μÆ.C(127): error C129: missing ';' before '{'應該怎么改
shunshun
2017-7-20 12:05
#include <reg51.h>
#include <intrins.h>
#define uint unsigned int
#define uchar unsigned char
sbit DS1302_CLK=P1^0;//實時時鐘時鐘線引腳
sbit DS1302_IO=P1^1; //實時時鐘數據線引腳
sbit DS1302_RST=P1^2;//實時時鐘復位線引腳
sbit ACC0=ACC^0;
sbit ACC7=ACC^7;
uchar hide_sec,hide_min,hide_hour,hide_day,hide_week,hide_month,hide_year;//秒,分,時到日,月,年位閃的計數
sbit Set=P3^4; //模式切換鍵,對應實驗板K5
sbit Up=P3^5; //加法按鈕,對應實驗板K6
sbit Down=P3^6; //減法按鈕,對應實驗板K7
sbit out=P3^7; //立刻跳出調整模式按鈕,對應實驗板K8
//sbit p35=P3^5;//定時時間轉換
sbit BEEP=P3^2;
sbit guang=P3^3;
uchar done,count,temp,up_flang,down_flang;
uchar h;
bit a,b; //閃爍標志位
uchar week_value[3];
void show_time(); //液晶顯示程序
//12864液晶顯示部分子程序
sbit rs =P2^0;
sbit rw =P2^1;
sbit e =P2^2;
#define lcddata P0
sbit busy=P0^7; //lcd busy bit
void wr_d_lcd (uchar content);
void wr_i_lcd (uchar content);
void clrram_lcd(void);
void init_lcd(void);
void busy_lcd(void);
void rev_row_lcd(uchar row);
void rev_co_lcd(uchar row,uchar col,uchar mode);
void clr_lcd(void);
void wr_co_lcd(uchar row,uchar col,uchar lcddata1,uchar lcddata2);
void wr_row_lcd(uchar row,char*p);
unsigned char idata i,tl0_temp=0,th0_temp=0;
//液晶初始化
void init_lcd(void)
wr_i_lcd(0x06); //光標的移動方向
wr_i_lcd(0x0c); //開顯示,關游標
//填充夜晶DDRAM全為空格
wr_i_lcd(0x30);
wr_i_lcd(0x01);
//對液晶寫數據
//content為要寫入的數據
void wr_d_lcd(uchar content)
busy_lcd();
rs=1;
rw=0;
lcddata=content;
e=1;
e=0;
//對液晶寫指令
//content為要寫入的指令代碼
void wr_i_lcd(uchar content)
busy_lcd();
rs=0;
rw=0;
lcddata=content;
e=1;
e=0;
//夜晶檢測忙狀態
//在寫入前必須執行
void busy_lcd(void)
lcddata=0xff;
rs=0;
rw=1;
e=1;
while(busy==1) ;
e=0;
//指定要顯示字符的坐標
void gotoxy(unsigned char y,unsigned char x)
if(y==1)
wr_i_lcd(0x80|x);
if(y==2)
wr_i_lcd(0x90|x);
if(y==3)
wr_i_lcd((0x80|x)+8);
if(y==4)
wr_i_lcd((0x90|x)+8);
//液晶顯示字符串程序
void print(uchar*str)
while(*str!='\0')
wr_d_lcd(*str);
str++;
//DS1302時鐘部分子程序模塊
typedef struct_SYSTEMTIME_
uchar Second;
uchar Minute;
uchar Hour;
uchar Week;
uchar Day;
uchar Month;
uchar Year;
uchar DateString[11];
uchar TimeString[9];
SYSTEMTIME;//定義的時間類型
SYSTEMTIME CurrentTime;
#define AM(X) X
#define PM(X) (X+12) //轉成24小時制
#define DS1302_SECOND 0X80 //時鐘芯片的寄存器位置,存放時間
#define DS1302_MINUTE 0X82
#define DS1302_HOUR 0X84
#define DS1302_WEEK 0X8A
#define DS1302_DAY 0X86
#define DS1302_MONTH 0X88
#define DS1302_YEAR 0X8C \
//實時時鐘寫入一個字節(內部函數)
void DS1302InputByte(uchar d)
uchar i;
ACC=d;
for(i=8;i>0;i--)
DS1302_IO=ACC0;
DS1302_CLK=1;
DS1302_CLK=0;
ACC=ACC>>1;
//實時時鐘讀取一個字節
uchar DS1302OutputByte(void)
uchar i;
for(i=8;i>0;i--)
ACC=ACC>>1;
ACC7=DS1302_IO;
DS1302_CLK=1;
DS1302_CLK=0;
return(ACC);
//ucAddr:DS1302地址,ucData:要寫的數據
void Write 1302(uchar ucAddr,uchar ucDa)
DS1302_RST=0;
DS1302_CLK=0;
DS1302_RST=1;
DS1302InputByte;//地址,命令
DS1302InputByte;//寫1Byte數據
DS1302_CLK=1;
DS1302_RST=0;
//讀取DS1302某地址的數據
uchar Read 1302(uchar ucAddr)
uchar ucData;
DS1302_RST=0;
DS1302_CLK=0;
DS1302_RST=1;
DS1302InputByte(ucAdd|0x01);//地址,命令
ucData=DS1302OutputByte();//讀1Byte數據
DS1302_CLK=1;
DS1302_RST=0;
return(ucData);
//獲取時鐘芯片的時鐘數據到自定義的結構型數組
void DS1302_GetTime(SYSTEMTIME*Time)
uchar ReadValue;
ReadValue=Read1302(DS13012_SECOND);
Time->Second=((ReadValue&0x70)>>4)*10+(ReadValue&0x0F);//轉換為相應的10進制數
ReadValue=Read1302(DS13012_MINUTE);
Time->Minute=((ReadValue&0x70)>>4)*10+(ReadValue&0x0F);
ReadValue=Read1302(DS13012_HOUR);
Time->Hour=((ReadValue&0x70)>>4)*10+(ReadValue&0x0F);
ReadValue=Read1302(DS13012_DAY);
Time->Day=((ReadValue&0x70)>>4)*10+(ReadValue&0x0F);
ReadValue=Read1302(DS13012_WEEK);
Time->Week=((ReadValue&0x10)>>4)*10+(ReadValue&0x0F);
ReadValue=Read1302(DS13012_MONTH);
Time->Month=((ReadValue&0x70)>>4)*10+(ReadValue&0x0F);
ReadValue=Read1302(DS13012_YEAR);
Time->Year=((ReadValue&0xf0)>>4)*10+(ReadValue&0x0F);
//將時間年月日星期數據轉換成液晶顯示字符串,
//放到數據里DateString[]
void DateStr(SYSTEMTIME*Time)
uchar tab[]={0XD2,0XBB,0XB6,0XFE,0XC8,0XFD,0XCB,0XC4,0XCE,0XE5,
0XC1,0XF9,0XC8,0XD5 };
if(hide_year<2)
Time->DateString[0]='2';
Time->DateString[1]='2';
Time->DateString[2]=Time->Year/10+'0';
Time->DateString[3]=Time->Year%10+'0';
Time->DateString[0]='';
Time->DateString[1]='';
Time->DateString[2]='';
Time->DateString[3]='';
Time->DateString[4]='-';
if(hide_month<2)
Time->DateString[5]=Time->Month/10+'0';
Time->DateString[6]=Time->Month%10+'0';
Time->DateString[5]='';
Time->DateString[6]='';
Time->DateString[7]='-';
if(hide_day<2)
Time->DateString[8]=Time->Day/10+'0';
Time->DateString[9]=Time->Day%10+'0';
Time->DateString[8]=' ';
Time->DateString[9]=' ';
if(hide_week<2)
week_value[0]=tab[2*(Time->Week%10)-2];
week_value[1]=tab[2*(Time->Week%10)-2];
week_value[0]='';
week_value[1]='';
week_value[2]='\0';
Time->DateString[10]='\0';//字符串末尾加'\0',判斷結束字符
//將時分秒數據轉換成液晶顯示字符串,
//放到數據里TimeString[]
void TimeTostr(SYSTEMTIME*Time)
if(hide_hour<2)
Time->TimeString[0]=Time->Hour/10+'0';
Time->TimeString[1]=Time->Hour%10+'0';
//定時器使能,開始計數
if(Time->Hour<0x06||Time->Hour>0x11)
TR0=1;
if(guang==0)
TR0=1;
TR0=0;
Time->TimeString[0]='';
Time->TimeString[1]='';
Time->TimeString[2]=':';
if(hide_min<2)
Time->TimeString[3]=Time->Minute/10+'0';
Time->TimeString[4]=Time->Minute%10+'0';
Time->TimeString[3]='';
Time->TimeString[4]='';
Time->TimeString[5]=':';
if(hide_sec<2)
Time->TimeString[6]=Time->Second/10+'0';
Time->TimeString[7]=Time->Second%10+'0';
Time->TimeString[6]='';
Time->TimeString[7]='';
Time->TimeString[8]='\0';
//時鐘芯片初始化
void Initial_Ds1302(void)
uchar Second=Read1302(DS1302_SECOND);
if(Second&0x80)//判斷時鐘芯片是否關閉
Write 1302(0x8e,0x00);//寫入允許
Write 1302(0x8c,0x12); //以下寫入初始化時間
Write 1302(0x88,0x11);
Write 1302(0x86,0x26);
Write 1302(0x8a,0x01);
Write 1302(0x84,0x18);
Write 1302(0x82,0x17);
Write 1302(0x80,0x55);
Write 1302(0x8e,0x80);//禁止寫入
//延時子程序模塊
void mdelay(uchar delay)
uint i;
for(;delay>0;delay--)
for(i=0;i<80;i++)//延時一毫秒
//按鍵設置程序模塊
//跳出調整模式,返回默認顯示
void outkey()
uchar Second;
if(out==0)
mdelay(5);
count=0;
hide_sec=0, hide_min=0, hide_hour=0,hide_day=0,hide_week=0, hide_month=0,hide_year=0;
Write 1302(0x8e,0x00); //寫入允許
Write 1302(0x80,Second&0x7f);
Write 1302(0x8E,0x80);//禁止寫入
done=0;
//升序按鍵
void Upkey()
Up=1;
if(Up=0)
mdelay(5);
switch(count)
case 1: temp=Read1302(DS1302_SECOND);//讀取秒數
temp=((temp&0x70)>>4)*10+(temp&0x0F);
temp=temp+1; //秒數+1
up_flag=1; //數據調整后更新標志
if((temp)>59) //超過59秒,清零
temp=0;
temp=temp/10*16+temp%10;
case 2: temp=Read1302(DS1302_MINUTE);//讀取分數
temp=temp+1; //分數+1
if((temp)>59) //超過59分,清零
temp=0;
case 3: temp=Read1302(DS1302_HOUR);//讀取小時數
temp=temp+1; //小時數+1
if((temp)>23) //超過23小時,清零
temp=0;
//定時器使能,開始計數
if(temp<0x06||temp>0x17)
TR0=1;
TR0=0;
case 4: temp=Read1302(DS1302_WEEK);//讀取 星期數
temp=temp+1; //興趣數+1
if((temp)>7)
temp=1;
case 5: temp=Read1302(DS1302_DAY);//讀取日數
temp=temp+1; //日數+1
up_flag=1;
if((temp)>31)
temp=1;
case 6: temp=Read1302(DS1302_MONTH);//讀取月數
temp=temp+1; //月數+1
up_flag=1;
if((temp)>12)
temp=1;
case 7: temp=Read1302(DS1302_YEAR);//讀取年數
temp=temp+1; //年數+1
up_flag=1;
if((temp)>99)
temp=0;
default:break;
//while(Up==0) ;
//降序按鍵
void Downkey
Down=1;
if(Down=0)
mdelay(5);
switch(count)
temp=temp-1; //秒數-1
down_flag=1; //數據調整后更新標志
if(temp==-1) //返回59秒,小于零
temp=59;
temp=temp-1; //分數-1
if(temp==-1) //返回59分,小于零
temp=59;
temp=temp-1; //小時數+1
if(temp==-1) //超過23小時,清零
temp=23;
//定時器使能,開始計數
TR0=1;
TR0=0;
temp=temp-1; //興趣數-1
if(temp==0)
temp=7;
temp=temp-1; //日數-1
down_flag=1;
if(temp==0)
temp=31;
temp=temp-1; //月數-1
down_flag=1;
if(temp==0)
temp=12;
temp=temp-1; //年數-1
down_flag=1;
if(temp==0)
temp=99;
default:break;
//while(down==0);
//按鍵模式選擇
void Setkey()
Set=1;
if(Set==0)
mdelay(5);
count=count+1;//Setkey按一次,count加1
done=1; //進入調整模式
while(Set==0);
//按鍵功能執行
void keydone()
uxhar Second;
/* if(flag==0)
temp=Read1302(0x80);
Write 1302(0x80,temp|0x80);
flag=1;
Setkey (); //掃描模式切換按鍵
switch(count)
case 1:do //count=1 ,調整秒
outkey();//掃描跳出按鍵
Upkey();//掃描加按鍵
Downkey();//掃描減按鍵
if(up_flag==1||down_flag==1)//數據更新,重新寫入新的數據
Write 1302(0x80,temp);//寫入新的秒數
up_flag=0;
down_flag=0;
if(Down!=0&&Up!=0)
hide_sec++;
if(hide_sec>3)
hide_sec=0;
hide_sec=0;
show_time();//液晶顯示顯示數據
while(count==2);
case 2:do //count=2 ,調整分
hide_sec=0;
outkey();//掃描跳出按鍵
Upkey();//掃描加按鍵
Downkey();//掃描減按鍵
if(temp>0x60)
temp=0;
Write 1302(0x82,temp);//寫入新的分數
up_flag=0;
down_flag=0;
if(Down!=0&&Up!=0)
hide_min++;
if(hide_min>3)
hide_min=0;
hide_min=0;
while(count==3);
case 3:do //count=3 ,調整小時
hide_min=0;
outkey();//掃描跳出按鍵
Upkey();//掃描加按鍵
Downkey();//掃描減按鍵
Write 1302(0x84,temp);//寫入新的分數
up_flag=0;
down_flag=0;
if(Down!=0&&Up!=0)
hide_hour++;
if(hide_hour>3)
hide_hour=0;
hide_hour=0;
while(count==4);
case 4:do //count=4 ,調整星期
hide_hour=0;
outkey();//掃描跳出按鍵
Upkey();//掃描加按鍵
Downkey();//掃描減按鍵
Write 1302(0x8a,temp);//寫入新的分數
up_flag=0;
down_flag=0;
if(Down!=0&&Up!=0)
hide_week++;
if(hide_week>3)
hide_week=0;
hide_week=0;
while(count==5);
case 5:do //count=5 ,調整日
hide_week=0;
outkey();//掃描跳出按鍵
Upkey();//掃描加按鍵
Downkey();//掃描減按鍵
if(temp>0x60)
temp=0;
Write 1302(0x86,temp);//寫入新的分數
up_flag=0;
down_flag=0;
if(Down!=0&&Up!=0)
hide_day++;
if(hide_day>3)
hide_day=0;
hide_day=0;
while(count==6);
case 6:do //count= ,調整月
hide_day=0;
outkey();//掃描跳出按鍵
Upkey();//掃描加按鍵
Downkey();//掃描減按鍵
if(temp>0x60)
temp=0;
Write 1302(0x88,temp);//寫入新的分數
up_flag=0;
down_flag=0;
if(Down!=0&&Up!=0)
hide_month++;
if(hide_month>3)
hide_momth=0;
hide_month=0;
while(count==7);
case 7:do //count=7 ,調整年
hide_month=0;
outkey();//掃描跳出按鍵
Upkey();//掃描加按鍵
Downkey();//掃描減按鍵
if(temp>0x60)
temp=0;
Write 1302(0x8c,temp);//寫入新的分數
up_flag=0;
down_flag=0;
if(Down!=0&&Up!=0)
hide_year++;
if(hide_year>3)
hide_year=0;
hide_year=0;
while(count==8);
case 8:count=0;hide_year=0;//count8跳出調整模式,返回默認顯示狀態
done=0;
break;//count=7,開始中斷,標志位置0并退出
default:break;
//液晶顯示主程序
void show_time()
DS1302_GetTime(&CurrentTime);//獲取時間芯片數據
TimeToStr(&CurrentTime); //時間數據轉換液晶字符
DateToStr(&CurrentTime); //日期數據轉換液晶字符
gotoxy(4,0);
print(" 時間:");
gotoxy(4,3);
print(CurrentTime.TimeString);//顯示時間
gotoxy(3,3);
print(CurrentTime.DateString);//顯示日期
gotoxy(3,0);
print("星期");
gotoxy(3,2);
print(week_value);//顯示星期
gotoxy(2,0);
print("定時:18:00--6:00");
gotoxy(1,0);
print("燈光狀態:明亮");
if(guang==0)
gotoxy(1,5);
print("黑暗");
mdelay(500);//掃描延時
//主程序
main()
//flag=1; //時鐘停止標志
init_lcd();
clrram_lcd();
Initial_DS1302();//時鐘芯片初始化
up_flag=0;
down_flag=0;
done=0;//進入默認液晶顯示
BEEP=1;
guang=1;
TMOD=0X01; //工作寄存器設置
ET0=1; //定時器0中斷使能
EA=1; //總中斷使能
TH0=0; //定時器計數寄存器賦初始值
TL0=0;
TCON=0x10; //工作寄存器設置
while(done==1)
keydone(); //進入調整模式
while(done==0)
show_time();// 液晶顯示數據
Setkey(); //掃描各功能鍵
void INTTO() interrupt 1 //定時器0中斷服務程序,定時器計數滿溢出以后自動進入
TH0=0xff;
TL1=0x00;
BEEP=~BEEP;
宮本無三四
2017-7-20 15:14
typedef struct后面缺個空格。另外你這個程序問題很多,我也沒時間一一看
中文字幕永久
精品免费国产
免费一区二区
亚洲v视频
超碰在线人人
色影视
国产精品一区二区三区免费
免费看a级片
黄色三级免费
综合色婷婷一区二区亚洲欧美国产
色多多在线观看
国产欧美综合一区二区三区
激情久久av
久草黄色
日韩久久久久久
亚洲精品观看
日韩在线欧美
久久久久久久影院
亚洲69
亚洲综合天堂
不卡中文字幕
www.第四色
91欧美大片
中文文字幕文字幕高清
久久亚洲免费视频
日日夜夜精品
免费的黄色大片
黄色成人毛片
国产欧美一区二区精品性色超碰
免费观看全黄做爰的视频
3p在线观看
国产精品理论
色哟哟一区二区三区
九月色婷婷
精品欧美在线
大尺度做爰呻吟舌吻网站
亚洲黄色录像
国产精品999
午夜av在线播放
国产精品久久久久久久成人午夜
日日夜夜精品免费
