標(biāo)題:
1602按鍵控制年月日時間顯示
qwertasdfg
2016-9-1 14:07
標(biāo)題:
1602按鍵控制年月日時間顯示
程序在KEIL軟件上調(diào)試成功
接上仿真軟件就可以運行
在這里就不發(fā)仿真軟件電路圖了
有需要可以聯(lián)系我
程序100%可以運行。。。。。
#include<reg51.h>
#include<intrins.h>
#define uchar unsigned char
#define uint unsigned int
#define DEC2BCD(X) ((X/10)<<4 | (X%10))
#define BCD2DEC(X) (((X&0x70)>>4)*10 + (X&0x0F))
void write_com(uchar com);
void write_data(uchar dat);
void init();
void write_time(uchar add,uchar dat);
void write_riqi(uchar add,uchar dat);
void write_xingqi(uchar dat);
void write_byte(uchar dat);
uchar read_byte();
void s_write(uchar add,uchar dat);
uchar s_read(uchar add);
void set_ds1302(uchar *pClock);
void rw_ds1302();
void keyscan();
uchar data table[]="2009-01-01 MON.";
uchar data table1[]="20-01-01 ";
uchar code week1[]="SUN";
uchar code week2[]="MON";
uchar code week3[]="TUE";
uchar code week4[]="WED";
uchar code week5[]="THU";
uchar code week6[]="FRI";
uchar code week7[]="SAT";
uchar code time[]={0x00,0x00,0x00,0x06,0x09,0x07,0x09};
uchar data time1[]={0x00,0x00,0x00,0x06,0x09,0x07,0x09};
uchar hour,min,sec,week,day,month,year,num,sfcount,flag;
sbit ds1302_sclk=P1^4;
sbit ds1302_io=P1^5;
sbit ds1302_ce=P2^2;
sbit acc0=ACC^0;
sbit acc7=ACC^7;
sbit lcdrs=P1^7;
sbit lcdrw=P1^6;
sbit lcde=P2^4;
sbit le=P3^6;
sbit leden=P2^5;
sbit dkle=P3^7;
sbit beep=P2^7;
sbit sf=P1^0;
sbit sup=P1^1;
void delay(uint a);
void keyscan();
s_write(0x8e,0x80);
init();
P0=0xff;
keyscan();
if(flag==0)
rw_ds1302();
uchar i;
ACC=dat;
for(i=8;i>0;i--)
ds1302_io=acc0;
ds1302_sclk=1;
ds1302_sclk=0;
ACC=ACC>>1;
uchar read_byte()
uchar i;
for(i=8;i>0;i--)
ACC=ACC>>1;
acc7=ds1302_io;
ds1302_sclk=1;
ds1302_sclk=0;
return(ACC);
ds1302_ce=0;
ds1302_sclk=0;
ds1302_ce=1;
write_byte(add);
write_byte(dat);
ds1302_sclk=1;
ds1302_ce=0;
uchar temp;
ds1302_ce=0;
ds1302_sclk=0;
ds1302_ce=1;
write_byte(add);
temp=read_byte();
ds1302_sclk=1;
ds1302_ce=0;
temp=BCD2DEC(temp);
return(temp);
uchar i;
uchar add=0x80;
EA=0;
s_write(0x8e,0x00);
for(i=7;i>0;i--)
s_write(add,*pClock);
pClock++;
add+=2;
s_write(0x8e,0x80);
EA=1;
void rw_ds1302()
EA=0;
sec=s_read(0x81);
write_time(8,sec);
write_com(0x80+0x40+9);
min=s_read(0x83);
write_time(5,min);
write_com(0x80+0x40+6);
hour=s_read(0x85);
write_time(2,hour);
write_com(0x80+0x40+3);
week=s_read(0x8b);
write_xingqi(week);
write_com(0x80+0x0d);
day=s_read(0x87);
write_riqi(8,day);
write_com(0x80+9);
month=s_read(0x89);
write_riqi(5,month);
write_com(0x80+6);
year=s_read(0x8d);
write_riqi(2,year);
write_com(0x80+3);
EA=1;
lcde=0;
lcdrw=0;
lcdrs=0;
delay(1);
lcde=1;
delay(1);
P0=com;
delay(1);
lcde=0;
lcde=0;
lcdrw=0;
lcdrs=1;
delay(1);
lcde=1;
delay(1);
P0=dat;
delay(1);
lcde=0;
void init()
s_write(0x90,0xa5);
set_ds1302(time);
delay(5);
lcde=0;
le=0;
leden=0;
write_com(0x38);
delay(100);
write_com(0x38);
delay(50);
write_com(0x38);
delay(10);
write_com(0x08);
write_com(0x01);
write_com(0x0c);
write_com(0x80);
for(num=0;num<15;num++)
write_data(table[num]);
write_com(0x80+0x40);
for(num=0;num<10;num++)
write_data(table1[num]);
uchar shi,ge;
shi=dat/10;
ge=dat%10;
write_com(0x80+0x40+add);
write_data(0x30+shi);
write_data(0x30+ge);
uchar shi,ge;
shi=dat/10;
ge=dat%10;
write_com(0x80+add);
/*void write_xingqi(uchar dat)
write_com(0x80+0x0b);
switch(dat)
case 1: for(num=0;num<4;num++)
write_data(xingqi[num]);
};break;
case 2: for(num=5;num<9;num++)
};break;
case 3: for(num=10;num<14;num++)
};break;
case 4: for(num=15;num<19;num++)
};break;
case 5: for(num=20;num<24;num++)
};break;
case 6: for(num=25;num<29;num++)
};break;
case 7: for(num=30;num<34;num++)
};break;
uchar i;
write_com(0x80+12);
switch(dat)
case 1: for(i=0;i<3;i++)
write_data(week1[i]);
delay(5);
case 2: for(i=0;i<3;i++)
write_data(week2[i]);
delay(5);
case 3: for(i=0;i<3;i++)
write_data(week3[i]);
delay(5);
case 4: for(i=0;i<3;i++)
write_data(week4[i]);
delay(5);
case 5: for(i=0;i<3;i++)
write_data(week5[i]);
delay(5);
case 6: for(i=0;i<3;i++)
write_data(week6[i]);
delay(5);
case 7: for(i=0;i<3;i++)
write_data(week7[i]);
delay(5);
void keyscan()
if(sf==0)
delay(2);
if(sf==0)
while(!sf);
sfcount++;
if(sfcount==1)
flag=1;
s_write(0x80,0x80);
write_com(0x0f);
if(sfcount==2)
if(sfcount==3)
if(sfcount==4)
if(sfcount==5)
write_com(0x80+9);
if(sfcount==6)
write_com(0x80+6);
if(sfcount==7)
write_com(0x80+3);
if(sfcount==8)
sfcount=0;
flag=0;
set_ds1302(time1);
delay(5);
write_com(0x0c);
s_write(0x80,0x00);
if(sup==0)
delay(5);
if(sup==0)
while(!sup);
if(sfcount==1)
sec++;
if(sec==60)
sec=0;
time1[0]=DEC2BCD(sec);
write_time(8,sec);
if(sfcount==2)
min++;
if(min==60)
min=0;
time1[1]=DEC2BCD(min);
write_time(5,min);
if(sfcount==3)
hour++;
if(hour==24)
hour=0;
time1[2]=DEC2BCD(hour);
write_time(2,hour);
if(sfcount==4)
week++;
if(week==8)
week=1;
time1[5]=week;
write_xingqi(week);
if(sfcount==5) //???
day++;
if(day==32)
day=1;
time1[3]=DEC2BCD(day);
write_riqi(8,day);
write_com(0x80+9);
if(sfcount==6) //???
month++;
if(month==13)
month=1;
time1[4]=DEC2BCD(month);
write_com(0x80+6);
if(sfcount==7) //???
year++;
if(year==100)
year=9;
time1[6]=DEC2BCD(year);
write_riqi(2,year);
write_com(0x80+3);
void delay(uint a)
uint i,j;
for(j=a;j>0;j--)
for(i=250;i>0;i--) ;
成人在线视频免费观看
男人天堂999
日本欧美国产
狠狠av
亚洲精品欧美精品
国产玖玖
超碰在线97国产
蜜臀av日日欢夜夜爽一区
黄色大片免费网站
精品美女在线观看视频在线观看
中文字幕在线三区
日韩在线免费
天堂资源最新在线
男女下面一进一出网站
中文一区
九九热精品视频
欧美在线视频一区二区
精品久久久久一区二区国产
久久久久91
欧美激情精品久久久久久变态
国产成人久久久
日韩成人精品一区二区三区
91高清免费
成人免费视频
日日夜夜精品视频
国精产品一品二品国精在线观看
99视频网
国产精品久久久久aaaa九色
国产一级片一区二区
天天天操天天天干
51ⅴ精品国产91久久久久久
黄色在线免费观看
亚洲免费视频一区
在线观看成人小视频
中文字幕综合
亚洲国产成人在线视频
久草免费在线视频
精品一区二区三区在线观看国产
一级黄色绿像片
在线观看国产视频
欧美性另类
