查看: 8510|回復: 1
利用舵機制作簡單機械臂
ID:162561 發表于 2017-12-13 17:03 | 顯示全部樓層 |閱讀模式
**項目名稱:利用舵機制作簡單機械臂
**編寫時間:2017.07.11
**使用芯片:stc12c2052ad
**時鐘頻率:使用外部晶振頻率12MHz
**簡要說明:本次制作的機械臂共用了3個舵機,可以控制機械臂上下、左右移動和抓放動作。
#include <stc12c2052ad.h>
#include <intrins.h>
typedef unsigned char u8;
typedef unsigned short int u16;
sbit CTRL_u_d = P3^3;                                                //控制上、下方向的舵機控制端口
sbit CTRL_l_r = P3^4;                                                //控制左、右方向的舵機控制端口
sbit CTRL_g = P3^5;                                                        //控制抓起的舵機控制端口
void delay_20ms(u16 x);
u8 KeyScan();
u16 TIME = 20000;        //PWM周期時間(單位us)
u16 Min = 700;        //高電平最小持續時間
u16 Max = 2300;        //高電平最大持續時間
u8 Degree = 50;        //單位時間寬度(最小是舵機死區設定大約10us)
u16 Times = 0;        //TIME/Degree(PWM周期除于單位時間寬度)
//高電平持續時間除于單位時間寬度
u16 cTimes_u_d = 0;
u8 cTimes_l_r = 0;
u8 cTimes_g = 0;
u8 Min_cTimes = 0;
u8 Max_cTimes = 0;
u8 R_TH0 = 0, R_TL0 = 0;                                //定時器0計數重載值
u8 KeyValue = 0;        //1-上、2-左、3-抓、4-右、5-下
        Times = TIME/Degree;
        cTimes_u_d = 1500/Degree;
        cTimes_l_r = 1500/Degree;
        cTimes_g = Min_cTimes;
        Min_cTimes = Min/Degree;
        Max_cTimes = Max/Degree;
        P1 = 0xff;
        CTRL_u_d = 0;
        CTRL_l_r = 0;
        CTRL_g = 0;
        R_TL0 = 65536 - Degree;
        R_TH0 = (65536 - Degree) >> 8;
        //設置定時器0
        TMOD = 0x01;        //16位計數
        TL0 = R_TL0;
        TH0 = R_TH0;
        ET0 = 1;        //定時器0中斷開關打開
        TR0 = 1;        //定時器0計數開始
        EA = 1;        //中斷總開關打開
                u8 temp = 0;
                KeyValue = KeyScan();
                switch(KeyValue)
                        case 1:        //向上移動
                                cTimes_u_d = --cTimes_u_d < Min_cTimes ? Min_cTimes : cTimes_u_d;
                                break;
                        case 2:        //向左移動
                                cTimes_l_r = --cTimes_l_r < Min_cTimes ? Min_cTimes : cTimes_l_r;
                                break;
                        case 3:        //抓、放動作
                                if(cTimes_g == Min_cTimes)
                                        cTimes_g = Max_cTimes;
                                delay_20ms(15);
                                break;
                        case 4:        //向右移動
                                cTimes_l_r = ++cTimes_l_r > Max_cTimes ? Max_cTimes : cTimes_l_r;
                                break;
                        case 5:        //向下移動
                                cTimes_u_d = ++cTimes_u_d > Max_cTimes ? Max_cTimes : cTimes_u_d;
                                break;
u8 KeyScan()
        u8 key = 0;
        if(P1 != 0xff)
                delay_20ms(2);
                if(P1 != 0xff)
                        u8 temp  = P1;
                        key = 1;
                        while(temp & 0x01)
                                temp = temp >> 1;
                                key++;
        return key;
void Delay20ms()                //@12.000MHz
        unsigned char i, j, k;
        _nop_();
        _nop_();
        i = 1;
        j = 234;
        k = 113;
        do
                do
                        while (--k);
                } while (--j);
        } while (--i);
        while(x--)  Delay20ms();
//定時器0中斷函數   每次進入中斷間隔時間為Degree(單位時間寬度)
void timer0() interrupt 1 using 1
        static u16 times = 0;
        TL0 = R_TL0;
        TH0 = R_TH0;
        //每次只控制一個舵機移動
        if(times == 0)
                switch(KeyValue)
                        case 1:
                        case 5:
                                CTRL_u_d = 1;
                                CTRL_l_r = 0;
                                CTRL_g = 0;
                                break;
                        case 2:
                        case 4:
                                CTRL_u_d = 0;
                                CTRL_l_r = 1;
                                CTRL_g = 0;
                                break;
                        case 3:
                                CTRL_u_d = 0;
                                CTRL_l_r = 0;
                                CTRL_g = 1;
                                break;
                switch(KeyValue)
                        case 1:
                        case 5:
                                if(times >= cTimes_u_d)
                                        CTRL_u_d = 0;
                                break;
                        case 2:
                        case 4:
                                if(times >= cTimes_l_r)
                                        CTRL_l_r = 0;
                                break;
                        case 3:
                                if(times >= cTimes_g)
                                        CTRL_g = 0;
                                break;
        times = ++times >= Times ? 0 : times;
ID:253033 發表于 2018-3-9 23:24 | 顯示全部樓層
這個單用51單片機就可以實現嗎?
主站蜘蛛池模板: 中文字幕第5页 | 日韩城人网站 | 狠狠干在线视频 | 国产成人三级一区二区在线观看一 | 色婷婷影院 | 超碰在线人人 | 午夜久久久久久久 | 日韩在线视频免费 | 99视频在线精品免费观看2 | 美日韩一区二区三区 | 国产欧美日韩综合精品 | 波多野结衣乳巨码无在线观看 | 99久久久国产精品 | 亚洲欧美另类在线观看 | 福利小视频在线观看 | 欧美在线视频一区 | 日本一级一片免费视频 | 911亚洲精品 | 欧美视频亚洲视频 | 蜜臀av性久久久久av蜜臀妖精 | aaa国产精品| 在线视频黄 | 乳色吐息樱花 | 成人免费福利视频 | av黄色在线观看 | 黄色www. | 国产成人亚洲精品自产在线 | 男人天堂手机在线 | 中文字幕在线观看网址 | 久久香蕉国产 | 91丝袜一区在线观看 | 国产91在线播放 | 在线看的av | 日韩视频专区 | 日产av在线 | 亚洲无av在线中文字幕 | 久久国产精品免费视频 | 日韩中文字幕一区 | 午夜精品一区二区三区在线视频 | 日韩欧美一级 | 国产无精乱码一区二区三区 |
