標(biāo)題: ISL8560引腳圖與電路圖及電源模塊datasheet資料下載 [打印本頁]
作者: wangzhixiong08    時(shí)間: 2017-8-21 21:43
ISL8560引腳圖:
ISL8560功能框圖:
ISL8560電路圖:
DC/DC Power Switching Regulator
The ISL8560 is a step down DC/DC power switching
regulator which accepts 9.0V to 60V input and provides a 2A
output current. The output voltage can be set in the range
between 1.21V and 55V by means of an external divider.
The device uses an internal power DMOS transistor with a
typical rDS(ON) of 0.19Ω to obtain very high efficiency and
high switching speed. A switching frequency in the range of
100kHz to 600kHz can be realized (the maximum power
dissipation of the various packages must be observed).
Notable features of this next generation of DC/DC converter
includes pulse-by-pulse current limit for FET protection,
hiccup mode for short circuit protection, voltage feedforward
regulation, Frequency SYNC, soft-start, low standby current
of 60µA typical in the disabled state, and thermal shut-down.
The device is available in a 20 Ld QFN package.
電源模塊datasheet全部資料下載地址:
ISL8560.PDF (1.03 MB, 下載次數(shù): 11)
主站蜘蛛池模板: 一区二区不卡视频 | 国产一区二区精品丝袜 | 欧美a级成人淫片免费看 | 免费黄色av | 日韩在线视频免费 | 精品黑人一区二区三区国语馆 | 成人免费看片视频 | 在线观看av的网站 | 免费av观看 | 一区两区小视频 | 久久久夜色精品 | 欧美亚洲天堂 | 欧美日韩国产在线观看 | 伊人网视频 | 久久综合久久鬼 | 天天干夜夜撸 | 黄色片91| 欧美视频在线观看一区 | 欧美一区二区在线播放 | 国产精品三级在线 | 国产午夜精品一区二区三区四区 | www.爱爱 | 欧美www.| 欧美成人久久 | 黄色片视频在线观看 | www.色中色 | 极品白嫩少妇无套内谢 | 中文字幕系列 | 久久精品视频一区二区 | 啪啪毛片| 天堂资源av | 欧美日韩一区二区三区四区 | 四虎影视在线 | 中文字幕免费观看视频 | 四虎www| 欧美日韩综合在线 | 九九视频在线免费观看 | 免费国产一区 | 日本精品在线视频 | 美女无遮挡网站 | 久久久久黄色 |
