籃球計分器(設(shè)計)仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
下載附件
2017-12-29 21:43 上傳
下載附件
2017-12-29 21:43 上傳
下載附件
2017-12-29 21:44 上傳
- #include<reg51.h>
- #define uint unsigned int
- #define uchar unsigned char
- uchar code table[]=".. Play ball! ....";
- uchar code table1[]="Welcome to here!" ;
- sbit key_ST=P1^5; //功能鍵(開始/暫停)
- sbit key_A1=P1^0; //功能鍵(A隊分數(shù)加1)
- sbit key_A2=P1^3; //功能鍵(A隊分數(shù)加2)
- sbit key_1A=P1^6; //功能鍵(A隊分數(shù)減1)
- sbit key_B1=P1^1; //功能鍵(B隊分數(shù)加1)
- sbit key_B2=P1^4; //功能鍵(B隊分數(shù)加2)
- sbit key_1B=P1^7; //功能鍵(B隊分數(shù)減1)
- sbit key_EX=P1^2; //功能鍵(交換場地,A/B兩隊分數(shù)交換)
- sbit key_JS=P3^0; //功能鍵(比賽節(jié)數(shù)加1)
- sbit FMQ=P3^3; //蜂鳴器
- sbit lcdrs=P3^5; //LCD顯示的數(shù)據(jù)/命令選擇端
- sbit lcden=P3^4; //LCD顯示的使能信號
- uchar flag,ms,mg,ss,sg,ags,agg,bgs,bgg,num,num1,num2,js=1,C,D,t,min=0,time_fmq;
- int sec=12;
- void delayms(uint xms)//定義延時函數(shù)
- uint i,j;
- for(i=xms;i>0;i--)
- for(j=110;j>0;j--);
- void write_data(uchar date)//定義為數(shù)據(jù)模式
- lcdrs=1;
- P0=date;
- delayms(5);
- lcden=1;
- delayms(5);
- lcden=0;
- void write_com(uchar com)//定義為命令模式
- lcdrs=0;
- P0=com;
- delayms(5);
- lcden=1;
- delayms(5);
- lcden=0;
- void lcd_init() //LCD顯示屏的初始化
- lcden=0;
- write_com(0x38);
- write_com(0x0c);
- write_com(0x06);
- write_com(0x01);
- void init() //LCD顯示屏的初始化2(即輸出“T-”、“Q-”、“A:”、“B:”)
- lcden=0;
- write_com(0x82);
- write_data('T');
- write_data('-');
- write_com(0x8a);
- write_data('Q');
- write_data('-');
- write_com(0x80+0x43);
- write_data('A');
- write_data(':');
- write_com(0x80+0x49);
- write_data('B');
- write_data(':');
- void init_start()//LCD顯示屏的初始化2(即輸出“T-”、“Q-”、“A:”、“B:”)
- lcden=0;
- write_com(0x80+0x10);
- for(num2=0;num2<16;num2++)
- write_data(table1[num2]);
- delayms(5);
- write_com(0x80+0x50);
- for(num2=0;num2<17;num2++)
- write_data(table[num2]);
- delayms(5);
- write_com(0x18);
- delayms(400);
- void display(uchar min,int sec,uchar C,uchar D,uchar js)//顯示函數(shù)
- ss=sec/10;
- sg=sec%10;
- ms=min/10;
- mg=min%10;
- ags=C/10;
- agg=C%10;
- bgs=D/10;
- bgg=D%10;
- write_com(0x84);
- write_data(0x30+ms);
- write_data(0x30+mg);
- write_data(':');
- write_data(0x30+ss);
- write_data(0x30+sg);
- write_com(0x8d-1);
- write_data(0x30+js);
- write_com(0x80+0x45);
- write_data(0x30+ags);
- write_data(0x30+agg);
- write_com(0x80+0x4b);
- write_data(0x30+bgs);
- write_data(0x30+bgg);
- void main()
- TMOD=0x11;//定義定時器0的工作方式為0001
- TH0=(65536-45872)/256;//裝初值
- TL0=(65536-45872)%256;
- TH1=(65536-45872)/256;//裝初值
- TL1=(65536-45872)%256;
- EA=1;//打開總中斷
- ET0=1;//打開定時器0的中斷
- TR0=0;
- ET1=1;
- TR1=0;
- lcd_init();
- init_start();
- while(1)
- TR1=0;
- if(key_ST==0)
- delayms(5);
- if(key_ST==0)
- FMQ=0;
- if(flag==0)
- lcd_init();
- init();
- flag=1;
- TR0=~TR0;
- while(!key_ST)
- display(min,sec,C,D,js);
- FMQ=1;
- if(key_A1==0)
- delayms(5);
- if(key_A1==0)
- FMQ=0;
- C++;
- while(!key_A1)
- FMQ=1;
- if(key_A2==0)
- delayms(5);
- if(key_A2==0)
- FMQ=0;
- C+=2;
- while(!key_A2)
- FMQ=1;
- if(key_1A==0)
- delayms(5);
- if(key_1A==0)
- FMQ=0;
- C--;
- while(!key_1A)
- FMQ=1;
- if(key_B1==0)
- delayms(5);
- if(key_B1==0)
- FMQ=0;
- D++;
- while(!key_B1)
- FMQ=1;
- if(key_B2==0)
- delayms(5);
- if(key_B2==0)
- FMQ=0;
- D+=2;
- while(!key_B2)
- FMQ=1;
- if(key_1B==0)
- delayms(5);
- if(key_1B==0)
- FMQ=0;
- D--;
- while(!key_1B)
- FMQ=1;
- while(min==0&&sec==0)
- TR0=0;
- TR1=1;
- if(key_ST==0)
- delayms(5);
- if(key_ST==0)
- FMQ=0;
- min=11;
- sec=60;
- TR0=~TR0;
- while(!key_ST)
- FMQ=1;
- if((key_EX==0)&&(js==2))
- delayms(10);
- if((key_EX==0)&&(js=2))
- FMQ=0;
- write_data('B');
- write_data('A');
- t=C;
- C=D;
- D=t;
- while(!key_EX)
- FMQ=1;
- if(key_JS==0)
- delayms(10);
- if(key_JS==0)
- FMQ=0;
- js++;
- while(!key_JS)
- FMQ=1;
籃球計分器.zip
(77.53 KB, 下載次數(shù): 132)
2017-12-29 09:42 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
