標(biāo)題: 匯編,按鍵數(shù)碼管顯示 [打印本頁]
作者: 殘夢流漣    時(shí)間: 2016-5-24 21:41
LNUM        EQU                0030H                                //將0030H定義為LNUM;
                ORG                0000H                                //程序在儲(chǔ)存器中存放的起始位置;
                JMP                START                                //跳轉(zhuǎn)到START;
                ORG                0100H                                //程序在儲(chǔ)存器中存放的起始位置;
START:        MOV                SP,#5FH                                //初始化SP值為5FH;
                MOV         LNUM,#4                                //共4行;
                MOV                P2,#9FH                                //初始化數(shù)碼管顯示為1;
                CLR                F0                                         //清零F0,初始化;
ST1:        CALL        MAKEY                                //單元矩陣鍵盤掃描子程序;
                JNB                F0,ST1                                //F0為0時(shí)無鍵按下,繼續(xù)掃描;
                ANL                A,#0FH                                //有鍵按下時(shí),鍵號在A中;
                MOV                DPTR,#CODE_P2                //將CODE_P0定義的數(shù)據(jù)表的首地址送給DPTR;
                MOVC        A,@A+DPTR                        //查表;
                MOV                P2,A                                //顯示所有按鍵的鍵號;
              JMP                ST1                                        //跳轉(zhuǎn)到ST1;
MAKEY:        CALL        KEYHN                                //調(diào)用子程序KEYHN;
        JNZ                HAVE                                //有鍵按下;
                JMP                NRET                                //清零F0,并返回再次進(jìn)行下面的程序;
HAVE:        CALL        D10ms                                //調(diào)用D10ms,延時(shí)10ms;
        CALL        KEYHN                                //延時(shí)后再判,去抖動(dòng);
                JNZ                TRUE                                //確認(rèn)有按鍵按下;
TRUE:        MOV                R1,#0EFH                        //首列掃描字;
                MOV                R4,#0                                //首列號;
SCAN:        MOV                A,R1                                //將R1中的值送給給A;
                MOV                P1,A                                //將A中的值送給P1;
                MOV                A,P1                                //將P1中的值送給A;
                JB                ACC.0,L1                        //0行無鍵按下,轉(zhuǎn)1行;
                MOV                A,#0                                //0行首鍵號;
                JMP                KEYNUM                                //轉(zhuǎn)鍵號計(jì)算;
        L1:        JB                ACC.1,L2                        //1行無鍵按下,轉(zhuǎn)2行;
                MOV                A,#4                                //1行首鍵號;
        L2: JB                ACC.2,L3                        //2行無鍵按下,轉(zhuǎn)3行;
                MOV                A,#8                                //2行首鍵號;
        L3:        JB                ACC.3,NEXT                        //3行無鍵按下,轉(zhuǎn)下一行;
            MOV                A,#0CH                                //3行首鍵號;
KEYNUM:        ADD                A,R4                                //鍵號=行首號+列號;
                PUSH        ACC                                        //將ACC中數(shù)給SP中;
UPKEY:        CALL        KEYHN                                //調(diào)用子程序KEYHN;
                JNZ                UPKEY                                //等待鍵釋放;
                POP                ACC                                        //將SP中的數(shù)給SP中;
                SETB        F0                                        //置有鍵按下標(biāo)志;
                JMP                HRET                                //跳轉(zhuǎn)到HRET;
NRET:        CLR                F0                                        //清零有鍵按下標(biāo)志;
HRET:        RET                                                        //返回到調(diào)用子程序NRET的下面;
NEXT:        INC                R4                                        //R4自加1,下一列;
                MOV                A,R1                                //將A中的數(shù)送給R1;
                DJNZ        LNUM,NDONE                        //若LUNM減1不為0,則跳轉(zhuǎn)到NDONE;
                                            //若LUNM減1為0,則程序往下執(zhí)行;
                JMP                NRET                            //跳轉(zhuǎn)到NRET;
NDONE:        RL                A                                        //掃描字左移,準(zhǔn)備掃描下一列;
                MOV                R1,A                                //置高四位全為0,低四位輸入狀態(tài);
                JMP                SCAN                                //跳轉(zhuǎn)到SCAN;
KEYHN:        MOV                P1,#0FH                                //置高四位全為0,低四位輸入狀態(tài);
                MOV                A,P1                            //將0FH送給A;
                CPL                A                                        //將A中的數(shù)取反再送給A;
                ANL                A,#0FH                                //A的高四位清零,低四位輸入狀態(tài);
                RET                                                        //返回;
D10ms:        MOV                R5,#10                                //10ms;
D1ms:        MOV                R4,#249                                //
DL:                NOP                                                        //空操作;
                NOP                                                        //空操作;
                DJNZ        R4,DL                            //R4減1,若為0,則結(jié)束循環(huán),程序往下執(zhí)行;
                                            //若不為0,則跳轉(zhuǎn)到DL;
                DJNZ        R5,D1ms                            //R5減1,若為0,則結(jié)束循環(huán),程序往下執(zhí)行;
                                            //若不為0,則跳轉(zhuǎn)到D1ms;
                RET                                                    //返回;
CODE_P2:DB                 03H,9FH,25H,0DH,99H,49H,40H,1FH
                DB                01H,09H,11H,0C1H,63H,85H,61H,71H //數(shù)碼管顯示數(shù)據(jù)表,0——F;
                END                                                    //結(jié)束;
作者: ahshmj    時(shí)間: 2016-5-24 22:08
有問題嗎?
主站蜘蛛池模板: 秋霞啪啪片 | 亚洲国产成人在线 | 欧美黄网站 | 久久性生活视频 | 国产三级视频在线播放 | 日本免费在线视频 | 国产精品亚洲综合 | 成人免费视频一区二区 | av免费网| 男人天堂久久 | 黄色小说在线免费观看 | 超碰在线免费公开 | 国模一区二区 | 成年人免费在线视频 | 日韩色黄大片 | 玖玖在线播放 | 中文字幕在线播放视频 | 国产女优在线 | 毛片网站视频 | av在线免费观看网址 | 国产免费91| 成人av免费看 | 99久久久国产精品免费蜜臀 | 一区二区三区在线播放 | 国产日韩欧美一区 | 国产网址 | 亚洲三级在线 | 美女张开腿 | 特黄aaaaaaaaa真人毛片 | 黄色一级免费视频 | 日韩国产在线播放 | 国产精品网站在线观看 | 伊人中文 | 久久综合久久鬼 | 毛片网站免费 | 国产成人午夜精品 | www.久久| 午夜性福利 | 四虎在线免费视频 | www亚洲精品| 99热国产 |
