求教搖搖棒制作方法
英語
2016-11-9 21:09
求教搖搖棒制作方法
求教搖搖棒制作方法
admin
2016-11-13 15:11
單片機搖搖棒:
http://m.zg4o1577.cn/bbs/dpj-37987-1.html
macade
2016-11-13 18:31
百度一下,你就知道了。
macade
2016-11-13 18:32
是的,我只是來整點兒
ilweis2
2016-11-14 21:02
google;有 shake
倒立的螞蟻
2016-11-16 14:23
http://m.zg4o1577.cn/bbs/dpj-49180-1.html
倒立的螞蟻
2016-11-16 14:24
很全的
高頻驅(qū)動-春哥
2016-11-16 14:58
電子市場有套件,你可以去看看
destinyk
2016-11-16 19:08
百度 吧 找教程
2515361695
2017-2-23 18:14
#在這里快/**************************************************************************************** /*硬件制作:07電氣工程 張國榮 /*軟件調(diào)試:07電氣工程 付春平 /*描 述: 搖搖棒程序,通過滾珠開關(guān)檢測周期,搖動時間自適應(yīng),圖像始終保持在中間。開機后每搖晃10次切換下一組字模 /* 按了一下按鍵后變成了手動切換,直到回到第一組字的時候再自動切換 如有問可直接加我QQ:77554971 技術(shù)交流群:120069344 套件出售 詳細制作在里面了! 最后祝各位制作成功!學習進步! /*****************************************************************************************/ #include <STC11F60XE.h> /*********外部接口定義**********/ #define uchar unsigned char #define uint unsigned int //宏定義 #define out P1 //數(shù)據(jù)輸出端口 sbit led1=P3^0; //第1組LED sbit led2=P3^1; //第2組LED sbit led3=P3^3; //第3組LED sbit led4=P3^4; //第4組LED sbit key1=P3^5; //按鍵輸入 sbit p3_2=P3^2; uchar KY,num; //KY作用在后面說明 uchar BUFF; //緩存 /*********全局變量定義**********/ unsigned long int TimeCount=0; unsigned int DelayN=80, //延時臨時計數(shù) DelayTime=80; //每次延時的周期個數(shù) unsigned char key,keyy; /**********************************************/ void delay(unsigned char n); void DelayMs(void); /*******************************************/ unsigned char code text0[]={ 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",0*/ 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x07,0x00,0xB7,0xBB,0xB7,0xBB,0xB3,0xBB,0xB4,0xBB,0xB5,0xBB,0xB7,0xBB,0xB7,0xBB,0xB7,0xBB,0x07,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*"自",1*/ 0xBF,0xBF,0xBE,0xDF,0x39,0xE0,0xFF,0xDF,0xEF,0xBF,0xEF,0xBF,0x6D,0xB0,0x6D,0xB7,0x6D,0xB7,0x01,0xB7,0x6E,0xB7,0x6E,0xB7,0x6E,0xB0,0xEF,0xBF,0xEF,0xBF,0xFF,0xFF,/*"適",2*/ 0xFF,0xBF,0xFF,0xC7,0x03,0xF8,0xBB,0xDF,0x7B,0xDF,0xFB,0xD0,0xEB,0xDB,0xDA,0xDF,0x39,0xDC,0x7B,0xCF,0xFB,0xD3,0xFB,0xDC,0x1B,0xDF,0xBB,0xDF,0xFF,0xDF,0xFF,0xFF,/*"應(yīng)",3*/ 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",4*/ 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",5*/ 0xEF,0xFB,0xEF,0xBB,0xEF,0x7D,0x00,0x80,0x6F,0xFF,0xAF,0xFD,0x75,0x05,0x8D,0xBD,0xB9,0xBD,0xA5,0xBD,0x3D,0x80,0x9E,0xBD,0xAE,0xBD,0xB6,0xBD,0xFF,0x05,0xFF,0xFF,/*"搖",6*/ 0xEF,0xFB,0xEF,0xBB,0xEF,0x7D,0x00,0x80,0x6F,0xFF,0xAF,0xFD,0x75,0x05,0x8D,0xBD,0xB9,0xBD,0xA5,0xBD,0x3D,0x80,0x9E,0xBD,0xAE,0xBD,0xB6,0xBD,0xFF,0x05,0xFF,0xFF,/*"搖",7*/ 0xEF,0xFC,0x2F,0xFF,0x00,0x00,0xAF,0xFF,0x6F,0xFD,0xBB,0xF5,0xAB,0xF6,0x2B,0xF5,0x8B,0xF5,0xA0,0x00,0x2B,0xF5,0xAB,0xF4,0xAB,0xF6,0xBB,0xF5,0xBF,0xFD,0xFF,0xFF,/*"棒",8*/ 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",9*/ }; unsigned char code text1[]={ 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",0*/ 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",1*/ 0xF7,0xFD,0xF7,0xFE,0x76,0xFF,0x31,0x00,0x57,0xFF,0xE7,0x7C,0xFF,0xBF,0x01,0xCF,0x7D,0xF0,0x7D,0xFF,0x7D,0xFF,0x7D,0x80,0x01,0x7F,0xFF,0x7F,0xFF,0x0F,0xFF,0xFF,/*"祝",2*/ 0x7F,0xFF,0xBF,0xFF,0x0F,0x80,0xD3,0xFF,0xBC,0xEF,0xDF,0xF3,0x67,0xFC,0xF0,0xDE,0xF5,0xBF,0x17,0xC0,0xF7,0xFF,0x77,0xFF,0xD7,0xFC,0xE3,0xE3,0xF7,0xF7,0xFF,0xFF,/*"你",3*/ 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",4*/ 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",5*/ 0xFF,0xFF,0xBF,0x7F,0xBD,0xBF,0xBD,0xDF,0xBD,0xEF,0xBD,0xF7,0xBD,0xF9,0x01,0xFE,0xBD,0xFD,0xBD,0xFB,0xBD,0xF7,0xBD,0xEF,0xBD,0xCF,0xBD,0x9F,0xBF,0xDF,0xFF,0xFF,/*"天",6*/ 0xFF,0xFF,0xBF,0x7F,0xBD,0xBF,0xBD,0xDF,0xBD,0xEF,0xBD,0xF7,0xBD,0xF9,0x01,0xFE,0xBD,0xFD,0xBD,0xFB,0xBD,0xF7,0xBD,0xEF,0xBD,0xCF,0xBD,0x9F,0xBF,0xDF,0xFF,0xFF,/*"天",7*/ 0xBF,0xFF,0xBD,0xBF,0xBD,0xDF,0xBD,0xEF,0xBD,0xF3,0x01,0xFC,0xBD,0xFF,0xBD,0xFF,0xBD,0xFF,0xBD,0xFF,0x01,0x80,0xBD,0xFF,0xBD,0xFF,0xBD,0xFF,0xBD,0xFF,0xFF,0xFF,/*"開",8*/ 0xFF,0xFB,0x7F,0xFC,0xFF,0xFF,0xFF,0xFF,0x0F,0xC0,0xFF,0xBF,0xFE,0xBF,0xFD,0xBF,0xE3,0xBF,0xF7,0xBF,0xFF,0xBF,0xBF,0x87,0x7F,0xFF,0xFF,0xF8,0xFF,0xFD,0xFF,0xFF,/*"心",9*/ }; unsigned char code text2[]={ 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF9,0xFF,0xFF,0x9F,0xF9,0xFF,0xFF,0x9F,0xF9,0xFF,0xFF,0x9F,0x01,0x00,0x00,0x80,0x01,0x00,0x00,0x80,0xF9,0xFF,0xFF,0x9F, 0xF9,0xFF,0xFF,0x9F,0xF9,0xFF,0xFF,0x9F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x87,0xFF,0xFF,0xFF,0x01,0xFE,0xFF, 0x7F,0x00,0xF8,0xFF,0x3F,0x00,0xF0,0xFF,0x1F,0x00,0xE0,0xFF,0x0F,0x00,0xC0,0xFF,0x07,0x00,0x80,0xFF,0x03,0x00,0x00,0xFF,0x03,0x00,0x00,0xFF,0x03,0x00,0x00,0xFE, 0x03,0x00,0x00,0xFC,0x03,0x00,0x00,0xF8,0x07,0x00,0x00,0xF0,0x0F,0x00,0x00,0xE0,0x1F,0x00,0x00,0xE0,0x3F,0x00,0x00,0xC0,0x3F,0x00,0x00,0x80,0x1F,0x00,0x00,0xC0, 0x0F,0x00,0x00,0xE0,0x07,0x00,0x00,0xF0,0x03,0x00,0x00,0xF8,0x03,0x00,0x00,0xFC,0x03,0x00,0x00,0xFE,0x03,0x00,0x00,0xFF,0x07,0x00,0x80,0xFF,0x0F,0x00,0xC0,0xFF, 0x1F,0x00,0xE0,0xFF,0x3F,0x00,0xE0,0xFF,0xFF,0x00,0xF8,0xFF,0xFF,0x01,0xFC,0xFF,0xFF,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x07,0x00,0x00,0xE0,0x07,0x00,0x00,0xC0,0x07,0x00,0x00,0xC0,0xFF,0xFF,0xFF,0xC7,0xFF,0xFF,0xFF,0xCF,0xFF,0xFF,0xFF,0xCF,0xFF,0xFF,0xFF,0xCF,0xFF,0xFF,0xFF,0xCF, 0xFF,0xFF,0xFF,0xCF,0xFF,0xFF,0xFF,0xCF,0xFF,0xFF,0xFF,0xCF,0xFF,0xFF,0xFF,0xC7,0x07,0x00,0x00,0xC0,0x07,0x00,0x00,0xC0,0x07,0x00,0x00,0xE0,0xFF,0xFF,0xFF,0xFF,/*"未命名文件",0*/ }; /***********n(us)延時子程序***************/ void DelayUs(uint N) { uint x; for(x=0; x<=N;x++); } /******************************************/ void main() { AUXR=0x80; CLK_DIV=1; EX0=1; //開放外部中斷0 IT0=1; //中斷0為邊沿觸發(fā)方式 IP=0x02; //設(shè)置中斷優(yōu)先級 TMOD=0x02; //定時器0方式2,8位重裝載 TH0=0x80; //設(shè)定定時器初值 TL0=0x80; KY=0; EA=1; //開放中斷 ET0=1; //開放定時器0中斷 TR0=1; //啟動定時器0,開始計時*/ key=0; //初始化顯示第一組文字 keyy=0; P1M0=0x55; //0101 0101 /P1.0 P1 .2 P1.4 P1.6推挽輸出 P1M1=0xAA; while(1){//等待中斷 if(key1==0){ //有鍵按下 DelayUs(50); if(key1==0){ key++; //更換下一幅圖片 if(key>2) key=0; //圖片循環(huán)顯示 根據(jù)顯示的組數(shù)來定義 這里有9組 所以就要keyy>9 while(key1==0); //等待按鍵釋放 } } if(num>10) //每中斷10次切換 { keyy++; num=0; } if(keyy>2)keyy=0; //圖片循環(huán)顯示 根據(jù)顯示的組數(shù)來定義 這里有9組 所以就要keyy>9 } } /*********文字顯示子程序**********/ void display_word(unsigned char code *text) { unsigned char i,j=2; //j為圖片起始位置 3 為第3個開始是圖片 如果要顯示高時32的大字 也屬于圖片格式 DelayUs(6400); for(i=0;i<64;i++) { P3M0=0x00; //0000 0000 //P3.0推挽輸出 P3 .1 P3.3 P3.4輸入高阻 P3M1=0x1B; if((key>=j)||(keyy>=j)) BUFF=(*(text+i*4+3)); else BUFF=(*(text+128+i*2+1)); led4=0; P1=~BUFF>>1; P3M0=0x10; //0001 0000 //P3.4推挽輸出 P3 .0 P3.3 P3.1輸入高阻 P3M1=0x0B; //0000 1011 delay(1); P3M0=0x00; //0000 0000 //P3.0推挽輸出 P3 .1 P3.3 P3.4輸入高阻 P3M1=0x1B; //0001 1011 led4=1; P1=BUFF; //01010101 1357 P3M0=0x10; //0001 0000 //P3.4推挽輸出 P3 .0 P3.3 P3.1輸入高阻 P3M1=0x0B; //0000 1011 delay(1); P3M0=0x00; //0000 0000 //P3.0推挽輸出 P3 .1 P3.3 P3.4輸入高阻 P3M1=0x1B; //0001 1011 if((key>=j)||(keyy>=j)) BUFF=(*(text+i*4+2)); else BUFF=(*(text+128+i*2)); led3=0; P1=~BUFF>>1; P3M0=0x08; //0000 1000 //P3.3推挽輸出 P3 .0 P3.1 P3.4輸入高阻 P3M1=0x13; //0001 0011 delay(1); P3M0=0x00; //0000 0000 //P3.0推挽輸出 P3 .1 P3.3 P3.4輸入高阻 P3M1=0x1B; //0001 1011 led3=1; P1=BUFF; //01010101 1357 P3M0=0x08; //0000 1000 //P3.3推挽輸出 P3 .0 P3.1 P3.4輸入高阻 P3M1=0x13; //0001 0011 delay(1); P3M0=0x00; //0000 0000 //P3.0推挽輸出 P3 .1 P3.3 P3.4輸入高阻 P3M1=0x1B; if((key>=j)||(keyy>=j)) BUFF=(*(text+i*4+1)); else BUFF=(*(text+i*2+1)); led2=0; P1=~BUFF>>1; P3M0=0x02; //0000 0010 //P3.1推挽輸出 P3 .0 P3.3 P3.4輸入高阻 P3M1=0x19; //0001 1001 delay(1); P3M0=0x00; //0000 0000 //P3.0推挽輸出 P3 .1 P3.3 P3.4輸入高阻 P3M1=0x1B; //0001 1011 led2=1; P1=BUFF; //01010101 1357 P3M0=0x02; //0000 0010 //P3.1推挽輸出 P3 .0 P3.3 P3.4輸入高阻 P3M1=0x19; //0001 1001 delay(1); P3M0=0x00; //0000 0000 //P3.0推挽輸出 P3 .1 P3.3 P3.4輸入高阻 P3M1=0x1B; //0001 if((key>=j)||(keyy>=j)) BUFF=(*(text+i*4)); else BUFF=(*(text+i*2)); led1=0; P1=~BUFF>>1; P3M0=0x01; //0000 0001 //P3.0推挽輸出 P3 .1 P3.3 P3.4輸入高阻 P3M1=0x1A; //0001 1010 delay(1); P3M0=0x00; //0000 0000 //P3.0推挽輸出 P3 .1 P3.3 P3.4輸入高阻 P3M1=0x1B; //0001 1011 led1=1; P1=BUFF; //01010101 1357 P3M0=0x01; //0000 0001 //P3.0推挽輸出 P3 .1 P3.3 P3.4輸入高阻 P3M1=0x1A; //0001 1010 delay(1); } } /*********顯示內(nèi)容選擇子程序**********/ void display(unsigned char t) { keyy=0; switch (t){ //通過按鍵選擇顯示內(nèi)容 case 0: {display_word(text0);}break; case 1: {display_word(text1);}break; case 2: {display_word(text2);}break; // case 3: {display_word(text3);}break; // case 4: {display_word(text4);}break; // case 5: {display_word(text5);}break; // case 6: {display_word(text6);}break; // case 7: {display_word(text7);}break; // case 8: {display_word(text8);}break; // case 9: {display_word(text9);}break; // case 10:{display_word(text10);}break; //default:{display_word(text1);} }} /*****************************************/ void display1(unsigned char y) { switch (y){ //通過按鍵選擇顯示內(nèi)容 case 0: {display_word(text0);}break; case 1: {display_word(text1);}break; case 2: {display_word(text2);}break; // case 3: {display_word(text3);}break; // case 4: {display_word(text4);}break; // case 5: {display_word(text5);}break; // case 6: {display_word(text6);}break; // case 7: {display_word(text7);}break; // case 8: {display_word(text8);}break; // case 9: {display_word(text9);}break; // case 10:{display_word(text10);}break; } } /***************************************/ /*********延時子程序**********/ void delay(unsigned char n) { for(;n>0;n--){ DelayN=DelayTime; while (DelayN); } } /*********中斷子程序**********/ void int0() interrupt 0 //使用外部中斷0 { KY=~KY; if(KY==0) { DelayTime=TimeCount/1580; TimeCount=0; //延時周期計數(shù)清零 if(key==0) { num++; display1(keyy); //根據(jù)按鍵選擇循環(huán)顯示文字 } else { display(key); //根據(jù)按鍵選擇循環(huán)顯示文字 } } } void timer0() interrupt 1 //定時器0中斷子程序 { TimeCount++; if (DelayN!=0) DelayN--; } 復制代碼速回復#
手机成人在线视频
日韩毛片网
精品无人国产偷自产在线
在线免费观看av片
三级黄色网址
国产精品一级二级
一区二区三区免费在线观看
不卡视频在线观看
www.国产91
日韩黄色在线视频
四虎黄色片
欧美激情视频网站
九九视频在线免费观看
爱福利视频
午夜影院福利
三级在线看
欧美久久久久久久久久
亚洲午夜av
黄色免费观看网站
四虎在线观看视频
免费在线小视频
午夜一区
黄色一区二区三区
亚洲黄色网址
91久久国产综合久久91
亚洲激情一区二区
91av免费
亚洲视频三区
人人干人人澡
国产高清视频
黄色大片免费观看
久久免费高清视频
免费在线a
中文字幕黄色片
免费毛片在线播放免费
欧美大片18
精品综合网
欧美精品在线免费观看
少妇激情视频
国内福利视频
国产精品国产三级国产
