STM32驅動 M25P64 FLASH讀寫程序
wjy666888wjy
2017-8-8 09:58
STM32單片機驅動M25P64 SPI_FLASH參考例程.
(42.4 KB, 下載次數: 91)
2017-8-8 17:58 上傳
全部資料下載地址:
STM32 M25P64 FLASH讀寫程序.rar
(14.41 KB, 下載次數: 57)
2017-8-8 09:56 上傳
/******************** (C) COPYRIGHT 2008 STMicroelectronics ********************
* File Name : main.c
* Author : MCD Application Team
* Version : V2.0.1
* Date : 06/13/2008
* Description : Main program body
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
/* Includes ------------------------------------------------------------------*/
#include "platform_config.h"
#include "spi_flash.h"
/* Local includes ------------------------------------------------------------*/
/* Private typedef -----------------------------------------------------------*/
typedef enum {FAILED = 0, PASSED = !FAILED} TestStatus;
/* Private define ------------------------------------------------------------*/
#define FLASH_WriteAddress 0x700000
#define FLASH_ReadAddress FLASH_WriteAddress
#define FLASH_SectorToErase FLASH_WriteAddress
#define M25P64_FLASH_ID 0x202017
#define BufferSize (countof(Tx_Buffer)-1)
/* Private macro -------------------------------------------------------------*/
#define countof(a) (sizeof(a) / sizeof(*(a)))
/* Private variables ---------------------------------------------------------*/
u8 Tx_Buffer[] = "STM32F10x SPI Firmware Library Example: communication with an M25P64 SPI FLASH";
u8 Index, Rx_Buffer[BufferSize];
volatile TestStatus TransferStatus1 = FAILED, TransferStatus2 = PASSED;
vu32 FLASH_ID = 0;
ErrorStatus HSEStartUpStatus;
/* Private functions ---------------------------------------------------------*/
TestStatus Buffercmp(u8* pBuffer1, u8* pBuffer2, u16 BufferLength);
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
* Function Name : main
* Input : None
* Output : None
* Return : None
int main(void)
#ifdef DEBUG
debug();
#endif
/* System clocks configuration */
RCC_Configuration();
/* NVIC configuration */
NVIC_Configuration();
/* GPIO configuration */
GPIO_Configuration();
/* Initialize the SPI FLASH driver */
SPI_FLASH_Init();
/* Get SPI Flash ID */
FLASH_ID = SPI_FLASH_ReadID();
/* Check the SPI Flash ID */
if (FLASH_ID == M25P64_FLASH_ID)
/* OK: Set GPIO_LED pin 6 */
GPIO_WriteBit(GPIO_LED, GPIO_Pin_6, Bit_SET);
/* Error: Set GPIO_LED pin 7 */
GPIO_WriteBit(GPIO_LED, GPIO_Pin_7, Bit_SET);
/* Perform a write in the Flash followed by a read of the written data */
/* Erase SPI FLASH Sector to write on */
SPI_FLASH_SectorErase(FLASH_SectorToErase);
/* Write Tx_Buffer data to SPI FLASH memory */
SPI_FLASH_BufferWrite(Tx_Buffer, FLASH_WriteAddress, BufferSize);
/* Read data from SPI FLASH memory */
SPI_FLASH_BufferRead(Rx_Buffer, FLASH_ReadAddress, BufferSize);
/* Check the corectness of written dada */
TransferStatus1 = Buffercmp(Tx_Buffer, Rx_Buffer, BufferSize);
/* TransferStatus1 = PASSED, if the transmitted and received data by SPI1
are the same */
/* TransferStatus1 = FAILED, if the transmitted and received data by SPI1
are different */
/* Perform an erase in the Flash followed by a read of the written data */
/* Check the corectness of erasing operation dada */
for (Index = 0; Index < BufferSize; Index++)
if (Rx_Buffer[Index] != 0xFF)
TransferStatus2 = FAILED;
/* TransferStatus2 = PASSED, if the specified sector part is erased */
/* TransferStatus2 = FAILED, if the specified sector part is not well erased */
while (1)
* Function Name : RCC_Configuration
* Description : Configures the different system clocks.
* Input : None
* Output : None
* Return : None
/* RCC system reset(for debug purpose) */
RCC_DeInit();
/* Enable HSE */
RCC_HSEConfig(RCC_HSE_ON);
/* Wait till HSE is ready */
HSEStartUpStatus = RCC_WaitForHSEStartUp();
if (HSEStartUpStatus == SUCCESS)
/* Enable Prefetch Buffer */
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
/* Flash 2 wait state */
FLASH_SetLatency(FLASH_Latency_2);
/* HCLK = SYSCLK */
RCC_HCLKConfig(RCC_SYSCLK_Div1);
/* PCLK2 = HCLK */
RCC_PCLK2Config(RCC_HCLK_Div1);
/* PCLK1 = HCLK/2 */
RCC_PCLK1Config(RCC_HCLK_Div2);
/* PLLCLK = 8MHz * 9 = 72 MHz */
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
/* Enable PLL */
RCC_PLLCmd(ENABLE);
/* Wait till PLL is ready */
while (RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
/* Select PLL as system clock source */
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
/* Wait till PLL is used as system clock source */
while (RCC_GetSYSCLKSource() != 0x08)
/* Enable GPIO_LED clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIO_LED, ENABLE);
* Function Name : GPIO_Configuration
* Description : Configures the different GPIO ports.
* Input : None
* Output : None
* Return : None
/* Configure GPIO LED pin6 and pin7 as Output push-pull --------------------*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIO_LED, &GPIO_InitStructure);
* Function Name : NVIC_Configuration
* Description : Configures Vector Table base location.
* Input : None
* Output : None
* Return : None
#ifdef VECT_TAB_RAM
/* Set the Vector Table base location at 0x20000000 */
NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else /* VECT_TAB_FLASH */
/* Set the Vector Table base location at 0x08000000 */
NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
* Function Name : Buffercmp
* Description : Compares two buffers.
* Input : - pBuffer1, pBuffer2: buffers to be compared.
* : - BufferLength: buffer's length
* Output : None
* Return : PASSED: pBuffer1 identical to pBuffer2
* FAILED: pBuffer1 differs from pBuffer2
while (BufferLength--)
if (*pBuffer1 != *pBuffer2)
return FAILED;
pBuffer1++;
pBuffer2++;
return PASSED;
#ifdef DEBUG
* Function Name : assert_failed
* Description : Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* Input : - file: pointer to the source file name
* - line: assert_param error line source number
* Output : None
* Return : None
void assert_failed(u8* file, u32 line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* Infinite loop */
while (1)
#endif
/******************* (C) COPYRIGHT 2008 STMicroelectronics *****END OF FILE****/
屏風燭影
2018-11-5 10:41
下載下來分析下
hugheao
2019-3-7 22:05
試試。。。。
日韩av在线不卡
国产成人精品免费视频
欧洲黄色录像
亚洲黄色在线
91爱爱网
日韩精品一级毛片在线播放
欧美vieox另类极品
成人深夜视频
免费av一区
精品视频在线观看免费
国产成人在线观看免费网站
国产黄色免费
精品免费国产一区二区三区四区
亚洲国产精品久久久久久久
日韩精品视频免费在线观看
中文字幕在线观看亚洲
婷婷在线视频
国产理论片在线观看
日产毛片
欧美a级成人淫片免费看
国产第三页
精品久久免费视频
国产日韩亚洲
欧美亚洲在线观看
18精品爽国产白嫩精品
成人影片在线
久久福利社
日本一区二区三区四区五区
国产又黄又粗
日韩在线视频免费观看
日本少妇做爰全过程毛片
天天射影院
aaaaa毛片
国产一区精品在线
亚洲三级网站
在线观看av网站
欧洲一区二区三区
韩国三级av
天天射天天操天天干
欧美日韩免费看
久草福利视频
