STM32自平衡小車源代碼
liukong
2017-3-16 23:19
STM32自平衡小車源代碼
平衡小車代碼
(49.98 KB, 下載次數: 80)
2017-3-16 23:44 上傳
全部源碼下載:
STM32自平衡小車源代碼.7z
(231.18 KB, 下載次數: 100)
2022-12-16 04:25 上傳
部分代碼預覽:
#include "stm32f10x.h"
#include "MPU6050.h"
#include "motor.h"
#include "control.h"
#include <math.h>
//******角度參數************
float Gyro_y; //Y軸陀螺儀數據暫存
float Angle_gy; //由角速度計算的傾斜角度
float Accel_x; //X軸加速度值暫存
float Angle_ax; //由加速度計算的傾斜角度
float Angle; //小車最終傾斜角度
//******PWM參數*************
int speed_mr; //右電機轉速
int speed_ml; //左電機轉速
float PWM; //綜合PWM計算
//******電機參數*************
float speed_r_l; //電機轉速
float speed; //電機轉速濾波
//******卡爾曼參數************
const float Q_angle=0.001;
const float Q_gyro=0.003;
const float R_angle=0.5;
const float dt=0.01; //dt為kalman濾波器采樣時間;
const char C_0 = 1;
float Q_bias, Angle_err;
float PCt_0, PCt_1, E;
float K_0, K_1, t_0, t_1;
float Pdot[4] ={0,0,0,0};
float PP[2][2] = { { 1, 0 },{ 0, 1 } };
static const float Kp = 35.0; //PID參數
static const float Kd = 2.5; //PID參數
static const float Ksp = 10.0; //PID參數
void TIM4_Configuration(void)
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;//定義一個定時器結構體變量
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);//使能定時器4
TIM_TimeBaseStructure.TIM_Period = (10000 - 1); //計數10000次,因為從0開始,所以減1
TIM_TimeBaseStructure.TIM_Prescaler = (72 - 1); //時鐘72分頻,因為0不分頻,所以減1
TIM_TimeBaseStructure.TIM_ClockDivision = 0; // 使用的采樣頻率之間的分頻比例
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //向上計數
TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure); //初始化定時器4
TIM_ClearITPendingBit(TIM4, TIM_IT_Update); //清除定時器4中斷標志位
TIM_ITConfig(TIM4, TIM_IT_Update, ENABLE); //打開定時器4中斷
TIM_Cmd(TIM4, ENABLE); //計數器使能,開始計數
void NVIC_Configuration(void)
NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0000);
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
/********************注冊定時器4中斷處理函數***********************/
NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
/******************注冊串口1中斷服務函數************************/
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;//配置串口中斷
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;//占先式優先級設置為0
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; //副優先級設置為0
NVIC_InitStructure.NVIC_IRQChannelCmd = DISABLE;//中斷禁止
NVIC_Init(&NVIC_InitStructure);//中斷初始化
void Control_Init(void)
TIM4_Configuration();
NVIC_Configuration();
/****************定時器4中斷服務函數***************************************/
void TIM4_IRQHandler(void)
if (TIM_GetITStatus(TIM4, TIM_IT_Update) != RESET)
Angle_Calculate();// 車體傾角計算
Speed_Calculate();//車速計算
PWM_Calculate();//電機PWM值計算
Motor_Control(PWM);//調節電機參數
/*****************卡爾曼濾波**************************************************/
void Kalman_Filter(float Accel,float Gyro)
Angle+=(Gyro - Q_bias) * dt; //先驗估計
Pdot[0]=Q_angle - PP[0][1] - PP[1][0]; // Pk-先驗估計誤差協方差的微分
Pdot[1]= -PP[1][1];
Pdot[2]= -PP[1][1];
Pdot[3]=Q_gyro;
PP[0][0] += Pdot[0] * dt; // Pk-先驗估計誤差協方差微分的積分
PP[0][1] += Pdot[1] * dt; // =先驗估計誤差協方差
PP[1][0] += Pdot[2] * dt;
PP[1][1] += Pdot[3] * dt;
Angle_err = Accel - Angle; //zk-先驗估計
PCt_0 = C_0 * PP[0][0];
PCt_1 = C_0 * PP[1][0];
E = R_angle + C_0 * PCt_0;
K_0 = PCt_0 / E;
K_1 = PCt_1 / E;
t_0 = PCt_0;
t_1 = C_0 * PP[0][1];
PP[0][0] -= K_0 * t_0; //后驗估計誤差協方差
PP[0][1] -= K_0 * t_1;
PP[1][0] -= K_1 * t_0;
PP[1][1] -= K_1 * t_1;
Angle += K_0 * Angle_err; //后驗估計
Q_bias += K_1 * Angle_err; //后驗估計
Gyro_y = Gyro - Q_bias; //輸出值(后驗估計)的微分=角速度
void Angle_Calculate(void)
static uint8_t DataBuffer[2]; //數據緩存
/****************************加速度****************************************/
I2C_ReadBuffer(DataBuffer, ACCEL_XOUT_H, 2);
Accel_x = (short)((DataBuffer[0]<<8)+DataBuffer[1]); //讀取X軸加速度
Angle_ax = (Accel_x +220) /16384; //去除零點偏移,計算得到角度(弧度)
Angle_ax = Angle_ax*1.2*180/3.14; //弧度轉換為度,
/****************************角速度****************************************/
I2C_ReadBuffer(DataBuffer, GYRO_YOUT_H, 2);
Gyro_y = (short)((DataBuffer[0]<<8)+DataBuffer[1]); //靜止時角速度Y軸輸出為-18左右
Gyro_y = (Gyro_y + 18)/16.4; //去除零點偏移,計算角速度值
//Angle_gy = Angle_gy + Gyro_y*0.01; //角速度積分得到傾斜角度,因為卡爾曼計算帶有時間dt,所以此處不用積分
/***************************卡爾曼融合*************************************/
Kalman_Filter(Angle_ax,Gyro_y); //卡爾曼濾波計算傾角
/****************************互補濾波****************************************/
/***補償原理是取當前傾角和加速度獲得傾角差值進行放大,然后與
****陀螺儀角速度疊加后再積分,從而使傾角最跟蹤為加速度獲得的
****角度 0.5為放大倍數,可調節補償度;0.01為系統周期10ms
// Angle = Angle + (((Angle_ax-Angle)*0.5 + Gyro_y)*0.01); //因為加或不加此語句處理效果一樣,故省略,原因搞不清楚。。。
void Speed_Calculate(void)
speed_mr=TIM_GetCounter(TIM2)-0x7fff;
speed_ml=TIM_GetCounter(TIM3)-0x7fff; //讀取編碼器寄存器計數值,并減去中間值,得到速度矢量
TIM_SetCounter(TIM2, 0x7fff);
TIM_SetCounter(TIM3, 0x7fff); //重置編碼器計數值
speed_r_l =(speed_mr + speed_ml)*0.5;
speed *= 0.7; //車輪速度濾波
speed += speed_r_l*0.3;
void PWM_Calculate(void)
if(Angle<-40||Angle>40) //傾角過大就關閉電機,進入死循環,直到復位
Motor_Stop();
while(1);
PWM = (short)(Kp*Angle + Kd*Gyro_y); //PID:角速度和角度調節
PWM += Ksp*speed; //PID:車速度調節
cm7626
2017-4-24 08:35
平衡車的代碼夠復雜的 初學者就不用考慮了
ddxx
2017-12-7 12:17
沒錢下載啊。
lemon0210
2017-12-7 14:51
只有代碼嗎
wj1994
2017-12-11 13:35
有人可以說一下有原理圖嗎?
張碭碭
2018-5-17 16:41
濾波原理
日韩精品小视频
日韩免费在线观看视频
亚欧在线观看
日本黄a三级三级三级
欧美日韩在线精品
免费视频久久久
欧美精品二区三区四区免费看视频
国产伦精品一区二区三毛
国模精品视频一区二区
av高清在线
精品视频在线免费观看
欧美一级久久
青青草视频网站
午夜免费观看视频
九九热在线观看
亚洲一区二区在线视频
国产精品伦子伦免费视频
天天操天天碰
黑人精品xxx一区一二区
国产免费高清视频
欧美一级在线观看
久久精品欧美一区二区
97精品国产97久久久久久免费
成人欧美激情
国产精品婷婷
黄色一级大片在线免费看国产一
免费久久久
草草视频在线
av免费网站
中文字幕在线观看网址
91女人18毛片水多国产
成av人片一区二区三区久久
午夜看片
久久久久女人精品毛片九一
久久久久人
欧美日韩一区二区三区视频
久久激情视频
一本色道久久综合亚洲精品小说
欧美日韩在线免费
欧美一级做性受免费大片免费
一区二区不卡
