cmp r0, r1 ; Check that they are different
; beq %F2
;1
; cmp r1, r3 ; Copy init data
; ldrcc r2, [r0], #4 ;--> LDRCC r2, [r0] + ADD r0, r0, #4
; strcc r2, [r1], #4 ;--> STRCC r2, [r1] + ADD r1, r1, #4
; bcc %B1
;2
; ldr r1, =|Image$ZI$Limit| ; Top of zero init segment
; mov r2, #0
;3
; cmp r3, r1 ; Zero init
; strcc r2, [r3], #4
; bcc %B3
[ :LNOT:THUMBCODE
bl Main ;Do not use main() because ......
;ldr pc, =Main ;
b .
[ THUMBCODE ;for start-up code for Thumb mode
orr lr,pc,#1
bx lr
CODE16
b .
CODE32
;function initializing stacks
InitStacks
;Do not use DRAM,such as stmfd,ldmfd......
;SVCstack is initialized before
;Under toolkit ver 2.5, 'msr cpsr,r1' can be used instead of 'msr cpsr_cxsf,r1'
mrs r0,cpsr
bic r0,r0,#MODEMASK
orr r1,r0,#UNDEFMODE|NOINT
msr cpsr_cxsf,r1 ;UndefMode
ldr sp,=UndefStack ; UndefStack=0x33FF_5C00
orr r1,r0,#ABORTMODE|NOINT
msr cpsr_cxsf,r1 ;AbortMode
ldr sp,=AbortStack ; AbortStack=0x33FF_6000
orr r1,r0,#IRQMODE|NOINT
msr cpsr_cxsf,r1 ;IRQMode
ldr sp,=IRQStack ; IRQStack=0x33FF_7000
orr r1,r0,#FIQMODE|NOINT
msr cpsr_cxsf,r1 ;FIQMode
ldr sp,=FIQStack ; FIQStack=0x33FF_8000
bic r0,r0,#MODEMASK|NOINT
orr r1,r0,#SVCMODE
msr cpsr_cxsf,r1 ;SVCMode
ldr sp,=SVCStack ; SVCStack=0x33FF_5800
;USER mode has not be initialized.
mov pc,lr
;The LR register will not be valid if the current mode is not SVC mode.
ReadNandID
mov r7,#NFCONF
ldr r0,[r7,#4] ;NFChipEn();
bic r0,r0,#2
str r0,[r7,#4]
mov r0,#0x90 ;WrNFCmd(RdIDCMD);
strb r0,[r7,#8]
mov r4,#0 ;WrNFAddr(0);
strb r4,[r7,#0xc]
1 ;while(NFIsBusy());
ldr r0,[r7,#0x20]
tst r0,#1
beq %B1
ldrb r0,[r7,#0x10] ;id = RdNFDat()<<8;
mov r0,r0,lsl #8
ldrb r1,[r7,#0x10] ;id |= RdNFDat();
orr r5,r1,r0
ldr r0,[r7,#4] ;NFChipDs();
orr r0,r0,#2
str r0,[r7,#4]
mov pc,lr
ReadNandStatus
mov r7,#NFCONF
bic r0,r0,#2
str r0,[r7,#4]
mov r0,#0x70 ;WrNFCmd(QUERYCMD);
strb r0,[r7,#8]
ldrb r1,[r7,#0x10] ;r1 = RdNFDat();
orr r0,r0,#2
str r0,[r7,#4]
mov pc,lr
WaitNandBusy
mov r1,#NFCONF
strb r0,[r1,#8]
1 ;while(!(RdNFDat()&0x40));
ldrb r0,[r1,#0x10]
tst r0,#0x40
beq %B1
mov r0,#0 ;WrNFCmd(READCMD0);
strb r0,[r1,#8]
mov pc,lr
CheckBadBlk
mov r7, lr
mov r5, #NFCONF
bic r0,r0,#0x1f ;addr &= ~0x1f;
ldr r1,[r5,#4] ;NFChipEn()
bic r1,r1,#2
str r1,[r5,#4]
mov r1,#0x50 ;WrNFCmd(READCMD2)
strb r1,[r5,#8]
mov r1, #5;6 ;6->5
strb r1,[r5,#0xc] ;WrNFAddr(5);(6) 6->5
strb r0,[r5,#0xc] ;WrNFAddr(addr)
mov r1,r0,lsr #8 ;WrNFAddr(addr>>8)
strb r1,[r5,#0xc]
cmp r6,#0 ;if(NandAddr)
movne r0,r0,lsr #16 ;WrNFAddr(addr>>16)
strneb r0,[r5,#0xc]
; bl WaitNandBusy ;WaitNFBusy()
;do not use WaitNandBusy, after WaitNandBusy will read part A!
mov r0, #100
1
subs r0, r0, #1
bne %B1
2
ldr r0, [r5, #0x20]
tst r0, #1
beq %B2
ldrb r0, [r5,#0x10] ;RdNFDat()
sub r0, r0, #0xff
mov r1,#0 ;WrNFCmd(READCMD0)
strb r1,[r5,#8]
ldr r1,[r5,#4] ;NFChipDs()
orr r1,r1,#2
str r1,[r5,#4]
mov pc, r7
ReadNandPage
mov r7,lr
mov r4,r1
mov r5,#NFCONF
bic r1,r1,#2
str r1,[r5,#4]
strb r1,[r5,#8]
strb r1,[r5,#0xc] ;WrNFAddr(0)
strb r1,[r5,#0xc]
strneb r0,[r5,#0xc]
ldr r0,[r5,#4] ;InitEcc()
orr r0,r0,#0x10
str r0,[r5,#4]
mov r0,#0 ;for(i=0; i<512; i++)
1
ldrb r1,[r5,#0x10] ;buf[i] = RdNFDat()
strb r1,[r4,r0]
add r0,r0,#1
bic r0,r0,#0x10000
cmp r0,#0x200
bcc %B1
ldr r0,[r5,#4] ;NFChipDs()
orr r0,r0,#2
str r0,[r5,#4]
mov pc,r7
LTORG
;GCS0->SST39VF1601
;GCS1->16c550
;GCS2->IDE
;GCS3->CS8900
;GCS4->DM9000
;GCS5->CF Card
;GCS6->SDRAM
;GCS7->unused
SMRDATA DATA
; Memory configuration should be optimized for best performance
; The following parameter is not optimized.
; Memory access cycle parameter strategy
; 1) The memory settings is safe parameters even at HCLK=75Mhz.
; 2) SDRAM refresh period is for HCLK<=75Mhz.
DCD (0+(B1_BWSCON<<4)+(B2_BWSCON<<8)+(B3_BWSCON<<12)+(B4_BWSCON<<16)+(B5_BWSCON<<20)+(B6_BWSCON<<24)+(B7_BWSCON<<28))
DCD ((B0_Tacs<<13)+(B0_Tcos<<11)+(B0_Tacc<<8)+(B0_Tcoh<<6)+(B0_Tah<<4)+(B0_Tacp<<2)+(B0_PMC)) ;GCS0
DCD ((B1_Tacs<<13)+(B1_Tcos<<11)+(B1_Tacc<<8)+(B1_Tcoh<<6)+(B1_Tah<<4)+(B1_Tacp<<2)+(B1_PMC)) ;GCS1
DCD ((B2_Tacs<<13)+(B2_Tcos<<11)+(B2_Tacc<<8)+(B2_Tcoh<<6)+(B2_Tah<<4)+(B2_Tacp<<2)+(B2_PMC)) ;GCS2
DCD ((B3_Tacs<<13)+(B3_Tcos<<11)+(B3_Tacc<<8)+(B3_Tcoh<<6)+(B3_Tah<<4)+(B3_Tacp<<2)+(B3_PMC)) ;GCS3
DCD ((B4_Tacs<<13)+(B4_Tcos<<11)+(B4_Tacc<<8)+(B4_Tcoh<<6)+(B4_Tah<<4)+(B4_Tacp<<2)+(B4_PMC)) ;GCS4
DCD ((B5_Tacs<<13)+(B5_Tcos<<11)+(B5_Tacc<<8)+(B5_Tcoh<<6)+(B5_Tah<<4)+(B5_Tacp<<2)+(B5_PMC)) ;GCS5
DCD ((B6_MT<<15)+(B6_Trcd<<2)+(B6_SCAN)) ;GCS6
DCD ((B7_MT<<15)+(B7_Trcd<<2)+(B7_SCAN)) ;GCS7
DCD ((REFEN<<23)+(TREFMD<<22)+(Trp<<20)+(Tsrc<<18)+(Tchr<<16)+REFCNT)
DCD 0x32 ;SCLK power saving mode, BANKSIZE 128M/128M
DCD 0x30 ;MRSR6 CL=3clk
DCD 0x30 ;MRSR7 CL=3clk
BaseOfROM DCD |Image$RO$Base|
TopOfROM DCD |Image$RO$Limit|
BaseOfBSS DCD |Image$RW$Base|
BaseOfZero DCD |Image$ZI$Base|
EndOfBSS DCD |Image$ZI$Limit|
ALIGN
;Function for entering power down mode
; 1. SDRAM should be in self-refresh mode.
; 2. All interrupt should be maksked for SDRAM/DRAM self-refresh.
; 3. LCD controller should be disabled for SDRAM/DRAM self-refresh.
; 4. The I-cache may have to be turned on.
; 5. The location of the following code may have not to be changed.
;void EnterPWDN(int CLKCON);
EnterPWDN
mov r2,r0 ;r2=rCLKCON
tst r0,#0x8 ;SLEEP mode?
bne ENTER_SLEEP
ENTER_STOP
ldr r0,=REFRESH
ldr r3,[r0] ;r3=rREFRESH
mov r1, r3
orr r1, r1, #BIT_SELFREFRESH
str r1, [r0] ;Enable SDRAM self-refresh
mov r1,#16 ;wait until self-refresh is issued. may not be needed.
0 subs r1,r1,#1
bne %B0
ldr r0,=CLKCON ;enter STOP mode.
str r2,[r0]
mov r1,#32
0 subs r1,r1,#1 ;1) wait until the STOP mode is in effect.
bne %B0 ;2) Or wait here until the CPU&Peripherals will be turned-off
; Entering SLEEP mode, only the reset by wake-up is available.
ldr r0,=REFRESH ;exit from SDRAM self refresh mode.
str r3,[r0]
MOV_PC_LR
ENTER_SLEEP
;NOTE.
;1) rGSTATUS3 should have the return address after wake-up from SLEEP mode.
ldr r0,=REFRESH
ldr r1,[r0] ;r1=rREFRESH
mov r1,#16 ;Wait until self-refresh is issued,which may not be needed.
0 subs r1,r1,#1
bne %B0
ldr r1,=MISCCR
ldr r0,[r1]
orr r0,r0,#(7<<17) ;Set SCLK0=0, SCLK1=0, SCKE=0.
str r0,[r1]
ldr r0,=CLKCON ; Enter sleep mode
str r2,[r0]
b . ;CPU will die here.
WAKEUP_SLEEP
;Release SCLKn after wake-up from the SLEEP mode.
ldr r1,=MISCCR
ldr r0,[r1]
bic r0,r0,#(7<<17) ;SCLK0:0->SCLK, SCLK1:0->SCLK, SCKE:0->=SCKE.
str r0,[r1]
ldr r0,=SMRDATA ;be careful!
0
ldr r3, [r0], #4
str r3, [r1], #4
cmp r2, r0
bne %B0
mov r1,#256
0 subs r1,r1,#1 ;1) wait until the SelfRefresh is released.
bne %B0
ldr r1,=GSTATUS3 ;GSTATUS3 has the start address just after SLEEP wake-up
ldr r0,[r1]
mov pc,r0
; Clock division test
; Assemble code, because VSYNC time is very short
EXPORT CLKDIV124
EXPORT CLKDIV144
CLKDIV124
ldr r0, = CLKDIVN
ldr r1, = 0x3 ; 0x3 = 1:2:4
str r1, [r0]
; wait until clock is stable
nop
nop
nop
nop
nop
ldr r0, = REFRESH
ldr r1, [r0]
bic r1, r1, #0xff
bic r1, r1, #(0x7<<8)
orr r1, r1, #0x470 ; REFCNT135
str r1, [r0]
nop
nop
nop
nop
nop
mov pc, lr
CLKDIV144
ldr r0, = CLKDIVN
ldr r1, = 0x4 ; 0x4 = 1:4:4
str r1, [r0]
nop
nop
nop
nop
nop
ldr r0, = REFRESH
ldr r1, [r0]
bic r1, r1, #0xff
orr r1, r1, #0x630 ; REFCNT675 - 1520
str r1, [r0]
nop
nop
nop
nop
nop
mov pc, lr
ALIGN
AREA RamData, DATA, READWRITE
^ _ISR_STARTADDRESS ; _ISR_STARTADDRESS=0x33FF_FF00
HandleReset # 4
HandleUndef # 4
HandleSWI # 4
HandlePabort # 4
HandleDabort # 4
HandleReserved # 4
HandleIRQ # 4
HandleFIQ # 4
;Do not use the label 'IntVectorTable',
;The value of IntVectorTable is different with the address you think it may be.
;IntVectorTable
;@0x33FF_FF20
HandleEINT0 # 4
HandleEINT1 # 4
HandleEINT2 # 4
HandleEINT3 # 4
HandleEINT4_7 # 4
HandleEINT8_23 # 4
HandleCAM # 4 ; Added for 2440.
HandleBATFLT # 4
HandleTICK # 4
HandleWDT # 4
HandleTIMER0 # 4
HandleTIMER1 # 4
HandleTIMER2 # 4
HandleTIMER3 # 4
HandleTIMER4 # 4
HandleUART2 # 4
;@0x33FF_FF60
HandleLCD # 4
HandleDMA0 # 4
HandleDMA1 # 4
HandleDMA2 # 4
HandleDMA3 # 4
HandleMMC # 4
HandleSPI0 # 4
HandleUART1 # 4
HandleNFCON # 4 ; Added for 2440.
HandleUSBD # 4
HandleUSBH # 4
HandleIIC # 4
HandleUART0 # 4
HandleSPI1 # 4
HandleRTC # 4
HandleADC # 4
;@0x33FF_FFA0
END
亚洲精品一二三区
狠狠撸狠狠干
福利视频网站
avtt久久
av激情网
中文字幕日韩欧美
黄色片国产
日本黄色免费看
日韩不卡一区
高清视频一区二区
亚洲国产精品久久久久
日韩欧美视频在线
久久久亚洲精品视频
蜜桃视频一区二区
麻豆chinese新婚xxx
黄网免费看
国产亚洲欧美在线
午夜影院在线观看视频
触手繁殖の地狱3d啪啪
日本在线看
国产日本在线观看
国产中文字幕一区二区
国产精品久久久久久久久久久久午夜片
亚洲激情一区
欧美亚洲国产精品
日韩免费大片
黄色影视大全
久久精品欧美一区二区三区不卡
亚洲成人精品在线观看
少妇高潮av久久久久久
久久国产精品99久久人人澡
日韩大片在线观看
激情五月综合色婷婷一区二区
国产一区在线观看视频
www.狠狠操
日韩高清一区
玖玖色资源
国产又粗又大又爽
国产一区二区不卡
亚洲亚洲人成综合网络
九九精品在线观看
