LCD12864液晶滾動顯示漢字程序帶proteus仿真
51黑小牛
2016-4-10 21:19
用51單片機驅動lcd12864液晶屏實現漢字滾動顯示,
(33.26 KB, 下載次數: 213)
2016-4-10 21:19 上傳
(43.67 KB, 下載次數: 222)
2016-4-10 21:19 上傳
以上壓縮包
下載帶仿真:
滾動顯示LCD12864.rar
(53.97 KB, 下載次數: 79)
2016-4-10 21:19 上傳
程序:
#include<reg51.h>
#include<absacc.h>
typedef unsigned char uchar;
typedef unsigned int uint;
#define LLCD_CMD_WR PBYTE[0x10]
#define LLCD_CMD_RD PBYTE[0x11]
#define LLCD_DATA_WR PBYTE[0x12]
#define LLCD_DATA_RD PBYTE[0x13]
#define RLCD_CMD_WR PBYTE[0x20]
#define RLCD_CMD_RD PBYTE[0x21]
#define RLCD_DATA_WR PBYTE[0x22]
#define RLCD_DATA_RD PBYTE[0x23]
sbit busy=P0^1;
uchar code hz0[]=
0x00, 0x00, 0xf8, 0x88, 0x99, 0xea, 0x8c, 0xf8, 0x88, 0xcc, 0xab, 0x99, 0x88, 0xf8, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0xfe, 0x4a, 0x4a, 0x4a, 0x4a, 0x4a, 0x4a, 0xfe, 0x00, 0x00, 0x00, 0x00,
0x20, 0x30, 0xac, 0x63, 0x10, 0x00, 0x40, 0x42, 0x22, 0x22, 0x12, 0x1a, 0x26, 0x42, 0xc0, 0x00,
0x22, 0x23, 0x22, 0x12, 0x12, 0x00, 0x20, 0x21, 0x21, 0x21, 0x3f, 0x21, 0x21, 0x21, 0x20, 0x00,
0x10, 0x60, 0x01, 0x86, 0x60, 0x20, 0xd0, 0x48, 0x44, 0x43, 0x44, 0xc8, 0x30, 0x60, 0x20, 0x00,
0x04, 0x04, 0xfe, 0x01, 0x00, 0x00, 0x7f, 0x80, 0x80, 0x84, 0x88, 0x87, 0x80, 0xe0, 0x00, 0x00,
0x10, 0x60, 0x01, 0xf6, 0x00, 0x10, 0xf8, 0x17, 0x34, 0x54, 0x14, 0x14, 0xf4, 0x04, 0x04, 0x00,
0x04, 0x04, 0xff, 0x00, 0x01, 0x01, 0x1f, 0x11, 0x13, 0x15, 0x51, 0x91, 0x7f, 0x11, 0x11, 0x00,
0x14, 0x24, 0x44, 0x84, 0x7c, 0x40, 0x30, 0xfc, 0x4b, 0x48, 0xf9, 0x4e, 0x48, 0x48, 0x08, 0x00,
0x10, 0x08, 0x06, 0x01, 0x03, 0x0c, 0x00, 0xff, 0x22, 0x22, 0x3f, 0x22, 0x22, 0x22, 0x20, 0x00,
0x00, 0x10, 0x10, 0x12, 0x14, 0x1c, 0x10, 0xf0, 0x9f, 0x10, 0x10, 0x10, 0x10, 0xf8, 0x10, 0x00,
0x00, 0x00, 0x40, 0x20, 0x10, 0x08, 0x06, 0x01, 0x00, 0x11, 0x26, 0x40, 0x20, 0x1f, 0x00, 0x00,
0x00, 0x10, 0x10, 0x10, 0x90, 0x70, 0x00, 0xff, 0x20, 0x60, 0x90, 0x08, 0x04, 0x00, 0x00, 0x00,
0x10, 0x10, 0x08, 0x06, 0x01, 0x40, 0x80, 0x7f, 0x00, 0x00, 0x01, 0x06, 0x0c, 0x18, 0x08, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x58, 0x38, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
uchar code hz1[]=
0xfe, 0x02, 0x32, 0xca, 0x46, 0x20, 0x30, 0x2c, 0xe3, 0x24, 0x28, 0x10, 0x20, 0x20, 0x00, 0x00,
0xff, 0x02, 0x04, 0x43, 0x20, 0x11, 0x4d, 0x81, 0x7f, 0x01, 0x05, 0x09, 0x11, 0x30, 0x00, 0x00,
0x80, 0x88, 0x88, 0x88, 0xff, 0x88, 0x88, 0x88, 0x00, 0xfe, 0x02, 0x02, 0x02, 0xfe, 0x00, 0x00,
0x00, 0x10, 0x3c, 0x13, 0x10, 0x08, 0x0a, 0x1c, 0x08, 0xff, 0x00, 0x08, 0x10, 0x0f, 0x00, 0x00,
0x00, 0x02, 0x82, 0x7a, 0x92, 0x02, 0x02, 0xfe, 0x02, 0x02, 0x02, 0xfa, 0x02, 0x02, 0x00, 0x00,
0x48, 0x46, 0x41, 0x40, 0x41, 0x46, 0x40, 0x7f, 0x48, 0x44, 0x43, 0x40, 0x41, 0x4e, 0x44, 0x00,
0x00, 0x00, 0xe0, 0x00, 0x00, 0x00, 0x00, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0xe0, 0x00, 0x00,
0x00, 0x20, 0x7f, 0x20, 0x20, 0x20, 0x20, 0x3f, 0x20, 0x20, 0x20, 0x20, 0x20, 0x7f, 0x00, 0x00,
0x00, 0x02, 0x02, 0x02, 0x02, 0x82, 0x42, 0xfe, 0x06, 0x42, 0xc2, 0x82, 0x02, 0x03, 0x02, 0x00,
0x00, 0x08, 0x04, 0x02, 0x01, 0x00, 0x00, 0x7f, 0x00, 0x00, 0x00, 0x01, 0x07, 0x02, 0x00, 0x00,
0x80, 0x80, 0x80, 0x80, 0xbe, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xbe, 0x80, 0x80, 0x80, 0x00,
0x00, 0x40, 0x20, 0x10, 0x0e, 0x10, 0x20, 0x3f, 0x44, 0x44, 0x44, 0x44, 0x44, 0x40, 0x40, 0x00,
0x40, 0x40, 0x44, 0x44, 0x44, 0x44, 0xc4, 0xc4, 0x44, 0x44, 0x46, 0x46, 0x64, 0x60, 0x40, 0x00,
0x00, 0x20, 0x70, 0x38, 0x2c, 0x27, 0x23, 0x31, 0x10, 0x12, 0x14, 0x18, 0x70, 0x20, 0x00, 0x00,
0x00, 0x00, 0x5b, 0x3b, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
uchar code hz2[]=
0x02, 0x02, 0xfe, 0x92, 0x92, 0x92, 0xfe, 0x02, 0x02, 0x7c, 0x84, 0x04, 0x84, 0x7c, 0x04, 0x00,
0x10, 0x10, 0x0f, 0x08, 0x08, 0x04, 0xff, 0x04, 0x22, 0x10, 0x09, 0x06, 0x09, 0x30, 0x10, 0x00,
0x00, 0x02, 0x1c, 0xc0, 0x30, 0x4c, 0x30, 0x0f, 0x08, 0xf8, 0x08, 0x08, 0x28, 0x18, 0x08, 0x00,
0x02, 0x5e, 0x43, 0x20, 0x20, 0x10, 0x08, 0x04, 0x03, 0x01, 0x06, 0x08, 0x30, 0x60, 0x20, 0x00,
0x04, 0x04, 0x04, 0x84, 0xf4, 0x2f, 0x04, 0x04, 0xe4, 0x0f, 0x04, 0xc4, 0x84, 0x04, 0x04, 0x00,
0x00, 0x02, 0x01, 0x00, 0xff, 0x00, 0x08, 0x04, 0x3f, 0x42, 0x41, 0x40, 0x40, 0x78, 0x20, 0x00,
0x00, 0x00, 0x00, 0x00, 0xfe, 0x00, 0x00, 0x00, 0x00, 0xfe, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
0x20, 0x30, 0x2c, 0x23, 0x20, 0x21, 0x36, 0x2c, 0x23, 0x20, 0x20, 0x23, 0x26, 0x3c, 0x28, 0x00,
0xe0, 0x00, 0xff, 0x10, 0xf4, 0x94, 0xff, 0x94, 0xf4, 0x08, 0xf4, 0x13, 0x92, 0x1a, 0xf6, 0x00,
0x00, 0x00, 0xff, 0x10, 0x08, 0x06, 0xff, 0x02, 0x04, 0x80, 0x4f, 0x20, 0x1f, 0x20, 0xcf, 0x00,
0x00, 0xfe, 0x02, 0x02, 0xf2, 0x12, 0x12, 0x12, 0x12, 0x12, 0xf2, 0x02, 0x02, 0xfe, 0x00, 0x00,
0x00, 0x7f, 0x40, 0x40, 0x47, 0x44, 0x44, 0x44, 0x44, 0x44, 0x47, 0x40, 0x40, 0x7f, 0x00, 0x00,
0x00, 0xfe, 0x02, 0xf2, 0x12, 0x12, 0xf2, 0x00, 0xf2, 0x12, 0x1a, 0xd6, 0x12, 0xf2, 0x02, 0x00,
0x20, 0x1f, 0x00, 0x3f, 0x10, 0x09, 0x45, 0x40, 0x2f, 0x20, 0x10, 0x0f, 0x10, 0x2f, 0x60, 0x00,
uchar code hz3[]=
0x00, 0x00, 0x42, 0x44, 0x5c, 0x48, 0x40, 0xff, 0x40, 0x50, 0x48, 0x46, 0x64, 0x40, 0x00, 0x00,
0x00, 0x04, 0x04, 0x04, 0x04, 0x04, 0x04, 0xff, 0x04, 0x04, 0x04, 0x04, 0x04, 0x06, 0x04, 0x00,
0x20, 0x38, 0xa7, 0x62, 0x10, 0x20, 0xa0, 0x6c, 0x6b, 0xaa, 0x2a, 0x3a, 0x26, 0xa0, 0x20, 0x00,
0x12, 0x13, 0x12, 0x0a, 0x29, 0x25, 0x12, 0x12, 0x49, 0x85, 0x7f, 0x02, 0x0d, 0x18, 0x08, 0x00,
0x20, 0x10, 0xfc, 0x07, 0xf2, 0x20, 0x98, 0x8f, 0x54, 0xa4, 0x24, 0x54, 0xcc, 0x80, 0x80, 0x00,
0x00, 0x00, 0x7f, 0x00, 0x03, 0x54, 0x54, 0x4a, 0x2b, 0x25, 0x15, 0x12, 0x0a, 0x09, 0x00, 0x00,
0x40, 0x42, 0xcc, 0x00, 0x04, 0x04, 0xe5, 0xb6, 0xac, 0xa4, 0xa6, 0xe5, 0x04, 0x04, 0x00, 0x00,
0x40, 0x20, 0x1f, 0x20, 0x40, 0x40, 0x5f, 0x4a, 0x4a, 0x4a, 0x4a, 0x5f, 0x40, 0x40, 0x40, 0x00,
0x10, 0x10, 0x92, 0x92, 0x92, 0xf2, 0x9e, 0x92, 0x92, 0x92, 0x92, 0x92, 0xfe, 0x10, 0x10, 0x00,
0x40, 0x20, 0x10, 0x0c, 0xfe, 0x45, 0x44, 0x44, 0x44, 0x44, 0x44, 0x44, 0xfd, 0x00, 0x00, 0x00,
0x00, 0x18, 0x24, 0x24, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
void lcd_cmd_wr(uchar cmdcode,uchar f);
void lcd_data_wr(uchar ldata,uchar f);
void chech_busy(uchar f);
void lcd_hz_wr(uchar posx,uchar posy,uchar *hz);
void lcd_str_wr(uchar row,uchar col,uchar n,uchar *str);
void lcd_rol();
void lcd_init();
void delay(uint n);
lcd_init();
lcd_str_wr(0,0,8,hz0);
delay(100);
lcd_str_wr(1,0,8,hz1);
delay(100);
lcd_str_wr(2,0,8,hz2);
delay(100);
lcd_str_wr(3,0,8,hz3);
delay(100);
lcd_rol();
delay(1000);
lcd_rol();
delay(1000);
void lcd_init()
uint i;
lcd_cmd_wr(0x3f,0);
lcd_cmd_wr(0xc0,0);
lcd_cmd_wr(0xb8,0);
lcd_cmd_wr(0x40,0);
lcd_cmd_wr(0x3f,1);
lcd_cmd_wr(0xc0,1);
lcd_cmd_wr(0xb8,1);
lcd_cmd_wr(0x40,1);
for(i=0;i<256;i++)
lcd_data_wr(0x00,0);
lcd_data_wr(0x00,1);
lcd_cmd_wr(0xb8+4,0);
lcd_cmd_wr(0xb8+4,1);
for(i=0;i<256;i++)
chech_busy(f);
if(f==0) LLCD_CMD_WR=cmdcode;
else RLCD_CMD_WR=cmdcode;
if(f==0) LLCD_CMD_RD;
else RLCD_CMD_RD;
while(busy);
uchar i;
for(i=0;i<n;i++)
lcd_hz_wr(row,col,str+i*32);
delay(50);
col++;
uchar i;
if(posy<4)
lcd_cmd_wr(0xb8+2*posx,0);
lcd_cmd_wr(0x40+16*posy,0);
for(i=0;i<16;i++) lcd_data_wr(hz[i],0);
lcd_cmd_wr(0xb8+2*posx+1,0);
for(i=16;i<32;i++) lcd_data_wr(hz[i],0);
lcd_cmd_wr(0xb8+2*posx,1);
lcd_cmd_wr(0x40+16*(posy-4),1);
for(i=0;i<16;i++) lcd_data_wr(hz[i],1);
lcd_cmd_wr(0xb8+2*posx+1,1);
for(i=16;i<32;i++) lcd_data_wr(hz[i],1);
chech_busy(f);
if(f==0) LLCD_DATA_WR=ldata;
else RLCD_DATA_WR=ldata;
void lcd_rol()
uchar i;
for(i=0;i<64;i++)
lcd_cmd_wr(0xc0+i,0);
lcd_cmd_wr(0xc0+i,1);
delay(10);
void delay(uint n)
uint i;
for(;n>0;n--)
for(i=500;i>0;i--);
MiuMiYa
2016-4-12 16:29
太有用了,對我幫助很大
7547163
2016-5-2 10:08
這漢字都的編碼呀?!。!
lb688
2016-6-18 13:10
不錯,學習了。
chuanqi12
2016-6-18 14:56
學習了,謝謝!
国产片一区二区
亚洲天堂日本
中文字幕av在线播放
日韩av手机在线观看
亚洲丝袜av
青青五月天
四虎影院在线
四虎视频
www.日韩
亚洲成年人在线观看
日韩a在线观看
免费一级黄色
成人在线不卡
日韩不卡免费视频
婷婷导航
欧美成人精品激情在线观看
在线视频福利
国产成人精品一区二区三区福利
91久久精品日日躁夜夜躁欧美
天天精品视频
成人在线国产
欧美福利在线
精品久久久久久一区二区里番
国产日韩精品在线
五月婷婷在线播放
97精品在线观看
日日操av
中文字幕高清
91免费视频
男女啪啪网站
国产又粗又大又长
欧美精产国品一二三区
国产盗摄一区二区
亚洲最大av网站
成年女人毛片
成人欧美一区二区三区白人
国产成人免费在线视频
日韩色网站
国语对白做受欧美
亚洲免费福利视频
99热播
