查看: 4352|回復(fù): 0
MEGA2560主控自行車騎行監(jiān)測器源碼
ID:266043 發(fā)表于 2017-12-24 15:20 | 顯示全部樓層 |閱讀模式
自行車騎行監(jiān)測器,可以GPS定位,檢測騎行速度,檢測心率,同時將以上數(shù)據(jù)寫入SD卡內(nèi)進行保存,使用MEGA2560主控
SD卡的SPI接口 ** MOSI - pin 51 ** MISO - pin 50 ** CLK  - pin 52 ** CS   - pin 53
GPS的串口使用mega2560的串口1  Serial 1: Pin19 (RX) and Pin18 (TX);Pin13接一個LED顯示GPS是否工作正常
兩個霍爾傳感器接在外部中斷  Pin2 (interrupt 0), Pin3 (interrupt 1)
心跳指示燈在 Pin5   int fadePin = 5
int blinkPin = 14;
  1. //#include"Arduino.h"
  2. //#include "AllSerialHanding.h"
  3. //#include "Interrupt.h"
  4. //#include "SD_ReadWrite.h"
  5. #include "all.h"
  6. #define PROCESSING_VISUALIZER 1
  7. #define SERIAL_PLOTTER  2
  8. volatile int BPM;                   // int that holds raw Analog in 0. updated every 2mS
  9. volatile int Signal;                // holds the incoming raw data
  10. volatile int IBI = 600;             // int that holds the time interval between beats! Must be seeded!
  11. static int outputType = SERIAL_PLOTTER;
  12. String beat_data = " BPM:0 IBI:0 Signal:0";
  13. void PulseSensor_SD_Write()
  14. {
  15.   SD_Write("test.txt",beat_data);  //脈沖數(shù)據(jù)寫入SD卡中PulseSensor.txt文件
  16. }
  17. //  Sends Data to Pulse Sensor Processing App, Native Mac App, or Third-party Serial Readers.
  18. void sendDataToSerial(char symbol, int data ){
  19.     Serial.print(symbol);
  20.     Serial.println(data);
  21.   }
  22. void serialOutput(){   // Decide How To Output Serial.
  23.
  24.   switch(outputType){
  25.     case PROCESSING_VISUALIZER:
  26.       sendDataToSerial('S', Signal);     // goes to sendDataToSerial function
  27.       break;
  28.     case SERIAL_PLOTTER:  // open the Arduino Serial Plotter to visualize these data
  29.       Serial.print(BPM);
  30.       Serial.print(",");
  31.       Serial.print(IBI);
  32.       Serial.print(",");
  33.       Serial.println(Signal);
  34.       beat_data=" BPM:"+String(BPM)+" IBI:"+String(IBI)+" Signal:"+String(Signal);
  35.
  36.       break;
  37.     default:
  38.       break;
  39.   }
  40. }
  41. //  Decides How To OutPut BPM and IBI Data
  42. void serialOutputWhenBeatHappens(){
  43.   switch(outputType){
  44.     case PROCESSING_VISUALIZER:    // find it here https://github.com/WorldFamousElectronics/PulseSensor_Amped_Processing_Visualizer
  45.       sendDataToSerial('B',BPM);   // send heart rate with a 'B' prefix
  46.       sendDataToSerial('Q',IBI);   // send time between beats with a 'Q' prefix
  47.       break;
  48.     default:
  49.       break;
  50.   }
  51. }
  52. // SET THE SERIAL OUTPUT TYPE TO YOUR NEEDS
  53. // PROCESSING_VISUALIZER works with Pulse Sensor Processing Visualizer
  54. //      https://github.com/WorldFamousElectronics/PulseSensor_Amped_Processing_Visualizer
  55. // SERIAL_PLOTTER outputs sensor data for viewing with the Arduino Serial Plotter
  56. //      run the Serial Plotter at 115200 baud: Tools/Serial Plotter or Command+L
  57. void ledFadeToBeat(){
  58.     fadeRate -= 15;                         //  set LED fade value
  59.     fadeRate = constrain(fadeRate,0,255);   //  keep LED fade value from going into negative numbers!
  60.     analogWrite(fadePin,fadeRate);          //  fade LED
  61.   }
  62. void Pulse_Init(){
  63.   pinMode(blinkPin,OUTPUT);         // pin that will blink to your heartbeat!
  64.   pinMode(fadePin,OUTPUT);          // pin that will fade to your heartbeat!
  65. //  Serial.begin(115200);             // we agree to talk fast!
  66.   interruptSetup();                 // sets up to read Pulse Sensor signal every 2mS
  67.    // IF YOU ARE POWERING The Pulse Sensor AT VOLTAGE LESS THAN THE BOARD VOLTAGE,
  68.    // UN-COMMENT THE NEXT LINE AND APPLY THAT VOLTAGE TO THE A-REF PIN
  69. //   analogReference(EXTERNAL);
  70. }
  71. //  Where the Magic Happens
  72. void Pulse_Allot(){
  73.     serialOutput() ;
  74.   if (QS == true){     // A Heartbeat Was Found
  75. ……………………
  76. …………限于本文篇幅 余下代碼請從51黑下載附件…………
自行車騎行監(jiān)測器.zip (11.53 KB, 下載次數(shù): 10)
主站蜘蛛池模板: 日本不卡视频 | 美日韩一区二区三区 | 黄色大片视频 | 天天操天天干天天操 | 在线一区视频 | 久久一级片 | 黄色小视频免费看 | 91禁蘑菇在线看 | 国产这里只有精品 | 日韩精品福利 | 午夜大片 | 特级毛片爽www免费版 | 日韩欧美视频在线 | 久久久久久久国产精品 | 在线播放中文字幕 | 成人黄色大片 | 岛国av免费观看 | www.久久久久| 神马午夜影院 | 亚洲成a人| 精品一区二区三区四区 | 久久少妇 | 亚洲国产三级 | 99视频在线精品免费观看2 | 国产香蕉在线 | 欧美黑人一区二区三区 | 国产永久在线 | 日韩欧美在线视频 | 精品福利一区 | 久久久久久一区二区 | 国产乡下妇女做爰视频 | 日本a v在线播放 | 黄色免费网站在线观看 | 国产精品自拍小视频 | 国产精品毛片久久久久久久 | www.狠狠操.com | 一区在线视频 | 欧美午夜精品一区二区三区 | 色激情网 | 在线观看h视频 | 一区在线播放 |
