查看: 10051|回復: 10
STM32驅動w5500_dhcp+http TCP/IP網絡集成模塊的源碼
ID:296725 發表于 2018-3-25 14:31 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
W5500 TCP/IP網絡集成模塊 STM32驅動
stm32_w5500_dhcp+http
  1. /* Includes ------------------------------------------------------------------*/
  2. #include "main.h"
  3. #include "usart.h"
  4. #include "delay.h"
  5. #include "spi.h"
  6. #include "socket.h"        // Just include one header for WIZCHIP
  7. #include "Internet/DHCP/dhcp.h"
  8. #include "httpServer.h"
  9. #include "httpParser.h"
  10. #include "httpUtil.h"
  11. /* Private typedef -----------------------------------------------------------*/
  12. /* Private define ------------------------------------------------------------*/
  13. #define SOCK_DHCP                        0
  14. #define MY_MAX_DHCP_RETRY        3
  15. #define DATA_BUF_SIZE   2048
  16. /* Private macro -------------------------------------------------------------*/
  17. uint8_t gDATABUF[DATA_BUF_SIZE];
  18. // Default Network Configuration
  19. uint8_t http_tx_buf[2048];
  20. uint8_t http_rx_buf[2048];
  21. const uint8_t flash_buffer[2048];
  22. uint8_t memsize[2][8] = {{2,2,2,2,2,2,2,2},{2,2,2,2,2,2,2,2}};
  23. uint8_t socklist[] = {0,1,2,3,4,5,6 };
  24. int g_time6=0;
  25. extern char index_html[4096];
  26. wiz_NetInfo gWIZNETINFO = { .mac = {0x00, 0x08, 0xdc,0x00, 0xab, 0xcd},
  27.                             .ip = {192, 168, 1, 123},
  28.                             .sn = {255,255,255,0},
  29.                             .gw = {192, 168, 1, 1},
  30.                             .dns = {0,0,0,0},
  31.                             .dhcp = NETINFO_STATIC };
  32. /* Private variables ---------------------------------------------------------*/
  33. /* Private function prototypes -----------------------------------------------*/
  34. /* Private functions ---------------------------------------------------------*/
  35. void platform_init(void);        // initialize the dependent host peripheral
  36. void my_ip_assign(void);
  37. void network_init(void);
  38.
  39.
  40.
  41.
  42.
  43. /************************************
  44. * @ brief Call back for ip Conflict
  45. ************************************/
  46. void my_ip_conflict(void)
  47. {
  48.         printf("CONFLICT IP from DHCP\r\n");
  49.         //halt or reset or any...
  50.         while(1); // this example is halt.
  51. }
  52. /**
  53.   * @brief  串口打印輸出
  54.   * @param  None
  55.   * @retval None
  56.   */
  57. int main(void)
  58. {
  59.         uint8_t tmp;
  60.         uint8_t memsize[2][8] = { {2,2,2,2,2,2,2,2},{2,2,2,2,2,2,2,2}};
  61.         uint8_t my_dhcp_retry = 0;
  62.
  63.         //Host dependent peripheral initialized
  64.         platform_init();
  65.         // First of all, Should register SPI callback functions implemented by user for accessing WIZCHIP
  66.         /* Critical section callback */
  67.         reg_wizchip_cris_cbfunc(SPI_CrisEnter, SPI_CrisExit);        //注冊臨界區函數
  68.         /* Chip selection call back */
  69. #if   _WIZCHIP_IO_MODE_ == _WIZCHIP_IO_MODE_SPI_VDM_
  70.         reg_wizchip_cs_cbfunc(SPI_CS_Select, SPI_CS_Deselect);//注冊SPI片選信號函數
  71. #elif _WIZCHIP_IO_MODE_ == _WIZCHIP_IO_MODE_SPI_FDM_
  72.         reg_wizchip_cs_cbfunc(SPI_CS_Select, SPI_CS_Deselect);  // CS must be tried with LOW.
  73. #else
  74.    #if (_WIZCHIP_IO_MODE_ & _WIZCHIP_IO_MODE_SIP_) != _WIZCHIP_IO_MODE_SIP_
  75.       #error "Unknown _WIZCHIP_IO_MODE_"
  76.    #else
  77.       reg_wizchip_cs_cbfunc(wizchip_select, wizchip_deselect);
  78.    #endif
  79. #endif
  80.         /* SPI Read & Write callback function */
  81.         reg_wizchip_spi_cbfunc(SPI_ReadByte, SPI_WriteByte);        //注冊讀寫函數
  82.         /* WIZCHIP SOCKET Buffer initialize */
  83.         if(ctlwizchip(CW_INIT_WIZCHIP,(void*)memsize) == -1){
  84.                  printf("WIZCHIP Initialized fail.\r\n");
  85.                  while(1);
  86.         }
  87.         /* PHY link status check */
  88.         do{
  89.                  if(ctlwizchip(CW_GET_PHYLINK, (void*)&tmp) == -1){
  90.                                 printf("Unknown PHY Link stauts.\r\n");
  91.                  }
  92.         }while(tmp == PHY_LINK_OFF);
  93.     /************************************************/
  94.     /* WIZnet W5500 Code Examples :                                 */
  95.     /* Implemented using ioLibrary_BSD Socket APIs        */
  96.     /************************************************/
  97.     /* >> DHCP Client        */
  98.     /************************************************/
  99.     // must be set the default mac before DHCP started.
  100.         setSHAR(gWIZNETINFO.mac);
  101.         DHCP_init(SOCK_DHCP, gDATABUF);
  102.         // if you want defiffent action instead defalut ip assign,update, conflict,
  103.         // if cbfunc == 0, act as default.
  104.         reg_dhcp_cbfunc(my_ip_assign, my_ip_assign, my_ip_conflict);
  105.     httpServer_init(http_tx_buf,http_rx_buf,7,socklist);
  106.     sprintf(index_html,INDEX_HTML_C,"");
  107.         /* Main Loop */
  108.         while(1)
  109.         {
  110.                 switch(DHCP_run())
  111.                 {
  112.                         case DHCP_IP_ASSIGN:
  113.                         case DHCP_IP_CHANGED:
  114.                                 /* If this block empty, act with default_ip_assign & default_ip_update */
  115.                                 //
  116.                                 // This example calls my_ip_assign in the two case.
  117.                                 //
  118.                                 // Add to ...
  119.                                 //
  120.                                 break;
  121.                         case DHCP_IP_LEASED:
  122.                                 //
  123.                                 // TO DO YOUR NETWORK APPs.
  124.                                 //
  125.                                 break;
  126.                         case DHCP_FAILED:
  127.                                 /* ===== Example pseudo code =====  */
  128.                                 // The below code can be replaced your code or omitted.
  129.                                 // if omitted, retry to process DHCP
  130.                                 my_dhcp_retry++;
  131.                                 if(my_dhcp_retry > MY_MAX_DHCP_RETRY)
  132.                                 {
  133.                                         printf(">> DHCP %d Failed\r\n", my_dhcp_retry);
  134.                                         my_dhcp_retry = 0;
  135.                                         DHCP_stop();      // if restart, recall DHCP_init()
  136.                                         network_init();   // apply the default static network and print out netinfo to serial
  137.                                 }
  138.                                 break;
  139.                         default:
  140.                                 break;
  141.                 }
  142.         httpServer_run(0);
  143.         httpServer_run(1);
  144.         httpServer_run(2);
  145.         httpServer_run(3);
  146.         httpServer_run(4);
  147.         httpServer_run(5);
  148.         httpServer_run(6);
  149.         }
  150. } // end of main()
  151. /**
  152.   * @brief  Loopback Test Example Code using ioLibrary_BSD
  153.   * @retval None
  154.   */
  155. void platform_init(void)
  156. {
  157.         SystemInit();//系統時鐘初始化
  158.         USART_Configuration();//串口1初始化
  159.         //Config SPI
  160.         SPI_Configuration();
  161.         //延時初始化
  162.         delay_init();
  163. }
  164. /*******************************************************
  165. * @ brief Call back for ip assing & ip update from DHCP
  166. *******************************************************/
  167. void my_ip_assign(void)
  168. {
  169.    getIPfromDHCP(gWIZNETINFO.ip);
  170.    getGWfromDHCP(gWIZNETINFO.gw);
  171.    getSNfromDHCP(gWIZNETINFO.sn);
  172.    getDNSfromDHCP(gWIZNETINFO.dns);
  173.    gWIZNETINFO.dhcp = NETINFO_DHCP;
  174.    /* Network initialization */
  175.    network_init();      // apply from dhcp
  176.    printf("DHCP LEASED TIME : %d Sec.\r\n", getDHCPLeasetime());
  177. }
  178. /******************************************************************************
  179. * @brief  Network Init
  180. * Intialize the network information to be used in WIZCHIP
  181. *****************************************************************************/
  182. void network_init(void)
  183. {
  184.         uint8_t tmpstr[6] = {0};
  185.         wiz_NetInfo netinfo;
  186.         // Set Network information from netinfo structure
  187.         ctlnetwork(CN_SET_NETINFO, (void*)&gWIZNETINFO);
  188.         // Get Network information
  189.         ctlnetwork(CN_GET_NETINFO, (void*)&netinfo);
  190.         // Display Network Information
  191.         ctlwizchip(CW_GET_ID,(void*)tmpstr);
  192.         if(netinfo.dhcp == NETINFO_DHCP) printf("\r\n=== %s NET CONF : DHCP ===\r\n",(char*)tmpstr);
  193.         else printf("\r\n=== %s NET CONF : Static ===\r\n",(char*)tmpstr);
  194.         printf("MAC: %02X:%02X:%02X:%02X:%02X:%02X\r\n",netinfo.mac[0],netinfo.mac[1],netinfo.mac[2],
  195.                         netinfo.mac[3],netinfo.mac[4],netinfo.mac[5]);
  196.         printf("SIP: %d.%d.%d.%d\r\n", netinfo.ip[0],netinfo.ip[1],netinfo.ip[2],netinfo.ip[3]);
  197.         printf("GAR: %d.%d.%d.%d\r\n", netinfo.gw[0],netinfo.gw[1],netinfo.gw[2],netinfo.gw[3]);
  198.         printf("SUB: %d.%d.%d.%d\r\n", netinfo.sn[0],netinfo.sn[1],netinfo.sn[2],netinfo.sn[3]);
  199.         printf("DNS: %d.%d.%d.%d\r\n", netinfo.dns[0],netinfo.dns[1],netinfo.dns[2],netinfo.dns[3]);
  200.         printf("===========================\r\n");
  201. }
  202. /*********************************END OF FILE**********************************/
stm32_w5500_dhcp+http.rar (744.49 KB, 下載次數: 404)
收藏收藏8 分享淘帖 頂1 踩
ID:298882 發表于 2018-3-29 14:54 | 只看該作者
正好是我想找的,只有這里有,下來看看學習一下
ID:552154 發表于 2019-7-16 09:43 | 只看該作者
還是下載不了
ID:580104 發表于 2019-7-16 10:20 | 只看該作者
沒幣,先留個標記,等有黑幣了再下吧!
ID:322573 發表于 2019-9-12 21:30 | 只看該作者
學習一下,不錯啊
ID:625716 發表于 2019-10-17 16:38 | 只看該作者
下載不了啥情況 樓主能發我下么  我最近正想搞這一塊
ID:39439 發表于 2019-10-18 08:28 | 只看該作者
好東西
ID:402986 發表于 2020-7-21 17:53 | 只看該作者
一直不知道怎么通過HTTP去接收數據,感謝分享~
ID:984493 發表于 2021-11-25 10:39 | 只看該作者
非常感謝樓主分享,也算是值得的。
ID:974713 發表于 2022-2-22 15:38 | 只看該作者
謝謝樓主,不過不是我想要的,樓主使用的代碼基本上來源于github上面,大家在github上搜索下w5500就用,我想要的是監聽w5500拔插,發現重新連接上之后,重新運行dhcp獲取新ip地址。
ID:974713 發表于 2022-2-22 15:40 | 只看該作者
剛剛找到解決辦法了,CW_GET_PHYLINK就是獲取鏈路狀態。
主站蜘蛛池模板: 亚洲午夜在线 | 欧美成在线 | 黄色特级片| 欧美日韩在线看 | 欧美不卡在线观看 | 深夜福利视频在线观看 | 一区二区三区国产精品 | 天天久久 | 97视频免费在线观看 | 黄色在线小视频 | www.欧美日韩 | 黄色片网站免费 | 亚洲人天堂 | 欧美精品一级片 | 成人高清视频在线观看 | 三上悠亚激情av一区二区三区 | 亚洲综合激情五月久久 | 色草在线 | 午夜国产在线观看 | 一级毛片黄色 | 国产精品久久久久久无人区 | 麻豆精品一区二区 | 黄色片一区二区 | 国产日韩欧美日韩大片 | 日本黄色三级视频 | 中文字幕av在线播放 | 免费的黄色网址 | 18视频在线观看男男 | 亚洲欧美日韩色图 | 国产精品手机在线观看 | 国产一区二区三区免费 | 黄色大片免费在线观看 | 四虎网站在线观看 | 色婷婷精品国产一区二区三区 | 伊人久久在线 | 久草网站 | 欧美黄色三级视频 | 日本在线www | 黄色片视频在线观看 | 天天综合天天 | 日韩高清一区二区 |
