標題: 火災報警系統_單片機proteus仿真及源碼 [打印本頁]
作者: zxasko3    時間: 2017-5-4 16:26
基于51單片機的火災報警系統, 用adc0809來采集模擬數據。包含源程序,下面是proteus仿真原理圖
單片機源程序:
  1. #include<REG51.H>
  2. #define uint unsigned int
  4. uchar code a[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};        //段碼組合,共陰極
  5. uchar code b[6]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf}; //位碼組合         低有效
  6. uchar code c[9]={201,202,203,204,205,206,207,208,0};
  7. uchar y[8]={0,0,0,0,0,0,0,0};
  8. //*************************************************************************************
  9. sbit ST=P3^1;
  10. sbit OE=P3^0;
  11. sbit Add=P3^4;
  12. sbit Bdd=P3^5;
  13. sbit Cdd=P3^6;
  14. uint t=0,h=0x9f;
  15. uchar p[8];
  16. uchar k,m,n,q,g,r,d,i,cnt=0,v=0;
  17. void delay(uchar s);
  18. void inrupt(void)
  19. {
  20.         TMOD=0x01;
  21.         TH0=0x3c;
  22.         TL0=0xb0;
  23.
  24.         EX0=1;
  25.         IT0=1;
  26.          EX1=1;
  27.         IT1=1;
  28.         EA=1;
  29. }
  30. void lxy(void)
  31. {
  32.         switch(d)
  33.                                 {
  34.                                         case 0:Add=0,Bdd=0,Cdd=0;ST=0,ST=1,ST=0;break;
  35.                                     case 1:Add=1,Bdd=0,Cdd=0;ST=0,ST=1,ST=0;break;
  36.                                         case 2:Add=0,Bdd=1,Cdd=0;ST=0,ST=1,ST=0;break;
  37.                                         case 3:Add=1,Bdd=1,Cdd=0;ST=0,ST=1,ST=0;break;
  38.                                         case 4:Add=0,Bdd=0,Cdd=1;ST=0,ST=1,ST=0;break;
  39.                                         case 5:Add=1,Bdd=0,Cdd=1;ST=0,ST=1,ST=0;break;
  40.                                         case 6:Add=0,Bdd=1,Cdd=1;ST=0,ST=1,ST=0;break;
  41.                                         case 7:Add=1,Bdd=1,Cdd=1;ST=0,ST=1,ST=0;break;
  42.
  43.                                 }
  44. }
  45.
  46.
  47.
  48. void time0(void) interrupt 2
  49. {
  50.         OE=1;
  51.         t=P1;
  52.         OE=0;
  53.         if(t>=h)
  54.           {
  55.                                           y[d]=t;
  56.                                         p[i]=d;
  57.                                         i++;
  58.
  59.
  60.       }
  61.          d++;
  62.          lxy();
  63.          r--;
  64.
  65. }
  66. void time1(void) interrupt 1
  67. {
  68.         TH0=0x3c;
  69.         TL0=0xb0;
  70.         cnt++;
  71.         if(cnt>=20)
  72.         {
  73.          v--;
  74.          cnt=0;
  75.          if(v==0)
  76.            {
  77.                      g=1;
  78.                   ET0=0;
  79.               TR0=0;
  80.            }
  81.           else g=0;
  82.         }
  83.
  84. }
  85. void time2(void) interrupt 0
  86. {
  87.         g=1;
  88.         i++;
  89.         if(p[i]==8)
  90.           {        i=0;
  91.             g=1;
  92.           }
  93.         delay(20);
  94. }
  95. void delay(uchar s) //延時0.1*n毫秒 0
  96. {
  97.   uchar j;
  98.   do
  99.    {
  100.      for(j=0;j<23;j++)
  101.      ;;;
  102.    } while(s--);
  103. }
  104. void display(void)
  105.         {                for(;;)
  106.                           {
  107.                            P2=b[0],P0=a[k];
  108.                                 delay(20);
  109.                                 P2=b[1],P0=a[m];
  110.                                 delay(20);
  111.
  112.                                 P2=b[2],P0=a[n];
  113.                                 delay(20);
  114.                                 P2=b[3],P0=a[q];
  115.                                 delay(20);
  116.                                 P2=b[4],P0=a[v/10];
  117.                                 delay(20);
  118.                                 P2=b[5],P0=a[v%10];
  119.                                 delay(20);
  120.                                 if(g==1)
  121.                                   {
  122.
  123.                                         break;
  124.                                   }
  125.                           }
  126.         }
  127. void main(void)
  128. {
  129.         inrupt();
  130.                         for(;;)
  131.                           {
  132.                             P2=0x3e,P0=a[0];
  133.                                 delay(20);
  134.                                 P2=0x3d,P0=a[0];
  135.                                 delay(20);
  136.
  137.                                 P2=0x3b,P0=a[0];
  138.                                 delay(20);
  139.                                 P2=0x37,P0=a[0];
  140.
  141.                                 for(i=0;i<8;i++)
  142.                                   {
  143.                                           p[i]=8;
  144.                                   }
  145.                                 i=0;
  146.                                 t=0;
  147.                                 d=0;
  148.                                 r=8;
  149.                     Add=0,Bdd=0,Cdd=0;
  150.
  151.                                 ST=0;
  152.                                 ST=1;
  153.                                 ST=0;
  154.                                 while(r);
  155.                                 i=0;
  156.                                 if(y[p[i]]>=h)
  157.                                 {
  158.
  159.                                         v=20;
  160.                                         ET0=1;
  161.                         TR0=1;
  162.                                  while(v)
  163.                                     {switch(p[i])
  164.                                    {
  165.                                         case 0:        k=c[p[i]]/1000;m=(c[p[i]]%1000)/100;n=(c[p[i]]%100)/10;q=c[p[i]]%10;display();break;
  166.                                     case 1: k=c[p[i]]/1000;m=(c[p[i]]%1000)/100;n=(c[p[i]]%100)/10;q=c[p[i]]%10;display();break;
  167.                                         case 2:        k=c[p[i]]/1000;m=(c[p[i]]%1000)/100;n=(c[p[i]]%100)/10;q=c[p[i]]%10;display();break;
  168.                                     case 3:        k=c[p[i]]/1000;m=(c[p[i]]%1000)/100;n=(c[p[i]]%100)/10;q=c[p[i]]%10;display();break;
  169.                                         case 4:        k=c[p[i]]/1000;m=(c[p[i]]%1000)/100;n=(c[p[i]]%100)/10;q=c[p[i]]%10;display();break;
  170.                                         case 5:
  171. …………限于本文篇幅 余下代碼請從51黑下載附件…………
下載:
火警報警系統.rar (24.4 KB, 下載次數: 157)
作者: DZSJD    時間: 2017-6-24 21:54
下下來看看呢
作者: muaalie    時間: 2018-1-3 09:48
下載啦
作者: cs1271725508    時間: 2018-12-28 17:20
樓主有相關論文嗎
作者: 2500633567    時間: 2020-2-21 16:32
能不能說明一下那些部分實現什么功能呢?謝謝!
主站蜘蛛池模板: 亚洲欧美日韩一区二区 | 三级网站在线播放 | 亚洲欧美视频 | 波多野结衣一区二区三区 | 91亚洲视频 | 韩日在线视频 | 国产理论在线观看 | 一区二区在线视频 | 天天草天天射 | 高清一区二区 | 特级西西444www大精品视频 | 91在线小视频 | 成人特级毛片 | 91av在线看 | 国产永久视频 | 欧美一级视频 | 日韩精品视频免费播放 | 欧美性猛交xxxx黑人猛交 | 成 人 黄 色 片 在线播放 | 国产一区精品在线 | 国产资源在线观看 | 国产九九热 | 色妞网站| 亚洲一区二区在线视频 | 国 产 黄 色 大 片 | 成人av一区二区三区在线观看 | 激情丁香 | 久久视频在线免费观看 | 国产精品九九 | 一级在线观看 | 五月天精品 | 五月在线视频 | 成人午夜毛片 | www.黄色| 欧美久久网 | 久久91精品 | 久久久精彩视频 | 久久精品一区二区国产 | 久久久精品在线 | 国产农村妇女aaaaa视频 | 国产51自产区 |
