查看: 6366|回復: 1
ST三軸gsensor傳感器LIS2DS12引腳圖與功能介紹及datasheet下載
ID:263059 發表于 2017-12-18 12:31 | 顯示全部樓層 |閱讀模式
供大家參考
LIS2DS12引腳圖:
LIS2DS12管腳功能介紹
Description
The LIS2DS12 is an ultra-low-power high-performance three-axis linear accelerometer belonging to the “pico” family which leverages on the robust and mature manufacturing processes already used for the production of micromachined accelerometers.
The LIS2DS12 has user-selectable full scales of 2g/4g/8g/16g and is capable of measuring accelerations with output data rates from 1 Hz to 6400 Hz.
The LIS2DS12 has an integrated 256-level first-in, first-out (FIFO) buffer allowing the user to store data in order to limit intervention by the host processor.
The embedded self-test capability allows the user to check the functioning of the sensor in the final application.
The LIS2DS12 has a dedicated internal engine architecture in order to process internally motion and acceleration detection including free-fall, wakeup, single and double-tap detection, activity-inactivity, portrait and landscape detection, step counter and step detection along with significant motion detection.
The LIS2DS12 is available in a small thin plastic land grid array package (LGA) and it is
guaranteed to operate over an extended temperature range from -40 °C to +85 °C.
完整的pdf格式datasheet文檔51黑下載地址:
LIS2DS12.pdf (1.3 MB, 下載次數: 27)
ID:385811 發表于 2021-5-20 09:37 | 顯示全部樓層
資料是英文原版
主站蜘蛛池模板: 亚洲高清毛片一区二区 | av狠狠干 | 激情综合五月婷婷 | 九九久久久 | 日韩欧美三级 | 国内精品视频在线观看 | 一区二区三区影院 | 精品欧美黑人一区二区三区 | 国产精品入口夜色视频大尺度 | 欧美资源在线 | 日韩欧美视频一区 | 午夜精品久久久久久久99 | 免费性网站 | 国产在线黄色 | 69视频网站 | 黄色福利视频 | 亚洲一区二区三区视频 | 日韩中文字幕第一页 | 99热99re6国产在线播放 | 欧洲精品一区二区 | 五月伊人网 | 国产一级免费视频 | 久久免费看视频 | 中文日韩欧美 | 黄视频免费看网站 | 成人在线免费观看网站 | 韩国三级影院 | 九色在线视频 | 久久久亚洲天堂 | 成人三级视频在线观看 | 69国产精品| 中文字幕亚洲欧美 | 草少妇 | 人成在线 | 欧美老少妇 | 蜜桃久久久 | 国产一级特黄 | 午夜性色 | 亚洲性视频 | 伊人久久在线 | 一区二区三区蜜桃 |
