查看: 12414|回復(fù): 9
51單片機讀寫RC522卡(LCD12864)RFID開發(fā)程序與原理圖
ID:270195 發(fā)表于 2018-1-2 14:59 | 顯示全部樓層 |閱讀模式
RFID RC522程序及原理
  1. #include "reg52.h"
  2. #include "main.h"
  3. #include "mfrc522.h"
  4. #include "LCD12864.h"
  5. #include <string.h>
  6. #include <stdio.h>
  7. sbit BEEP=P0^1        ;
  8. #define SET_BEEP  BEEP = 0
  9. #define CLR_BEEP         BEEP = 1
  10. //M1卡的某一塊寫為如下格式,則該塊為錢包,可接收扣款和充值命令
  11. //4字節(jié)金額(低字節(jié)在前)+4字節(jié)金額取反+4字節(jié)金額+1字節(jié)塊地址+1字節(jié)塊地址取反+1字節(jié)塊地址+1字節(jié)塊地址取反
  12. unsigned char code data2[4]  = {0x12,0,0,0};
  13. unsigned char code DefaultKey[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
  14. //unsigned char g_ucTempbuf[20];
  15. unsigned char idata MLastSelectedSnr[4];
  16. unsigned char idata RevBuffer[30];
  17. //unsigned char data SerBuffer[20];
  18. bit CmdValid;
  19. unsigned char code ASCII_NUM[]={'0','1','2','3','4','5','6','7','8','9','A','B','C','D','E','F'};
  20. unsigned char idata LastKeyA[6]={0xFF,0xFF,0xFF,0xFF,0xFF,0xFF};//NO.2卡
  21. unsigned char idata NewKeyA[6]={0x19,0x84,0x07,0x15,0x76,0x14};//NO.2卡
  22. unsigned char idata NewKey[16]={0x19,0x84,0x07,0x15,0x76,0x14,
  23.                                 0xff,0x07,0x80,0x69,
  24.                                 0x19,0x84,0x07,0x15,0x76,0x14};
  25. unsigned char idata Read_Data[16]={0x00};
  26. //unsigned char idata RevBuffer[30];
  27. //unsigned char idata MLastSelectedSnr[4];
  28. unsigned char data OperationCard;
  29. uchar data bWarn,bPass;
  30. #define        REGCARD                        0xa1
  31. #define        CONSUME                        0xa2
  32. #define READCARD                0xa3
  33. #define ADDMONEY                0xa4
  34. void KeyScan(void)
  35. {
  36.                 if(REGCARDBTN == 0)//注冊
  37.                 {
  38.                                 delay_10ms(1);
  39.                                 if(REGCARDBTN == 0 )
  40.                                                 OperationCard = REGCARD;
  41.                                 LCD_PutString(0,3,"注冊:");
  42.                 }
  43.                 if(CONSUMEBTN == 0)//消費
  44.                 {
  45.                                 delay_10ms(1);
  46.                                 if(CONSUMEBTN == 0 )
  47.                                                 OperationCard = CONSUME;
  48.                                 LCD_PutString(0,3,"消費:      ");
  49.                 }
  50.                 if(ADDMONEYBTN == 0)//充值
  51.                 {
  52.                                 delay_10ms(1);
  53.                                 if(ADDMONEYBTN == 0 )
  54.                                                 OperationCard = ADDMONEY;
  55.                                 LCD_PutString(0,3,"充值:      ");
  56.                 }
  57.                 if(READCARDBTN == 0)//讀卡信息
  58.                 {
  59.                                 delay_10ms(1);
  60.                                 if(READCARDBTN == 0 )
  61.                                                 OperationCard = READCARD;
  62.                                 LCD_PutString(0,3,"查詢:      ");
  63.                 }
  64. }
  65. /*
  66. void delay(void)
  67. {
  68.         uint i ;
  69.         for(i=0;i++;i<100)
  70.         ;
  71. }
  72. void ShortBeep(void)
  73. {
  74.         uint i;
  75.         for(i=0;i<3;i++)
  76.         {
  77.                 SET_BEEP;
  78.                 delay_10ms(3);
  79.                 CLR_BEEP;
  80.                 delay();
  81.         }
  82. }
  83. void LongBeep(void)
  84. {
  85.         uint i;
  86.         for(i=0;i<20;i++)
  87.         {
  88.                 SET_BEEP;
  89.                 delay_10ms(5);
  90.                 CLR_BEEP;
  91.                 delay();
  92.         }
  93. }
  94. */
  95. void Warn(void)
  96. {
  97.   uchar data ii;
  98.   for(ii=0;ii<3;ii++)
  99.   {
  100.     SET_BEEP;//ShortBeep();如果是有源蜂鳴器就一句SET_BEEP就ok了
  101.     delay_10ms(5);
  102.     CLR_BEEP;
  103.     delay_10ms(5);
  104.   }
  105. }
  106. void Pass(void)
  107. {
  108.   SET_BEEP;//LongBeep();如果是有源蜂鳴器就一句SET_BEEP就ok了
  109.   delay_10ms(30);
  110.   CLR_BEEP;
  111. }
  112. void CtrlProcess(void)
  113. {
  114.         //        unsigned char idata Write_First_Data[16];
  115.           char string[]="           ";
  116.                 unsigned char idata Write_Consume_Data[16];
  117.
  118.                 signed long money_value;
  119.           float f_money_value;
  120.           unsigned char ii;
  121.           char status;
  122.           status=PcdRequest(PICC_REQIDL,&RevBuffer[0]);//尋天線區(qū)內(nèi)未進入休眠狀態(tài)的卡,返回卡片類型 2字節(jié)
  123.           if(status!=MI_OK)
  124.                           return;
  125.
  126.                 for(ii=0;ii<2;ii++)
  127.                 {
  128.                                 string[2*ii]   = ASCII_NUM[(RevBuffer[ii]>>4)&0x0f];
  129.                                 string[2*ii+1] = ASCII_NUM[RevBuffer[ii]&0x0f];
  130.                 }
  131.                 string[4] = '\0';
  132.                 LCD_PutString(3,1,string);//LCD顯示卡類型
  133.                 status=PcdAnticoll(&RevBuffer[2]);//防沖撞,返回卡的序列號 4字節(jié)
  134.
  135.                 if(status!=MI_OK)
  136.               return;
  137.           memcpy(MLastSelectedSnr,&RevBuffer[2],4);//4字節(jié)序列號 放到MLastSelectedSnr
  138.                 for(ii=0;ii<4;ii++)
  139.                 {
  140.                                 string[2*ii]   = ASCII_NUM[(MLastSelectedSnr[ii]>>4)&0x0f];
  141.                                 string[2*ii+1] = ASCII_NUM[MLastSelectedSnr[ii]&0x0f];
  142.                 }
  143.                 string[9] = '\0';
  144.                 LCD_PutString(3,2,string);// LCD顯示序列號
  145.
  146.           status=PcdSelect(MLastSelectedSnr);//選卡
  147.           if(status!=MI_OK)
  148.                     return;
  149.
  150.                 if(OperationCard==REGCARD)//注冊
  151.           {
  152.                     status=PcdAuthState(PICC_AUTHENT1A,7,LastKeyA,MLastSelectedSnr);//
  153.                     //DelayNS(1);
  154.                     if(status!=MI_OK)
  155.                     {
  156.                               bWarn=1;
  157.                               return;
  158.                     }
  159.                     status=PcdWrite(7,&NewKey[0]);
  160.
  161.                                 if(status!=MI_OK)
  162.                     {
  163.                               bWarn=1;
  164.                               return;
  165.                     }
  166.                     for(ii=0;ii<16;ii++)
  167.                     {
  168.                               Write_Consume_Data[ii]=0xaa;//Write_First_Data
  169.                     }
  170.                                 memset( Write_Consume_Data, 0, sizeof(Write_Consume_Data) );//Write_First_Data         Write_First_Data
  171.                                 money_value = 5000;
  172.                                 memcpy( Write_Consume_Data, ( uchar * )&money_value, 4 );        //Write_First_Data
  173.
  174.                                 status=PcdWrite(4,&Write_Consume_Data[0]);//Write_First_Data
  175.                     if(status!=MI_OK)
  176.                     {
  177.                               bWarn=1;
  178.                               return;
  179.                     }
  180.                                 LCD_PutString(0,3,"注冊: 成功");
  181.                     bPass=1;
  182.                     PcdHalt();
  183.                 }
  184.           else if(OperationCard==READCARD)//讀卡
  185.           {
  186.                     status=PcdAuthState(PICC_AUTHENT1A,7,NewKeyA,MLastSelectedSnr);//????KUAI4?
  187.
  188.                                 if(status!=MI_OK)
  189.                               return;
  190.
  191.                                 status=PcdRead(4,Read_Data);
  192.
  193.                                 if(status!=MI_OK)
  194.                     {
  195.                                                 bWarn=1;
  196.                               return;
  197.                     }
  198.                                 memcpy( (uchar *)&money_value, Read_Data, 4 );
  199.
  200.                                 LCD_PutString(0,3,"查詢:      ");
  201.                                 f_money_value = money_value * 1.0/100;
  202.                                 sprintf(string,"%5.2f",f_money_value);
  203.                                 LCD_PutString(3,4,string);
  204.                                 //ShowFloat816( 4, 5, ( f_money_value >= 0 ) ? ( ( f_money_value+0.5 )/100 ) : ( ( f_money_value-0.5 )/100 ) );
  205.                     if(f_money_value<0)
  206.                               bWarn=1;
  207.                     bPass=1;
  208.                     PcdHalt();
  209.                 }
  210.           else if(OperationCard==CONSUME)//消費
  211.           {
  212.                     status=PcdAuthState(PICC_AUTHENT1A,7,NewKeyA,MLastSelectedSnr);//
  213.
  214.                                 if(status!=MI_OK)
  215.                               return;
  216.
  217.                                 status=PcdRead(4,Read_Data);
  218.                     if(status!=MI_OK)
  219.                     {
  220.                               bWarn=1;
  221.                               return;
  222.                     }
  223.                     memcpy( (uchar *)&money_value, Read_Data, 4 );
  224.                     if(money_value<-10000)
  225.                               money_value=-10000;
  226.                     if(money_value<0)
  227.                               money_value+=10000;
  228.                     money_value=money_value-258;
  229.                                 memcpy( Write_Consume_Data, (uchar *)&money_value, 4 );
  230.                     status=PcdWrite(4,&Write_Consume_Data[0]);
  231.
  232.                     if(status!=MI_OK)
  233.                     {
  234.                               bWarn=1;
  235.                               return;
  236.                     }
  237.                                 //ShowFloat816(2,5,2.58);
  238.                                 LCD_PutString(0,3,"消費: 2.58   ");
  239.                                 f_money_value = money_value * 1.0/100;
  240.                                 sprintf(string,"%5.2f",f_money_value);
  241.                                 LCD_PutString(3,4,string);
  242.                                 //ShowFloat816(4,5,( f_money_value >= 0 ) ? ( ( f_money_value+0.5 )/100 ) : ( ( f_money_value-0.5 )/100 ));
  243.                     if(money_value<0)
  244.                       bWarn=1;
  245.                     else
  246.                       bPass=1;
  247.                     PcdHalt();
  248.                 }
  249.           else if(OperationCard==ADDMONEY)//充值
  250.           {
  251.                     status=PcdAuthState(PICC_AUTHENT1A,7,NewKeyA,MLastSelectedSnr);//????KUAI4?
  252.
  253.                                 if(status!=MI_OK)
  254.                               return;
  255.                     status=PcdRead(4,Read_Data);
  256.                     if(status!=MI_OK)
  257.                     {
  258.                               bWarn=1;
  259.                               return;
  260.                     }
  261.                                 memcpy( (uchar *)&money_value, Read_Data, 4 );
  262.                     if(money_value<-10000)
  263.                               money_value=-10000;
  264.                     if(money_value<0)
  265.                               money_value+=10000;
  266.                     money_value=money_value+5000;
  267.                                 memcpy( Write_Consume_Data, (uchar *)&money_value, 4 );
  268.                     status=PcdWrite(4,&Write_Consume_Data[0]);
  269.
  270.                                 if(status!=MI_OK)
  271.                     {
  272.                               bWarn=1;
  273.                               return;
  274.                     }
  275.
  276.                                 //ShowFloat816(2,5,50.00);
  277.                                 LCD_PutString(0,3,"充值: 50.00  ");
  278.                                 f_money_value = money_value * 1.0/100;
  279.                                 sprintf(string,"%5.2f",f_money_value);
  280.                                 LCD_PutString(3,4,string);
  281.                                 //ShowFloat816(4,5,( f_money_value >= 0 ) ? ( ( f_money_value+0.5 )/100 ) : ( ( f_money_value-0.5 )/100 ));
  282.                     bPass=1;
  283.                     PcdHalt();
  284.                 }
  285.                 OperationCard = 0;
  286. }
  287. void iccardcode()
  288. {
  289.           unsigned char cmd;
  290.         unsigned char status;
  291.
  292.         cmd = RevBuffer[0];
  293.         switch(cmd)
  294.         {
  295.                 case 1:     // Halt the card     //終止卡的操作
  296.                         status= PcdHalt();;
  297.                         RevBuffer[0]=1;
  298.                         RevBuffer[1]=status;
  299.                         break;
  300.                 case 2:     // Request,Anticoll,Select,return CardType(2 bytes)+CardSerialNo(4 bytes)
  301.                                 // 尋卡,防沖突,選擇卡    返回卡類型(2 bytes)+ 卡系列號(4 bytes)
  302.                         status= PcdRequest(RevBuffer[1],&RevBuffer[2]);
  303.                         if(status!=0)
  304.                         {
  305.                                 status= PcdRequest(RevBuffer[1],&RevBuffer[2]);
  306.                                 if(status!=0)
  307.                                 {
  308.                                         RevBuffer[0]=1;
  309.                                         RevBuffer[1]=status;
  310.                                         break;
  311.                                 }
  312.                         }
  313.                         RevBuffer[0]=3;
  314.                         RevBuffer[1]=status;
  315.                         break;
  316.
  317.                 case 3:                         // 防沖突 讀卡的系列號 MLastSelectedSnr
  318.                         status = PcdAnticoll(&RevBuffer[2]);
  319.                         if(status!=0)
  320.                         {
  321.                                 RevBuffer[0]=1;
  322.                                 RevBuffer[1]=status;
  323.                                 break;
  324.                         }
  325.                         memcpy(MLastSelectedSnr,&RevBuffer[2],4);
  326.                         RevBuffer[0]=5;
  327.                         RevBuffer[1]=status;
  328.                         break;
  329.                 case 4:                                    // 選擇卡 Select Card
  330.                         status=PcdSelect(MLastSelectedSnr);
  331.                         if(status!=MI_OK)
  332.                         {
  333.                                 RevBuffer[0]=1;
  334.                                 RevBuffer[1]=status;
  335.                                 break;
  336.                         }
  337.                         RevBuffer[0]=3;
  338.                         RevBuffer[1]=status;
  339.                         break;
  340.                 case 5:            // Key loading into the MF RC500's EEPROM
  341.             status = PcdAuthState(RevBuffer[1], RevBuffer[3], DefaultKey, MLastSelectedSnr);// 校驗卡密碼
  342.                         RevBuffer[0]=1;
  343.                         RevBuffer[1]=status;
  344.                         break;
  345.                 case 6:
  346.                         RevBuffer[0]=1;
  347.                         RevBuffer[1]=status;
  348.                         break;
  349.                 case 7:
  350.                     RevBuffer[0]=1;
  351.                         RevBuffer[1]=status;
  352.                         break;
  353.                 case 8:     // Read the mifare card
  354.                             // 讀卡
  355.                         status=PcdRead(RevBuffer[1],&RevBuffer[2]);
  356.                         if(status==0)
  357.                         {RevBuffer[0]=17;}
  358.                         else
  359.                         {RevBuffer[0]=1;}
  360.                         RevBuffer[1]=status;
  361.                         break;
  362.                 case 9:     // Write the mifare card
  363.                             // 寫卡  下載密碼
  364.                         status=PcdWrite(RevBuffer[1],&RevBuffer[2]);
  365.                         RevBuffer[0]=1;
  366.                         RevBuffer[1]=status;
  367.                         break;
  368.                 case 10:
  369.             PcdValue(RevBuffer[1],RevBuffer[2],&RevBuffer[3]);
  370.                         RevBuffer[0]=1;
  371.                         RevBuffer[1]=status;
  372.                         break;
  373.                 case 12:    // 參數(shù)設(shè)置
  374.                     PcdBakValue(RevBuffer[1], RevBuffer[2]);
  375.                         RevBuffer[0]=1;        //contact
  376.                         RevBuffer[1]=0;
  377.                         break;
  378.         }
  379.         }
  380. /////////////////////////////////////////////////////////////////////
  381. //系統(tǒng)初始化
  382. /////////////////////////////////////////////////////////////////////
  383. void InitializeSystem()
  384. {
  385.     P0 = 0xFF; P1 = 0xFF; P3 = 0xFF;
  386.         ET2 = 0;
  387.         T2CON = 0x04;                  //TR2=1 LYF
  388.     PCON = 0x00;//0x80;
  389.     SCON = 0x70;//SMO SM1= 0 1 方式1,對于方式1,SM2=1,接收到有效的停止位時,將RI置1,REN置1時允許接收數(shù)據(jù)
  390.     TMOD = 0x21;//TMOD = 0x22; TIMER1:C/T=0,定時器,M1M0=10,T1為工作模式2,即8位自動重裝載模式
  391.                                                          //TIMER0: C/T=0,定時器,M1M0=01,16位計數(shù)器
  392.         TH1   = BAUD_2400;
  393.         TL1   = TH1;
  394.         TR1   = 1;             // T1 作為波特率發(fā)生器
  395.         TH0 = 0x60;
  396.     TL0 = 0x60;
  397.     TR0 = 0;
  398.
  399.     ET0=0;
  400.         ET1=0;
  401.         EA=1;
  402.         //EX0=1;
  403.         //IT0 = 1;
  404.         TR2=0;
  405.         ES = 1;
  406.         CmdValid=0;
  407.      LED_GREEN = 1;
  408.      PcdReset();
  409.      PcdAntennaOff();
  410.      PcdAntennaOn();
  411.          M500PcdConfigISOType( 'A' );
  412.      LED_GREEN = 0;
  413.          delay_10ms(10);
  414.      LED_GREEN = 1;
  415.          delay_10ms(10);
  416.      LED_GREEN = 0;
  417. }
  418. /////////////////////////////////////////////////////////////////////
  419. //用T2做延時子程序
  420. /////////////////////////////////////////////////////////////////////
  421. ///////////////////////////////////////////////////////////////////////
  422. // 接收和發(fā)送中斷
  423. ///////////////////////////////////////////////////////////////////////
  424. void isr_UART(void) interrupt 4 using 1
  425. {
  426.     unsigned char len, i;
  427.           unsigned int j=0;
  428.
  429.           if(RI)
  430.         {
  431.                 len=SBUF;
  432.                 RI=0;
  433.                 for(i=0;i<len;i++)
  434.                 {
  435.                         while(!RI)
  436.                         {
  437.                                 j++;
  438.                                 if(j>1000)
  439.                                 {
  440.                                     break;
  441.                                 }
  442.                         }
  443.                         if(j<1000)
  444.                         {
  445.                                 RevBuffer[i]=SBUF;
  446.                                 RI=0;
  447.                                 j=0;
  448.                         }
  449.                         else
  450.                         {
  451.                             break;
  452.                         }
  453.                 }
  454.                 if(i==len)
  455.                 {
  456.                         REN=0;
  457.                         CmdValid=1;
  458.                 }
  459.         }
  460.         else if(!RI && TI)
  461.         {
  462.                 TI=0;
  463.                 len=RevBuffer[0];
  464.                 for(i=0;i<len+1;i++)
  465.                 {
  466.                         SBUF=RevBuffer[i];
  467.                         while(!TI);
  468.                         TI=0;
  469.                 }
  470.                 REN=1;
  471.         }
  472. }
  473. void UartProcess(void)
  474. {
  475.     unsigned char baud;
  476.                 if(RevBuffer[0]==11)            //為了加快相應(yīng)速度 測試風鳴器
  477.                 {
  478.                                 RevBuffer[2]=RevBuffer[1];
  479.                           RevBuffer[0]=1;         //contact
  480.                                 RevBuffer[1]=0;
  481.                                 CALL_isr_UART();
  482.         LED_GREEN = 1;
  483.                                 delay_10ms(RevBuffer[2]);
  484.         LED_GREEN = 0;
  485.                 }
  486.                 else if(RevBuffer[0]==13)   //設(shè)置通訊波特率
  487.           {
  488.                                 switch(RevBuffer[1])
  489.                                 {
  490.                                                 case 0:
  491.        baud=BAUD_9600;
  492.        break;
  493.                                                 case 1:
  494.        baud=BAUD_14400;
  495.        break;
  496.                                                 case 2:
  497.        baud=BAUD_19200;
  498.        break;
  499.                                                 case 3:
  500.        baud=BAUD_28800;
  501.        break;
  502.                                                 case 4:
  503.        baud=BAUD_38400;
  504.        break;
  505.                                                 case 5:
  506.        baud=BAUD_57600;
  507.        break;
  508.                                                 case 6:
  509.        baud=BAUD_115200;
  510.        break;
  511.                                                 default:
  512.        baud=BAUD_9600;
  513.        break;
  514.                                 }
  515. ……………………
  516. …………限于本文篇幅 余下代碼請從51黑下載附件…………
6-51讀寫卡程序(LCD12864).rar (98.49 KB, 下載次數(shù): 373)
ID:539433 發(fā)表于 2019-5-22 16:26 | 顯示全部樓層
對于1602來說,這個程序適用嗎?
ID:551761 發(fā)表于 2019-6-18 12:13 | 顯示全部樓層
原理圖用什么軟件畫的
ID:679122 發(fā)表于 2020-1-1 20:38 | 顯示全部樓層
小白H 發(fā)表于 2019-6-18 12:13
原理圖用什么軟件畫的
AD軟件。。。。。。。。
ID:704509 發(fā)表于 2020-3-8 13:02 | 顯示全部樓層
感謝分享
ID:470242 發(fā)表于 2020-4-14 20:03 | 顯示全部樓層
樓主,怎么沒有顯示呢?
ID:759554 發(fā)表于 2020-5-24 01:01 | 顯示全部樓層
能問一下樓主UartProccess跟iccardcode兩個函數(shù)的作用嗎?什么情況下會調(diào)用呢?
ID:17396 發(fā)表于 2021-4-22 11:33 | 顯示全部樓層
謝謝樓主分享。非常感謝,學(xué)習(xí)中
ID:228360 發(fā)表于 2024-10-1 09:20 | 顯示全部樓層
感謝分享,有空看看.
ID:316613 發(fā)表于 2025-2-6 16:48 | 顯示全部樓層
實測刷卡+顯示+按鍵都好用
主站蜘蛛池模板: 久久视频免费观看 | 久久久久久久97 | 久久国内视频 | 五月播播 | 好了av在线 | 欧美日韩色 | 国产又粗又猛视频免费 | 欧美高清在线 | 亚洲精品伦理 | 日韩av在线网站 | 一区二区三区在线免费 | 嫩草嫩草嫩草嫩草 | 97色婷婷| 亚洲激情四射 | 午夜一级视频 | 在线观看黄色av | 成人午夜网站 | 女人一级一片30分 | 性欧美8khd高清极品 | 在线播放中文字幕 | 精品黑人一区二区三区国语馆 | 欧美日韩中文 | 懂色av一区二区夜夜嗨 | 亚洲视频免费观看 | 91精品久久久久久 | 欧美黄色片 | 日韩一区二区三区在线播放 | 天天躁日日躁狠狠躁伊人 | 一级黄色片在线观看 | 欧美精品一区二区在线观看 | 久久888 | 美女视频福利 | 少妇一级片 | 久久精品国产亚洲 | 国产乱人乱偷精品视频 | 天天综合精品 | 成人一级片 | 福利视频免费观看 | 黄色片网站免费 | 二区三区在线观看 | 日本天天操 |
