標(biāo)題:
ARM之LPC2132流水燈LCD1602
51黑小牛
時(shí)間:
2016-4-10 17:35
標(biāo)題:
1、匯編程序
GPADIR EQU 0xE0028008
GPASET EQU 0xE0028004
GPACLR EQU 0xE002800C
EXPORT xmain
AREA Init,CODE,READONLY
ENTRY
xmain
ldr r0,=GPADIR
orr r1,r1,#0x0ff
orr r1,#0x300
str r1,[r0] ;A=out
;===========init1602=================
mov r4,#0x38
BL w1602C
mov r4,#0x06
BL w1602C
mov r4,#0x0c
BL w1602C
mov r4,#0x01
BL w1602C
;============main=================
loop mov r4,#0x80
bl w1602C
mov r7,#0x30
loop1 mov r4,r7
bl w1602D
add r7,r7,#1
cmp r7,#0x3A
bne loop1
mov r4,#0xc0
bl w1602C
mov r7,#0x41
loop2 mov r4,r7
bl w1602D
add r7,r7,#1
cmp r7,#0x4f
bne loop2
B loop
w1602C orr r1,r1,#0x0ff
orr r1,#0x300
ldr r0,=GPACLR
str r1,[r0]
mov r1,#0
ORR r1,r1,r4
ldr r0,=GPASET
str r1,[r0]
nop
nop
orr r1,r1,#0x200
str r1,[r0]
nop
nop
nop
nop
ldr r0,=GPACLR
mov r1,#0x200
str r1,[r0]
mov pc,lr
w1602D orr r1,r1,#0x0ff
orr r1,#0x300
ldr r0,=GPACLR
str r1,[r0]
mov r1,#0x100
ORR r1,r1,r4
ldr r0,=GPASET
str r1,[r0]
nop
nop
orr r1,r1,#0x200
str r1,[r0]
nop
nop
nop
nop
ldr r0,=GPACLR
mov r1,#0x200
str r1,[r0]
mov pc,lr
delay mov r5,#3
delay1 sub r5,r5,#1
cmp r5,#0
bne delay1
mov pc,lr
end
2、以下為C程序
//GPIO0=32Pin;(Pin0----Pin31)
#define GPIO0IN (*(volatile unsigned long *) 0xE0028000)//輸入寄存器
#define GPIO0SET (*(volatile unsigned long *) 0xE0028004)//輸出1,那位為1,管腳輸出1
#define GPIO0CLR (*(volatile unsigned long *) 0xE002800C)//輸出0,那位為1,管腳輸出0
#define GPIO0DIR (*(volatile unsigned long *) 0xE0028008)//方向控制,1為輸出,0輸入
//GPIO0=16Pin;(Pin16----Pin31)
#define GPIO1IN (*(volatile unsigned long *) 0xE0028010)//輸入寄存器
#define GPIO1SET (*(volatile unsigned long *) 0xE0028014)//輸出1,那位為1,管腳輸出1
#define GPIO1CLR (*(volatile unsigned long *) 0xE002801C)//輸出0,那位為1,管腳輸出0
#define GPIO1DIR (*(volatile unsigned long *) 0xE0028018)//方向控制,1為輸出,0輸入
void xmain()
unsigned short n,m;
GPIO1DIR =0xffff0000;
for(n=16;n<32;n++)
GPIO1CLR=0xffff0000;
for(m=0;m<30000;m++)
GPIO1SET=1<<n;
#define GPIO0IN (*(volatile unsigned long *) 0xE0028000)//1ü½ÅÖμ
#define GPIO0SET (*(volatile unsigned long *) 0xE0028004)//êä3ö1¼Ä′æÆ÷
#define GPIO0CLR (*(volatile unsigned long *) 0xE002800C)//êä3ö0¼Ä′æÆ÷
#define GPIO0DIR (*(volatile unsigned long *) 0xE0028008)//fangx
#define GPIO1IN (*(volatile unsigned long *) 0xE0028010)//1ü½ÅÖμ
#define GPIO1SET (*(volatile unsigned long *) 0xE0028014)//êä3ö1¼Ä′æÆ÷
#define GPIO1CLR (*(volatile unsigned long *) 0xE002801C)//êä3ö0¼Ä′æÆ÷
#define GPIO1DIR (*(volatile unsigned long *) 0xE0028018)//fangx
void xmain()
unsigned short n,m,k;
GPIO1DIR =0xff030000;
GPIO1CLR |=0xff030000;
GPIO1SET |=0x38000000;
for(n=0;n<8;n++);
GPIO1SET |=0x00020000;
for(n=0;n<12;n++);
GPIO1CLR |=0x00020000;
GPIO1SET |=0x06000000;
for(n=0;n<8;n++);
for(n=0;n<12;n++);
GPIO1SET |=0x0c000000;
for(n=0;n<8;n++);
for(n=0;n<12;n++);
GPIO1SET |=0x01000000;
for(n=0;n<8;n++);
for(n=0;n<12;n++);
GPIO1SET |=0x80000000;
for(n=0;n<8;n++);
for(n=0;n<12;n++);
for(m=0;m<10;m++)
GPIO1SET |=(0x30010000 +(m<<24));
for(n=0;n<5;n++);
GPIO1SET |=(0x00030000 + (m<<24));
for(n=0;n<8;n++);
k=30000;
while(k--);
GPIO1SET |=0xc0000000;
for(n=0;n<8;n++);
GPIO1SET |=0xc0020000;
for(n=0;n<12;n++);
for(m=0;m<16;m++)
GPIO1SET |=(0x41010000 +(m<<24));
for(n=0;n<8;n++);
GPIO1SET |=(0x41030000 + (m<<24));
for(n=0;n<12;n++);
k=30000;
while(k--);
k=60000;
while(k--);
for(n=0;n<8;n++);
GPIO1SET |=0x01020000;
for(n=0;n<12;n++);
unsigned char tt[13]="Shanxi Dianzi";
void xmain()
unsigned short n,m;
GPIO0DIR =0x3ff;
GPIO0CLR |=0x3ff;
for(n=0;n<12;n++)
GPIO0SET |=0x38;
GPIO0SET |=0x200;
for(n=0;n<12;n++);
GPIO0CLR |=0x200;
GPIO0CLR |=0x3ff;
for(n=0;n<12;n++)
GPIO0SET |=0x06;
GPIO0SET |=0x200;
for(n=0;n<12;n++);
GPIO0CLR |=0x200;
GPIO0CLR |=0x000003ff;
for(n=0;n<12;n++)
GPIO0SET |=0x0c;
GPIO0SET |=0x00000200;
for(n=0;n<12;n++);
GPIO0CLR |=0x00000200;
for(n=0;n<12;n++)
GPIO0SET |=0x01;
for(n=0;n<12;n++);
GPIO0SET |=0x80;
for(n=0;n<12;n++);
for(n=0;n<12;n++);
for(m=0;m<10;m++)
GPIO0CLR |=0x3ff;
GPIO0SET |=0x100;
GPIO0SET |=0x30 + m;
or(n=0;n<12;n++);
GPIO0SET |=0x300;
for(n=0;n<12;n++);
GPIO0CLR |=0x200;
GPIO0CLR |=0x3ff;
GPIO0SET |=0xc0;
for(n=0;n<12;n++);
GPIO0SET |=0x200;
for(n=0;n<12;n++);
GPIO0CLR |=0x200;
for(m=0;m<13;m++)
GPIO0CLR |=0x3ff;
GPIO0SET |=0x100;
GPIO0SET |=0x41+m;
for(n=0;n<5;n++);
GPIO0SET |=0x300;
for(n=0;n<8;n++);
GPIO0CLR |=0x200;
欧美成人精品一区二区三区在线看
国产精品一级
国产一区二区视频在线
国产激情视频在线
免费av网站在线观看
欧美性视频在线
色综合99
亚洲综合在线播放
亚洲激情欧美
av高清在线
97精品国产露脸对白
成人理论影院
国产精品亚洲综合
国产天堂网
免费观看全黄做爰大片视频美国
免费av大片
欧美在线免费观看视频
欧美一级网站
三上悠亚一区
日韩欧美网站
日本特黄特色aaa大片免费
国产精品3
国产精品久久久久久久久久久久久久
日本一本草久p
三级在线观看
三年中文在线观看免费大全中国
国产精品成人一区二区三区
精品一区二区三区视频
国产欧美日韩
中文字幕在线观看一区二区
国产成人午夜高潮毛片
成人免费av
欧美日韩一区二区在线观看
黄色一级片黄色一级片
中文字幕在线观看网址
爱爱免费小视频
欧美日韩激情
九九在线观看高清免费
国产欧美日韩视频
成人免费看片
在线观看欧美日韩
