小菜鳥(niǎo)第一次使用L298N驅(qū)動(dòng)模塊,求大神交我怎么連線?
查看數(shù): 4666 | 評(píng)論數(shù): 6 | 收藏 1
    組圖打開(kāi)中,請(qǐng)稍候......
發(fā)布時(shí)間: 2017-7-21 12:01
求大神指導(dǎo)下我的問(wèn)題,51單片機(jī)開(kāi)發(fā)板已經(jīng)和L298N驅(qū)動(dòng)模塊連接了,但我不知道是否正確,目前我只是控制了一個(gè)小的直流電機(jī),但是按下按鍵沒(méi)有反應(yīng),不清楚是程序還是原理圖出了問(wèn)題,求大神指教,非常感謝! 以下 ...
ID:221804 發(fā)表于 2017-7-23 17:55
注意和單片機(jī)共地
ID:221507 發(fā)表于 2017-7-23 09:45
前幾天剛做了一個(gè)
#include <reg52.h>
typedef unsigned char uchar;
typedef unsigned int  uint;
sbit shineng = P1^2;
sbit i0        = P1^0;
sbit i1        = P1^1;
sbit stop  = P3^4;
sbit fan     = P3^5;
sbit jia     = P3^7;
sbit jian      = P3^6;
sbit we=P2^7;
sbit du=P2^6;
static uchar c;
uchar th0=(65535-50000)/256;
uchar tl0=(65535-50000)%256;
code uchar disptab[]={0x3f,0x6,0x5b,0x4f,0x66,
0x6d,0x7d,0x27,0x7f,0x6f,0x77,0x7c,0x39,0x5e,
0x79,0x71,0x0};
code uchar dispbit[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf};
uchar dispbuf[6];
uchar speed = 0;
delayms(uint k);
PWM() ;
key();
delay1(uchar x);
Inittimer0();
void main(void)
        delayms(10);
        Inittimer0();
  while(1)
                key();
                PWM();
                if(speed<100)
                  dispbuf[5]=speed/20;
                else if(speed>=100)
                        dispbuf[5]=5;
delayms(uint k)
        uint a,s;
   for(a=k;a>0;a--)
       for(s=110;s>0;s--);
PWM()
  shineng=1;
  delayms(speed);
  shineng=0;
  delayms(100-speed);
key()
        if(stop==0)
                delayms(1);
                if(stop==0)
                        while(stop==0);
                        i0 = 0;
                        i1 = 0;
        if(fan==0)
                delayms(1);
                if(fan==0)
                        while(fan==0);
                        i0=~i1;
      i0=~i0;
                        i1=~i1;
        if(jia==0)              //??
                delayms(1);
                if(jia==0)
                        while(jia==0);
                                speed=speed+20;
                                if(speed >= 100)
                                        speed=100;
        if(jian==0)             //??
                delayms(1);
                if(jian==0)
                        while(jian==0);
                        if(speed != 0)
                                speed=speed-20;
                  else if(speed<=0)
                                speed=0;
delay1(uchar x)
        uint y;
        for(;x>0;x--)
                for(y=100;y>0;y--);
timer0() interrupt 1
        static uchar count=0;
        uchar tmp;
        P0|=0x3f;
        we=1;
        tmp=dispbit[count];
        P0=P0&tmp;
        we=0;
  P0=disptab[16];
        du=1;
        tmp=dispbuf[count];
        tmp=disptab[tmp];
    P0=tmp;
        du=0;
        count++;
        if(count==6)
                count=0;
        TH0=th0;
        TL0=tl0;
Inittimer0()
        TMOD=0x02;
        TH0=th0;
        TL0=tl0;
        EA=1;
        ET0=1;
        TR0=1;
ID:164602 發(fā)表于 2017-7-22 08:48
看我給你的圖。
要注意的是:5V是輸出,供小車(chē)上的單片機(jī)用電。看你的圖,是不需要的。
ID:34643 發(fā)表于 2017-7-22 06:32
你這程序怎么前面都加了“//”,還能編譯不?
ID:150593 發(fā)表于 2017-7-21 15:59
ENA端為0停止,讓P1.0輸出低電平停止
ID:169394 發(fā)表于 2017-7-21 14:09
按照以上的連接正反轉(zhuǎn)能夠?qū)崿F(xiàn)了,但是停止實(shí)現(xiàn)不了,求大神指教!
主站蜘蛛池模板: 黄色一级视频网站 | 黄视频免费观看 | 日韩精品一级 | 人人看人人爱 | 精品一区二区在线播放 | 99福利视频 | 色综合88 | 久久久97 | 青青草综合网 | 欧美精品一区在线 | 日本男人的天堂 | 久久久久成人网 | 日韩av高清在线观看 | 四虎影音 | 亚洲黄色免费 | 久久亚洲免费视频 | 精品一区二区三区四区五区 | 夜夜操天天 | 免费在线观看av | 国产精品入口夜色视频大尺度 | 精品欧美黑人一区二区三区 | 欧美成人精品激情在线观看 | 中文字幕一区在线观看 | 欧美国产一区二区 | 成人一级视频 | 亚洲成人av在线 | 国产精品欧美日韩 | 中文字幕无人区二 | 午夜精品视频 | 狠狠干免费视频 | 免费在线观看黄色片 | 国产aa视频| 91网站在线免费观看 | 98国产精品 | 在线观看黄色小视频 | 久久精品99| 男女av在线 | 激情五月综合网 | 欧美在线一区二区 | 91亚洲国产成人久久精品网站 | 久久精品欧美一区二区三区不卡 |
