查看: 8539|回復: 7
3D打印機Marin固件 Corexy自動調平固件下載
ID:272634 發表于 2018-1-7 10:42 | 顯示全部樓層 |閱讀模式
  1. /* -*- c++ -*- */
  2. /*
  3.     Reprap firmware based on Sprinter and grbl.
  4. Copyright (C) 2011 Camiel Gubbels / Erik van der Zalm
  5. This program is free software: you can redistribute it and/or modify
  6. it under the terms of the GNU General Public License as published by
  7. the Free Software Foundation, either version 3 of the License, or
  8. (at your option) any later version.
  9. This program is distributed in the hope that it will be useful,
  10. but WITHOUT ANY WARRANTY; without even the implied warranty of
  11. MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
  12. GNU General Public License for more details.
  13. You should have received a copy of the GNU General Public License
  14. along with this program.  If not, see <http://www.gnu.org/licenses/>.
  15. */
  16. /*
  17. This firmware is a mashup between Sprinter and grbl.
  18.   (https://github.com/kliment/Sprinter)
  19.   (https://github.com/simen/grbl/tree)
  20. It has preliminary support for Matthew Roberts advance algorithm
  21.     http://reprap.org/pipermail/reprap-dev/2011-May/003323.html
  22. */
  23. /* All the implementation is done in *.cpp files to get better compatibility with avr-gcc without the Arduino IDE */
  24. /* Use this file to help the Arduino IDE find which Arduino libraries are needed and to keep documentation on GCode */
  25. #include "Configuration.h"
  26. #include "pins.h"
  27. #ifdef ULTRA_LCD
  28.   #if defined(LCD_I2C_TYPE_PCF8575)
  29.     #include <Wire.h>
  30.     #include <LiquidCrystal_I2C.h>
  31.   #elif defined(LCD_I2C_TYPE_MCP23017) || defined(LCD_I2C_TYPE_MCP23008)
  32.     #include <Wire.h>
  33.     #include <LiquidTWI2.h>
  34.   #elif defined(DOGLCD)
  35.     #include <U8glib.h> // library for graphics LCD by Oli Kraus (https://code.google.com/p/u8glib/)
  36.   #else
  37.     #include <LiquidCrystal.h> // library for character LCD
  38.   #endif
  39. #endif
  40. #if defined(DIGIPOTSS_PIN) && DIGIPOTSS_PIN > -1
  41. #include <SPI.h>
  42. #endif
  43. #if defined(DIGIPOT_I2C)
  44.   #include <Wire.h>
  45. #endif
Corexy自動調平固件 (自動調平).zip (2.82 MB, 下載次數: 75)
ID:272634 發表于 2018-1-7 10:44 | 顯示全部樓層
Marin固件的程序在壓縮包里面
ID:138918 發表于 2019-4-30 14:28 | 顯示全部樓層
看看 不知道可不可以 拿來參考下
ID:108573 發表于 2020-2-20 09:13 | 顯示全部樓層
怎么都是arduino的,有沒有STM32的
ID:762137 發表于 2020-5-27 07:27 | 顯示全部樓層
學習一下,我雖然是個菜鳥,看著還是挺牛的
ID:778969 發表于 2020-6-14 14:20 | 顯示全部樓層
學習一下  第一次完這個結構的打印機
ID:802858 發表于 2020-7-14 00:18 | 顯示全部樓層
marin固件太多了
ID:449082 發表于 2020-7-21 16:45 | 顯示全部樓層
Arduino:1.8.9 (Windows 7), 開發板:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Error reading file (C:\Program Files (x86)\Arduino\hardware\arduino\avr\boards.txt:0): Invalid line format, should be 'key=value'
為開發板 Arduino/Genuino Mega or Mega 2560 編譯時出錯。
在文件 -> 首選項開啟
“編譯過程中顯示詳細輸出”選項
這份報告會包含更多信息。
這什么原因?
主站蜘蛛池模板: 国产一区二区三区在线 | av一区二区三区在线观看 | 国产精品午夜视频 | 91av在线免费观看 | 午夜拍拍 | 久久av影院 | 亚洲成人精品在线观看 | av影片在线观看 | 国产精品hd| 国产一区在线视频 | 欧美在线视频播放 | 伊人久久在线 | 成人特级毛片 | 亚洲成人免费在线观看 | 少妇一级淫片免费看 | 91插插插插插| 国产在线观看一区 | 狠狠五月| 久久88 | 亚洲天堂网在线观看 | 国产免费一区二区三区免费视频 | 日本特级淫片 | 天堂中文av | 亚洲精品一区二区三区精华液 | 久久精品区 | 中文字幕在线观看亚洲 | 国产91在线看 | 中文字幕精品三区 | 国产呦小j女精品视频 | 国产一级视频在线观看 | 成人在线视频免费 | 好色网站 | 97cao| 亚洲一级大片 | 91爱看 | 欧美一区不卡 | 成人免费看| 国产aⅴ爽av久久久久成人 | 日韩欧美中文在线 | 五月天婷婷丁香 | 一级片国产|
