查看: 4743|回復: 2
發一個利用兩個IIC數字光傳感器(BH1750),進行平面定位
ID:125150 發表于 2018-3-31 16:42 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
看了去年電賽,在網上查呢下,很少有資料分享,最近剛好在做可見光定位,所以先將寫的兩個IIC數字光傳感器(BH1750),采用差分方式進行定位程序分享下,還在改進中,完成后將全部開放!(用的是arduino UNOd的板子)
arduino源程序如下:
  1. #include <Wire.h> //BH1750 IIC Mode
  2. #include <math.h>
  3. #include <SPI.h>
  4. #include <Wire.h>
  5. #include <Adafruit_GFX.h>
  6. #include <Adafruit_SSD1306.h>
  7. int potpin=0;
  8. int a;//定義模擬接口0
  9. int now;
  10. int BH1750address0 = 0x5c; //setting i2c address
  11. int BH1750address1 = 0x23;
  12. uint16_t val0=0;
  13.   uint16_t val1=0;
  14. byte buff0[2];
  15. byte buff1[2];
  16. #define OLED_RESET 4
  17. Adafruit_SSD1306 display(OLED_RESET);
  18.
  19. static const unsigned char PROGMEM logo[] =
  20. {
  21. /*--  調入了一幅圖像:這是您新建的圖像  --*/
  22. /*--  寬度x高度=128x64  --*/
  23. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  24. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  25. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  26. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  27. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  28. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  29. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  30. 0x00,0x00,0x00,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  31. 0x00,0x00,0x01,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  32. 0x00,0x00,0x01,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  33. 0x00,0x00,0x01,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  34. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  35. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  36. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  37. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  38. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  39. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  40. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  41. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  42. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  43. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  44. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  45. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  46. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  47. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  48. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  49. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  50. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  51. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  52. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  53. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  54. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  55. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  56. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  57. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  58. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  59. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  60. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  61. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  62. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  63. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  64. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  65. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  66. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  67. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  68. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  69. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  70. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  71. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  72. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  73. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  74. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  75. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  76. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  77. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  78. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  79. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  80. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  81. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  82. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  83. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  84. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  85. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  86. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
  87. };
  88.
  89. #if (SSD1306_LCDHEIGHT != 64)
  90. #error("Height incorrect, please fix Adafruit_SSD1306.h!");
  91. #endif
  92.   int outputValue,outputValue1;
  93. void setup()
  94. {  outputValue=0;
  95.   outputValue1=0;
  96.   Wire.begin();
  97.   Serial.begin(19200);
  98.   display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
  99.   display.clearDisplay();
  100. }
  101. void loop()
  102. {a=analogRead(potpin);//讀取模擬接口0 的值,
  103.   int i,j;
  104. // uint16_t val0=0;
  105. // uint16_t val1=0;
  106.   BH1750_Init(BH1750address0);
  107.   BH1750_Init(BH1750address1);
  108.   delay(200);
  109.   if(2==BH1750_Read0(BH1750address0))
  110.   {
  111.     val0=((buff0[0]<<8)|buff0[1])/1.2;
  112.      Serial.print(now);
  113.   Serial.print( ",");
  114.     Serial.print(val0,DEC);
  115.     Serial.print(",");
  116.       Serial.print(val1,DEC);
  117.    Serial.print(",");
  118.        Serial.print(val1,DEC);
  119.     Serial.print(";");
  120.   }
  121.   delay(10);
  122. if(2==BH1750_Read1(BH1750address1))
  123.   {
  124.     val1=((buff1[0]<<8)|buff1[1])/1.2;
  125.      Serial.print(now);
  126.   Serial.print( ",");
  127.     Serial.print(val0,DEC);
  128.    Serial.print(",");
  129. Serial.print(val1,DEC);
  130.     Serial.print(",");
  131.     Serial.print(val1,DEC);
  132.     Serial.print(";");
  133.
  134.   }
  135.   delay(10);
  136.
  137.    outputValue = map(val0, 0, 700, 0, 64);
  138.     outputValue1 = map(val1, 0, 700, 0, 128);
  139.    display.drawBitmap(outputValue1,outputValue , logo, 128, 64,1);  //在坐標X0,Y0的位置開始顯示圖片
  140.                                                //128是取模軟件顯示的寬度
  141.                                                //64是取模軟件顯示的高度
  142. display.display();                           //把緩存的都顯示
  143.   delay(1);
  144.
  145.   display.clearDisplay();    //清除屏幕
  146.   delay(10);
  147. }
  148. int BH1750_Read0(int address) //
  149. {
  150.   int i=0;
  151.   Wire.beginTransmission(address);
  152.   Wire.requestFrom(address, 2);
  153.   while(Wire.available()) //
  154.   {
  155.     buff0[i] = Wire.read();  // receive one byte
  156.     i++;
  157.   }
  158.     Wire.endTransmission();
  159.     return i;
  160. }
  161. int BH1750_Read1(int address) //
  162. {
  163.   int j=0;
  164.   Wire.beginTransmission(address);
  165.   Wire.requestFrom(address, 2);
  166.   while(Wire.available()) //
  167.   {
  168.     buff1[j] = Wire.read();  // receive one byte
  169.     j++;
  170.   }
  171.   Wire.endTransmission();
  172.   return j;
  173. }
  174. void BH1750_Init(int address)
  175. {
  176.   Wire.beginTransmission(address);
  177.   Wire.write(0x10);//1lx reolution 120ms
  178.   Wire.endTransmission();
  179. }
下載:
bh1750s.rar (1.32 KB, 下載次數: 22)
ID:454017 發表于 2019-4-14 10:19 來自觸屏版 | 只看該作者
樓主做完了嗎?我用51單片機去做,速度趕不趕得上
ID:560595 發表于 2019-6-28 15:55 | 只看該作者
樓主做完了嗎?
主站蜘蛛池模板: www.久久精品 | 欧美网站在线观看 | 伊人一区| 麻豆精品在线播放 | 天天做天天爱 | 国产伦理一区 | 欧美日韩免费看 | 国产一区高清 | av免费网| 精品久久网 | 日本美女性生活 | 国产黄色大片 | 亚洲一区在线视频 | 一区视频在线 | 国产成人高清 | 中文字幕在 | 欧美激情综合 | 亚洲乱码在线观看 | 日本中文字幕在线 | 中文字幕在线免费观看 | 五月天婷婷社区 | 日韩视频在线观看 | 91欧美日韩 | 欧美日韩中文字幕在线 | 欧美18免费视频 | 欧美久久网 | 永久黄网站色视频免费观看w | 成人免费网站黄 | 国产在线播放av | 国产欧美激情 | 香蕉视频免费 | 影音先锋国产精品 | 日韩一区二区在线视频 | 日韩中文字幕精品 | 国产成人在线播放 | 欧美精品网 | 欧美成人一区二区三区 | 成人激情综合网 | 四虎久久 | 91精品国产一区二区三区 | 日韩欧美在线一区 |
