查看: 3909|回復: 2
STM8+ADS1232+串口發(fā)送
ID:296323 發(fā)表于 2018-3-24 14:00 | 顯示全部樓層 |閱讀模式
/* Includes ------------------------------------------------------------------*/
#include "stm8s.h"
#include "stdio.h"
#include <math.h>
/* Private defines -----------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
void Send(uint8_t dat);
void Delay(uint16_t nCount);
void print(double a);
void delay_us(uint16_t dly1);
unsigned long Read_ADS1232(void);
void ADS1232_GPIO_Init();
double KalmanFilter(const double ResrcData,double ProcessNiose_Q,double MeasureNoise_R,double InitialPrediction);
/* Private functions ---------------------------------------------------------*/
#define LED_GPIO_PORT  (GPIOD)
#define LED_GPIO_PINS  (GPIO_PIN_1)
#define SCK_Low GPIO_WriteLow(GPIOA,(GPIO_Pin_TypeDef)GPIO_PIN_3)
#define SCK_High GPIO_WriteHigh(GPIOA,(GPIO_Pin_TypeDef)GPIO_PIN_3)
#define DOUT GPIO_ReadInputPin(GPIOD,(GPIO_Pin_TypeDef)GPIO_PIN_4)
void main(void)
  /* Initialize I/Os in Output Mode */
  unsigned char n=0,m=0;
  unsigned long i=0,j;
  double a=0,b=0,c=0,d=0;
  double Q=0.0018;
  GPIO_Init(LED_GPIO_PORT, (GPIO_Pin_TypeDef)LED_GPIO_PINS, GPIO_MODE_OUT_PP_LOW_FAST);
  UART1_DeInit();
  UART1_Init((u32)9600, UART1_WORDLENGTH_8D, UART1_STOPBITS_1, UART1_PARITY_NO, UART1_SYNCMODE_CLOCK_DISABLE, UART1_MODE_TX_ENABLE);
  while (1)
    n++,m++;
    /* Toggles LEDs */
   // GPIO_WriteReverse(LED_GPIO_PORT, (GPIO_Pin_TypeDef)LED_GPIO_PINS);
    //Delay(0xffff);
    i=Read_ADS1232();
    if(abs(i-j)>1000)
      Q=0.0018;
      n=0;
    if(n==50)Q=0.000000000000001;
    j=i;
      a=(double)i;
      a/=16777216;
      a*=4.99899;
      b=KalmanFilter(a,Q,0.000000000002,1);
      c+=b;
      d+=a;
      if(m==10)
        c*=10000000;
        d*=10000000;
        /*i=(unsigned long)d;
        //print(a);
        Send(i%1000000000/100000000+48);
        Send('.');
        Send(i%100000000/10000000+48);
        Send(i%10000000/1000000+48);
        Send(i%1000000/100000+48);
        Send(i%100000/10000+48);
        Send(i%10000/1000+48);
        Send(i%1000/100+48);
        Send(i%100/10+48);
        Send(i%10+48);
        Send(',');*/
        i=(unsigned long)c;
        Send('.');
        Send(i%100/10+48);
        Send(i%10+48);
        Send('\n');
        c=0;
        d=0;
        m=0;
        Q:過程噪聲,Q增大,動態(tài)響應變快,收斂穩(wěn)定性變壞
        R:測量噪聲,R增大,動態(tài)響應變慢,收斂穩(wěn)定性變好
  double R = MeasureNoise_R;
  double Q = ProcessNiose_Q;
  static double x_last;
  double x_mid = x_last;
  double x_now;
  static double p_last;
  double p_mid ;
  double p_now;
  double kg;
  x_mid=x_last; //x_last=x(k-1|k-1),x_mid=x(k|k-1)
  p_mid=p_last+Q; //p_mid=p(k|k-1),p_last=p(k-1|k-1),Q=噪聲
  kg=p_mid/(p_mid+R); //kg為kalman filter,R為噪聲
  x_now=x_mid+kg*(ResrcData-x_mid);//估計出的最優(yōu)值
  p_now=(1-kg)*p_mid;//最優(yōu)值對應的covariance
  p_last = p_now; //更新covariance值
  x_last = x_now; //更新系統(tǒng)狀態(tài)值
  return x_now;
  uint16_t i;
  for(i=dly1;i>0;i--);
  GPIO_Init(GPIOA, (GPIO_Pin_TypeDef)GPIO_PIN_3, GPIO_MODE_OUT_PP_LOW_FAST);
  GPIO_Init(GPIOD, (GPIO_Pin_TypeDef)GPIO_PIN_4, GPIO_MODE_IN_FL_NO_IT);
unsigned long val = 0;
unsigned char i = 0;
SCK_Low; //SCK=0
while(DOUT);//等待DOUT=0
delay_us(1);
for(i=0;i<24;i++)
  SCK_High;//SCK=1
  val=val<<1;
  delay_us(1);
  SCK_Low; //SCK=0
  if(DOUT)//DOUT=1
  val++;
  delay_us(1);
SCK_High;
delay_us(1);
SCK_Low;
delay_us(1);
return val;
  /* Decrement nCount value */
  while (nCount != 0)
    nCount--;
  while(( UART1_GetFlagStatus(UART1_FLAG_TXE)==RESET));
UART1_SendData8(dat);
  unsigned long temp=0;
  temp=(unsigned long)a*1000000;
  Send(temp/1000000+48);
  Send('.');
  Send(temp%1000000/100000+48);
  Send(temp%100000/10000+48);
  Send(temp%10000/1000+48);
  Send(temp%1000/100+48);
  Send(temp%100/10+48);
  Send(temp%10+48);
  Send('\n');
#ifdef USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @param file: pointer to the source file name
  * @param line: assert_param error line source number
  * @retval : None
void assert_failed(u8* file, u32 line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
ADS1232 and STM8.zip
1.55 MB, 下載次數(shù): 63, 下載積分: 黑幣 -5
IAR工程文件
ID:261706 發(fā)表于 2019-9-10 09:42 | 顯示全部樓層
好文學習了
ID:80750 發(fā)表于 2019-9-23 18:06 | 顯示全部樓層
正好用上,學習了
主站蜘蛛池模板: 经典三级第一页 | 色妞网 | 免费视频一区二区 | av网站免费在线观看 | 国产免费无遮挡 | 欧洲av网站 | 3d动漫精品h区xxxxx区 | 日韩欧美在线视频 | 玖玖视频 | 一级做a爱片性色毛片 | 国产精品黄色片 | 日本亚洲精品 | 免费在线小视频 | 中文字幕av在线 | 日韩精品成人 | 日韩新片王网 | 高潮毛片7777777毛片 | 国产精品美女 | 精品网站999www | 亚州成人| 激情av网| 国产精品久久久久久亚洲影视 | 欧美在线视频一区 | 久久精品福利 | 一区二区视频在线播放 | 激情五月综合网 | 91tv国产成人福利 | 国产福利91 | 欧美另类z0zx974 | 欧美超碰在线 | 激情小说在线视频 | 日韩资源| 亚洲精品一区二区三区在线 | 日韩免费一区 | 国产亚洲视频在线观看 | 午夜色播 | 久久最新视频 | 欧美一二| 精品日韩在线观看 | 艳妇乳肉豪妇荡乳 | 成人av资源 |
