標(biāo)題:
來(lái)大佬看下LCD顯示溫濕度程序 兩個(gè)程序怎么合并在一起
[打印本頁(yè)]
炫銘小弟弟
時(shí)間:
2017-6-4 18:15
標(biāo)題:
一個(gè)是LCD顯示溫濕度的程序如下
#include <reg51.h>
#include <intrins.h>
typedef unsigned char BYTE;
typedef unsigned int WORD;
#define uint unsigned int
#define uchar unsigned char
sbit io=P2^2;
sbit rw=P2^6;
sbit rs=P2^7;
sbit ep=P2^5;
typedef bit BOOL;
uchar data_byte;
uchar RH,RL,TH,TL;
void delay(uchar ms)
uchar i;
while(ms--)
for(i=0;i<100;i++);
void delay1()
uchar i;
for(i=0;i<1;i++);
BOOL lcd_bz()
BOOL result;
rs=0;
rw=1;
ep=1;
_nop_();
_nop_();
_nop_();
_nop_();
result = (BOOL)(P2&0x80);
ep=0;
return result ;
void write_cmd(uchar cmd)
while (lcd_bz());
rs=0;
rw=0;
ep=0;
_nop_();
_nop_();
P0=cmd ;
_nop_();
_nop_();
_nop_();
_nop_();
ep=1;
_nop_();
_nop_();
_nop_();
_nop_();
ep=0;
void write_addr(uchar addr)
write_cmd(addr|0x80);
void write_byte(uchar dat)
while (lcd_bz());
rs=1;
rw=0;
ep=0;
_nop_();
_nop_();
P0=dat ;
_nop_();
_nop_();
_nop_();
_nop_();
ep=1;
_nop_();
_nop_();
_nop_();
_nop_();
ep=0;
void lcd_init()
write_cmd(0x38);
delay(1);
write_cmd(0x0c);
delay(1);
write_cmd(0x06);
delay(1);
write_cmd(0x01);
delay(1);
void display(uchar addr,uchar q)
delay(10);
write_addr(addr);
write_byte(q);
delay(1);
void start()
io=1;
delay1();
io=0;
delay(25);
io=1;
delay1();
delay1();
delay1();
uchar receive_byte()
uchar i,temp;
for(i=0;i<8;i++)
while(!io);
delay1();
delay1();
delay1();
temp=0;
if(io==1)
temp=1;
while(io);
data_byte<<=1;
data_byte|=temp;
return data_byte;
void receive()
uchar T_H,T_L,R_H,R_L,check,num_check,i;
start();
io=1;
if(!io)
while(!io);
while(io);
R_H=receive_byte();
R_L=receive_byte();
T_H=receive_byte();
T_L=receive_byte();
check=receive_byte();
io=0;
for(i=0;i<7;i++)
delay1();
io=1;
num_check=R_H+R_L+T_H+T_L;
if(num_check==check)
RH=R_H;
RL=R_L;
TH=T_H;
TL=T_L;
check=num_check;
lcd_init();
receive();
display(0x00,'R');
display(0x01,':');
display(0x02,RH/10+0x30);
display(0x03,RH%10+0x30);
display(0X04,'%');
display(0x40,'T');
display(0x41,':');
display(0x42,TH/10+0x30);
display(0x43,TH%10+0x30);
display(0x44,0xdf);
display(0x45,0x43);
另一個(gè)是PWN調(diào)光的程序如下
/*單片機(jī)實(shí)現(xiàn)PWM調(diào)節(jié)LED燈的亮度*/
#include<reg52.h>
sbit P2_0=P2^0;
sbit P2_1=P2^1;
sbit key1=P1^0;
sbit key2=P1^1;
sbit key3=P1^2;
sbit key4=P1^3;
uchar zkb,i;// zkb指占空比
uchar zkb2,i;
void time0(void) interrupt 1 //中斷函數(shù)
TH0=(65536-10)/256;
TL0=(65536-10)%256;
++i;
if(i>10)
i=0;
if(i<=zkb)
P2_0=1;
else P2_0=0;
if(i<=zkb2)
P2_1=1;
else P2_1=0;
void delay(uchar z)
uchar x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void init() //初始化函數(shù)
TMOD=0X01;
TH0=(65536-10)/256;
TL0=(65536-10)%256;
EA=1;
ET0=1;
TR0=1;
void keyscan() //鍵盤掃描
P1=0XFF;
if(key1==0)
delay(5);
if(key1==0)
while(!key1);
if(zkb<9)
zkb++;
if(key2==0)
delay(5);
if(key2==0)
while(!key2);
if(zkb>0)
zkb--;
if(key3==0)
delay(5);
if(key3==0)
while(!key3);
if(zkb2<9)
zkb2++;
if(key4==0)
delay(5);
if(key4==0)
while(!key4);
if(zkb2>0)
zkb2--;
void main() //主函數(shù)
zkb=2;
zkb2=2;
init();
keyscan();
有沒(méi)有大俠幫忙看下怎么合并在一起 兩個(gè)程序單獨(dú)都可以下載到板子里實(shí)現(xiàn)功能 想同時(shí)實(shí)現(xiàn)功能自己不會(huì)合并 本人學(xué)生新手小白一個(gè) 程序是網(wǎng)上找的 有沒(méi)有大佬幫忙合并一下 想跟著學(xué)學(xué)
zl2168
時(shí)間:
2017-6-4 22:01
搞懂了2個(gè)程序,就能合并,搞不懂,就不能合并。
a121357984
時(shí)間:
2017-6-4 22:10
tinglengyue
時(shí)間:
2017-6-4 22:59
對(duì)的,相當(dāng)于移植
tinglengyue
時(shí)間:
2017-6-4 23:03
是的,相當(dāng)于移植
精品在线免费视频
日韩一级黄色片
国产香蕉视频在线观看
欧美成人极品
国产精品99久久久久久www
毛片一级片
国产乱码精品一区二区三区忘忧草
激情都市亚洲
99精品成人
国产一级片免费观看
在线观看免费毛片
久久久天堂国产精品女人
成年人免费看视频
成人精品免费视频
天天干天天做
一级片网址
久久国产精品一区二区三区
激情视频网址
亚洲看片
国产精品尤物
亚洲国产精品久久久久久久
国产欧美综合一区二区三区
国产精品偷乱一区二区三区
日韩中文字幕在线观看
日韩精品视频免费播放
国产肉体xxxx裸体784大胆
亚洲免费a
亚洲va视频
国产黄a三级三级三级看三级男男
免费视频久久久
黄频在线观看
黄色成人av
www久久
亚洲国产成人精品女人久久久
97人人爱
亚洲日本欧美
亚洲综合二区
色中色综合
黄色片亚洲
亚洲精品911
成人午夜影院
