查看: 4403|回復: 3
ardiuno的電機正反轉
ID:236761 發表于 2017-12-23 14:04 | 顯示全部樓層 |閱讀模式
  1. //定義引腳
  2. int Pin0 = 8;
  3. int Pin1 = 9;
  4. int Pin2 = 10;
  5. int Pin3 = 11;
  6. int _step = 0;
  7. boolean dir = false;//正反轉
  8. int stepperSpeed = 1;//電機轉速,1ms一步
  9. //脈沖總數,或者說步的總數
  10. int stepsum=0;
  11. void setup()
  12. {
  13.   pinMode(Pin0, OUTPUT);
  14.   pinMode(Pin1, OUTPUT);
  15.   pinMode(Pin2, OUTPUT);
  16.   pinMode(Pin3, OUTPUT); }
  17. void loop()
  18. {
  19. //進步機的驅動方式,有八種
  20. switch(_step){
  21.     case 0:
  22.       digitalWrite(Pin0, LOW);
  23.       digitalWrite(Pin1, LOW);
  24.       digitalWrite(Pin2, LOW);
  25.       digitalWrite(Pin3, HIGH);
  26.     break;
  27.     case 1:
  28.       digitalWrite(Pin0, LOW);
  29.       digitalWrite(Pin1, LOW);
  30.       digitalWrite(Pin2, HIGH);
  31.       digitalWrite(Pin3, HIGH);
  32.     break;
  33.     case 2:
  34.       digitalWrite(Pin0, LOW);
  35.       digitalWrite(Pin1, LOW);
  36.       digitalWrite(Pin2, HIGH);
  37.       digitalWrite(Pin3, LOW);
  38.     break;
  39.     case 3:
  40.       digitalWrite(Pin0, LOW);
  41.       digitalWrite(Pin1, HIGH);
  42.       digitalWrite(Pin2, HIGH);
  43.       digitalWrite(Pin3, LOW);
  44.     break;
  45.     case 4:
  46.       digitalWrite(Pin0, LOW);
  47.       digitalWrite(Pin1, HIGH);
  48.       digitalWrite(Pin2, LOW);
  49.       digitalWrite(Pin3, LOW);
  50.     break;
  51.     case 5:
  52.       digitalWrite(Pin0, HIGH);
  53.       digitalWrite(Pin1, HIGH);
  54.       digitalWrite(Pin2, LOW);
  55.       digitalWrite(Pin3, LOW);
  56.       break;
  57.       case 6:
  58.       digitalWrite(Pin0, HIGH);
  59.       digitalWrite(Pin1, LOW);
  60.       digitalWrite(Pin2, LOW);
  61.       digitalWrite(Pin3, LOW);
  62.     break;
  63.     case 7:
  64.       digitalWrite(Pin0, HIGH);
  65.       digitalWrite(Pin1, LOW);
  66.       digitalWrite(Pin2, LOW);
  67.       digitalWrite(Pin3, HIGH);
  68.     break;
  69.     default:
  70.       digitalWrite(Pin0, LOW);
  71.       digitalWrite(Pin1, LOW);
  72.       digitalWrite(Pin2, LOW);
  73.       digitalWrite(Pin3, LOW);
  74.     break;
  75.   }
  76. //判斷是正轉還是反轉
  77.   if(dir)
  78.   {
  79.     _step++;
  80.   }else{
  81.     _step--;
  82.   }
  83. //每八步一個驅動方式的循環
  84.   if(_step>7){
  85.
  86.     _step=0;
  87.   }
  88.   if(_step<0){
  89.
  90.     _step=7;
  91.   }
  92.
  93.   delay(stepperSpeed);
  94. //計算脈沖數,每4096個脈沖停1秒
  95.   stepsum++;
  96.   if(stepsum==4096)
  97.   {
  98.     Serial.println(stepsum);
  99.     stepsum=0;
  100.     delay(1000);
  101.   }
  102. }
用ardiuno實現的電機正反轉
正反轉.doc
18 KB, 下載次數: 18, 下載積分: 黑幣 -5
如題
參與人數 1黑幣 +4 收起 理由
QIUYUQINGH + 4 贊一個!
ID:270560 發表于 2018-1-3 09:03 | 顯示全部樓層
很有用,學習了
ID:429997 發表于 2018-11-20 16:29 | 顯示全部樓層
很有用,學習了。
ID:430734 發表于 2018-11-21 18:47 | 顯示全部樓層
很有用,學習了!
主站蜘蛛池模板: 夜夜骑夜夜操 | 黄色片网站在线观看 | 亚洲午夜18毛片在线看 | 欧美黄色一区 | 99久久99| 无遮挡毛片| 国产区视频在线观看 | 成年人免费在线视频 | 四虎网站| 国产对白videos麻豆高潮 | 亚洲精品免费观看 | 在线免费观看黄色片 | 国产天堂在线观看 | 亚洲成人精品视频 | 色综合久久综合 | 青青青草视频 | 黄色大片免费在线观看 | 福利网站在线观看 | 国产精品成人免费视频 | 成年视频在线观看 | www.亚洲天堂 | 天天澡天天狠天天天做 | 国产精品尤物 | 人人草人人爽 | 午夜快播 | 在线中文字幕av | 国产在线观看一区 | 成人精品免费视频 | 黄色av免费看 | 成人涩涩视频 | 成人国产精品免费观看 | 自拍偷拍中文字幕 | 免费的毛片| 精品欧美一区二区精品久久 | 蜜臀久久99精品久久久久久宅男 | 国产一区二区在线观看视频 | 精品小视频 | 高潮一区二区三区乱码 | 午夜天堂av| 久草中文在线 | 欧美激情成人 |
