查看: 3111|回復: 0
STM32F429 GT811觸摸芯片驅動源碼
ID:282685 發表于 2018-2-6 19:47 | 顯示全部樓層 |閱讀模式
Project Settings :
Project Name : STM32F746I
Project Folder : C:\Users\Administrator\Desktop\3.touch 1024x600 GT811
Toolchain / IDE : MDK-ARM V5
Firmware Package Name and Version : STM32Cube FW_F7 V1.3.0
touch 1024x600 GT811源碼包:
  1. /**
  2.   ******************************************************************************
  3.   * File Name          : main.c
  4.   * Description        : Main program body
  5.   ******************************************************************************
  6.   *
  7.   * COPYRIGHT(c) 2016 STMicroelectronics
  8.   *
  9.   * Redistribution and use in source and binary forms, with or without modification,
  10.   * are permitted provided that the following conditions are met:
  11.   *   1. Redistributions of source code must retain the above copyright notice,
  12.   *      this list of conditions and the following disclaimer.
  13.   *   2. Redistributions in binary form must reproduce the above copyright notice,
  14.   *      this list of conditions and the following disclaimer in the documentation
  15.   *      and/or other materials provided with the distribution.
  16.   *   3. Neither the name of STMicroelectronics nor the names of its contributors
  17.   *      may be used to endorse or promote products derived from this software
  18.   *      without specific prior written permission.
  19.   *
  20.   * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  21.   * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  22.   * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  23.   * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  24.   * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  25.   * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  26.   * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  27.   * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  28.   * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  29.   * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
  30.   *
  31.   ******************************************************************************
  32.   */
  33. /* Includes ------------------------------------------------------------------*/
  34. #include "stm32f7xx_hal.h"
  35. #include "dma.h"
  36. #include "dma2d.h"
  37. #include "i2c.h"
  38. #include "ltdc.h"
  39. #include "usart.h"
  40. #include "gpio.h"
  41. #include "fmc.h"
  42. /* USER CODE BEGIN Includes */
  43. #include "stm32746g_sdram.h"
  44. #include "stm32746g_LCD.h"
  45. #include "GT811.h"
  46. /* USER CODE END Includes */
  47. /* Private variables ---------------------------------------------------------*/
  48. /* USER CODE BEGIN PV */
  49. /* Private variables ---------------------------------------------------------*/
  50. TS_StateTypeDef  TS_State={0};
  51. uint8_t TS_flag ;
  52. uint8_t TouchPoit;
  53. TS_StateTypeDef  TS_BKState;
  54. uint8_t value = 0;
  55. uint16_t i;
  56. uint32_t PointColor[]={LCD_COLOR_BLUE,LCD_COLOR_GREEN,LCD_COLOR_RED,LCD_COLOR_MAGENTA,LCD_COLOR_YELLOW};
  57. /* USER CODE END PV */
  58. /* Private function prototypes -----------------------------------------------*/
  59. void SystemClock_Config(void);
  60. /* USER CODE BEGIN PFP */
  61. /* Private function prototypes -----------------------------------------------*/
  62. /* USER CODE END PFP */
  63. /* USER CODE BEGIN 0 */
  64. /* USER CODE END 0 */
  65. int main(void)
  66. {
  67.   /* USER CODE BEGIN 1 */
  68.
  69.   /* USER CODE END 1 */
  70.   /* Enable I-Cache-------------------------------------------------------------*/
  71.   SCB_EnableICache();
  72.   /* Enable D-Cache-------------------------------------------------------------*/
  73.   SCB_EnableDCache();
  74.   /* MCU Configuration----------------------------------------------------------*/
  75.   /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  76.   HAL_Init();
  77.   /* Configure the system clock */
  78.   SystemClock_Config();
  79.   /* Initialize all configured peripherals */
  80.   MX_GPIO_Init();
  81.   MX_DMA_Init();
  82.   MX_DMA2D_Init();
  83.   MX_FMC_Init();
  84. //  MX_I2C4_Init();
  85.   MX_LTDC_Init();
  86.   MX_USART1_UART_Init();
  87.   /* USER CODE BEGIN 2 */
  88.         /* Program the SDRAM external device */
  89.         HAL_GPIO_WritePin(GPIOA,GPIO_PIN_3,GPIO_PIN_RESET);
  90.   BSP_SDRAM_Init();
  91.         BSP_LCD_Init();
  92.         GT811_Init();
  93.
  94.         BSP_LCD_SetLayerVisible(1,DISABLE);
  95.         BSP_LCD_SelectLayer(0);
  96.         BSP_LCD_SetTextColor(LCD_COLOR_BLUE);
  97.         BSP_LCD_SetBackColor(LCD_COLOR_BLACK);
  98.         BSP_LCD_Clear(BSP_LCD_GetBackColor());
  99.         BSP_LCD_SetFont(&Font24);
  100.         BSP_LCD_DisplayStringAt(0,0, (uint8_t*)"Capacitive touch screen test",CENTER_MODE);
  101.         BSP_LCD_SetTextColor(LCD_COLOR_WHITE);
  102.         BSP_LCD_DrawHLine(0, 30, 1024);
  103.
  104.   /* USER CODE END 2 */
  105.   /* Infinite loop */
  106.   /* USER CODE BEGIN WHILE */
  107.   while (1)
  108.   {
  109.   /* USER CODE END WHILE */
  110.   /* USER CODE BEGIN 3 */
  111.                 if(TS_flag == 1)
  112.                 {
  113.                         GT811_GetState(&TS_State);
  114.                         if(TS_State.touchDetected != 0)
  115.                         {
  116.                                 TouchPoit = TS_BKState.touchDetected;
  117.                                 for(i = 0;i < 5;i++)
  118.                                 {
  119.                                         if(TouchPoit & 0x01)
  120.                                         {
  121.                                                 BSP_LCD_SetTextColor(LCD_COLOR_BLACK);
  122.                                                 BSP_LCD_FillCircle(TS_BKState.touchX[i],TS_BKState.touchY[i],20);
  123.                                                 BSP_LCD_DrawVLine(TS_BKState.touchX[i], 55, 580);
  124.                                                 BSP_LCD_DrawHLine(5, TS_BKState.touchY[i], 1004);
  125.                                         }
  126.                                         TouchPoit >>= 1;
  127.                                 }
  128.
  129.                                 TouchPoit = TS_State.touchDetected;
  130.                                 for(i = 0;i < 5;i++)
  131.                                 {
  132.                                         if(TouchPoit & 0x01)
  133.                                         {
  134.                                                 if(TS_State.touchY[i] <  75)TS_State.touchY[i] =  75;
  135.                                                 if(TS_State.touchY[i] > 580)TS_State.touchY[i] = 580;
  136.                                                 if(TS_State.touchX[i] <  20)TS_State.touchX[i] =  20;
  137.                                                 if(TS_State.touchX[i] > 1004)TS_State.touchX[i] = 1004;
  138.
  139.                                                 BSP_LCD_SetTextColor(PointColor[i]);
  140.                                                 BSP_LCD_FillCircle(TS_State.touchX[i],TS_State.touchY[i],20);
  141.                                                 BSP_LCD_DrawVLine(TS_State.touchX[i], 55, 580);
  142.                                                 BSP_LCD_DrawHLine(5, TS_State.touchY[i], 1004);
  143.                                                 TS_BKState.touchX[i] = TS_State.touchX[i];
  144.                                                 TS_BKState.touchY[i] = TS_State.touchY[i];
  145.                                         }
  146.                                         TouchPoit >>= 1;
  147.                                 }
  148.                                 TS_BKState.touchDetected = TS_State.touchDetected;
  149.                         }
  150.                         TS_flag = 0;
  151.                 }
  152.   }
  153.   /* USER CODE END 3 */
  154. }
  155. /** System Clock Configuration
  156. */
  157. void SystemClock_Config(void)
  158. {
  159.   RCC_OscInitTypeDef RCC_OscInitStruct;
  160.   RCC_ClkInitTypeDef RCC_ClkInitStruct;
  161.   RCC_PeriphCLKInitTypeDef PeriphClkInitStruct;
  162.   __PWR_CLK_ENABLE();
  163.   __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  164.   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  165.   RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  166.   RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  167.   RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  168.   RCC_OscInitStruct.PLL.PLLM = 8;
  169.   RCC_OscInitStruct.PLL.PLLN = 432;
  170.   RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  171.   RCC_OscInitStruct.PLL.PLLQ = 2;
  172.   HAL_RCC_OscConfig(&RCC_OscInitStruct);
  173.   HAL_PWREx_ActivateOverDrive();
  174.   RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
  175.                               |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  176.   RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  177.   RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  178.   RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  179.   RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  180.   HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_7);
  181.   PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_LTDC|RCC_PERIPHCLK_USART1
  182.                               |RCC_PERIPHCLK_I2C4;
  183.   PeriphClkInitStruct.PLLSAI.PLLSAIN = 192;
  184.   PeriphClkInitStruct.PLLSAI.PLLSAIR = 3;
  185.   PeriphClkInitStruct.PLLSAI.PLLSAIQ = 2;
  186.   PeriphClkInitStruct.PLLSAI.PLLSAIP = RCC_PLLSAIP_DIV2;
  187.   PeriphClkInitStruct.PLLSAIDivQ = 1;
  188.   PeriphClkInitStruct.PLLSAIDivR = RCC_PLLSAIDIVR_2;
  189.   PeriphClkInitStruct.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK2;
  190.   PeriphClkInitStruct.I2c4ClockSelection = RCC_I2C4CLKSOURCE_SYSCLK;
  191.   HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct);
  192.   HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  193.   HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  194.   /* SysTick_IRQn interrupt configuration */
  195.   HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
  196. }
  197. /* USER CODE BEGIN 4 */
  198. /**
  199.   * @}
  200.   */
  201. void HAL_GPIO_EXTI_Callback(uint16_t GPIO_Pin)
  202. {
  203.         if(GPIO_Pin == GPIO_PIN_7)
  204.         {
  205.                 TS_flag = 1;
  206.                 printf("ok\r\n");
  207.         }
  208. }
  209. /* USER CODE END 4 */
  210. ……………………
  211. …………限于本文篇幅 余下代碼請從51黑下載附件…………
代碼.7z (2.48 MB, 下載次數: 27)
主站蜘蛛池模板: 精品国产一区二区在线观看 | 成年人免费视频网站 | 国产黄a三级三级看三级 | 久草网站| 精品在线免费视频 | 色妞综合网 | 欧美视频一区二区三区 | 日韩激情一区二区 | 久久在线 | 国产精品国产成人国产三级 | 久久久久久久国产精品 | 国产www在线观看 | 在线视频一区二区三区 | 18国产免费视频动漫 | 98国产精品| 午夜精品在线 | 欧美日韩在线一区二区 | 日韩怡红院 | 免费看黄色av| 福利小视频在线观看 | 久久久综合网 | 91免费版看片 | 精品免费观看 | 亚洲精品久久久蜜桃 | 超碰人人网 | 日本不卡一区二区三区 | 欧美日韩黄 | 亚洲精品a| 一区二区三区四区国产 | 日韩女优在线 | 亚洲男人av| 日韩怡红院 | 日韩欧美在线一区 | 日韩二区三区 | 成人毛片在线 | 日本伊人网 | 欧美a级成人淫片免费看 | 91精品国产99久久久久久红楼 | 天堂资源网 | 毛片一级片| 一级片国产 |
