標(biāo)題: 8*8*8光立方制作2803+573 單片機(jī)程序+原理圖 [打印本頁]
作者: dvfrf42    時(shí)間: 2016-10-14 23:20
8*8*8的光立方原理圖 +程序源碼,給大家分享:
光立方2803+573.rar (2.67 MB, 下載次數(shù): 79)
這是用573的電路,材料清單如下:
1:8個(gè)74HC573(封裝為DIP—16);
2:1個(gè)2803(封裝為DIP—14);
3:2個(gè)30PF的瓷介電容;一個(gè)10UF的電解電容;一個(gè)220UF的電解電容;
4:一塊stc12a60s2(單片機(jī));
5:每個(gè)芯片配套的座子;
6:24或者12MHZ的晶振;
7: 1個(gè)1K,1個(gè)10K(都是碳膜電阻);
8:一個(gè)按鍵開關(guān),3個(gè)按鍵;
9:最好買600個(gè)燈,因?yàn)楹附拥臅r(shí)候可能會(huì)損壞(顏色隨便你自己選擇);
10:你可以考慮買4個(gè)銅柱;
備注:上面的3個(gè)按鍵可以只要1個(gè),另外2個(gè)是我設(shè)計(jì)的外部中斷,你可以不用它;同時(shí)我自己有開發(fā)板,所以我沒有設(shè)計(jì)程序下載電路,全以最節(jié)省的方案為前提,你只要把單片機(jī)在開發(fā)板上下載好程序,再插到光立方上就好了。同時(shí)畫電路時(shí)每個(gè)芯片的電源引腳隱藏了,(單片機(jī)是20接負(fù),40接正;595是8接負(fù),16接正;7404是7接負(fù),14接正。),還有注意電解電容的極性。關(guān)于你接電源的問題是你自己的事,我是在板子上面安裝了一個(gè)USB的接口供電。
單片機(jī)源程序:
  1. #include <REG52.H>
  2. #include <intrins.h>
  4. #define uint unsigned int
  5. uchar display[8][8];
  6. /*rank:A,1,2,3,4,I,心,U*/
  7. uchar code table_cha[8][8]={0x51,0x51,0x51,0x4a,0x4a,0x4a,0x44,0x44,0x18,0x1c,0x18,0x18,0x18,0x18,0x18,0x3c,0x3c,0x66,0x66,0x30,0x18,0xc,0x6,0xf6,0x3c,0x66,0x60,0x38,0x60,0x60,0x66,0x3c,0x30,0x38,0x3c,0x3e,0x36,0x7e,0x30,0x30,0x3c,0x3c,0x18,0x18,0x18,0x18,0x3c,0x3c,0x66,0xff,0xff,0xff,0x7e,0x3c,0x18,0x18,0x66,0x66,0x66,0x66,0x66,0x66,0x7e,0x3c};
  8. /*the "ideasoft"*/
  9. uchar code table_id[40]={0x81,0xff,0x81,0x00,0xff,0x81,0x81,0x7e,0x00,0xff,0x89,0x89,0x00,0xf8,0x27,0x27,0xf8,0x00,0x8f,0x89,0x89,0xf9,0x00,0xff,0x81,0x81,0xff,0x00,0xff,0x09,0x09,0x09,0x01,0x0,0x01,0x01,0xff,0x01,0x01,0x00};
  10. /*railway*/
  11. uchar code dat[128]={0x0,0x20,0x40,0x60,0x80,0xa0,0xc0,0xe0,0xe4,0xe8,0xec,0xf0,0xf4,0xf8,0xfc,0xdc,0xbc,0x9c,0x7c,0x5c,0x3c,0x1c,0x18,0x14,0x10,0xc,0x8,0x4,0x25,0x45,0x65,0x85,0xa5,0xc5,0xc9,0xcd,0xd1,0xd5,0xd9,0xb9,0x99,0x79,0x59,0x39,0x35,0x31,0x2d,0x29,0x4a,0x6a,0x8a,0xaa,0xae,0xb2,0xb6,0x96,0x76,0x56,0x52,0x4e,0x6f,0x8f,0x93,0x73,0x6f,0x8f,0x93,0x73,0x4a,0x6a,0x8a,0xaa,0xae,0xb2,0xb6,0x96,0x76,0x56,0x52,0x4e,0x25,0x45,0x65,0x85,0xa5,0xc5,0xc9,0xcd,0xd1,0xd5,0xd9,0xb9,0x99,0x79,0x59,0x39,0x35,0x31,0x2d,0x29,0x0,0x20,0x40,0x60,0x80,0xa0,0xc0,0xe0,0xe4,0xe8,0xec,0xf0,0xf4,0xf8,0xfc,0xdc,0xbc,0x9c,0x7c,0x5c,0x3c,0x1c,0x18,0x14,0x10,0xc,0x8,0x4};
  12. /*railway 2*/
  13. uchar code dat2[28]={0x0,0x20,0x40,0x60,0x80,0xa0,0xc0,0xe0,0xe4,0xe8,0xec,0xf0,0xf4,0xf8,0xfc,0xdc,0xbc,0x9c,0x7c,0x5c,0x3c,0x1c,0x18,0x14,0x10,0xc,0x8,0x4};
  14. /*railway 3*/
  15. uchar code dat3[24]={0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x16,0x26,0x36,0x46,0x56,0x66,0x65,0x64,0x63,0x62,0x61,0x60,0x50,0x40,0x30,0x20,0x10};
  16. /*3p char*/
  17. uchar code table_3p[3][8]={0xff,0x89,0xf5,0x93,0x93,0xf5,0x89,0xff,0x0e,0x1f,0x3f,0x7e,0x7e,0x3f,0x1f,0x0e,0x18,0x3c,0x7e,0xff,0x18,0x18,0x18,0x18};
  18. /*initializtion
  19. That is to initialize the program .
  20. It is write to set the timer in c52 mcu.
  21. So the program can renovate the led_3d_cube in fixed time use the interrupt function.*/
  22. void sinter()
  23. {
  24.          IE=0x82;
  25.          TCON=0x01;
  26.          TH0=0xc0;
  27.          TL0=0;
  28.          TR0=1;
  29. }
  30. void delay5us(void)   //誤差 -0.026765046296us STC 1T 22.1184Mhz
  31. {
  32.     unsigned char a,b;
  33.     for(b=7;b>0;b--)
  34.         for(a=2;a>0;a--);
  35. }
  36. void delay(uint i)
  37. {
  38.          while (i--){
  39.                  delay5us();}//12t的mcu 注釋這個(gè)延時(shí)即可
  40. }
  41. /*To judge the num bit*/
  42. uchar judgebit(uchar num,uchar b)
  43. {
  44.          char n;
  45.          num=num&(1<<b);
  46.          if (num)
  47.          n=1;
  48.          else
  49.          n=0;
  50.          return n;
  51. }
  52. /*To figure out the round number*/
  53. uchar abs(uchar a)
  54. {
  55.          uchar b;
  56.          b=a/10;
  57.          a=a-b*10;
  58.          if (a>=5)
  59.          b++;
  60.          return b;
  61. }
  62. /*To figure out the absolute value*/
  63. uchar abss(char a)
  64. {
  65.          if (a<0)
  66.          a=-a;
  67.          return a;
  68. }
  69. /*The function can comparat the character.
  70. And remove the big one to the back.*/
  71. void max(uchar *a,uchar *b)
  72. {
  73.    uchar t;
  74.    if ((*a)>(*b))
  75.    {
  76.                    t=(*a);
  77.                    (*a)=(*b);
  78.                    (*b)=t;
  79.    }
  80. }
  81. /*The function is to figure out the max number and return it.*/
  82. uchar maxt(uchar a,uchar b,uchar c)
  83. {
  84.          if (a<b)
  85.          a=b;
  86.          if (a<c)
  87.          a=c;
  88.          return a;
  89. }
  90. void clear(char le)
  91. {
  92.          uchar i,j;
  93.          for (j=0;j<8;j++)
  94.          {
  95.                    for (i=0;i<8;i++)
  96.                    display[j][i]=le;
  97.          }
  98. }
  99. void trailler(uint speed)
  100. {
  101.          char i,j;
  102.          for (i=6;i>=-3;i--)
  103.          {
  104.                    if (i>=0)
  105.                    {
  106.                             for (j=0;j<8;j++)
  107.                             display[j][i]=display[j][i+1];
  108.                    }
  109.                    if (i<4)
  110.                    {
  111.                             for (j=0;j<8;j++)
  112.                             display[j][i+4]=0;
  113.                    }
  114.                    delay(speed);
  115.          }
  116. }
  117. void point(uchar x,uchar y,uchar z,uchar le)
  118. {
  119.          uchar ch1,ch0;
  120.          ch1=1<<x;
  121.          ch0=~ch1;
  122.          if (le)
  123.          display[z][y]=display[z][y]|ch1;
  124.          else
  125.          display[z][y]=display[z][y]&ch0;
  126. }
  127. void type(uchar cha,uchar y)
  128. {
  129.          uchar xx;
  130.          for (xx=0;xx<8;xx++)
  131.          {
  132.          display[xx][y]=table_cha[cha][xx];
  133.          }
  134. }
  135. /*The first variable is the distance from the midpoint.
  136. The second is the layer.
  137. the third is the flash speed of the time between each two point.
  138. The forth is the enable io,it controls weather draw or claen.*/
  139. void cirp(char cpp,uchar dir,uchar le)
  140. {
  141.          uchar a,b,c,cp;
  142.          if ((cpp<128)&(cpp>=0))
  143.          {
  144.                    if (dir)
  145.                    cp=127-cpp;
  146.                    else
  147.                    cp=cpp;
  148.                    a=(dat[cp]>>5)&0x07;
  149.                    b=(dat[cp]>>2)&0x07;
  150.                    c=dat[cp]&0x03;
  151.                    if (cpp>63)
  152.                    c=7-c;
  153.                    point (a,b,c,le);
  154.          }
  155. }
  156. void line(uchar x1,uchar y1,uchar z1,uchar x2,uchar y2,uchar z2,uchar le)
  157. {
  158.          char t,a,b,c,a1,b1,c1,i;
  159.          a1=x2-x1;
  160.          b1=y2-y1;
  161.          c1=z2-z1;
  162.          t=maxt(abss(a1),abss(b1),abss(c1));
  163.          a=x1*10;
  164.          b=y1*10;
  165.          c=z1*10;
  166.          a1=a1*10/t;
  167.          b1=b1*10/t;
  168.          c1=c1*10/t;
  169.          for (i=0;i<t;i++)
  170.          {
  171.                    point(abs(a),abs(b),abs(c),le);
  172.                    a+=a1;
  173.                    b+=b1;
  174.                    c+=c1;
  175.          }
  176.          point(x2,y2,z2,le);
  177. }
  178. void box(uchar x1,uchar y1,uchar z1,uchar x2,uchar y2,uchar z2,uchar fill,uchar le)
  179. {
  180.          uchar i,j,t=0;
  181.          max(&x1,&x2);
  182.          max(&y1,&y2);
  183.          max(&z1,&z2);
  184.          for (i=x1;i<=x2;i++)
  185.                    t|=1<<i;
  186.          if (!le)
  187.                    t=~t;
  188.          if (fill)
  189.          {
  190.                    if (le)
  191.                    {
  192.                             for (i=z1;i<=z2;i++)
  193.                             {
  194.                                      for (j=y1;j<=y2;j++)
  195.                                                display[j][i]|=t;
  196.                             }
  197.                    }
  198.                    else
  199.                    {
  200.                             for (i=z1;i<=z2;i++)
  201.                             {
  202.                                      for (j=y1;j<=y2;j++)
  203.                                                display[j][i]&=t;
  204.                             }
  205.                    }
  206.          }
  207.          else
  208.          {
  209.                    if (le)
  210.                    {
  211.                             display[y1][z1]|=t;
  212.                             display[y2][z1]|=t;
  213.                             display[y1][z2]|=t;
  214.                             display[y2][z2]|=t;
  215.                    }
  216.                    else
  217.                    {
  218.                            display[y1][z1]&=t;
  219.                             display[y2][z1]&=t;
  220.                             display[y1][z2]&=t;
  221.                             display[y2][z2]&=t;
  222.                    }
  223.                    t=(0x01<<x1)|(0x01<<x2);
  224.                    if (!le)
  225.                             t=~t;
  226.                    if (le)
  227.                    {
  228.                             for (j=z1;j<=z2;j+=(z2-z1))
  229.                             {
  230.                                      for (i=y1;i<=y2;i++)
  231.                                                display[i][j]|=t;
  232.                             }
  233.                             for (j=y1;j<=y2;j+=(y2-y1))
  234.                             {
  235.                                      for (i=z1;i<=z2;i++)
  236.                                                display[j][i]|=t;
  237.                             }
  238.                    }
  239.                    else
  240.                    {
  241.                             for (j=z1;j<=z2;j+=(z2-z1))
  242.                             {
  243.                                      for (i=y1;i<=y2;i++)
  244.                                      {
  245.                                      display[i][j]&=t;
  246.                                      }
  247.                             }
  248.                             for (j=y1;j<=y2;j+=(y2-y1))
  249.                             {
  250.                                      for (i=z1;i<=z2;i++)
  251.                                      {
  252.                                      display[j][i]&=t;
  253.                                      }
  254.                             }
  255.                    }
  256.          }
  257. }
  258. void box_apeak_xy(uchar x1,uchar y1,uchar z1,uchar x2,uchar y2,uchar z2,uchar fill,uchar le)
  259. {
  260.          uchar i;
  261.          max(&z1,&z2);
  262.          if (fill)
  263.          {
  264.                    for (i=z1;i<=z2;i++)
  265.                    {
  266.                             line (x1,y1,i,x2,y2,i,le);
  267.                    }
  268.          }
  269.          else
  270.          {
  271.                    line (x1,y1,z1,x2,y2,z1,le);
  272.                    line (x1,y1,z2,x2,y2,z2,le);
  273.                    line (x2,y2,z1,x2,y2,z2,le);
  274.                    line (x1,y1,z1,x1,y1,z2,le);
  275.          }
  276. }
  277. void poke(uchar n,uchar x,uchar y)
  278. {
  279.          uchar i;
  280.          for (i=0;i<8;i++)
  281.          {
  282.           point(x,y,i,judgebit(n,i));
  283.          }
  284. }
  285. void boxtola(char i,uchar n)
  286. {
  287.          if ((i>=0)&(i<8))
  288.          {
  289.                    poke(n,0,7-i);
  290.          }
  291.          if ((i>=8)&(i<16))
  292.          {
  293.                    poke(n,i-8,0);
  294.          }
  295.          if ((i>=16)&(i<24))
  296.          {
  297.                    poke(n,7,i-16);
  298.          }
  299. }
  300. void rolldisplay(uint speed)
  301. {
  302.          uchar j;
  303.          char i,a;
  304.          for (i=23;i>-40;i--)
  305.          {
  306.                    for (j=0;j<40;j++)
  307.                    {
  308.                             a=i+j;
  309.                             if ((a>=0)&(a<24))
  310.                             boxtola(a,table_id[j]);
  311.                    }
  312.                    delay(speed);
  313.          }
  314. }
  315. void roll_apeak_yz(uchar n,uint speed)
  316. {
  317.          uchar i;
  318.          switch(n)
  319.          {
  320.                    case 1:
  321.                             for (i=0;i<7;i++)
  322.                             {
  323.                                      display[i][7]=0;
  324.                                      display[7][6-i]=255;
  325.                                      delay(speed);
  326.                             };
  327.                             break;
  328.                    case 2:
  329.                             for (i=0;i<7;i++)
  330.                             {
  331.                                      display[7][7-i]=0;
  332.                                      display[6-i][0]=255;
  333.                                      delay(speed);
  334.                             };
  335.                             break;
  336.                    case 3:
  337.                             for (i=0;i<7;i++)
  338.                             {
  339.                                      display[7-i][0]=0;
  340.                                      display[0][i+1]=255;
  341.                                      delay(speed);
  342.                             };
  343.                             break;
  344.                    case 0:
  345.                             for (i=0;i<7;i++)
  346.                             {
  347.                                      display[0][i]=0;
  348.                                      display[i+1][7]=255;
  349.                                      delay(speed);
  350.                             };
  351.          }
  352. }
  353. void roll_apeak_xy(uchar n,uint speed)
  354. {
  355.          uchar i;
  356.          switch(n)
  357.          {
  358.                    case 1:
  359.                             for (i=0;i<7;i++)
  360.                             {
  361.                                      line(0,i,0,0,i,7,0);
  362.                                      line(i+1,7,0,i+1,7,7,1);
  363.                                      delay(speed);
  364.                             };
  365.                             break;
  366.                    case 2:
  367.                             for (i=0;i<7;i++)
  368.                             {
  369.                                      line(i,7,0,i,7,7,0);
  370.                                      line(7,6-i,0,7,6-i,7,1);
  371.                                      delay(speed);
  372.                             };
  373.                             break;
  374.                    case 3:
  375.                             for (i=0;i<7;i++)
  376.                             {
  377.                                      line(7,7-i,0,7,7-i,7,0);
  378.                                      line(6-i,0,0,6-i,0,7,1);
  379.                                      delay(speed);
  380.                             };
  381.                             break;
  382.                    case 0:
  383.                             for (i=0;i<7;i++)
  384.                             {
  385.                                      line(7-i,0,0,7-i,0,7,0);
  386.                                      line(0,i+1,0,0,i+1,7,1);
  387.                                      delay(speed);
  388.                             };
  389.          }
  390. }
  391. void roll_3_xy(uchar n,uint speed)
  392. {
  393.          uchar i;
  394.          switch(n)
  395.          {
  396.                    case 1:
  397.                             for (i=0;i<8;i++)
  398.                             {
  399.                                      box_apeak_xy (0,i,0,7,7-i,7,1,1);
  400.                                      delay(speed);
  401.                                      if (i<7)
  402.                                      box_apeak_xy (3,3,0,0,i,7,1,0);
  403.                             };
  404.                             break;
  405.                    case 2:
  406.                             for (i=0;i<8;i++)
  407.                             {
  408.                                       box_apeak_xy (7-i,0,0,i,7,7,1,1);
  409.                                      delay(speed);
  410.                                      if (i<7)
  411.                                      box_apeak_xy (3,4,0,i,7,7,1,0);
  412.                             };
  413.                             break;
  414.                    case 3:
  415.                             for (i=0;i<8;i++)
  416.                             {
  417.                                      box_apeak_xy (0,i,0,7,7-i,7,1,1);
  418.                                      delay(speed);
  419.                                      if (i<7)
  420.                                      box_apeak_xy (4,4,0,7,7-i,7,1,0);
  421.                             };
  422.                             break;
  423.                    case 0:
  424.                             for (i=0;i<8;i++)
  425.                             {
  426.                                      box_apeak_xy (7-i,0,0,i,7,7,1,1);
  427.                                      delay(speed);
  428.                                      if (i<7)
  429.                                      box_apeak_xy (4,3,0,7-i,0,7,1,0);
  430.                             };
  431.          }
  432. }
  433. void trans(uchar z,uint speed)
  434. {
  435.          uchar i,j;
  436.          for (j=0;j<8;j++)
  437.          {
  438.                    for (i=0;i<8;i++)
  439.                    {
  440.                             display[z][i]>>=1;
  441.                    }
  442.                    delay(speed);
  443.          }
  444. }
  445. void tranoutchar(uchar c,uint speed)
  446. {
  447.          uchar i,j,k,a,i2=0;
  448.          for (i=0;i<8;i++)
  449.          {
  450.                    if (i<7)
  451.                    box_apeak_xy (i+1,0,0,i+1,7,7,1,1);
  452.                    box_apeak_xy (i2,0,0,i2,7,7,1,0);
  453.                    a=0;
  454.                    i2=i+1;
  455.                    for (j=0;j<=i;j++)
  456.                    {
  457.                             a=a|(1<<j);
  458.                    }
  459.                    for (k=0;k<8;k++)
  460.                    {
  461.                             display[k][3]|=table_cha[c][k]&a;
  462.                             display[k][4]|=table_cha[c][k]&a;
  463.                    }
  464.                    delay(speed);
  465.          }
  466. }
  467. void transss()
  468. {
  469.          uchar i,j;
  470.          for (i=0;i<8;i++)
  471.          {
  472.                    for (j=0;j<8;j++)
  473.                    display[i][j]<<=1;
  474.          }
  475. }
  476. /*From now on,the function below is to display the flash.*/
  477. void flash_1()
  478. {
  479.          clear(0);
  480.          type(1,0);
  481.          delay(60000);
  482.          type(2,0);
  483.          delay(60000);
  484.          type(3,0);
  485.          delay(60000);
  486.          type(4,0);
  487.          delay(60000);
  488.          delay(60000);
  489.          clear(0);
  490.          rolldisplay(30000);
  491.          type(0,7);
  492.          delay(60000);
  493.          trailler(6000);
  494.          delay(60000);
  495. }
  496. void flash_2()
  497. {
  498.          uchar i;
  499.          for (i=129;i>0;i--)
  500.          {
  501.                    cirp(i-2,0,1);
  502.                    delay(8000);
  503.                    cirp(i-1,0,0);
  504.          }
  505.          delay(8000);
  506.          for (i=0;i<136;i++)
  507.          {
  508.                    cirp(i,1,1);
  509.                    delay(8000);
  510.                    cirp(i-8,1,0);
  511.          }
  512.          delay(8000);
  513.                   for (i=129;i>0;i--)
  514.          {
  515.                    cirp(i-2,0,1);
  516.                    delay(8000);
  517.          }
  518.          delay(8000);
  519.                    for (i=0;i<128;i++)
  520.          {
  521.                    cirp(i-8,1,0);
  522.                    delay(8000);
  523.          }
  524.          delay(60000);
  525. }
  526. void flash_3()
  527. {
  528.          char i;
  529.          for (i=0;i<8;i++)
  530.          {
  531.                    box_apeak_xy(0,i,0,7,i,7,1,1);
  532.                    delay(20000);
  533.                    if (i<7)
  534.                    box_apeak_xy(0,i,0,7,i,7,1,0);
  535.          }
  536.          for (i=7;i>=0;i--)
  537.          {
  538.                    box_apeak_xy(0,i,0,7,i,7,1,1);
  539.                    delay(20000);
  540.                    if (i>0)
  541.                    box_apeak_xy(0,i,0,7,i,7,1,0);
  542.          }
  543.          for (i=0;i<8;i++)
  544.          {
  545.                    box_apeak_xy(0,i,0,7,i,7,1,1);
  546.                    delay(20000);
  547.                    if (i<7)
  548.                    box_apeak_xy(0,i,0,7,i,7,1,0);
  549.          }
  550. }
  551. void flash_4()
  552. {
  553.          char i,j,an[8];
  554.          for (j=7;j<15;j++)
  555.                    an[j-7]=j;
  556.          for (i=0;i<=16;i++)
  557.          {
  558.                    for (j=0;j<8;j++)
  559.                    {
  560.                             if ((an[j]<8)&(an[j]>=0))
  561.                             line(0,an[j],j,7,an[j],j,1);
  562.                    }
  563.                    for (j=0;j<8;j++)
  564.                    {
  565.                             if (((an[j]+1)<8)&(an[j]>=0))
  566.                             line(0,an[j]+1,j,7,an[j]+1,j,0);
  567.                    }
  568.                    for (j=0;j<8;j++)
  569.                    {
  570.                             if (an[j]>0)
  571.                             an[j]--;
  572.                    }
  573.                    delay(15000);
  574.          }
  575.          for (j=0;j<8;j++)
  576.                    an[j]=1-j;
  577.          for (i=0;i<=16;i++)
  578.          {
  579.                    for (j=0;j<8;j++)
  580.                    {
  581.                             if ((an[j]<8)&(an[j]>=0))
  582.                             line(0,an[j],j,7,an[j],j,1);
  583.                    }
  584.                    for (j=0;j<8;j++)
  585.                    {
  586.                             if (((an[j]-1)<7)&(an[j]>0))
  587.                             line(0,an[j]-1,j,7,an[j]-1,j,0);
  588.                    }
  589.                    for (j=0;j<8;j++)
  590.                    {
  591.                             if (an[j]<7)
  592.                             an[j]++;
  593.                    }
  594.                    delay(15000);
  595.          }
  596. }
  597. void flash_5()
  598. {
  599.          uint a=15000;//a=delay
  600.          char i=8,j,an[4];
  601.          //1
  602.          for (j=7;j<11;j++)
  603.                    an[j-7]=j;
  604.          while(i--)
  605.          {
  606.                    for (j=0;j<4;j++)
  607.                    {
  608.                             if (an[j]<8)
  609.                             box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  610.                             if (an[j]<7)
  611.                             box_apeak_xy(j,an[j]+1,j,7-j,an[j]+1,7-j,0,0);
  612.                    }
  613.                    for (j=0;j<4;j++)
  614.                    {
  615.                             if (an[j]>3)
  616.                             an[j]--;
  617.                    }
  618.                    delay(a);
  619.          }
  620.          //2
  621.          i=3;
  622.          for (j=0;j<4;j++)
  623.          an[j]=5-j;
  624.          while(i--)
  625.          {
  626.                    for (j=1;j<4;j++)
  627.                    {
  628.                             if (an[j]<4)
  629.                             box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  630.                             if (an[j]<3)
  631.                             box_apeak_xy(j,an[j]+1,j,7-j,an[j]+1,7-j,0,0);
  632.                    }
  633.                    for (j=0;j<4;j++)
  634.                    {
  635.                             if (an[j]>0)
  636.                             an[j]--;
  637.                    }
  638.                    delay(a);
  639.          }
  640.          //3
  641.          i=3;
  642.          for (j=1;j<4;j++)
  643.          an[j]=4-j;
  644.          while(i--)
  645.          {
  646.                    for (j=1;j<4;j++)
  647.                    {
  648.                             if (an[j]>=0)
  649.                             box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  650.                             if (an[j]>0)
  651.                             box_apeak_xy(j,an[j]-1,j,7-j,an[j]-1,7-j,0,0);
  652.                    }
  653.                    for (j=1;j<4;j++)
  654.                    {
  655.                             if (an[j]<3)
  656.                             an[j]++;
  657.                    }
  658.                    delay(a);
  659.          }
  660.          //4
  661.          i=3;
  662.          for (j=0;j<4;j++)
  663.          an[j]=j+1;
  664.          while(i--)
  665.          {
  666.                    for (j=1;j<4;j++)
  667.                    {
  668.                             if (an[j]>3)
  669.                             box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  670.                             if (an[j]>3)
  671.                             box_apeak_xy(j,an[j]-1,j,7-j,an[j]-1,7-j,0,0);
  672.                    }
  673.                    for (j=0;j<4;j++)
  674.                             an[j]++;
  675.                    delay(a);
  676.          }
  677.          //5
  678.          i=3;
  679.          for (j=3;j<6;j++)
  680.                    an[j-2]=j;
  681.          while(i--)
  682.          {
  683.                    for (j=1;j<4;j++)
  684.                    {
  685.                             box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  686.                             box_apeak_xy(j,an[j]+1,j,7-j,an[j]+1,7-j,0,0);
  687.                    }
  688.                    for (j=0;j<4;j++)
  689.                    {
  690.                             if (an[j]>3)
  691.                             an[j]--;
  692.                    }
  693.                    delay(a);
  694.          }
  695.          //6
  696.          i=3;
  697.          for (j=0;j<4;j++)
  698.          an[j]=5-j;
  699.          while(i--)
  700.          {
  701.                    for (j=1;j<4;j++)
  702.                    {
  703.                             if (an[j]<4)
  704.                             box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  705.                             if (an[j]<3)
  706.                             box_apeak_xy(j,an[j]+1,j,7-j,an[j]+1,7-j,0,0);
  707.                    }
  708.                    for (j=0;j<4;j++)
  709.                    {
  710.                             if (an[j]>0)
  711.                             an[j]--;
  712.                    }
  713.                    delay(a);
  714.          }
  715.          //7
  716.          i=3;
  717.          for (j=0;j<4;j++)
  718.          an[j]=3-j;
  719.          an[0]=2;
  720.          while(i--)
  721.          {
  722.                    for (j=0;j<3;j++)
  723.                    {
  724.                             if (an[j]>=0)
  725.                                      box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  726.                             if (an[j]>=0)
  727.                                      box_apeak_xy(j,an[j]+1,j,7-j,an[j]+1,7-j,0,0);
  728.                    }
  729.                    for (j=0;j<4;j++)
  730.                    {
  731.                             if (j<5-i)
  732.                             an[j]--;
  733.                    }
  734.                    delay(a);
  735.          }
  736.          //8
  737.          i=10;
  738.          for (j=0;j<4;j++)
  739.                    an[j]=j-2;
  740.          while(i--)
  741.          {
  742.                    for (j=0;j<4;j++)
  743.                    {
  744.                             if (an[j]>=0)
  745.                             box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  746.                             if (an[j]>=0)
  747.                             box_apeak_xy(j,an[j]-1,j,7-j,an[j]-1,7-j,0,0);
  748.                    }
  749.                    for (j=0;j<4;j++)
  750.                    {
  751.                             if (an[j]<7)
  752.                             an[j]++;
  753.                    }
  754.                    delay(a);
  755.          }
  756. }
  757. void flash_6()
  758. {
  759.       uchar i,j,k,z;
  760.       roll_apeak_yz(1,10000);
  761.       roll_apeak_yz(2,10000);
  762.       roll_apeak_yz(3,10000);
  763.       roll_apeak_yz(0,10000);
  764.       roll_apeak_yz(1,10000);
  765.       roll_apeak_yz(2,10000);
  766.       roll_apeak_yz(3,10000);
  767.       for (i=0;i<3;i++)
  768.                {
  769.                          for (j=0;j<8;j++)
  770.                          {
  771.                                   for (k=0;k<8;k++)
  772.                                   {
  773.                                            if ((table_3p[i][j]>>k)&1)
  774.                                            {
  775.                                                      for (z=1;z<8;z++)
  776.                                                               {
  777.        point (j,7-k,z,1);
  778.        if (z-1)
  779.        point (j,7-k,z-1,0);
  780.        delay(5000);
  781.                                                               }
  782.                                            }
  783.                                   }
  784.                          }
  785.                          trans(7,15000);
  786.                }
  787. }
  788. void flash_7()
  789. {
  790.       uchar i;
  791.       uint a=3000;
  792.       roll_apeak_yz(0,10000);
  793.       roll_apeak_yz(1,10000);
  794.       roll_apeak_yz(2,10000);
  795.       roll_apeak_yz(3,10000);
  796.       roll_apeak_yz(0,10000);
  797.       roll_apeak_yz(1,10000);
  798.       roll_apeak_yz(2,10000);
  799.       roll_apeak_yz(3,10000);
  800.       roll_apeak_yz(0,10000);
  801.       roll_apeak_yz(1,10000);
  802.       roll_apeak_yz(2,10000);
  803.       roll_apeak_xy(0,10000);
  804.       roll_apeak_xy(1,10000);
  805.       roll_apeak_xy(2,10000);
  806.       roll_apeak_xy(3,10000);
  807.       roll_apeak_xy(0,10000);
  808.       roll_apeak_xy(1,10000);
  809.       roll_apeak_xy(2,10000);
  810.       roll_apeak_xy(3,10000);
  811.       for (i=0;i<8;i++)
  812.       {
  813.                box_apeak_xy (0,i,0,7-i,i,7,1,1);
  814.                delay(a);
  815.       }
  816.       delay(30000);
  817.       roll_3_xy(0,a);
  818.       delay(30000);
  819.       roll_3_xy(1,a);
  820.       delay(30000);
  821.       roll_3_xy(2,a);
  822.       delay(30000);
  823.       roll_3_xy(3,a);
  824.       delay(30000);
  825.       roll_3_xy(0,a);
  826.       delay(30000);
  827.       roll_3_xy(1,a);
  828.       delay(30000);
  829.       roll_3_xy(2,a);
  830.       delay(30000);
  831.       roll_3_xy(3,a);
  832.       for (i=7;i>0;i--)
  833.       {
  834.                box_apeak_xy(i,0,0,i,7,7,1,0);
  835.                delay(a);
  836.       }
  837. }
  838. void flash_8()
  839. {
  840.       uchar i;
  841.       for (i=5;i<8;i++)
  842.       {
  843.                tranoutchar(i,10000);
  844.                delay(60000);
  845.                delay(60000);
  846.       }
  847. }
  848. void flash_9()
  849. {
  850.       char i;
  851.       uchar j,an[8],x,y,t,x1,y1;
  852.       for (i=0;i<8;i++)
  853.       {
  854.                box_apeak_xy (i,0,0,i,7,7,1,1);
  855.                if (i)
  856.                box_apeak_xy (i-1,0,0,i-1,7,7,1,0);
  857.                delay(10000);
  858.       }
  859.       roll_apeak_xy(3,10000);
  860.       roll_apeak_xy(0,10000);
  861.       roll_apeak_xy(1,10000);
  862.       for (i=0;i<7;i++)
  863.       {
  864.                line(6-i,6-i,0,6-i,6-i,7,1);
  865.                line(i,7,0,i,7,7,0);
  866.                delay(10000);
  867.       }
  868.       for (i=0;i<8;i++)
  869.                an[i]=14;
  870.       for (i=0;i<85;i++)
  871.       {
  872.                clear(0);
  873.                for (j=0;j<8;j++)
  874.                {
  875.                          t=an[j]%28;
  876.                          x=dat2[t]>>5;
  877.                          y=(dat2[t]>>2)&0x07;
  878.                          t=(an[j]-14)%28;
  879.                          x1=dat2[t]>>5;
  880.                          y1=(dat2[t]>>2)&0x07;
  881.                          line(x,y,j,x1,y1,j,1);
  882.                }
  883.                for (j=0;j<8;j++)
  884.                {
  885.                if ((i>j)&(j>i-71))
  886.                an[j]++;
  887.                }
  888.                delay(5000);
  889.       }
  890.       for (i=0;i<85;i++)
  891.       {
  892.                clear(0);
  893.                for (j=0;j<8;j++)
  894.                {
  895.                          t=an[j]%28;
  896.                          x=dat2[t]>>5;
  897.                          y=(dat2[t]>>2)&0x07;
  898.                          t=(an[j]-14)%28;
  899.                          x1=dat2[t]>>5;
  900.                          y1=(dat2[t]>>2)&0x07;
  901.                          line(x,y,j,x1,y1,j,1);
  902.                }
  903.                for (j=0;j<8;j++)
  904.                {
  905.                if ((i>j)&(j>i-71))
  906.                an[j]--;
  907.                }
  908.                delay(5000);
  909.       }
  910.       for (i=0;i<29;i++)
  911.       {
  912.                clear(0);
  913.                t=an[0]%28;
  914.                x=dat2[t]>>5;
  915.                y=(dat2[t]>>2)&0x07;
  916.                t=(an[0]-14)%28;
  917.                x1=dat2[t]>>5;
  918.                y1=(dat2[t]>>2)&0x07;
  919.                box_apeak_xy(x,y,0,x1,y1,7,0,1);
  920.                box_apeak_xy(x,y,1,x1,y1,6,0,1);
  921.                an[0]++;
  922.                delay(5000);
  923.       }
  924.       for (i=0;i<16;i++)
  925.       {
  926.                clear(0);
  927.                t=an[0]%28;
  928.                x=dat2[t]>>5;
  929.                y=(dat2[t]>>2)&0x07;
  930.                t=(an[0]-14)%28;
  931.                x1=dat2[t]>>5;
  932.                y1=(dat2[t]>>2)&0x07;
  933.                box_apeak_xy(x,y,0,x1,y1,7,1,1);
  934.                an[0]--;
  935.                delay(5000);
  936.       }
  937.       for (i=0;i<8;i++)
  938.       {
  939.                line(i,i,0,0,0,i,0);
  940.                delay(5000);
  941.       }
  942.       for (i=1;i<7;i++)
  943.       {
  944.                line(i,i,7,7,7,i,0);
  945.                delay(5000);
  946.       }
  947.       for (i=1;i<8;i++)
  948.       {
  949.                clear(0);
  950.                box(7,7,7,7-i,7-i,7-i,0,1);
  951.                delay(10000);
  952.       }
  953.       for (i=1;i<7;i++)
  954.       {
  955.                clear(0);
  956.                box(0,0,0,7-i,7-i,7-i,0,1);
  957.                delay(10000);
  958.       }
  959.       for (i=1;i<8;i++)
  960.       {
  961.                clear(0);
  962.                box(0,0,0,i,i,i,0,1);
  963.                delay(10000);
  964.       }
  965.       for (i=1;i<7;i++)
  966.       {
  967.                clear(0);
  968.                box(7,0,0,i,7-i,7-i,0,1);
  969.                delay(10000);
  970.       }
  971.       for (i=1;i<8;i++)
  972.       {
  973.                box(7,0,0,7-i,i,i,1,1);
  974.                delay(10000);
  975.       }
  976.       for (i=1;i<7;i++)
  977.       {
  978.                clear(0);
  979.                box(0,7,7,7-i,i,i,1,1);
  980.                delay(10000);
  981.       }
  982. }
  983. void flash_10()
  984. {
  985.       uchar i,j,an[4],x,y,t;
  986.       for (i=1;i<7;i++)
  987.       {
  988.
  989.                clear(0);
  990.                box(0,6,6,1,7,7,1,1);
  991.                box(i,6,6-i,i+1,7,7-i,1,1);
  992.                box(i,6,6,i+1,7,7,1,1);
  993.                box(0,6,6-i,1,7,7-i,1,1);
  994.                box(0,6-i,6,1,7-i,7,1,1);
  995.                box(i,6-i,6-i,i+1,7-i,7-i,1,1);
  996.                box(i,6-i,6,i+1,7-i,7,1,1);
  997.                box(0,6-i,6-i,1,7-i,7-i,1,1);
  998.                delay(30000);
  999.       }
  1000.       for (i=0;i<4;i++)
  1001.       {
  1002.                an[i]=6*i;
  1003.       }
  1004.       for (i=0;i<35;i++)
  1005.       {
  1006.                clear(0);
  1007.                for(j=0;j<4;j++)
  1008.                {
  1009.                          t=an[j]%24;
  1010.                          x=dat3[t]>>4;
  1011.                          y=dat3[t]&0x0f;
  1012.                          box(x,y,0,x+1,y+1,1,1,1);
  1013.                          box(x,y,6,x+1,y+1,7,1,1);
  1014.                }
  1015.                for (j=0;j<4;j++)
  1016.                an[j]++;
  1017.                delay(10000);
  1018.       }
  1019.       for (i=0;i<35;i++)
  1020.       {
  1021.                clear(0);
  1022.                for(j=0;j<4;j++)
  1023.                {
  1024.                          t=an[j]%24;
  1025.                          x=dat3[t]>>4;
  1026.                          y=dat3[t]&0x0f;
  1027.                          box(x,y,0,x+1,y+1,1,1,1);
  1028.                          box(x,y,6,x+1,y+1,7,1,1);
  1029.                }
  1030.                for (j=0;j<4;j++)
  1031.                an[j]--;
  1032.                delay(10000);
  1033.       }
  1034.       for (i=0;i<35;i++)
  1035.       {
  1036.                clear(0);
  1037.                for(j=0;j<4;j++)
  1038.                {
  1039.                          t=an[j]%24;
  1040.                          x=dat3[t]>>4;
  1041.                          y=dat3[t]&0x0f;
  1042.                          box(x,0,y,x+1,1,y+1,1,1);
  1043.                          box(x,6,y,x+1,7,y+1,1,1);
  1044.                }
  1045.                for (j=0;j<4;j++)
  1046.                an[j]++;
  1047.                delay(10000);
  1048.       }
  1049.       for (i=0;i<36;i++)
  1050.       {
  1051.                clear(0);
  1052.                for(j=0;j<4;j++)
  1053.                {
  1054.                          t=an[j]%24;
  1055.                          x=dat3[t]>>4;
  1056.                          y=dat3[t]&0x0f;
  1057.                          box(x,0,y,x+1,1,y+1,1,1);
  1058.                          box(x,6,y,x+1,7,y+1,1,1);
  1059.                }
  1060.                for (j=0;j<4;j++)
  1061.                an[j]--;
  1062.                delay(10000);
  1063.       }
  1064.       for (i=6;i>0;i--)
  1065.       {
  1066.
  1067.                clear(0);
  1068.                box(0,6,6,1,7,7,1,1);
  1069.                box(i,6,6-i,i+1,7,7-i,1,1);
  1070.                box(i,6,6,i+1,7,7,1,1);
  1071.                box(0,6,6-i,1,7,7-i,1,1);
  1072.                box(0,6-i,6,1,7-i,7,1,1);
  1073.                box(i,6-i,6-i,i+1,7-i,7-i,1,1);
  1074.                box(i,6-i,6,i+1,7-i,7,1,1);
  1075.                box(0,6-i,6-i,1,7-i,7-i,1,1);
  1076.                delay(30000);
  1077.       }
  1078. }
  1079. void flash_11()
  1080. {
  1081.       uchar i,j,t,x,y;
  1082.       uchar code daa[13]={0,1,2,0x23,5,6,7,6,5,0x23,2,1,0};
  1083.       for (j=0;j<5;j++)
  1084.       {
  1085.                for (i=0;i<13;i++)
  1086.                {
  1087.                          if (daa[i]>>4)
  1088.                          {
  1089.                                   t=daa[i]&0x0f;
  1090.                                   line (0,0,t+1,0,7,t+1,1);
  1091.                          }
  1092.                          else
  1093.                                   t=daa[i];
  1094.                          line (0,0,t,0,7,t,1);
  1095.                          transss();
  1096.                          delay(10000);
  1097.                }
  1098.       }
  1099.       for (j=1;j<8;j++)
  1100.       {
  1101.                if (j>3)
  1102.                          t=4;
  1103.                else
  1104.                          t=j;
  1105.                for (i=0;i<24;i+=j)
  1106.                {
  1107.                          x=dat3[i]>>4;
  1108.                          y=dat3[i]&0x0f;
  1109.                          box_apeak_xy(0,x,y,0,x+1,y+1,1,1);
  1110.                          transss();
  1111.                          delay(10000);
  1112.                }
  1113.       }
  1114.       for (j=1;j<8;j++)
  1115.       {
  1116.                if (j>3)
  1117.                          t=4;
  1118.                else
  1119.                          t=j;
  1120.                for (i=0;i<24;i+=j)
  1121.                {
  1122.                          x=dat3[i]>>4;
  1123.                          y=dat3[i]&0x0f;
  1124.                          point (0,x,y,1);
  1125.                          transss();
  1126.                          delay(10000);
  1127.                }
  1128.       }
  1129. }
  1130. void main()
  1131. {
  1132.
  1133.          sinter();
  1134.                  while(1){
  1135.         // clear(0);
  1136.          /*play list*/
  1137.          //flash_1();
  1138.          clear(0);
  1139.          flash_2();
  1140.          flash_3();
  1141.          flash_4();
  1142.          flash_4();
  1143.          flash_5();
  1144.       flash_5();
  1145.       flash_6();
  1146.       flash_7();
  1147.       flash_8();
  1148.       flash_9();
  1149.       flash_10();
  1150.       clear (0);
  1151.       flash_11();
  1152.       flash_9();
  1153.       flash_5();
  1154.       flash_7();
  1155.       flash_5();
  1156.       flash_6();
  1157.       flash_8();
  1158.       flash_9();
  1159.       flash_10();
  1160.          }
  1161. }
  1162. //P0;   //573 in
  1163. //P1;  //uln2803
  1164. //P2;  //573 LE
  1165. void print() interrupt 1
  1166. {
  1167.          uchar i;
  1168.          static uchar layer=0;
  1169.          P1=0;
  1170.          for (i=0;i<8;i++)
  1171.          {
  1172.                    P2=1<<i;
  1173.                    delay(3);
  1174.                    P0=display[layer][i];
  1175.                    delay(3);
  1176.          }
  1177.          P1=1<<layer;
  1178.          if (layer<7)
  1179.                    layer++;
  1180.          else
  1181.                    layer=0;
  1182.          TH0=0xc0;
  1183.          TL0=0;
  1184. }
作者: 木的風(fēng)    時(shí)間: 2017-8-3 21:42
大神,你好,我的硬件按照你的做著了,程序可以直接復(fù)制你發(fā)出來的用嗎
作者: stolle    時(shí)間: 2019-5-26 04:36
完美一直在尋找它很長一段時(shí)間! 謝謝你的分享。
作者: 凌鴆    時(shí)間: 2019-5-31 10:55
感謝分享,51Hie有你更精彩。
作者: 你的臉紅了    時(shí)間: 2024-3-26 09:39
單片機(jī)可以換成stc89c52單片機(jī)嗎
主站蜘蛛池模板: 亚洲 欧美 激情 另类 校园 | 久久精品国产精品 | 成人超碰在线 | 久久九九国产 | 亚洲天堂中文字幕 | 亚洲欧美日韩在线 | 欧美第一页 | 一级毛片在线播放 | av影片在线观看 | 国产又粗又黄又爽又硬的视频 | 亚洲国产91 | 欧美日韩成人一区二区三区 | 亚洲第一免费视频 | 国产成人精品一区二区三区福利 | 深夜福利视频网站 | 青青草国产成人av片免费 | 国产激情视频在线 | 黄色影院在线观看 | 精品国产欧美一区二区三区成人 | 欧美顶级黄色大片免费 | 伊人av综合| 国产在线观看不卡 | 亚洲精品免费在线观看 | 人与拘一级a毛片 | 最新中文字幕在线观看 | av不卡在线播放 | 一级特黄毛片 | 国产欧美精品一区二区 | 欧美国产在线观看 | 欧美mv日韩mv国产 | 黄色日批视频 | 日韩成人在线免费观看 | 涩五月婷婷 | 日韩在线免费播放 | 中文字幕av一区二区三区 | 欧美亚洲国产日韩 | 日本不卡视频在线观看 | 欧美国产综合 | 国产日韩中文字幕 | 色综合88 | 毛片网站免费观看 |
