標(biāo)題:
酒精測試儀程序
1592281111
時(shí)間:
2017-11-27 20:54
標(biāo)題:
酒精測試儀程序
我現(xiàn)在有原理圖,實(shí)物已經(jīng)按照原理圖接線,程序現(xiàn)在有問題,望各位大神指教
#include "reg52.H"
#include <STC89c52.h>
#include <L1602.h>
#include <2402.h>
#define uchar unsigned char
#define uint unsigned int
//聲明常量
#define ALCH 80 //醉駕標(biāo)準(zhǔn)80mg/L
//K_MG_MV和K_ZERO為傳感器校準(zhǔn)系數(shù),要根據(jù)每個(gè)MQ-3模塊校準(zhǔn)
#define K_MG_MV 160/66 //傳感器靈敏度系數(shù),每毫克/L對(duì)應(yīng)的10毫伏數(shù)
#define K_ZERO 15 //傳感器零點(diǎn)漂移,約130mV
//定義按鍵
sbit Key_Up = P3^6;
sbit Key_Down = P3^7;
//定義LED報(bào)警燈
sbit Led_Warn1 = P2^0;
sbit Led_Warn2 = P2^1;
sbit Led_Warn3 = P2^2;
//定義乙醇傳感器TTL電平輸出引腳
sbit DOUT = P1^4;
//定義標(biāo)識(shí)
volatile bit FlagStartAL = 0; //開始轉(zhuǎn)換標(biāo)志
volatile bit FlagKeyPress = 0; //有鍵彈起標(biāo)志
//全局變量定義
uchar Threshold; //酒精濃度上限報(bào)警值
uint ALCounter; //酒精轉(zhuǎn)換計(jì)時(shí)器
long ALValue; //酒精測量值
float ALtemp; //計(jì)算臨時(shí)變量
uint keyvalue, keyUp, keyDown; //鍵值
char * pSave; //EEPROM存盤用指針
//函數(shù)聲明
void Data_Init();
void Timer0_Init();
void Port_Init();
void ADC_Init();
uchar GetADVal();
void KeyProcess(uint );
//數(shù)據(jù)初始化
void Data_Init()
ALCounter = 0;
ALValue = 0;
Led_Warn1 = 1;
Led_Warn2 = 2;
Led_Warn3 = 3;
keyvalue = 0;
keyUp = 1;
keyDown = 1;
//定時(shí)器0初始化,中斷時(shí)間約2毫秒
//計(jì)算:晶振11.0592MHz,定時(shí)器時(shí)鐘11059200/12=921600,每毫秒922個(gè)脈沖
// 16位定時(shí)器初值65536-1844=63692=0xf8cc
void Timer0_Init()
ET0 = 1; //允許定時(shí)器0中斷
TMOD = 1; //定時(shí)器工作方式選擇
TL0 = 0xcc; //
TH0 = 0xf8; //定時(shí)器賦予初值,大約為2毫秒中斷1次
TR0 = 1; //啟動(dòng)定時(shí)器
//定時(shí)器0中斷
void Timer0_ISR (void) interrupt 1 using 0
TL0 = 0xcc;
//每1秒鐘啟動(dòng)一次AD轉(zhuǎn)換
ALCounter ++;
if (ALCounter >= 500)
FlagStartAL = 1;
ALCounter = 0;
//存入設(shè)定值
void Save_Setting()
pSave = (char *)&Threshold; //地址低位對(duì)應(yīng)低8位,高位對(duì)應(yīng)高8位
wrteeprom(0, *pSave); //存醉酒閾值低8位
DELAY(300);
pSave ++;
wrteeprom(1, *pSave); //存醉酒閾值高8位
DELAY(300);
//載入設(shè)定值
void Load_Setting()
*pSave++ = rdeeprom(0);
*pSave = rdeeprom(1);
if ((Threshold>=255)||(Threshold<0)) Threshold = 80;
//按鍵處理程序,參數(shù)為鍵值,1為Up鍵,2為Down鍵
void KeyProcess(uint num)
switch (num)
case 1:
if (Threshold<255) Threshold++;
case 2:
if (Threshold>1) Threshold--;
default:
L1602_int(2,9,Threshold);
Save_Setting();
uint i,j;
EA = 0;
Data_Init(); //數(shù)據(jù)初始化
Timer0_Init(); //定時(shí)器0初始化
Port_Init(); //端口初始化
ADC_Init(); //ADC初始化
EA = 1;
L1602_init();
L1602_string(1,1,"Welcome to ALCT! ");
L1602_string(2,1,"Designed by AAA ");
//延時(shí)
for (i=0;i<1000;i++)
for (j=0;j<1000;j++)
//清屏
L1602_string(1,1," ");
L1602_string(2,1," ");
L1602_string(1,1,"Alcohol: mg/L");
L1602_string(2,1,"Thresho: mg/L");
//載入設(shè)定值
Load_Setting();
//如果FlagStartAL標(biāo)志置位,則進(jìn)行AD轉(zhuǎn)換
if (FlagStartAL == 1)
//酒精濃度換算,50mg/L=62.5ppm,傳感器靈敏度應(yīng)事先校準(zhǔn)
ALValue = 500 * GetADVal() / 256; //8位ADC,首先得到電壓值,單位10毫伏
ALValue = ALValue - K_ZERO; //首先減去零點(diǎn)漂移,一般是130mV
if (ALValue < 0) ALValue = 0;
ALValue = ALValue * K_MG_MV; //將mV轉(zhuǎn)變成mg/L,K_MG_MV系數(shù)需要校準(zhǔn)
L1602_int(1,9,ALValue);
if (ALValue > Threshold) Led_Warn1 = 0; //超過閾值,則 Led_Warn1燈報(bào)警,否則報(bào)警燈滅。
else Led_Warn1 = 1;
FlagStartAL = 0;
//查詢乙醇傳感器TTL電平,該指示燈為傳感器模塊報(bào)警
if (DOUT == 0) Led_Warn2 = 0;
//鍵盤查詢,在彈起時(shí)響應(yīng)
if ((Key_Up)&&(keyUp==0)) {FlagKeyPress = 1; keyvalue = 1;}
else if ((Key_Down)&&(keyDown==0)) {FlagKeyPress = 1; keyvalue = 2;}
if (FlagKeyPress == 1)
KeyProcess(keyvalue);
FlagKeyPress = 0;
if (!Key_Up) keyUp = 0;
else keyUp = 1;
if (!Key_Down) keyDown = 0;
else keyDown = 1;
DELAY(100);
(161.41 KB, 下載次數(shù): 62)
2017-11-27 20:54 上傳
原理圖
055441
時(shí)間:
2019-4-26 17:30
看不懂
kaixin999
時(shí)間:
2019-4-28 20:03
感謝分享
老頑固
時(shí)間:
2020-12-12 23:46
wrteeprom這個(gè)報(bào)錯(cuò)了
湖南
時(shí)間:
2020-12-30 17:02
是顯示問題嗎
君子之膠淡如水
時(shí)間:
2024-5-18 20:06
這個(gè)500和256有什么說法
伊人av网
久草免费在线观看
五月天视频
黄视频免费观看
国产一区二区三区
99亚洲精品
国产美女视频网站
国产成人小视频
精品少妇一区二区三区免费观
91久久久久国产一区二区
精品久久久久久一区二区里番
欧美在线观看一区
黄色大片免费在线观看
福利视频午夜
日韩理论在线
免费性视频
国产精品免费一区
日本精品视频在线
ass亚洲尤物裸体pics
中文字幕av在线播放
一级黄色片免费观看
亚洲视频在线播放
日韩一区中文字幕
久久99精品久久久久久琪琪
日韩欧美三级
日韩免费看
天天色播
亚洲成人精品视频
成年人一级片
亚洲第一在线
国产成人亚洲精品自产在线
久久人体视频
午夜精品一区二区三区在线视频
aaa亚洲
www国产亚洲精品久久网站
av一区二区三区
国产精品一区二区在线播放
国产一区精品视频
中文在线免费观看
国产激情久久久
免费的黄色大片
