查看: 3808|回復: 1
藍牙遙控測距滅火車單片機源程序
ID:253933 發表于 2017-12-4 22:09 | 顯示全部樓層 |閱讀模式
學校比賽的時候和同學一塊做了一個藍牙遙控測距滅火車。
可以藍牙遙控并進行測距
  1.
  2. /*************************************************************************/
  3. #include "reg52.h"
  5. #define uint unsigned int
  6. #define ulong unsigned long
  7. #define LCD_data P0
  8. sbit LCD_RS=P2^6;//................................
  9. sbit LCD_RW=P2^5;
  10. sbit LCD_EN=P2^4;
  11. sbit LCD_PSB=P2^7;
  12. sbit Trig = P3^3;//................................
  13. sbit Echo = P3^2;
  14. sbit Beep=P3^4;//...................................蜂鳴器端口
  15. sbit huoyan=P3^5;//.................................光照傳感器端口
  16. sbit Fan=P3^6;//....................................風扇端口
  17. sbit PWM1= P1^1;//..................................
  18. sbit Photosensitive_resistor = P3^7;//..............
  19. sbit led = P1^0;
  20. sbit motor_control_1 = P1^2;
  21. sbit motor_control_2 = P1^3;
  22. sbit motor_control_4 = P1^4;
  23. sbit motor_control_3 = P1^5;
  24. sbit PWM2 = P1^6;
  25. sfr T2MOD = 0xC9;//.................................定時器2模式控制寄存器
  26. unsigned char ucBluetoothData = 230;//..............
  27. unsigned char ucLock = 0;//.........................
  28. unsigned int uiPWMCnt1 = 0;
  29. unsigned int uiPWM1 = 230;
  30. unsigned int uiPWMCnt2 = 0;
  31. unsigned int uiPWM2 = 230;
  32. unsigned char ucTempPWM;//.......................
  33. bit flag;
  34. uchar outcomeL , outcomeH;
  35. uint num,a;
  36. uint distance_data;
  37. uchar code dis1[] = {"  功能小車  "};
  38. uchar code dis2[] = {"  誤差范圍4mm -4m"};
  39. uchar code dis3[] = {"   距離:"};
  40. uchar code dis4[] = {"   單位:mm"};
  41. uchar code dis5[] = {"  危險!!"};
  42. uchar code dis6[] = {"  安全"};
  43. void initial_myself();
  44. void initial_peripheral();//........................
  45. void T0_time();
  46. void usart_service(void);//.........................通用同步異步收發機服務
  47. void delay_long(unsigned int uiDelayLong);
  48. void go_forward(void);//............................前進
  49. void fall_back(void);//.............................后退
  50. void turn_left(void);//.............................左轉
  51. void turn_right(void);//............................右轉
  52. void stop();//......................................剎車
  53. void lcd_init();//..................................
  54. void fire_alarm();//................................
  55. void display();//...................................
  56. void Ultrasonic_ranging ();//.......................
  57. void Photosensitive ();//...........................
  58. void main()
  59. {
  60.         TMOD = 0x01;
  61.
  62.         IT0 = 0;
  63.
  64.         EX0 = 0;
  65.
  66.         lcd_init() ;
  67.
  68.         Trig = 0;
  69.
  70.         initial_myself();
  71.
  72.         delay_long(100);
  73.
  74.         initial_peripheral();
  75.
  76.         while(1)
  77.       {
  78.                           fire_alarm();
  79.
  80.                         Photosensitive ();
  81.                         display();
  82.
  83.                         usart_service();
  84.
  85.                         Ultrasonic_ranging () ;
  86.
  87.
  88.       }
  89. }
  90. void delay(uint z)//...............................延時函數
  91. {
  92.         uchar i, j ;
  93.         for( i = z ; i > 0 ; i-- )
  94.         for( j = 110 ; j > 0 ; j-- );
  95. }
  96. void fire_alarm ()//................................火災報警處理系統
  97.   {
  98.     if( huoyan == 0)
  99.     {
  100.                   Beep = 0;
  101.
  102.                   Fan = 0;
  103.         }
  104.                      if( huoyan == 1 )
  105.             {
  106.                                   Beep = 1;
  107.
  108.                                 Fan = 1;
  109.             }
  110.   }
  111. void Photosensitive ()
  112.         {
  113.                 if(Photosensitive_resistor == 0)
  114.                         {
  115.                                 led = 1;
  116.                         }
  117.                 if(Photosensitive_resistor == 1)
  118.                         {
  119.                                 led = 0;
  120.                         }
  121.         }
  122. void write_cmd(uchar cmd)
  123. {
  124.         LCD_RS = 0;
  125.         LCD_RW = 0;
  126.         LCD_EN = 0;
  127.         P0 = cmd;
  128.         delay(1);
  129.         LCD_EN = 1;
  130.         delay(1);
  131.         LCD_EN = 0;
  132. }
  133. void write_dat(uchar dat)
  134. {
  135.         LCD_RS = 1;
  136.         LCD_RW = 0;
  137.         LCD_EN = 0;
  138.         P0 = dat;
  139.         delay(1);
  140.         LCD_EN = 1;
  141.         delay(1);
  142.         LCD_EN = 0;
  143. }
  144. void lcd_init()//
  145. {
  146.         LCD_PSB = 1;
  147.         write_cmd(0x30);
  148.         delay(1);
  149.         write_cmd(0x30);
  150.         delay(1);
  151.         write_cmd(0x0c);
  152.         delay(1);
  153.         write_cmd(0x01);
  154.         delay(1);
  155. }
  156. void usart_service()
  157. {
  158.         switch(ucBluetoothData)
  159.             {
  160.                          case 0x41://........................前進
  161.
  162.                                 ucBluetoothData = 0x02;//避免一直觸發
  163.
  164.                                 go_forward();
  165.
  166.                             ucLock = 1;
  167.
  168.                                     uiPWM1 = uiPWM2 = ucTempPWM;
  169.
  170.                             ucLock = 0;
  171.
  172.                             break;
  173.
  174.                 case 0x43://........................左轉
  175.
  176.                                     ucBluetoothData = 0x02;
  177.
  178.                                 turn_left();
  179.
  180.                             ucLock = 1;
  181.
  182.                                     uiPWM2 = ucTempPWM / 2;
  183.
  184.                                 uiPWM1 = ucTempPWM;
  185.
  186.                             ucLock = 0;
  187.
  188.                                 break;
  189.
  190.                 case 0x47://........................右轉
  191.
  192.                             ucBluetoothData = 0x02;
  193.
  194.                                         turn_right();
  195.
  196.                                             ucLock = 1;
  197.
  198.                                             uiPWM2 = ucTempPWM;
  199.
  200.                                             uiPWM1 = ucTempPWM / 2;
  201.
  202.                                         ucLock = 0;
  203.
  204.                                     break;
  205.
  206.                       case 0x45://......................后退
  207.
  208.                                         ucBluetoothData = 0x02;
  209.
  210.                                         fall_back();
  211.
  212.
  213.
  214. ……………………
  215. …………限于本文篇幅 余下代碼請從51黑下載附件…………
qqq.zip (48.19 KB, 下載次數: 15)
ID:243549 發表于 2017-12-12 12:40 來自觸屏版 | 顯示全部樓層
這個滅火是什么模塊呢?
主站蜘蛛池模板: 免费黄网站在线观看 | 国产成人精品视频 | 欧美资源在线 | 闷骚老干部cao个爽 欧美区一区二 | 超碰com| 亚洲在线免费观看 | av中文网| 国产伦精品一区二区三毛 | 色婷婷av一区二区三区之e本道 | 日韩在线观看中文字幕 | 国产三级在线观看视频 | 日韩国产精品视频 | 日本a在线观看 | 2017天天干 | 一级免费看 | 久久er99热精品一区二区 | 久久久久久久影院 | 国产一区二区三区免费视频 | 国产精品www | 高清免费av | 在线h片| 免费一级黄色 | 黄色免费网站 | 黄色片视频免费 | av超碰在线 | 亚洲免费播放 | 在线观看欧美日韩 | 国产成年妇视频 | 日本一区二区不卡 | 亚洲欧美在线视频 | 午夜看看 | 中文字幕一区二区三区在线观看 | 国产草草影院 | 欧美色图一区二区三区 | 亚洲精品91天天久久人人 | 三级av片| 超碰在线观看免费版 | 国产精品久久一区二区三区 | 欧美激情一区二区 | av福利在线 | 国产传媒一区二区 |
