查看: 5002|回復: 2
基于51單片機的簡易計算器帶PCB文件與原理圖
ID:260392 發表于 2017-12-13 16:29 | 顯示全部樓層 |閱讀模式
Altium Designer畫的單片機計算器原理圖和PCB圖如下:(51hei附件中可下載工程文件)
  1. #include<reg52.h>
  2. #include<stdio.h>
  3. #include<string.h>
  4. #include<math.h>
  5. #define PI        3.1415926
  6. #define uint unsigned int
  7. #define uchar unsigned char
  8. #define ulong        unsigned long
  9. uchar table[20]="";
  10. float a=0;
  11. sbit dula=P2^6;
  12. sbit wela=P2^7;
  13. sbit lcden=P2^5;
  14. sbit lcdrs=P1^0;
  15. sbit ledrw=P1^1;
  16. sbit k1=P1^4;
  17. sbit k2=P1^5;
  18. sbit k3=P1^6;
  19. sbit k4=P1^7;
  20. uchar shift;//shift鍵
  21. uchar saojiao;//三角函數flag   sin 1,cox 2,tan 3,asin 4,acos 5,atan 6
  22. int flag1=0; //判斷是否之前輸出了等號,繼續計算改為第一行
  23. uchar num;
  24. uint t=0;
  25. uchar temp;
  26. float p=0.1;
  27. int q=0;
  28. //int o;          判斷等號運算后是否為整數
  29. //float p;    判斷等號運算后是否為整數
  30. void keyscan();
  31. void dulianjian();
  32. void delay(uint z)
  33. {
  34.         uint x,y;
  35.         for(x=z;x>0;x--)
  36.                 for(y=110;y>0;y--);
  37. }
  38. void write_com(uchar com)
  39. {
  40.         lcdrs=0;
  41.         P0=com;
  42.         delay(5);
  43.         lcden=1;
  44.         delay(5);
  45.         lcden=0;
  46. }
  47. void write_data(uchar date)
  48. {
  49.         lcdrs=1;
  50.         P0=date;
  51.         delay(5);
  52.         lcden=1;
  53.         delay(5);
  54.         lcden=0;
  55. }
  56. void init()
  57. {
  58.         ledrw=0;
  59.         dula=0;
  60.         wela=0;
  61.         lcden=0;
  62.         write_com(0x38);
  63.         write_com(0x0e);
  64.         write_com(0x06);
  65.         write_com(0x01);
  66. }
  67. void main()
  68. {
  69.                         init();
  70.     while(1)
  71.         {
  72.                         keyscan();
  73.                         dulianjian();
  74.         }
  75. }
  76. void dulianjian()
  77. {
  78.                 if(k1==0)
  79.                 {
  80.                         delay(20);                 //消抖
  81.                         if(k1==0)
  82.                         {
  83.                           while(!k1);
  84.                           if(shift==0)
  85.                           {
  86.                                 saojiao=1;
  87.                                 write_data('s');q++;if(q>16)write_com(0x18);
  88.                                 write_data('i');q++;if(q>16)write_com(0x18);
  89.                                 write_data('n');q++;if(q>16)write_com(0x18);
  90.                           }
  91.                           if(shift==1)
  92.                           {
  93.                                 saojiao=4;
  94.                                 write_data('a');q++;if(q>16)write_com(0x18);
  95.                                 write_data('s');q++;if(q>16)write_com(0x18);
  96.                                 write_data('i');q++;if(q>16)write_com(0x18);
  97.                                 write_data('n');q++;if(q>16)write_com(0x18);
  98.                                 shift=0;
  99.                           }
  100.                         }
  101.                 }
  102.                 if(k2==0)
  103.                 {
  104.                         delay(20);                 //消抖
  105.                         if(k2==0)
  106.                         {
  107.                           while(!k2);
  108.                            if(shift==0)
  109.                           {
  110.                                 saojiao=2;
  111.                                 write_data('c');q++;if(q>16)write_com(0x18);
  112.                                 write_data('o');q++;if(q>16)write_com(0x18);
  113.                                 write_data('s');q++;if(q>16)write_com(0x18);
  114.                           }
  115.                           if(shift==1)
  116.                           {
  117.                                 saojiao=5;
  118.                                 write_data('a');q++;if(q>16)write_com(0x18);
  119.                                 write_data('c');q++;if(q>16)write_com(0x18);
  120.                                 write_data('o');q++;if(q>16)write_com(0x18);
  121.                                 write_data('s');q++;if(q>16)write_com(0x18);
  122.                                 shift=0;
  123.                           }
  124.
  125.                         }
  126.                 }
  127.                 if(k3==0)
  128.                 {
  129.                         delay(20);                 //消抖
  130.                         if(k3==0)
  131.                         {
  132.                           while(!k3);
  133.                            if(shift==0)
  134.                           {
  135.                                 saojiao=3;
  136.                                 write_data('t');q++;if(q>16)write_com(0x18);
  137.                                 write_data('a');q++;if(q>16)write_com(0x18);
  138.                                 write_data('n');q++;if(q>16)write_com(0x18);
  139.                           }
  140.                           if(shift==1)
  141.                           {
  142.                                 saojiao=6;
  143.                                 write_data('a');q++;if(q>16)write_com(0x18);
  144.                                 write_data('t');q++;if(q>16)write_com(0x18);
  145.                                 write_data('a');q++;if(q>16)write_com(0x18);
  146.                                 write_data('n');q++;if(q>16)write_com(0x18);
  147.                                 shift=0;
  148.                           }
  149.                         }
  150.                 }
  151.                 if(k4==0)
  152.                 {
  153.                         delay(20);                 //消抖
  154.                         if(k4==0)
  155.                         {
  156.                           while(!k4);
  157.                                 shift=1;
  158.                         }
  159.                 }
  160. }
  161. void keyscan()
  162. {
  163. char size;
  164. float shu_1,shu_2;
  165. uint num;
  166. uchar m;
  167.                         P3=0xfe;
  168.                         temp=P3;
  169.                         temp=temp&0xf0;
  170.                         while(temp!=0xf0)
  171.                                 {
  172.                                         delay(5);
  173.                                         temp=P3;
  174.                                         temp=temp&0xf0;
  175.                                         while(temp!=0xf0)
  176.                                         {
  177.                                                 temp=P3;
  178.                                         switch(temp)
  179.                                                 {
  180.                                                         case 0xee:num=1;write_data('1');q++;if(q>16)write_com(0x18);
  181.        break;
  182.                                                         case 0xde:num=2; write_data('2');q++;if(q>16)write_com(0x18);
  183.        break;
  184.                                                         case 0xbe:num=3; write_data('3');q++;if(q>16)write_com(0x18);
  185.        break;
  186.                                                         case 0x7e: num=11;;
  187.                                                         if(flag1==1){
  188.        init();flag1=0;q=strlen(table);for(num=0;table[num]!='\0';num++)
  189.        {
  190.        write_data(table[num]);
  191.        delay(5);
  192.        }
  193.        }
  194.        write_data('+'); p=0.1;m=0;q++;if(q>16)write_com(0x18);
  195.        {
  196.        t++;
  197.        if(t==1&&saojiao==0)shu_1=a;
  198.        if(t>=2&&saojiao==0)
  199.        {
  200.        if(size=='+')shu_1+=a;
  201.        if(size=='-')shu_1-=a;
  202.        if(size=='*')shu_1*=a;
  203.        if(size=='/')shu_1/=a;
  204.        }
  205.        if(saojiao==1)
  206.        {
  207.        shu_1=sin(a*(2*PI/360));
  208.        saojiao=0;
  209.        }
  210.        if(saojiao==2)
  211.        {
  212.        shu_1=cos(a*(2*PI/360));
  213.        saojiao=0;
  214.        }
  215.        if(saojiao==3)
  216.        {
  217.        shu_1=tan(a*(2*PI/360));
  218.        saojiao=0;
  219.        }
  220.        if(saojiao==4)
  221.        {
  222.
  223. ……………………
  224. …………限于本文篇幅 余下代碼請從51黑下載附件…………
計算器PCB最終.rar (1006.77 KB, 下載次數: 60)
計算器實驗程序.zip (58.02 KB, 下載次數: 29)
ID:274291 發表于 2018-1-15 10:03 | 顯示全部樓層
你好,可以私聊發我一份么?VX425683638
ID:649892 發表于 2019-11-26 14:10 | 顯示全部樓層
有仿真圖嗎
主站蜘蛛池模板: 免费视频国产 | 无套内谢的新婚少妇国语播放 | 四虎影院免费观看 | 91午夜精品亚洲一区二区三区 | 亚洲另类视频 | 96看片 | 在线网站免费观看18 | 夜夜嗨av一区二区三区网页 | 国产精品一区二区三区在线 | 欧美黄色免费网站 | 亚洲精品在线看 | 麻豆精品久久 | 91成人免费 | 中文字幕不卡视频 | 一区二区在线看 | 波多野结衣av在线播放 | 亚洲a在线观看 | 巨骚综合 | 国产一区精品视频 | 久精品视频 | 超碰在线观看免费版 | 亚洲人成免费 | 中文字幕一二区 | 在线观看视频一区二区 | av看片| 一级片毛片 | 黄色片免费在线观看 | 毛片网站视频 | 欧美一级特黄aa大片 | 性色av一区二区 | 91av视频在线观看 | 久久高清免费视频 | 黄色一级大片在线免费看国产一 | 久久久久性| 亚洲精品xxx | 国产91免费视频 | 美女免费网站 | 精品日韩av | 久久九 | 精品视频在线观看免费 | 高清免费视频日本 |
