STM32規則組ADC轉換(DMA 多通道單次采集)源程序
百寶
2017-5-8 16:04
STM32規則組轉換 (DMA 多通道單次采集)
(52.42 KB, 下載次數: 96)
2017-5-8 22:41 上傳
stm32單片機源程序:
//通過串口實時打印KEY3 KEY4電壓值。
//每個通道采集一次
#include "pbdata.h"
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
void USART_Configuration(void);
void ADC1_Configuration(void);
void DMA_Configuration(void);
vu16 AD_Value[M]; //用來存放ADC轉換結果,也是DMA的目標地址
int fputc(int ch,FILE *f)
USART_SendData(USART1,(u8)ch);
while(USART_GetFlagStatus(USART1,USART_FLAG_TXE)==RESET);
return ch;
int main(void)
RCC_Configuration();
GPIO_Configuration();
USART_Configuration();
NVIC_Configuration();
ADC1_Configuration();
DMA_Configuration();
printf("AD_Value[0]=%f\r\n",AD_Value[0]*3.3/4095);
printf("AD_Value[1]=%f\r\n",AD_Value[1]*3.3/4095);
printf("AD_Value[2]=%f\r\n",AD_Value[2]*3.3/4095);
delay_ms(1000);
// printf("value[%d]=\t%d\r\n",i,value[i]);
SystemInit();//72m
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE); //GPIOA
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE); //USART
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE); //AFIO
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,ENABLE); //GPIOC
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE); //ADC
RCC_ADCCLKConfig(RCC_PCLK2_Div6); //12M 最大14M
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); //使能DMA傳輸
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_9;//TX
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
GPIO_Init(GPIOA,&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_10;//RX
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING;
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0|GPIO_Pin_2|GPIO_Pin_3;//ADin: POT K3 K4
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AIN; //模擬輸入
GPIO_Init(GPIOC,&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0|GPIO_Pin_1;//ADin: sensor1 sensor2 VOC
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel1_IRQn;//中斷向量
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; //1
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //0
USART_InitTypeDef USART_InitStructure;
USART_InitStructure.USART_BaudRate=9600;
USART_InitStructure.USART_WordLength=USART_WordLength_8b;
USART_InitStructure.USART_StopBits=USART_StopBits_1;
USART_InitStructure.USART_Parity=USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl=USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode=USART_Mode_Rx|USART_Mode_Tx;
USART_Init(USART1,&USART_InitStructure);
USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);
USART_Cmd(USART1,ENABLE);
USART_ClearFlag(USART1,USART_FLAG_TC);
ADC_InitTypeDef ADC_InitStructure;
ADC_DeInit(ADC1); //將外設 ADC1 的全部寄存器重設為缺省值
ADC_InitStructure.ADC_Mode=ADC_Mode_Independent; //ADC1 ADC2工作在獨立模式
ADC_InitStructure.ADC_ScanConvMode=ENABLE; //工作在單通道模式(還是掃描模式:多通道模式)
ADC_InitStructure.ADC_ContinuousConvMode=ENABLE; //模數轉換工作在單次模式(還是連續模式)
ADC_InitStructure.ADC_ExternalTrigConv=ADC_ExternalTrigConv_None;//轉換由軟件而不是外部觸發啟動
ADC_InitStructure.ADC_DataAlign=ADC_DataAlign_Right; //ADC數據右對齊
ADC_InitStructure.ADC_NbrOfChannel=M; //順序進行轉換的通道數
ADC_Init(ADC1, &ADC_InitStructure); //根據ADC_InitStruct中指定的參數初始化外設ADCx的寄存器
//設置指定ADC的規則組通道,設置它們的轉化順序和采樣時間
//ADC1,ADC通道x,規則采樣順序值為y,采樣時間為239.5周期
// ADC_RegularChannelConfig(ADC1,ADC_Channel_0, 1,ADC_SampleTime_239Cycles5);//選擇ADC1通道0 -PA0 SENSOR1
// ADC_RegularChannelConfig(ADC1,ADC_Channel_1, 2,ADC_SampleTime_239Cycles5);//選擇ADC1通道1 -PA1 SENSOR2
ADC_RegularChannelConfig(ADC1,ADC_Channel_10,3,ADC_SampleTime_239Cycles5);//選擇ADC1通道10-PC0 POT
ADC_RegularChannelConfig(ADC1,ADC_Channel_12,1,ADC_SampleTime_239Cycles5);//選擇ADC1通道12-PC2 KEY3
ADC_RegularChannelConfig(ADC1,ADC_Channel_13,2,ADC_SampleTime_239Cycles5);//選擇ADC1通道13-PC3 KEY4
ADC_DMACmd(ADC1, ENABLE); // 開啟ADC的DMA支持(要實現DMA功能,還需獨立配置DMA通道等參數)
ADC_Cmd(ADC1, ENABLE); //使能指定的ADC1
ADC_ResetCalibration(ADC1); //重置校準器
while(ADC_GetResetCalibrationStatus(ADC1));//獲取校準狀態
ADC_StartCalibration(ADC1);//開始指定ADC的校準狀態
while(ADC_GetCalibrationStatus(ADC1)); //獲取指定ADC的校準程序
// ADC_ITConfig(ADC1,ADC_IT_EOC,ENABLE); //中斷使能
ADC_SoftwareStartConvCmd(ADC1,ENABLE);//使能軟件啟動功能
DMA_InitTypeDef DMA_InitStructure;
DMA_DeInit(DMA1_Channel1); //將DMA的通道1寄存器重設為缺省值
DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)&ADC1->DR; //DMA外設ADC基地址
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&AD_Value; //DMA內存基地址
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //內存作為數據傳輸的目的地 外設作為數據傳輸的來源
DMA_InitStructure.DMA_BufferSize = M; //DMA通道的DMA緩存的大小
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //外設地址寄存器不變
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //內存地址寄存器遞增
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; //數據寬度為16位
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; //數據寬度為16位
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //工作在循環緩存模式,當傳輸完一次后,重新接著傳送,永不停息。
DMA_InitStructure.DMA_Priority = DMA_Priority_High; //DMA通道 x擁有高優先級
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; //DMA通道x沒有設置為內存到內存傳輸
DMA_Init(DMA1_Channel1, &DMA_InitStructure); //根據DMA_InitStruct中指定的參數初始化DMA的通道
DMA_Cmd(DMA1_Channel1, ENABLE); //啟動DMA通道
…………限于本文篇幅 余下代碼請從51黑下載附件…………
完整代碼下載:
3 規則組轉換 (DMA 多通道單次采集).7z
(189.76 KB, 下載次數: 87)
2021-9-29 03:23 上傳
亡命徒
2017-8-17 22:41
奇跡挑了好久沒跳出來,過來看看。
xsnina
2018-9-6 17:05
受益匪淺,但是如果遇見了,兩個通道都要采集ADC1和ADC2,同時通道數不一樣,比如ADC1有8通道,ADC2只有2個通道的情況,DMA又該如何配置呢
tdunam
2019-5-29 11:23
這里這樣設置,不是單次吧?
13574103468
2019-5-29 17:37
謝謝樓主,資料非常好用, 很不錯66666
精品一区二区三区免费
午夜在线观看视频
国产一区欧美
精品视频在线播放
欧美中文字幕在线观看
蜜臀久久99精品久久久久宅男
97色伦图片
8090理论片午夜理伦片
国产精品久久
精品在线看
日韩不卡免费视频
一级黄色网
五月天毛片
亚洲国产精品va在线看黑人
一级做a爱片性色毛片
免费a网站
日韩精品网站
色综合五月天
国产一区在线播放
黄色a一级片
丰满少妇高潮
久久都是精品
欧美91
日日干天天干
99在线视频观看
国 产 黄 色 大 片
国产一区二区福利
av福利网
日韩精品久久久久久
三级视频在线
中文字幕在线免费
a天堂在线视频
懂色av懂色av粉嫩av
9191av
www.欧美日韩
久久成人免费视频
精品蜜桃一区二区三区
久久久久国产一区二区三区
国 产 黄 色 大 片
91久久久精品
黄色激情视频网站
