dsp通過MPU6050測量加速度,角速度等值 dsp硬件I2C通信
ruidong
2016-4-23 01:26
基于dsp硬件I2C通信,dsp通過MPU6050測量加速度,角速度等值!!!!!
(33.99 KB, 下載次數: 198)
2016-4-24 04:28 上傳
全部源碼下載:
I2C_MPU6050.rar
(213.35 KB, 下載次數: 57)
2016-4-23 01:24 上傳
c程序
// TI File $Revision: /main/1 $
// Checkin $Date: August 18, 2006 13:46:27 $
// FILE: DSP2833x_I2C.c
// TITLE: DSP2833x SCI Initialization & Support Functions.
// $TI Release: DSP2833x Header Files V1.01 $
// $Release Date: September 26, 2007 $
#include "DSP2833x_Device.h" // DSP2833x Headerfile Include File
#include "DSP2833x_Examples.h" // DSP2833x Examples Include File
// InitI2C:
// This function initializes the I2C to a known state.
void InitI2C(void)
// Initialize I2C-A:
I2caRegs.I2CMDR.all = 0x0000; // Take I2C reset 復位I2C
// Stop I2C when suspended
InitI2CGpio(); //初始化GPIO
//復位FIFO寄存器
I2caRegs.I2CFFTX.all = 0x0000; // Disable FIFO mode and TXFIFO
I2caRegs.I2CFFRX.all = 0x0040; // Disable RXFIFO, clear RXFFINT,
//根據晶振不同設置預定標寄存器的值
#if (CPU_FRQ_150MHZ) // Default - For 150MHz SYSCLKOUT
I2caRegs.I2CPSC.all = 14; // Prescaler - need 7-12 Mhz on module clk (150/15 = 10MHz)
#endif
#if (CPU_FRQ_100MHZ) // For 100 MHz SYSCLKOUT
I2caRegs.I2CPSC.all = 9; // Prescaler - need 7-12 Mhz on module clk (100/10 = 10MHz)
#endif
//設定時鐘值
// I2caRegs.I2CCLKL = 20; // NOTE: must be non zero
// I2caRegs.I2CCLKH =15; // NOTE: must be non zero
// I2caRegs.I2CIER.all = 0x24; // Enable SCD & ARDY interrupts
// I2caRegs.I2CMDR.all = 0x0020; // Take I2C out of reset 從復位狀態恢復
// // Stop I2C when suspended
// I2caRegs.I2CFFTX.all = 0x6000; // Enable FIFO mode and TXFIFO 允許寫數據FIFO
// I2caRegs.I2CFFRX.all = 0x206E; // Enable RXFIFO, clear RXFFINT, 允許讀取FIFO
I2caRegs.I2CCLKL = 10; // NOTE: must be non zero
I2caRegs.I2CCLKH = 5; // NOTE: must be non zero
I2caRegs.I2CFFRX.all = 0x2040; // Enable RXFIFO, clear RXFFINT
// I2caRegs.I2CFFRX.bit.RXFFINTCLR =1; //清除I2C FIFO中斷標志位
// I2caRegs.I2CFFRX.bit.RXFFRST=0; //復位I2C FIFO
//EDIS;
//return;
//tbd...
// Example: InitI2CGpio:
// This function initializes GPIO pins to function as I2C pins
// Each GPIO pin can be configured as a GPIO pin or up to 3 different
// peripheral functional pins. By default all pins come up as GPIO
// inputs after reset.
// Caution:
// Only one GPIO pin should be enabled for SDAA operation.
// Only one GPIO pin shoudl be enabled for SCLA operation.
// Comment out other unwanted lines.
void InitI2CGpio(void)
EALLOW;
/* Enable internal pull-up for the selected pins */
// Pull-ups can be enabled or disabled disabled by the user.
// This will enable the pullups for the specified pins.
GpioCtrlRegs.GPBPUD.bit.GPIO32 = 0; // Enable pull-up for GPIO32 (SDAA)
GpioCtrlRegs.GPBPUD.bit.GPIO33 = 0; // Enable pull-up for GPIO33 (SCLA)
/* Set qualification for selected pins to asynch only */
// This will select asynch (no qualification) for the selected pins.
GpioCtrlRegs.GPBQSEL1.bit.GPIO32 = 3; // Asynch input GPIO32 (SDAA)
GpioCtrlRegs.GPBQSEL1.bit.GPIO33 = 3; // Asynch input GPIO33 (SCLA)
/* Configure SCI pins using GPIO regs*/
// This specifies which of the possible GPIO pins will be I2C functional pins.
GpioCtrlRegs.GPBMUX1.bit.GPIO32 = 1; // Configure GPIO32 for SDAA operation
GpioCtrlRegs.GPBMUX1.bit.GPIO33 = 1; // Configure GPIO33 for SCLA operation
EDIS;
// End of file.
ruidong
2016-4-23 11:25
怎莫不給黑幣????
SmartCar0119
2016-12-13 20:23
樓主,進不了IIC中斷是什么原因。
bigsegway3
2018-5-1 19:06
你好~請問要在哪個寄存器看陀螺儀MPU6050的輸出訊號?我們的控制板也是28335?
rbmachine
2019-4-10 21:33
感謝分享
土豆子00
2019-10-11 19:43
謝謝分享!!
peeta
2020-5-31 17:19
感謝分享,謝謝!
亚洲精品国产精品国自产观看浪潮
日日操夜夜干
国语对白做受欧美
1级黄色片
国产美女永久免费无遮挡
国产精品久久久久久久久久久久久久
丨国产丨调教丨91丨
国产激情在线
波多野结衣乳巨码无在线观看
蜜臀av在线播放
成年人国产
www.日本高清
www.爱爱
91污视频在线观看
色视频www在线播放国产人成
成人免费视频网址
久久视频这里只有精品
日韩激情一区
黄色一级影片
日韩成人综合
91精品国产99久久久久久红楼
韩日在线视频
91看片看淫黄大片
精品第一页
国内福利视频
国产精品久久久久久久久久久久久久
精品国产一区二区在线观看
成人黄色录像
亚洲精品18在线观看
欧美在线视频观看
精品欧美日韩
久久黄色录像
精品毛片一区二区三区
国产成人91
黄色成人在线
黄色片91
91成人在线
欧美自拍视频
亚洲免费精品
国产一区二区三区免费
欧美视频在线观看一区
