如何根據成型的單片機時鐘編寫程序?
查看數: 3988 | 評論數: 4 | 收藏 0
發布時間: 2016-12-28 11:51
如圖,單片機的型號是stc15f204ea,之前在網上買了些零件,將之組裝完成后才發現缺少相對應的程序。 請問,如果想要編寫出相對應的時鐘鬧鐘程序,需要怎么做? 可以的話,請務必留下詳細的回復。
ID:158248 發表于 2016-12-28 23:09
這個得根據電路來寫程序,你可以用已有的原件設計電路,再編寫程序。
ID:155507 發表于 2016-12-28 21:21
相對應的時鐘鬧鐘程序
  1. //
  2. // STC15F204EA DIY LED Clock
  3. //
  4. #include "stc15.h"
  5. #include <stdint.h>
  6. #include <stdio.h>
  7. #include "adc.h"
  8. #include "ds1302.h"
  9. #include "led.h"
  10.
  11. #define FOSC    11059200
  12. // clear wdt
  13. #define WDT_CLEAR()    (WDT_CONTR |= 1 << 4)
  14. // alias for relay and buzzer outputs, using relay to drive led for indication of main loop status
  15. #define RELAY   P1_4
  16. #define BUZZER  P1_5
  17.
  18. // adc channels for sensors
  19. #define ADC_LIGHT 6
  20. #define ADC_TEMP  7
  21. // three steps of dimming. Photoresistor adc value is 0-255. Lower values = brighter.
  22. #define DIM_HI  100
  23. #define DIM_LO  190
  24. // button switch aliases
  25. #define SW2     P3_0
  26. #define S2      1
  27. #define SW1     P3_1
  28. #define S1      0
  29. // display mode states
  30. enum keyboard_mode {
  31.     K_NORMAL,
  32.     K_WAIT_S1,
  33.     K_WAIT_S2,
  34.     K_SET_HOUR,
  35.     K_SET_MINUTE,
  36.     K_SET_HOUR_12_24,
  37.     K_SEC_DISP,
  38.     K_TEMP_DISP,
  39.     K_DATE_DISP,
  40.     K_DATE_SWDISP,
  41.     K_SET_MONTH,
  42.     K_SET_DAY,
  43.     K_WEEKDAY_DISP,
  44.     K_DEBUG
  45. };
  46. // display mode states
  47. enum display_mode {
  48.     M_NORMAL,
  49.     M_SET_HOUR_12_24,
  50.     M_SEC_DISP,
  51.     M_TEMP_DISP,
  52.     M_DATE_DISP,
  53.     M_WEEKDAY_DISP,
  54.     M_DEBUG
  55. };
  56. /* ------------------------------------------------------------------------- */
  57. void _delay_ms(uint8_t ms)
  58. {
  59.     // i,j selected for fosc 11.0592MHz, using oscilloscope
  60.     // the stc-isp tool gives inaccurate values (perhaps for C51 vs sdcc?)
  61.     // max 255 ms
  62.     uint8_t i, j;
  63.     do {
  64.             i = 4;
  65.             j = 240;
  66.             do
  67.             {
  68.                     while (--j);
  69.             } while (--i);
  70.     } while (--ms);
  71. }
  72. // GLOBALS
  73. uint8_t  count;     // was uint16 - 8 seems to be enough
  74. uint16_t temp;      // temperature sensor value
  75. uint8_t  lightval;  // light sensor value
  76. volatile uint8_t displaycounter;
  77. volatile uint8_t _100us_count;
  78. volatile uint8_t _10ms_count;
  79. uint8_t dmode = M_NORMAL;     // display mode state
  80. uint8_t kmode = K_NORMAL;
  81. uint8_t smode,lmode;
  82. volatile __bit  display_colon;         // flash colon
  83. __bit  flash_01;
  84. __bit  flash_23;
  85. __bit  beep = 1;
  86. volatile __bit  S1_LONG;
  87. volatile __bit  S1_PRESSED;
  88. volatile __bit  S2_LONG;
  89. volatile __bit  S2_PRESSED;
  90. volatile uint8_t debounce[2];      // switch debounce buffer
  91. volatile uint8_t switchcount[2];
  92. #define SW_CNTMAX 80
  93. void timer0_isr() __interrupt 1 __using 1
  94. {
  95.     // display refresh ISR
  96.     // cycle thru digits one at a time
  97.     uint8_t digit = displaycounter % 4;
  98.     // turn off all digits, set high
  99.     P3 |= 0x3C;
  100.     // auto dimming, skip lighting for some cycles
  101.     if (displaycounter % lightval < 4 ) {
  102.         // fill digits
  103.         P2 = dbuf[digit];
  104.         // turn on selected digit, set low
  105.         P3 &= ~(0x4 << digit);
  106.     }
  107.     displaycounter++;
  108.     //  divider: every 10ms
  109.     if (++_100us_count == 100) {
  110.         _100us_count = 0;
  111.         _10ms_count++;
  112.         // colon blink stuff, 500ms
  113.         if (_10ms_count == 50) {
  114.             display_colon = !display_colon;
  115.             _10ms_count = 0;
  116.         }
  117.
  118.         // switch read, debounce:
  119.         // increment count if settled closed
  120.         if ((debounce[0]) == 0x00) {
  121.             // down for at least 8 ticks
  122.             S1_PRESSED = 1;
  123.             switchcount[0]++;
  124.         } else {
  125.             // released or bounced, reset state
  126.             S1_PRESSED = 0;
  127.             switchcount[0] = 0;
  128.         }
  129.         if ((debounce[1]) == 0x00) {
  130.             // down for at least 8 ticks
  131.             S2_PRESSED = 1;
  132.             switchcount[1]++;
  133.         } else {
  134.             // released or bounced, reset state
  135.             S2_PRESSED = 0;
  136.             switchcount[1] = 0;
  137.         }
  138.         // debouncing stuff
  139.         // keep resetting halfway if held long
  140.         if (switchcount[0] > SW_CNTMAX)
  141.             {switchcount[0] = SW_CNTMAX; S1_LONG=1;}
  142.         if (switchcount[1] > SW_CNTMAX)
  143.             {switchcount[1] = SW_CNTMAX; S2_LONG=1;}
  144.         // read switch positions into sliding 8-bit window
  145.         debounce[0] = (debounce[0] << 1) | SW1;
  146.         debounce[1] = (debounce[1] << 1) | SW2;
  147.     }
  148. }
  149. void Timer0Init(void)                //100us @ 11.0592MHz
  150. {
  151.         TL0 = 0xA4;                //Initial timer value
  152.         TH0 = 0xFF;                //Initial timer value
  153.     TF0 = 0;                //Clear TF0 flag
  154.     TR0 = 1;                //Timer0 start run
  155.     ET0 = 1;        // enable timer0 interrupt
  156.     EA = 1;         // global interrupt enable
  157. }
  158. #define getkeypress(a) a##_PRESSED
  159. int8_t gettemp(uint16_t raw) {
  160.     // formula for ntc adc value to approx C
  161.     return 76 - raw * 64 / 637;
  162. }
  163. /*********************************************/
  164. int main()
  165. {
  166.     // SETUP
  167.     // set photoresistor & ntc pins to open-drain output
  168.     P1M1 |= (1<<6) | (1<<7);
  169.     P1M0 |= (1<<6) | (1<<7);
  170.
  171.     // init rtc
  172.     ds_init();
  173.     // init/read ram config
  174.     ds_ram_config_init();
  175.
  176.     // uncomment in order to reset minutes and hours to zero.. Should not need this.
  177.     //ds_reset_clock();
  178.
  179.     Timer0Init(); // display refresh & switch read
  180.
  181.     // LOOP
  182.     while(1)
  183.     {
  184.       RELAY = 0;
  185.       _delay_ms(100);
  186.       RELAY = 1;
  187.       // run every ~1 secs
  188.       if ((count & 3) == 0) {
  189.           lightval = getADCResult8(ADC_LIGHT) >> 3;
  190.           temp = gettemp(getADCResult(ADC_TEMP)) + (config_table[CONFIG_TEMP_BYTE]&CONFIG_TEMP_MASK) - 4;
  191.           // constrain dimming range
  192.           if (lightval < 4)
  193.               lightval = 4;
  194.       }
  195.       ds_readburst(); // read rtc
  196.       // keyboard decision tree
  197.       switch (kmode) {
  198.
  199.           case K_SET_HOUR:
  200.               flash_01 = !flash_01;
  201.               if (! flash_01) {
  202.                   if (getkeypress(S2)) ds_hours_incr();
  203.                   if (getkeypress(S1)) kmode = K_SET_MINUTE;
  204.               }
  205.               break;
  206.
  207.           case K_SET_MINUTE:
  208.               flash_01 = 0;
  209.               flash_23 = !flash_23;
  210.               if (! flash_23) {
  211.                   if (getkeypress(S2)) ds_minutes_incr();
  212.                   if (getkeypress(S1)) kmode = K_SET_HOUR_12_24;
  213.               }
  214.               break;
  215.           case K_SET_HOUR_12_24:
  216.               dmode=M_SET_HOUR_12_24;
  217.               if (getkeypress(S2)) ds_hours_12_24_toggle();
  218.               if (getkeypress(S1)) kmode = K_NORMAL;
  219.               break;
  220.
  221.           case K_TEMP_DISP:
  222.               dmode=M_TEMP_DISP;
  223.               if (getkeypress(S1))
  224.                   { uint8_t offset=config_table[CONFIG_TEMP_BYTE]&CONFIG_TEMP_MASK;
  225.                     offset++; offset&=CONFIG_TEMP_MASK;
  226.                     config_table[CONFIG_TEMP_BYTE]=(config_table[CONFIG_TEMP_BYTE]&~CONFIG_TEMP_MASK)|offset;
  227.                   }
  228.               if (getkeypress(S2)) kmode = K_DATE_DISP;
  229.               break;
  230.
  231.           case K_DATE_DISP:
  232.               dmode=M_DATE_DISP;
  233.               if (getkeypress(S1)) {kmode=K_WAIT_S1; lmode=CONF_SW_MMDD?K_SET_DAY:K_SET_MONTH; smode=K_DATE_SWDISP; }
  234.               if (getkeypress(S2)) kmode = K_WEEKDAY_DISP;
  235.               break;
  236.           case K_DATE_SWDISP:
  237.               CONF_SW_MMDD=!CONF_SW_MMDD;
  238.               kmode=K_DATE_DISP;
  239.               break;
  240.
  241.           case K_SET_MONTH:
  242.               flash_01 = !flash_01;
  243.               if (! flash_01) {
  244.                   if (getkeypress(S2)) { ds_month_incr(); }
  245.                   if (getkeypress(S1)) { flash_01 = 0; kmode = CONF_SW_MMDD?K_DATE_DISP:K_SET_DAY; }
  246.               }
  247.               break;
  248.
  249.           case K_SET_DAY:
  250.               flash_23 = !flash_23;
  251.               if (! flash_23) {
  252.                   if (getkeypress(S2)) { ds_day_incr(); }
  253.                   if (getkeypress(S1)) { flash_23 = 0; kmode = CONF_SW_MMDD?K_SET_MONTH:K_DATE_DISP;
  254.                   }
  255.               }
  256.               break;
  257.
  258.           case K_WEEKDAY_DISP:
  259.               dmode=M_WEEKDAY_DISP;
  260.               if (getkeypress(S1)) ds_weekday_incr();
  261.               if (getkeypress(S2)) kmode = K_NORMAL;
  262.               break;
  263.
  264.           case K_DEBUG:
  265.               dmode=M_DEBUG;
  266.               if (count>100) kmode = K_NORMAL;
  267.               if (S1_PRESSED||S2_PRESSED) count=0;
  268.               break;
  269.           case K_SEC_DISP:
  270.               dmode=M_SEC_DISP;
  271.               if (getkeypress(S1) || (count>100)) { kmode = K_NORMAL; }
  272.               if (getkeypress(S2)) { ds_sec_zero(); }
  273.               break;
  274.           case K_WAIT_S1:
  275.               count=0;
  276.               if (!S1_PRESSED) {
  277.                if (S1_LONG) {S1_LONG=0; kmode=lmode;}
  278.                       else  {kmode=smode;}
  279.                }
  280.               break;
  281.           case K_WAIT_S2:
  282.               count=0;
  283.               if (!S2_PRESSED) {
  284.                if (S2_LONG) {S2_LONG=0; kmode=lmode;}
  285.                       else  {kmode=smode;}
  286.                }
  287.               break;
  288.           case K_NORMAL:
  289.           default:
  290.               flash_01 = 0;
  291.               flash_23 = 0;
  292.               dmode=M_NORMAL;
  293.               if (S1_PRESSED) { kmode = K_WAIT_S1; lmode=K_SET_HOUR; smode=K_SEC_DISP;  }
  294.               //if (S2_PRESSED) { kmode = K_WAIT_S2; lmode=K_DEBUG;    smode=K_TEMP_DISP; }
  295.               if (S2_PRESSED) { kmode = K_TEMP_DISP; }
  296.
  297.       };
  298.       // display execution tree
  299.
  300.       clearTmpDisplay();
  301.       switch (dmode) {
  302.           case M_NORMAL:
  303.               if (flash_01) {
  304.                   dotdisplay(1,display_colon);
  305.               } else {
  306.                   if (!H12_24) {
  307.                       filldisplay( 0, (rtc_table[DS_ADDR_HOUR]>>4)&(DS_MASK_HOUR24_TENS>>4), 0);        // tenhour
  308.                   } else {
  309.                       if (H12_TH) filldisplay( 0, 1, 0);        // tenhour in case AMPM mode is on, then '1' only is H12_TH is on
  310.                   }
  311.                   filldisplay( 1, rtc_table[DS_ADDR_HOUR]&DS_MASK_HOUR_UNITS, display_colon);
  312.               }
  313.
  314.               if (flash_23) {
  315.                   dotdisplay(2,display_colon);
  316.                   dotdisplay(3,H12_24&H12_PM);        // dot3 if AMPM mode and PM=1
  317.               } else {
  318.                   filldisplay( 2, (rtc_table[DS_ADDR_MINUTES]>>4)&(DS_MASK_MINUTES_TENS>>4), display_colon);        //tenmin
  319.                   filldisplay( 3, rtc_table[DS_ADDR_MINUTES]&DS_MASK_MINUTES_UNITS, H12_24 & H12_PM);                  //min
  320.               }
  321.               break;
  322.           case M_SET_HOUR_12_24:
  323.               if (!H12_24) {
  324.                   filldisplay( 1, 2, 0); filldisplay( 2, 4, 0);
  325.               } else {
  326.                   filldisplay( 1, 1, 0); filldisplay( 2, 2, 0);
  327.               }
  328.               filldisplay( 3, LED_h, 0);
  329.               break;
  330.           case M_SEC_DISP:
  331.               dotdisplay(0,display_colon);
  332.               dotdisplay(1,display_colon);
  333.               filldisplay(2,(rtc_table[DS_ADDR_SECONDS]>>4)&(DS_MASK_SECONDS_TENS>>4),0);
  334.               filldisplay(3,rtc_table[DS_ADDR_SECONDS]&DS_MASK_SECONDS_UNITS,0);
  335.               break;
  336.
  337.           case M_DATE_DISP:
  338.               if (flash_01) {
  339.                   dotdisplay(1,1);
  340.               } else {
  341.                  if (!CONF_SW_MMDD) {
  342.                   filldisplay( 0, rtc_table[DS_ADDR_MONTH]>>4, 0);        // tenmonth ( &MASK_TENS useless, as MSB bits are read as '0')
  343.                   filldisplay( 1, rtc_table[DS_ADDR_MONTH]&DS_MASK_MONTH_UNITS, 1); }
  344.                  else {
  345.                   filldisplay( 2, rtc_table[DS_ADDR_MONTH]>>4, 0);        // tenmonth ( &MASK_TENS useless, as MSB bits are read as '0')
  346.                   filldisplay( 3, rtc_table[DS_ADDR_MONTH]&DS_MASK_MONTH_UNITS, 0); }
  347.               }
  348.               if (!flash_23) {
  349.                  if (!CONF_SW_MMDD) {
  350.                   filldisplay( 2, rtc_table[DS_ADDR_DAY]>>4, 0);                      // tenday   ( &MASK_TENS useless)
  351.                   filldisplay( 3, rtc_table[DS_ADDR_DAY]&DS_MASK_DAY_UNITS, 0); }     // day
  352.                  else {
  353.                   filldisplay( 0, rtc_table[DS_ADDR_DAY]>>4, 0);                      // tenday   ( &MASK_TENS useless)
  354.                   filldisplay( 1, rtc_table[DS_ADDR_DAY]&DS_MASK_DAY_UNITS, 1); }     // day
  355.               }
  356.               break;
  357.
  358.           case M_WEEKDAY_DISP:
  359.               filldisplay( 1, LED_DASH, 0);
  360.               filldisplay( 2, rtc_table[DS_ADDR_WEEKDAY], 0);                //weekday ( &MASK_UNITS useless, all MSBs are '0')
  361.               filldisplay( 3, LED_DASH, 0);
  362.               break;
  363.
  364.           case M_TEMP_DISP:
  365.               filldisplay( 0, ds_int2bcd_tens(temp), 0);
  366.               filldisplay( 1, ds_int2bcd_ones(temp), 0);
  367.               filldisplay( 2, CONF_C_F ? LED_f : LED_c, 1);
  368.               // if (temp<0) filldisplay( 3, LED_DASH, 0);  -- temp defined as uint16, cannot be <0
  369.               break;
  370.           case M_DEBUG:
  371.               filldisplay( 0, switchcount[0]>>4, S1_LONG);
  372.               filldisplay( 1, switchcount[0]&15, S1_PRESSED);
  373.               filldisplay( 2, switchcount[1]>>4, S2_LONG);
  374.               filldisplay( 3, switchcount[1]&15, S2_PRESSED);
  375.               break;
  376.       }
  377.       __critical { updateTmpDisplay(); }
  378.
  379.       // save ram config
  380.       ds_ram_config_write();
  381.
  382.       if (S1_PRESSED || S2_PRESSED && ! (S1_LONG || S2_LONG)) {
  383.           // try to dampen button over-response
  384.           _delay_ms(100);
  385.       }
  386.       // reset long presses when button released
  387.       if (! S1_PRESSED && S1_LONG) {
  388.           S1_LONG = 0;
  389.       }
  390.       if (! S2_PRESSED && S2_LONG) {
  391.           S2_LONG = 0;
  392.       }
  393.
  394.       count++;
  395.       WDT_CLEAR();
  396.     }
  397. }
  398. /* ------------------------------------------------------------------------- */
https://github.com/zerog2k/stc_diyclock
ID:7485 發表于 2016-12-28 21:21
有電路圖就可以。要知道按鍵、顯示、蜂鳴器、ds1302各自對應的IO。
ID:113208 發表于 2016-12-28 21:02
這個要有電路圖呀!而且你跟他買,他應該會提供程序。
主站蜘蛛池模板: 成人在线一区二区 | 午夜在线视频观看 | 天堂av在线播放 | 伊人免费视频 | 一区二区水蜜桃 | 日韩在线视频免费观看 | 亚洲va视频| 国产免费久久 | 精品视频免费在线观看 | 国产三级在线免费观看 | 中文字幕一区二区在线播放 | 91在线 | 天天综合视频 | 婷婷综合 | 中文字幕一区二区三区四区视频 | 中文字幕av片 | 免费h片| 九九热这里 | 日韩精品在线免费观看 | 亚洲日本在线观看 | 中文字幕黄色 | 亚洲看片| 国产激情综合 | 日日夜夜天天 | 俺去俺来也在线www色官网 | 欧美久久久久久久久 | 亚洲天堂av网 | 国产一区在线视频 | 色综合久久久 | 午夜视频免费在线观看 | 一道本在线观看 | 国产精品区二区三区日本 | 九九视频免费观看 | 国产免费成人 | 久久久久久久久久国产 | 黄色一级免费看 | av在线一区二区 | 男女操操操 | 亚洲一级二级三级 | 国产成人综合视频 | 91视频免费在线观看 |
