altium designer 原理圖復制出錯問題 InvalidParameter at AdvSch.dll, Base Addre...
查看數: 63221 | 評論數: 26 | 收藏 2
發(fā)布時間: 2014-12-25 01:10
InvalidParameter at 2510219C. AdvSch.dll, Base Address: 24C80000. Exception Occurred In Copy 使用AD14在復制的時候偶爾會出現這樣的一個問題 然后會出先復制出錯的情況,也有人說這是破解版的一 ...
ID:247810 發(fā)表于 2019-7-17 21:55
謝謝 分享
ID:475783 發(fā)表于 2019-7-7 10:36
牛人,這都可以
ID:529775 發(fā)表于 2019-7-7 10:27
感謝,復制沒問題了
ID:575820 發(fā)表于 2019-7-1 17:05
ming759053364 發(fā)表于 2015-6-19 20:44
**** 作者被禁止或刪除 內容自動屏蔽 ****
牛逼啊兄嘚
ID:34556 發(fā)表于 2019-3-13 10:06
非常給力
ID:339180 發(fā)表于 2019-2-26 13:49
大神,解決了,謝謝
ID:382973 發(fā)表于 2018-11-13 11:19
liuyufengdq 發(fā)表于 2015-4-16 11:03
牛逼  贊贊啊
ID:389771 發(fā)表于 2018-8-24 20:33
萬分感謝,已解決
ID:198323 發(fā)表于 2018-6-27 09:06
我安裝了 怎么不行,是還需要其他操作嗎
ID:169623 發(fā)表于 2017-3-10 13:55
感謝大神  弄好了
ID:143559 發(fā)表于 2017-1-19 10:17
O(∩_∩)O謝謝
ID:152226 發(fā)表于 2016-12-5 10:09
我也 要
ID:150909 發(fā)表于 2016-11-29 09:20
我也遇到過
ID:149871 發(fā)表于 2016-11-24 09:18
謝謝啊  好人一生平安
ID:123002 發(fā)表于 2016-5-24 22:47
謝謝分享。
ID:113663 發(fā)表于 2016-4-12 10:04
太感謝樓主了,現在好啦
ID:87879 發(fā)表于 2015-8-7 20:04
為什么會出現這種問題呢?是不是清理軟件搞的鬼
ID:87339 發(fā)表于 2015-7-31 13:34
我也出現了這個問題,我先試試上面的方法
ID:85199 發(fā)表于 2015-7-9 15:02
下載一個虛擬打印機,給個網址可以下載http://www.cr173.com/soft/32263.html
牛人,照你的方法下了打印機安裝上就好了
ID:85181 發(fā)表于 2015-7-9 11:32
I had this issue with AD13 and AD14 after reinstalling and in SAFE MODE just in case it was some other program interfering. Well it turn out that this issue was related to the spooler service being turned off. I have a habit of turning off features on my computer that i do not use, and since i dont have a printer attached to my machine... i stoped the spooler service. So make sure that it is running first before you run altium.
go to start -> run -> type "cmd"
in the command prompt window type:
net start spooler
You should see this:
The Print Spooler service is starting.
The Print Spooler service was started successfully.
Re-open Altium and you should be good.
Why in the world AD needs the spooler service turned on to do a simple copy paste operation is beyond me.
ID:83463 發(fā)表于 2015-6-19 20:44
參與人數 1黑幣 +5 收起 理由
tangquan + 5 很給力!
ID:77133 發(fā)表于 2015-4-16 11:03
剛剛解決這個問題:
先看看能不能添加本地打印機,要是無法添加打印機,在桌面選中“我的電腦”,鼠標右鍵選擇“管理”;
在“管理”窗口中,選取“服務和應用程序”擴展項目下的“服務”選項,在右側出現系統(tǒng)服務列表中找到“Print Spooler”服務,雙擊進入“Print Spooler”服務設置;
在“Print Spooler”服務設置窗口中,將“啟動類型”設置為“自動”,點擊“啟動”按鈕;
此時系統(tǒng)會嘗試啟動該服務;
當服務啟動成功后,“服務狀態(tài)”會顯示為“已啟動”,重新進行添加或是使用打印機的其它操作。
如果復制還出錯:
添加本地打印機:開始》》設備和打印機》》添加打印機》》創(chuàng)建新端口》》下一步》》輸入test》》廠商選Microsoft,打印機選Microsoft XPS Document Writer
        轉載來自百度altuim吧   慶州123
ID:76631 發(fā)表于 2015-4-10 22:15
我也出現這樣的問題,怎么解決?
ID:75918 發(fā)表于 2015-4-1 21:25
這個問題難道就無解了嗎
ID:74817 發(fā)表于 2015-3-18 22:59
出現上述怎樣解決
ID:73167 發(fā)表于 2015-2-2 20:45
同問
主站蜘蛛池模板: 精品视频网站 | 一级a毛片| 午夜精品在线观看 | 成人一区二区在线 | 九色91popny蝌蚪新疆 | 欧美一级片在线 | 天天爽天天爽 | 黄色大片免费在线观看 | 国产午夜精品一区二区三区 | 欧美激情五月 | 69国产精品 | 欧美18免费视频 | 天天曰天天操 | 亚洲美女一区 | 日本一级一片免费视频 | a级片免费在线观看 | 永久黄网站色视频免费观看w | 中文在线观看免费视频 | 久久精品国产成人av | 国产欧美一区二区精品性色超碰 | 香蕉视频一区二区 | 中文字幕一区二区三区在线观看 | 精品一区二区三区免费 | 国产精品久免费的黄网站 | 国产精品久久网 | 国产精品一级二级 | 成人福利在线 | 久久精品在线观看 | 欧美一级在线视频 | 久久超 | 三级a毛片 | 日韩欧美小视频 | 三级av网站 | 午夜一区二区三区 | 国产黄色免费观看 | 五月激情久久 | av高清在线 | 日韩在线欧美 | 国产精品嫩草影院桃色 | 国产精品美女 | 一区二区三区视频在线 |
