查看: 5048|回復(fù): 2
單片機多檔倒計時proteus仿真與源程序
ID:140489 發(fā)表于 2018-1-17 13:07 | 顯示全部樓層 |閱讀模式
//30秒,300秒,600秒三檔倒計時,key1按鍵切換時間,key2鍵LED點亮,松手后啟動倒計時,數(shù)碼管顯示數(shù)值每秒減1,
//倒計時結(jié)束,LED熄滅,數(shù)碼管顯示設(shè)定值;如果倒計時沒結(jié)束時,再按下key2鍵,倒計時時間置設(shè)定值重新計時
//仿真通過;附件有源程序,仿真文件,hex文件
單片機源程序:
  1. //30秒,300秒,600秒三檔倒計時,key1按鍵切換時間,key2鍵LED點亮,松手后啟動倒計時,數(shù)碼管顯示數(shù)值每秒減1,
  2. //倒計時結(jié)束,LED熄滅,數(shù)碼管顯示設(shè)定值;如果倒計時沒結(jié)束時,再按下key2鍵,倒計時時間置設(shè)定值重新計時
  3. //仿真通過
  4. #include <reg52.h>
  5. #define uchar unsigned char
  6. #define uint  unsigned int
  7. sbit led = P1^7;
  8. sbit key1 = P1^0; //時間切換鍵
  9. sbit key2 = P1^1; //啟動按鍵
  10. sbit we1 = P2^0;  //數(shù)碼管位端口
  11. sbit we2 = P2^1;
  12. sbit we3 = P2^2;
  13. uchar knum;                  //key1按鍵按下次數(shù)計數(shù)變量
  14. uchar cont;                  //中斷次數(shù)變量
  15. uint cont1=30,cont2=300,cont3=600;        //定義時間變量并賦值30秒,300秒,600秒
  16. uchar code LedTab[]=  //定義共陰極數(shù)碼管段碼
  17.    {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00};
  18. void delay(uint z)
  19. {
  20.         uint x,y;
  21.         for(x=z; x>0; x--)
  22.                 for(y=114; y>0; y--);
  23. }
  24. void display1(uint shu)
  25. {
  26.         we1 = 0;
  27.         P0 = LedTab[shu/100];
  28.         delay(5);
  29.         we1 = 1;
  30.
  31.         we2 = 0;
  32.         P0 = LedTab[shu%100/10];
  33.         delay(5);
  34.         we2 = 1;
  35.
  36.         we3 = 0;
  37.         P0 = LedTab[shu%10];
  38.         delay(5);
  39.         we3 = 1;
  40. }
  41. void keyscan()
  42. {
  43.         if(key1==0)
  44.         {
  45.                 delay(5);
  46.                 if(key1==0)
  47.                 {
  48.                         while(!key1);
  49.                         knum++;
  50.                         if(knum==3)
  51.                                 knum=0;
  52.                 }
  53.         }
  54.         if(key2 == 0)
  55.         {
  56.                 delay(5);
  57.                 if(key2 == 0)         //key2按下
  58.                 {
  59.                         led = 0;         //點亮LED,松手后啟動倒計時
  60.                         while(!key2)        //這句后面不加分號,下一句調(diào)用顯示函數(shù),按鍵時數(shù)碼管才不會滅
  61.                         {
  62. //                                if(knum==0)
  63. //                                display1(cont1);
  64. //                                if(knum==1)
  65. //                                display1(cont2);
  66. //                                if(knum==2)
  67. //                                display1(cont3);
  68.                                 switch(knum)
  69.                                 {
  70.                                          case 0: display1(cont1);  break;
  71.                                          case 1: display1(cont2);  break;
  72.                                          case 2: display1(cont3);  break;
  73.                                 }
  74.
  75.                                 TR0 = 1;         //啟動定時器
  76.         //                        led = 0;         //點亮LED
  77.                                 cont1=30;
  78.                                 cont2=300;
  79.                                 cont3=600;
  80.                         }
  81.                 }
  82.         }
  83. }
  84. void main()
  85. {
  86.         TMOD = 0X01;                          //T0定時器,模式1, 16位計數(shù)
  87.         TH0 = (65536-46082)/256;  //50ms初值
  88.         TL0 = (65536-46082)%256;
  89.         EA = 1;                         //開總中斷
  90.         ET0 = 1;                 //開定時器中斷
  91.         while(1)
  92.         {
  93.                 keyscan();
  94.                 switch(knum)
  95.                 {
  96.                          case 0: display1(cont1); cont2=300; cont3=600; break;
  97.                          case 1: display1(cont2); cont1=30; cont3=600; break;
  98.                          case 2: display1(cont3); cont1=30; cont2=300; break;
  99.                 }
  100.         }
  101. }
  102. void timer0() interrupt 1
  103. {
  104.         TH0 = (65536-46082)/256; //重裝初值
  105.         TL0 = (65536-46082)%256;
  106.         cont++;
  107.         if(cont == 20)
  108.         {
  109.                 cont = 0;
  110.                 switch(knum)
  111.                 {
  112.                         case 0: cont1--;
  113.                                         if(cont1==0)
  114.                                         {
  115.                                                 cont1=30;  //倒計時時間到
  116.                                                 led=1;           //熄滅LED
  117.                                                 TR0=0;           //關(guān)閉定時器
  118.                                         } break;
  119.                         case 1: cont2--;
  120.                                         if(cont2==0)
  121.                                         {
  122.                                                 cont2=300;
  123.                                                 led=1;
  124.                                                 TR0=0;
  125.                                         } break;
  126.                         case 2: cont3--;
  127.                                         if(cont3==0)
  128.                                         {
  129.                                                 cont3=600;
  130.                                                 led=1;
  131.                                                 TR0=0;
  132.                                         } break;
  133.                 }
  134.         }
  135. }
全部資料51hei下載地址:
多檔倒計時.rar (22.25 KB, 下載次數(shù): 82)
ID:89835 發(fā)表于 2018-11-7 23:35 | 顯示全部樓層
試了下,還不錯,很經(jīng)典的小例子,感謝樓主分享
ID:1045601 發(fā)表于 2023-6-2 14:03 來自觸屏版 | 顯示全部樓層
可以
ID:53813 發(fā)表于 2023-11-23 09:38 | 顯示全部樓層
正好是我類似項目需要的,參考下,謝謝樓主
主站蜘蛛池模板: 黄色影视大全 | 久热在线 | 99精品视频在线观看 | 日韩一区二区中文字幕 | 最新中文字幕av | 二区在线观看 | 亚洲a在线观看 | 久久国产99 | 日日干夜夜爽 | 99精品色| 国产免费一区二区三区免费视频 | 亚洲丝袜av | 国产青青操 | 久久久久久网 | 久久国产一区 | 99精品成人| 久久黄色录像 | 999在线视频 | 亚洲国产成人av | 久久久一区二区 | 国产成人91 | 国产精品第一区 | 成人毛片在线 | 在线免费看黄网站 | 国产成人免费观看 | 天天射天天操天天干 | 久久久午夜精品 | 91av免费| 亚洲一区二区三区视频 | 国产无遮挡又黄又爽免费网站 | 性视频在线 | 成年人国产 | 欧美日韩精品一区二区在线播放 | 国产精品视频一区二区三区 | 超碰成人在线观看 | av自拍偷拍 | 黄色av免费观看 | 国产激情小视频 | www视频在线观看 | 五月婷婷亚洲 | 亚洲高清在线视频 |
