查看: 2466|回復: 0
Low Noise Flat Gain 40M~1GHz DVB-C LNA with BFG425W
ID:273791 發表于 2018-1-9 14:47 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
With the new NXP silicon bipolar double poly BFG400W series, it is possible to design low noise amplifiers for high frequency applications with a low current and a low supply voltage. These amplifiers are well suited for the new generation low voltage high frequency wireless applications.
In this note a first study of such an amplifier will be given. This amplifier is designed for a wideband working frequency from 40MHz to 1GHz. It is designed for DVB-C application, so the solution need provide a pretty good Gain flatness.
DVB-C stands for "Digital Video Broadcasting - Cable" and it is the DVB European consortium standard for the broadcast transmission of digital television over cable. This system transmits a MPEG-2 or MPEG-4 family digital audio/digital video stream, using a QAM modulation with channel coding. The standard was first published by the ETSI in 1994, and subsequently became the most widely used transmission system for digital cable television in Europe. It is deployed worldwide in systems ranging from the larger cable television networks (CATV) down to smaller satellite master antenna TV (SMATV) systems.
The circuit shown in this application note is intended to demonstrate the performance of the BFG425W in a 40M ~ 1GHz LNA for DVB-C applications.
Key requirements for this application are:
• Frequency Band 40M – 1GHz
• Gain
• Input/output Match
• Linearity
• NF
• Gain Flatness
Low Noise Flat Gain 40M~1GHz DVB-C LNA with BFG425W.pdf
468.79 KB, 下載次數: 7, 下載積分: 黑幣 -5
主站蜘蛛池模板: 日韩免费视频一区二区 | 国产亚洲天堂 | 亚洲 欧美 激情 另类 校园 | 久久黄色网 | 欧美成人精品欧美一级私黄 | 国产又粗又大又硬 | 天天色天天 | 放几个免费的毛片出来看 | 三级av在线 | 午夜影院在线 | 亚洲二三区 | 久久久久久亚洲 | 日韩av在线一区 | 深夜福利网 | 天天摸天天操 | 欧美亚洲国产精品 | 国产成人+综合亚洲+天堂 | 成人免费毛片嘿嘿连载视频 | 91porn在线| 黄色片视频网站 | 九九九精品视频 | 国产精品福利在线观看 | 日韩国产在线 | 日韩在线免费 | 中文在线免费观看 | 最新国产在线 | 破处视频在线观看 | 黄网免费 | 日韩免费高清 | 日韩精品一区二区视频 | 亚洲视频国产 | 欧美一级做性受免费大片免费 | 福利视频网站 | 在线观看国产小视频 | 精品福利一区 | 在线视频一区二区三区 | 久久免费看视频 | 国产a久久麻豆入口 | 国产做爰视频免费播放 | 国产wwwwww| 久久久精品国产sm调教 |
