MPU6050的資料打包:
mpu6050的arduino源程序如下:
- // I2Cdev library collection - MPU6050 I2C device class
- // Based on InvenSense MPU-6050 register map document rev. 2.0, 5/19/2011 (RM-MPU-6000A-00)
- // 8/24/2011 by Jeff Rowberg <jeff@rowberg.net>
- // Updates should (hopefully) always be available at https://github.com/jrowberg/i2cdevlib
- // Changelog:
- // ... - ongoing debug release
- // NOTE: THIS IS ONLY A PARIAL RELEASE. THIS DEVICE CLASS IS CURRENTLY UNDERGOING ACTIVE
- // DEVELOPMENT AND IS STILL MISSING SOME IMPORTANT FEATURES. PLEASE KEEP THIS IN MIND IF
- // YOU DECIDE TO USE THIS PARTICULAR CODE FOR ANYTHING.
- I2Cdev device library code is placed under the MIT license
- Copyright (c) 2011 Jeff Rowberg
- Permission is hereby granted, free of charge, to any person obtaining a copy
- of this software and associated documentation files (the "Software"), to deal
- in the Software without restriction, including without limitation the rights
- to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
- copies of the Software, and to permit persons to whom the Software is
- furnished to do so, subject to the following conditions:
- The above copyright notice and this permission notice shall be included in
- all copies or substantial portions of the Software.
- THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
- AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
- OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
- THE SOFTWARE.
- #include "MPU6050.h"
- /** Default constructor, uses default I2C address.
- * @see MPU6050_DEFAULT_ADDRESS
- MPU6050::MPU6050() {
- devAddr = MPU6050_DEFAULT_ADDRESS;
- /** Specific address constructor.
- * @param address I2C address
- * @see MPU6050_ADDRESS_AD0_LOW
- * @see MPU6050_ADDRESS_AD0_HIGH
- MPU6050::MPU6050(uint8_t address) {
- devAddr = address;
- /** Power on and prepare for general usage.
- * This will activate the device and take it out of sleep mode (which must be done
- * after start-up). This function also sets both the accelerometer and the gyroscope
- * to their most sensitive settings, namely +/- 2g and +/- 250 degrees/sec, and sets
- * the clock source to use the X Gyro for reference, which is slightly better than
- * the default internal clock source.
- void MPU6050::initialize() {
- setClockSource(MPU6050_CLOCK_PLL_XGYRO);
- setFullScaleGyroRange(MPU6050_GYRO_FS_250);
- setFullScaleAccelRange(MPU6050_ACCEL_FS_2);
- setSleepEnabled(false); // thanks to Jack Elston for pointing this one out!
- /** Verify the I2C connection.
- * Make sure the device is connected and responds as expected.
- * @return True if connection is valid, false otherwise
- bool MPU6050::testConnection() {
- return getDeviceID() == 0b110100;
- // AUX_VDDIO register (InvenSense demo code calls this RA_*G_OFFS_TC)
- /** Get the auxiliary I2C supply voltage level.
- * When set to 1, the auxiliary I2C bus high logic level is VDD. When cleared to
- * 0, the auxiliary I2C bus high logic level is VLOGIC. This does not apply to
- * the MPU-6000, which does not have a VLOGIC pin.
- * @return I2C supply voltage level (0=VLOGIC, 1=VDD)
- uint8_t MPU6050::getAuxVDDIOLevel() {
- I2Cdev::readBit(devAddr, MPU6050_RA_YG_OFFS_TC, MPU6050_TC_PWR_MODE_BIT, buffer);
- return buffer[0];
- /** Set the auxiliary I2C supply voltage level.
- * @param level I2C supply voltage level (0=VLOGIC, 1=VDD)
- void MPU6050::setAuxVDDIOLevel(uint8_t level) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_YG_OFFS_TC, MPU6050_TC_PWR_MODE_BIT, level);
- // SMPLRT_DIV register
- /** Get gyroscope output rate divider.
- * The sensor register output, FIFO output, DMP sampling, Motion detection, Zero
- * Motion detection, and Free Fall detection are all based on the Sample Rate.
- * The Sample Rate is generated by dividing the gyroscope output rate by
- * SMPLRT_DIV:
- * Sample Rate = Gyroscope Output Rate / (1 + SMPLRT_DIV)
- * where Gyroscope Output Rate = 8kHz when the DLPF is disabled (DLPF_CFG = 0 or
- * 7), and 1kHz when the DLPF is enabled (see Register 26).
- * Note: The accelerometer output rate is 1kHz. This means that for a Sample
- * Rate greater than 1kHz, the same accelerometer sample may be output to the
- * FIFO, DMP, and sensor registers more than once.
- * For a diagram of the gyroscope and accelerometer signal paths, see Section 8
- * of the MPU-6000/MPU-6050 Product Specification document.
- * @return Current sample rate
- * @see MPU6050_RA_SMPLRT_DIV
- uint8_t MPU6050::getRate() {
- return I2Cdev::readByte(devAddr, MPU6050_RA_SMPLRT_DIV, buffer);
- return buffer[0];
- /** Set gyroscope sample rate divider.
- * @param rate New sample rate divider
- * @see getRate()
- void MPU6050::setRate(uint8_t rate) {
- I2Cdev::writeByte(devAddr, MPU6050_RA_SMPLRT_DIV, rate);
- // CONFIG register
- /** Get external FSYNC configuration.
- * Configures the external Frame Synchronization (FSYNC) pin sampling. An
- * external signal connected to the FSYNC pin can be sampled by configuring
- * EXT_SYNC_SET. Signal changes to the FSYNC pin are latched so that short
- * strobes may be captured. The latched FSYNC signal will be sampled at the
- * Sampling Rate, as defined in register 25. After sampling, the latch will
- * reset to the current FSYNC signal state.
- * The sampled value will be reported in place of the least significant bit in
- * a sensor data register determined by the value of EXT_SYNC_SET according to
- * the following table.
- * <pre>
- * EXT_SYNC_SET | FSYNC Bit Location
- * 0 | Input disabled
- * 1 | TEMP_OUT_L[0]
- * 2 | GYRO_XOUT_L[0]
- * 3 | GYRO_YOUT_L[0]
- * 4 | GYRO_ZOUT_L[0]
- * 5 | ACCEL_XOUT_L[0]
- * 6 | ACCEL_YOUT_L[0]
- * 7 | ACCEL_ZOUT_L[0]
- * </pre>
- * @return FSYNC configuration value
- uint8_t MPU6050::getExternalFrameSync() {
- I2Cdev::readBits(devAddr, MPU6050_RA_CONFIG, MPU6050_CFG_EXT_SYNC_SET_BIT, MPU6050_CFG_EXT_SYNC_SET_LENGTH, buffer);
- return buffer[0];
- /** Set external FSYNC configuration.
- * @see getExternalFrameSync()
- * @see MPU6050_RA_CONFIG
- * @param sync New FSYNC configuration value
- void MPU6050::setExternalFrameSync(uint8_t sync) {
- I2Cdev::writeBits(devAddr, MPU6050_RA_CONFIG, MPU6050_CFG_EXT_SYNC_SET_BIT, MPU6050_CFG_EXT_SYNC_SET_LENGTH, sync);
- /** Get digital low-pass filter configuration.
- * The DLPF_CFG parameter sets the digital low pass filter configuration. It
- * also determines the internal sampling rate used by the device as shown in
- * the table below.
- * <pre>
- * | ACCELEROMETER | GYROSCOPE
- * DLPF_CFG | Bandwidth | Delay | Bandwidth | Delay | Sample Rate
- * 0 | 260Hz | 0ms | 256Hz | 0.98ms | 8kHz
- * 1 | 184Hz | 2.0ms | 188Hz | 1.9ms | 1kHz
- * 2 | 94Hz | 3.0ms | 98Hz | 2.8ms | 1kHz
- * 3 | 44Hz | 4.9ms | 42Hz | 4.8ms | 1kHz
- * 4 | 21Hz | 8.5ms | 20Hz | 8.3ms | 1kHz
- * 5 | 10Hz | 13.8ms | 10Hz | 13.4ms | 1kHz
- * 6 | 5Hz | 19.0ms | 5Hz | 18.6ms | 1kHz
- * 7 | -- Reserved -- | -- Reserved -- | Reserved
- * </pre>
- * @return DLFP configuration
- * @see MPU6050_CFG_DLPF_CFG_BIT
- * @see MPU6050_CFG_DLPF_CFG_LENGTH
- uint8_t MPU6050::getDLPFMode() {
- I2Cdev::readBits(devAddr, MPU6050_RA_CONFIG, MPU6050_CFG_DLPF_CFG_BIT, MPU6050_CFG_DLPF_CFG_LENGTH, buffer);
- return buffer[0];
- /** Set digital low-pass filter configuration.
- * @param mode New DLFP configuration setting
- * @see getDLPFBandwidth()
- * @see MPU6050_DLPF_BW_256
- void MPU6050::setDLPFMode(uint8_t mode) {
- I2Cdev::writeBits(devAddr, MPU6050_RA_CONFIG, MPU6050_CFG_DLPF_CFG_BIT, MPU6050_CFG_DLPF_CFG_LENGTH, mode);
- // GYRO_CONFIG register
- /** Get full-scale gyroscope range.
- * The FS_SEL parameter allows setting the full-scale range of the gyro sensors,
- * as described in the table below.
- * <pre>
- * 0 = +/- 250 degrees/sec
- * 1 = +/- 500 degrees/sec
- * 2 = +/- 1000 degrees/sec
- * 3 = +/- 2000 degrees/sec
- * </pre>
- * @return Current full-scale gyroscope range setting
- * @see MPU6050_GYRO_FS_250
- * @see MPU6050_RA_GYRO_CONFIG
- * @see MPU6050_GCONFIG_FS_SEL_BIT
- * @see MPU6050_GCONFIG_FS_SEL_LENGTH
- uint8_t MPU6050::getFullScaleGyroRange() {
- I2Cdev::readBits(devAddr, MPU6050_RA_GYRO_CONFIG, MPU6050_GCONFIG_FS_SEL_BIT, MPU6050_GCONFIG_FS_SEL_LENGTH, buffer);
- return buffer[0];
- /** Set full-scale gyroscope range.
- * @param range New full-scale gyroscope range value
- * @see getFullScaleRange()
- void MPU6050::setFullScaleGyroRange(uint8_t range) {
- I2Cdev::writeBits(devAddr, MPU6050_RA_GYRO_CONFIG, MPU6050_GCONFIG_FS_SEL_BIT, MPU6050_GCONFIG_FS_SEL_LENGTH, range);
- // ACCEL_CONFIG register
- /** Get self-test enabled setting for accelerometer X axis.
- * @return Self-test enabled value
- * @see MPU6050_RA_ACCEL_CONFIG
- bool MPU6050::getAccelXSelfTest() {
- I2Cdev::readBit(devAddr, MPU6050_RA_ACCEL_CONFIG, MPU6050_ACONFIG_XA_ST_BIT, buffer);
- return buffer[0];
- * @param enabled Self-test enabled value
- void MPU6050::setAccelXSelfTest(bool enabled) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_ACCEL_CONFIG, MPU6050_ACONFIG_XA_ST_BIT, enabled);
- /** Get self-test enabled value for accelerometer Y axis.
- bool MPU6050::getAccelYSelfTest() {
- I2Cdev::readBit(devAddr, MPU6050_RA_ACCEL_CONFIG, MPU6050_ACONFIG_YA_ST_BIT, buffer);
- return buffer[0];
- void MPU6050::setAccelYSelfTest(bool enabled) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_ACCEL_CONFIG, MPU6050_ACONFIG_YA_ST_BIT, enabled);
- /** Get self-test enabled value for accelerometer Z axis.
- bool MPU6050::getAccelZSelfTest() {
- I2Cdev::readBit(devAddr, MPU6050_RA_ACCEL_CONFIG, MPU6050_ACONFIG_ZA_ST_BIT, buffer);
- return buffer[0];
- /** Set self-test enabled value for accelerometer Z axis.
- void MPU6050::setAccelZSelfTest(bool enabled) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_ACCEL_CONFIG, MPU6050_ACONFIG_ZA_ST_BIT, enabled);
- /** Get full-scale accelerometer range.
- * The FS_SEL parameter allows setting the full-scale range of the accelerometer
- * sensors, as described in the table below.
- * <pre>
- * 0 = +/- 2g
- * 1 = +/- 4g
- * 2 = +/- 8g
- * 3 = +/- 16g
- * </pre>
- * @return Current full-scale accelerometer range setting
- * @see MPU6050_ACCEL_FS_2
- * @see MPU6050_ACONFIG_AFS_SEL_BIT
- * @see MPU6050_ACONFIG_AFS_SEL_LENGTH
- uint8_t MPU6050::getFullScaleAccelRange() {
- I2Cdev::readBits(devAddr, MPU6050_RA_ACCEL_CONFIG, MPU6050_ACONFIG_AFS_SEL_BIT, MPU6050_ACONFIG_AFS_SEL_LENGTH, buffer);
- return buffer[0];
- /** Set full-scale accelerometer range.
- * @param range New full-scale accelerometer range setting
- * @see getFullScaleAccelRange()
- void MPU6050::setFullScaleAccelRange(uint8_t range) {
- I2Cdev::writeBits(devAddr, MPU6050_RA_ACCEL_CONFIG, MPU6050_ACONFIG_AFS_SEL_BIT, MPU6050_ACONFIG_AFS_SEL_LENGTH, range);
- /** Get the high-pass filter configuration.
- * The DHPF is a filter module in the path leading to motion detectors (Free
- * Fall, Motion threshold, and Zero Motion). The high pass filter output is not
- * available to the data registers (see Figure in Section 8 of the MPU-6000/
- * MPU-6050 Product Specification document).
- * The high pass filter has three modes:
- * <pre>
- * Reset: The filter output settles to zero within one sample. This
- * effectively disables the high pass filter. This mode may be toggled
- * to quickly settle the filter.
- * On: The high pass filter will pass signals above the cut off frequency.
- * Hold: When triggered, the filter holds the present sample. The filter
- * output will be the difference between the input sample and the held
- * sample.
- * </pre>
- * <pre>
- * ACCEL_HPF | Filter Mode | Cut-off Frequency
- * 0 | Reset | None
- * 1 | On | 5Hz
- * 2 | On | 2.5Hz
- * 3 | On | 1.25Hz
- * 4 | On | 0.63Hz
- * 7 | Hold | None
- * </pre>
- * @return Current high-pass filter configuration
- * @see MPU6050_DHPF_RESET
- uint8_t MPU6050::getDHPFMode() {
- I2Cdev::readBits(devAddr, MPU6050_RA_ACCEL_CONFIG, MPU6050_ACONFIG_ACCEL_HPF_BIT, MPU6050_ACONFIG_ACCEL_HPF_LENGTH, buffer);
- return buffer[0];
- /** Set the high-pass filter configuration.
- * @param bandwidth New high-pass filter configuration
- * @see setDHPFMode()
- void MPU6050::setDHPFMode(uint8_t bandwidth) {
- I2Cdev::writeBits(devAddr, MPU6050_RA_ACCEL_CONFIG, MPU6050_ACONFIG_ACCEL_HPF_BIT, MPU6050_ACONFIG_ACCEL_HPF_LENGTH, bandwidth);
- // FF_THR register
- /** Get free-fall event acceleration threshold.
- * This register configures the detection threshold for Free Fall event
- * detection. The unit of FF_THR is 1LSB = 2mg. Free Fall is detected when the
- * absolute value of the accelerometer measurements for the three axes are each
- * less than the detection threshold. This condition increments the Free Fall
- * duration counter (Register 30). The Free Fall interrupt is triggered when the
- * Free Fall duration counter reaches the time specified in FF_DUR.
- * For more details on the Free Fall detection interrupt, see Section 8.2 of the
- * MPU-6000/MPU-6050 Product Specification document as well as Registers 56 and
- * 58 of this document.
- * @return Current free-fall acceleration threshold value (LSB = 2mg)
- * @see MPU6050_RA_FF_THR
- uint8_t MPU6050::getFreefallDetectionThreshold() {
- I2Cdev::readByte(devAddr, MPU6050_RA_FF_THR, buffer);
- return buffer[0];
- * @param threshold New free-fall acceleration threshold value (LSB = 2mg)
- * @see getFreefallDetectionThreshold()
- void MPU6050::setFreefallDetectionThreshold(uint8_t threshold) {
- I2Cdev::writeByte(devAddr, MPU6050_RA_FF_THR, threshold);
- // FF_DUR register
- /** Get free-fall event duration threshold.
- * This register configures the duration counter threshold for Free Fall event
- * detection. The duration counter ticks at 1kHz, therefore FF_DUR has a unit
- * of 1 LSB = 1 ms.
- * The Free Fall duration counter increments while the absolute value of the
- * accelerometer measurements are each less than the detection threshold
- * (Register 29). The Free Fall interrupt is triggered when the Free Fall
- * duration counter reaches the time specified in this register.
- * the MPU-6000/MPU-6050 Product Specification document as well as Registers 56
- * and 58 of this document.
- * @return Current free-fall duration threshold value (LSB = 1ms)
- * @see MPU6050_RA_FF_DUR
- uint8_t MPU6050::getFreefallDetectionDuration() {
- I2Cdev::readByte(devAddr, MPU6050_RA_FF_DUR, buffer);
- return buffer[0];
- * @param duration New free-fall duration threshold value (LSB = 1ms)
- * @see getFreefallDetectionDuration()
- void MPU6050::setFreefallDetectionDuration(uint8_t duration) {
- I2Cdev::writeByte(devAddr, MPU6050_RA_FF_DUR, duration);
- // MOT_THR register
- /** Get motion detection event acceleration threshold.
- * This register configures the detection threshold for Motion interrupt
- * generation. The unit of MOT_THR is 1LSB = 2mg. Motion is detected when the
- * absolute value of any of the accelerometer measurements exceeds this Motion
- * detection threshold. This condition increments the Motion detection duration
- * counter (Register 32). The Motion detection interrupt is triggered when the
- * Motion Detection counter reaches the time count specified in MOT_DUR
- * (Register 32).
- * The Motion interrupt will indicate the axis and polarity of detected motion
- * in MOT_DETECT_STATUS (Register 97).
- * For more details on the Motion detection interrupt, see Section 8.3 of the
- * @return Current motion detection acceleration threshold value (LSB = 2mg)
- * @see MPU6050_RA_MOT_THR
- uint8_t MPU6050::getMotionDetectionThreshold() {
- I2Cdev::readByte(devAddr, MPU6050_RA_MOT_THR, buffer);
- return buffer[0];
- /** Set free-fall event acceleration threshold.
- * @param threshold New motion detection acceleration threshold value (LSB = 2mg)
- * @see getMotionDetectionThreshold()
- void MPU6050::setMotionDetectionThreshold(uint8_t threshold) {
- I2Cdev::writeByte(devAddr, MPU6050_RA_MOT_THR, threshold);
- // MOT_DUR register
- /** Get motion detection event duration threshold.
- * This register configures the duration counter threshold for Motion interrupt
- * generation. The duration counter ticks at 1 kHz, therefore MOT_DUR has a unit
- * of 1LSB = 1ms. The Motion detection duration counter increments when the
- * absolute value of any of the accelerometer measurements exceeds the Motion
- * detection threshold (Register 31). The Motion detection interrupt is
- * triggered when the Motion detection counter reaches the time count specified
- * in this register.
- * MPU-6000/MPU-6050 Product Specification document.
- * @return Current motion detection duration threshold value (LSB = 1ms)
- * @see MPU6050_RA_MOT_DUR
- uint8_t MPU6050::getMotionDetectionDuration() {
- I2Cdev::readByte(devAddr, MPU6050_RA_MOT_DUR, buffer);
- return buffer[0];
- /** Set motion detection event duration threshold.
- * @param duration New motion detection duration threshold value (LSB = 1ms)
- * @see getMotionDetectionDuration()
- void MPU6050::setMotionDetectionDuration(uint8_t duration) {
- I2Cdev::writeByte(devAddr, MPU6050_RA_MOT_DUR, duration);
- // ZRMOT_THR register
- /** Get zero motion detection event acceleration threshold.
- * This register configures the detection threshold for Zero Motion interrupt
- * generation. The unit of ZRMOT_THR is 1LSB = 2mg. Zero Motion is detected when
- * the absolute value of the accelerometer measurements for the 3 axes are each
- * less than the detection threshold. This condition increments the Zero Motion
- * duration counter (Register 34). The Zero Motion interrupt is triggered when
- * the Zero Motion duration counter reaches the time count specified in
- * ZRMOT_DUR (Register 34).
- * Unlike Free Fall or Motion detection, Zero Motion detection triggers an
- * interrupt both when Zero Motion is first detected and when Zero Motion is no
- * longer detected.
- * When a zero motion event is detected, a Zero Motion Status will be indicated
- * in the MOT_DETECT_STATUS register (Register 97). When a motion-to-zero-motion
- * condition is detected, the status bit is set to 1. When a zero-motion-to-
- * motion condition is detected, the status bit is set to 0.
- * For more details on the Zero Motion detection interrupt, see Section 8.4 of
- * @return Current zero motion detection acceleration threshold value (LSB = 2mg)
- * @see MPU6050_RA_ZRMOT_THR
- uint8_t MPU6050::getZeroMotionDetectionThreshold() {
- I2Cdev::readByte(devAddr, MPU6050_RA_ZRMOT_THR, buffer);
- return buffer[0];
- /** Set zero motion detection event acceleration threshold.
- * @param threshold New zero motion detection acceleration threshold value (LSB = 2mg)
- * @see getZeroMotionDetectionThreshold()
- void MPU6050::setZeroMotionDetectionThreshold(uint8_t threshold) {
- I2Cdev::writeByte(devAddr, MPU6050_RA_ZRMOT_THR, threshold);
- // ZRMOT_DUR register
- /** Get zero motion detection event duration threshold.
- * This register configures the duration counter threshold for Zero Motion
- * interrupt generation. The duration counter ticks at 16 Hz, therefore
- * ZRMOT_DUR has a unit of 1 LSB = 64 ms. The Zero Motion duration counter
- * increments while the absolute value of the accelerometer measurements are
- * each less than the detection threshold (Register 33). The Zero Motion
- * interrupt is triggered when the Zero Motion duration counter reaches the time
- * count specified in this register.
- * the MPU-6000/MPU-6050 Product Specification document, as well as Registers 56
- * @return Current zero motion detection duration threshold value (LSB = 64ms)
- * @see MPU6050_RA_ZRMOT_DUR
- uint8_t MPU6050::getZeroMotionDetectionDuration() {
- I2Cdev::readByte(devAddr, MPU6050_RA_ZRMOT_DUR, buffer);
- return buffer[0];
- /** Set zero motion detection event duration threshold.
- * @param duration New zero motion detection duration threshold value (LSB = 1ms)
- * @see getZeroMotionDetectionDuration()
- void MPU6050::setZeroMotionDetectionDuration(uint8_t duration) {
- I2Cdev::writeByte(devAddr, MPU6050_RA_ZRMOT_DUR, duration);
- // FIFO_EN register
- /** Get temperature FIFO enabled value.
- * When set to 1, this bit enables TEMP_OUT_H and TEMP_OUT_L (Registers 65 and
- * 66) to be written into the FIFO buffer.
- * @return Current temperature FIFO enabled value
- * @see MPU6050_RA_FIFO_EN
- bool MPU6050::getTempFIFOEnabled() {
- I2Cdev::readBit(devAddr, MPU6050_RA_FIFO_EN, MPU6050_TEMP_FIFO_EN_BIT, buffer);
- return buffer[0];
- /** Set temperature FIFO enabled value.
- * @param enabled New temperature FIFO enabled value
- * @see getTempFIFOEnabled()
- void MPU6050::setTempFIFOEnabled(bool enabled) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_FIFO_EN, MPU6050_TEMP_FIFO_EN_BIT, enabled);
- /** Get gyroscope X-axis FIFO enabled value.
- * When set to 1, this bit enables GYRO_XOUT_H and GYRO_XOUT_L (Registers 67 and
- * 68) to be written into the FIFO buffer.
- * @return Current gyroscope X-axis FIFO enabled value
- bool MPU6050::getXGyroFIFOEnabled() {
- I2Cdev::readBit(devAddr, MPU6050_RA_FIFO_EN, MPU6050_XG_FIFO_EN_BIT, buffer);
- return buffer[0];
- /** Set gyroscope X-axis FIFO enabled value.
- * @param enabled New gyroscope X-axis FIFO enabled value
- * @see getXGyroFIFOEnabled()
- void MPU6050::setXGyroFIFOEnabled(bool enabled) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_FIFO_EN, MPU6050_XG_FIFO_EN_BIT, enabled);
- /** Get gyroscope Y-axis FIFO enabled value.
- * When set to 1, this bit enables GYRO_YOUT_H and GYRO_YOUT_L (Registers 69 and
- * 70) to be written into the FIFO buffer.
- * @return Current gyroscope Y-axis FIFO enabled value
- bool MPU6050::getYGyroFIFOEnabled() {
- I2Cdev::readBit(devAddr, MPU6050_RA_FIFO_EN, MPU6050_YG_FIFO_EN_BIT, buffer);
- return buffer[0];
- /** Set gyroscope Y-axis FIFO enabled value.
- * @param enabled New gyroscope Y-axis FIFO enabled value
- * @see getYGyroFIFOEnabled()
- void MPU6050::setYGyroFIFOEnabled(bool enabled) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_FIFO_EN, MPU6050_YG_FIFO_EN_BIT, enabled);
- /** Get gyroscope Z-axis FIFO enabled value.
- * When set to 1, this bit enables GYRO_ZOUT_H and GYRO_ZOUT_L (Registers 71 and
- * 72) to be written into the FIFO buffer.
- * @return Current gyroscope Z-axis FIFO enabled value
- bool MPU6050::getZGyroFIFOEnabled() {
- I2Cdev::readBit(devAddr, MPU6050_RA_FIFO_EN, MPU6050_ZG_FIFO_EN_BIT, buffer);
- return buffer[0];
- /** Set gyroscope Z-axis FIFO enabled value.
- * @param enabled New gyroscope Z-axis FIFO enabled value
- * @see getZGyroFIFOEnabled()
- void MPU6050::setZGyroFIFOEnabled(bool enabled) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_FIFO_EN, MPU6050_ZG_FIFO_EN_BIT, enabled);
- /** Get accelerometer FIFO enabled value.
- * When set to 1, this bit enables ACCEL_XOUT_H, ACCEL_XOUT_L, ACCEL_YOUT_H,
- * ACCEL_YOUT_L, ACCEL_ZOUT_H, and ACCEL_ZOUT_L (Registers 59 to 64) to be
- * written into the FIFO buffer.
- * @return Current accelerometer FIFO enabled value
- bool MPU6050::getAccelFIFOEnabled() {
- I2Cdev::readBit(devAddr, MPU6050_RA_FIFO_EN, MPU6050_ACCEL_FIFO_EN_BIT, buffer);
- return buffer[0];
- /** Set accelerometer FIFO enabled value.
- * @param enabled New accelerometer FIFO enabled value
- * @see getAccelFIFOEnabled()
- void MPU6050::setAccelFIFOEnabled(bool enabled) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_FIFO_EN, MPU6050_ACCEL_FIFO_EN_BIT, enabled);
- /** Get Slave 2 FIFO enabled value.
- * When set to 1, this bit enables EXT_SENS_DATA registers (Registers 73 to 96)
- * associated with Slave 2 to be written into the FIFO buffer.
- * @return Current Slave 2 FIFO enabled value
- bool MPU6050::getSlave2FIFOEnabled() {
- I2Cdev::readBit(devAddr, MPU6050_RA_FIFO_EN, MPU6050_SLV2_FIFO_EN_BIT, buffer);
- return buffer[0];
- /** Set Slave 2 FIFO enabled value.
- * @param enabled New Slave 2 FIFO enabled value
- * @see getSlave2FIFOEnabled()
- void MPU6050::setSlave2FIFOEnabled(bool enabled) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_FIFO_EN, MPU6050_SLV2_FIFO_EN_BIT, enabled);
- /** Get Slave 1 FIFO enabled value.
- * associated with Slave 1 to be written into the FIFO buffer.
- * @return Current Slave 1 FIFO enabled value
- bool MPU6050::getSlave1FIFOEnabled() {
- I2Cdev::readBit(devAddr, MPU6050_RA_FIFO_EN, MPU6050_SLV1_FIFO_EN_BIT, buffer);
- return buffer[0];
- /** Set Slave 1 FIFO enabled value.
- * @param enabled New Slave 1 FIFO enabled value
- * @see getSlave1FIFOEnabled()
- void MPU6050::setSlave1FIFOEnabled(bool enabled) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_FIFO_EN, MPU6050_SLV1_FIFO_EN_BIT, enabled);
- /** Get Slave 0 FIFO enabled value.
- * associated with Slave 0 to be written into the FIFO buffer.
- * @return Current Slave 0 FIFO enabled value
- bool MPU6050::getSlave0FIFOEnabled() {
- I2Cdev::readBit(devAddr, MPU6050_RA_FIFO_EN, MPU6050_SLV0_FIFO_EN_BIT, buffer);
- return buffer[0];
- /** Set Slave 0 FIFO enabled value.
- * @param enabled New Slave 0 FIFO enabled value
- * @see getSlave0FIFOEnabled()
- void MPU6050::setSlave0FIFOEnabled(bool enabled) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_FIFO_EN, MPU6050_SLV0_FIFO_EN_BIT, enabled);
- // I2C_MST_CTRL register
- /** Get multi-master enabled value.
- * Multi-master capability allows multiple I2C masters to operate on the same
- * bus. In circuits where multi-master capability is required, set MULT_MST_EN
- * to 1. This will increase current drawn by approximately 30uA.
- * In circuits where multi-master capability is required, the state of the I2C
- * bus must always be monitored by each separate I2C Master. Before an I2C
- * Master can assume arbitration of the bus, it must first confirm that no other
- * I2C Master has arbitration of the bus. When MULT_MST_EN is set to 1, the
- * MPU-60X0's bus arbitration detection logic is turned on, enabling it to
- * detect when the bus is available.
- * @return Current multi-master enabled value
- * @see MPU6050_RA_I2C_MST_CTRL
- bool MPU6050::getMultiMasterEnabled() {
- I2Cdev::readBit(devAddr, MPU6050_RA_I2C_MST_CTRL, MPU6050_MULT_MST_EN_BIT, buffer);
- return buffer[0];
- /** Set multi-master enabled value.
- * @param enabled New multi-master enabled value
- * @see getMultiMasterEnabled()
- void MPU6050::setMultiMasterEnabled(bool enabled) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_I2C_MST_CTRL, MPU6050_MULT_MST_EN_BIT, enabled);
- /** Get wait-for-external-sensor-data enabled value.
- * When the WAIT_FOR_ES bit is set to 1, the Data Ready interrupt will be
- * delayed until External Sensor data from the Slave Devices are loaded into the
- * EXT_SENS_DATA registers. This is used to ensure that both the internal sensor
- * data (i.e. from gyro and accel) and external sensor data have been loaded to
- * their respective data registers (i.e. the data is synced) when the Data Ready
- * interrupt is triggered.
- * @return Current wait-for-external-sensor-data enabled value
- bool MPU6050::getWaitForExternalSensorEnabled() {
- I2Cdev::readBit(devAddr, MPU6050_RA_I2C_MST_CTRL, MPU6050_WAIT_FOR_ES_BIT, buffer);
- return buffer[0];
- /** Set wait-for-external-sensor-data enabled value.
- * @param enabled New wait-for-external-sensor-data enabled value
- * @see getWaitForExternalSensorEnabled()
- void MPU6050::setWaitForExternalSensorEnabled(bool enabled) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_I2C_MST_CTRL, MPU6050_WAIT_FOR_ES_BIT, enabled);
- /** Get Slave 3 FIFO enabled value.
- * associated with Slave 3 to be written into the FIFO buffer.
- * @return Current Slave 3 FIFO enabled value
- * @see MPU6050_RA_MST_CTRL
- bool MPU6050::getSlave3FIFOEnabled() {
- I2Cdev::readBit(devAddr, MPU6050_RA_I2C_MST_CTRL, MPU6050_SLV_3_FIFO_EN_BIT, buffer);
- return buffer[0];
- /** Set Slave 3 FIFO enabled value.
- * @param enabled New Slave 3 FIFO enabled value
- * @see getSlave3FIFOEnabled()
- void MPU6050::setSlave3FIFOEnabled(bool enabled) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_I2C_MST_CTRL, MPU6050_SLV_3_FIFO_EN_BIT, enabled);
- /** Get slave read/write transition enabled value.
- * The I2C_MST_P_NSR bit configures the I2C Master's transition from one slave
- * read to the next slave read. If the bit equals 0, there will be a restart
- * between reads. If the bit equals 1, there will be a stop followed by a start
- * of the following read. When a write transaction follows a read transaction,
- * the stop followed by a start of the successive write will be always used.
- * @return Current slave read/write transition enabled value
- bool MPU6050::getSlaveReadWriteTransitionEnabled() {
- I2Cdev::readBit(devAddr, MPU6050_RA_I2C_MST_CTRL, MPU6050_I2C_MST_P_NSR_BIT, buffer);
- return buffer[0];
- /** Set slave read/write transition enabled value.
- * @param enabled New slave read/write transition enabled value
- * @see getSlaveReadWriteTransitionEnabled()
- void MPU6050::setSlaveReadWriteTransitionEnabled(bool enabled) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_I2C_MST_CTRL, MPU6050_I2C_MST_P_NSR_BIT, enabled);
- /** Get I2C master clock speed.
- * I2C_MST_CLK is a 4 bit unsigned value which configures a divider on the
- * MPU-60X0 internal 8MHz clock. It sets the I2C master clock speed according to
- * the following table:
- * <pre>
- * I2C_MST_CLK | I2C Master Clock Speed | 8MHz Clock Divider
- * 0 | 348kHz | 23
- * 1 | 333kHz | 24
- * 2 | 320kHz | 25
- * 3 | 308kHz | 26
- * 4 | 296kHz | 27
- * 5 | 286kHz | 28
- * 6 | 276kHz | 29
- * 7 | 267kHz | 30
- * 8 | 258kHz | 31
- * 9 | 500kHz | 16
- * 10 | 471kHz | 17
- * 11 | 444kHz | 18
- * 12 | 421kHz | 19
- * 13 | 400kHz | 20
- * 14 | 381kHz | 21
- * 15 | 364kHz | 22
- * </pre>
- * @return Current I2C master clock speed
- uint8_t MPU6050::getMasterClockSpeed() {
- I2Cdev::readBits(devAddr, MPU6050_RA_I2C_MST_CTRL, MPU6050_I2C_MST_CLK_BIT, MPU6050_I2C_MST_CLK_LENGTH, buffer);
- return buffer[0];
- /** Set I2C master clock speed.
- * @reparam speed Current I2C master clock speed
- void MPU6050::setMasterClockSpeed(uint8_t speed) {
- I2Cdev::writeBits(devAddr, MPU6050_RA_I2C_MST_CTRL, MPU6050_I2C_MST_CLK_BIT, MPU6050_I2C_MST_CLK_LENGTH, speed);
- // I2C_SLV* registers (Slave 0-3)
- /** Get the I2C address of the specified slave (0-3).
- * Note that Bit 7 (MSB) controls read/write mode. If Bit 7 is set, it's a read
- * operation, and if it is cleared, then it's a write operation. The remaining
- * bits (6-0) are the 7-bit device address of the slave device.
- * In read mode, the result of the read is placed in the lowest available
- * EXT_SENS_DATA register. For further information regarding the allocation of
- * read results, please refer to the EXT_SENS_DATA register description
- * (Registers 73 ?96).
- * The MPU-6050 supports a total of five slaves, but Slave 4 has unique
- * characteristics, and so it has its own functions (getSlave4* and setSlave4*).
- * I2C data transactions are performed at the Sample Rate, as defined in
- * Register 25. The user is responsible for ensuring that I2C data transactions
- * to and from each enabled Slave can be completed within a single period of the
- * Sample Rate.
- * The I2C slave access rate can be reduced relative to the Sample Rate. This
- * reduced access rate is determined by I2C_MST_DLY (Register 52). Whether a
- * slave's access rate is reduced relative to the Sample Rate is determined by
- * I2C_MST_DELAY_CTRL (Register 103).
- * The processing order for the slaves is fixed. The sequence followed for
- * processing the slaves is Slave 0, Slave 1, Slave 2, Slave 3 and Slave 4. If a
- * particular Slave is disabled it will be skipped.
- * Each slave can either be accessed at the sample rate or at a reduced sample
- * rate. In a case where some slaves are accessed at the Sample Rate and some
- * slaves are accessed at the reduced rate, the sequence of accessing the slaves
- * (Slave 0 to Slave 4) is still followed. However, the reduced rate slaves will
- * be skipped if their access rate dictates that they should not be accessed
- * during that particular cycle. For further information regarding the reduced
- * access rate, please refer to Register 52. Whether a slave is accessed at the
- * Sample Rate or at the reduced rate is determined by the Delay Enable bits in
- * Register 103.
- * @param num Slave number (0-3)
- * @return Current address for specified slave
- * @see MPU6050_RA_I2C_SLV0_ADDR
- uint8_t MPU6050::getSlaveAddress(uint8_t num) {
- if (num > 3) return 0;
- I2Cdev::readByte(devAddr, MPU6050_RA_I2C_SLV0_ADDR + num*3, buffer);
- return buffer[0];
- /** Set the I2C address of the specified slave (0-3).
- * @param address New address for specified slave
- * @see getSlaveAddress()
- void MPU6050::setSlaveAddress(uint8_t num, uint8_t address) {
- if (num > 3) return;
- I2Cdev::writeByte(devAddr, MPU6050_RA_I2C_SLV0_ADDR + num*3, address);
- /** Get the active internal register for the specified slave (0-3).
- * Read/write operations for this slave will be done to whatever internal
- * register address is stored in this MPU register.
- * characteristics, and so it has its own functions.
- * @return Current active register for specified slave
- * @see MPU6050_RA_I2C_SLV0_REG
- uint8_t MPU6050::getSlaveRegister(uint8_t num) {
- I2Cdev::readByte(devAddr, MPU6050_RA_I2C_SLV0_REG + num*3, buffer);
- return buffer[0];
- /** Set the active internal register for the specified slave (0-3).
- * @param reg New active register for specified slave
- * @see getSlaveRegister()
- void MPU6050::setSlaveRegister(uint8_t num, uint8_t reg) {
- I2Cdev::writeByte(devAddr, MPU6050_RA_I2C_SLV0_REG + num*3, reg);
- /** Get the enabled value for the specified slave (0-3).
- * When set to 1, this bit enables Slave 0 for data transfer operations. When
- * cleared to 0, this bit disables Slave 0 from data transfer operations.
- * @return Current enabled value for specified slave
- * @see MPU6050_RA_I2C_SLV0_CTRL
- bool MPU6050::getSlaveEnabled(uint8_t num) {
- I2Cdev::readBit(devAddr, MPU6050_RA_I2C_SLV0_CTRL + num*3, MPU6050_I2C_SLV_EN_BIT, buffer);
- return buffer[0];
- /** Set the enabled value for the specified slave (0-3).
- * @param enabled New enabled value for specified slave
- * @see getSlaveEnabled()
- void MPU6050::setSlaveEnabled(uint8_t num, bool enabled) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_I2C_SLV0_CTRL + num*3, MPU6050_I2C_SLV_EN_BIT, enabled);
- /** Get word pair byte-swapping enabled for the specified slave (0-3).
- * When set to 1, this bit enables byte swapping. When byte swapping is enabled,
- * the high and low bytes of a word pair are swapped. Please refer to
- * I2C_SLV0_GRP for the pairing convention of the word pairs. When cleared to 0,
- * bytes transferred to and from Slave 0 will be written to EXT_SENS_DATA
- * registers in the order they were transferred.
- * @return Current word pair byte-swapping enabled value for specified slave
- bool MPU6050::getSlaveWordByteSwap(uint8_t num) {
- I2Cdev::readBit(devAddr, MPU6050_RA_I2C_SLV0_CTRL + num*3, MPU6050_I2C_SLV_BYTE_SW_BIT, buffer);
- return buffer[0];
- /** Set word pair byte-swapping enabled for the specified slave (0-3).
- * @param enabled New word pair byte-swapping enabled value for specified slave
- * @see getSlaveWordByteSwap()
- void MPU6050::setSlaveWordByteSwap(uint8_t num, bool enabled) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_I2C_SLV0_CTRL + num*3, MPU6050_I2C_SLV_BYTE_SW_BIT, enabled);
- /** Get write mode for the specified slave (0-3).
- * When set to 1, the transaction will read or write data only. When cleared to
- * 0, the transaction will write a register address prior to reading or writing
- * data. This should equal 0 when specifying the register address within the
- * Slave device to/from which the ensuing data transaction will take place.
- * @return Current write mode for specified slave (0 = register address + data, 1 = data only)
- bool MPU6050::getSlaveWriteMode(uint8_t num) {
- I2Cdev::readBit(devAddr, MPU6050_RA_I2C_SLV0_CTRL + num*3, MPU6050_I2C_SLV_REG_DIS_BIT, buffer);
- return buffer[0];
- /** Set write mode for the specified slave (0-3).
- * @param mode New write mode for specified slave (0 = register address + data, 1 = data only)
- * @see getSlaveWriteMode()
- void MPU6050::setSlaveWriteMode(uint8_t num, bool mode) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_I2C_SLV0_CTRL + num*3, MPU6050_I2C_SLV_REG_DIS_BIT, mode);
- /** Get word pair grouping order offset for the specified slave (0-3).
- * This sets specifies the grouping order of word pairs received from registers.
- * When cleared to 0, bytes from register addresses 0 and 1, 2 and 3, etc (even,
- * then odd register addresses) are paired to form a word. When set to 1, bytes
- * from register addresses are paired 1 and 2, 3 and 4, etc. (odd, then even
- * register addresses) are paired to form a word.
- * @return Current word pair grouping order offset for specified slave
- bool MPU6050::getSlaveWordGroupOffset(uint8_t num) {
- I2Cdev::readBit(devAddr, MPU6050_RA_I2C_SLV0_CTRL + num*3, MPU6050_I2C_SLV_GRP_BIT, buffer);
- return buffer[0];
- /** Set word pair grouping order offset for the specified slave (0-3).
- * @param enabled New word pair grouping order offset for specified slave
- * @see getSlaveWordGroupOffset()
- void MPU6050::setSlaveWordGroupOffset(uint8_t num, bool enabled) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_I2C_SLV0_CTRL + num*3, MPU6050_I2C_SLV_GRP_BIT, enabled);
- /** Get number of bytes to read for the specified slave (0-3).
- * Specifies the number of bytes transferred to and from Slave 0. Clearing this
- * bit to 0 is equivalent to disabling the register by writing 0 to I2C_SLV0_EN.
- * @return Number of bytes to read for specified slave
- uint8_t MPU6050::getSlaveDataLength(uint8_t num) {
- I2Cdev::readBits(devAddr, MPU6050_RA_I2C_SLV0_CTRL + num*3, MPU6050_I2C_SLV_LEN_BIT, MPU6050_I2C_SLV_LEN_LENGTH, buffer);
- return buffer[0];
- /** Set number of bytes to read for the specified slave (0-3).
- * @param length Number of bytes to read for specified slave
- * @see getSlaveDataLength()
- void MPU6050::setSlaveDataLength(uint8_t num, uint8_t length) {
- I2Cdev::writeBits(devAddr, MPU6050_RA_I2C_SLV0_CTRL + num*3, MPU6050_I2C_SLV_LEN_BIT, MPU6050_I2C_SLV_LEN_LENGTH, length);
- // I2C_SLV* registers (Slave 4)
- /** Get the I2C address of Slave 4.
- * @return Current address for Slave 4
- * @see MPU6050_RA_I2C_SLV4_ADDR
- uint8_t MPU6050::getSlave4Address() {
- I2Cdev::readByte(devAddr, MPU6050_RA_I2C_SLV4_ADDR, buffer);
- return buffer[0];
- /** Set the I2C address of Slave 4.
- * @param address New address for Slave 4
- * @see getSlave4Address()
- void MPU6050::setSlave4Address(uint8_t address) {
- I2Cdev::writeByte(devAddr, MPU6050_RA_I2C_SLV4_ADDR, address);
- /** Get the active internal register for the Slave 4.
- * @return Current active register for Slave 4
- * @see MPU6050_RA_I2C_SLV4_REG
- uint8_t MPU6050::getSlave4Register() {
- I2Cdev::readByte(devAddr, MPU6050_RA_I2C_SLV4_REG, buffer);
- return buffer[0];
- /** Set the active internal register for Slave 4.
- * @param reg New active register for Slave 4
- * @see getSlave4Register()
- void MPU6050::setSlave4Register(uint8_t reg) {
- I2Cdev::writeByte(devAddr, MPU6050_RA_I2C_SLV4_REG, reg);
- /** Set new byte to write to Slave 4.
- * This register stores the data to be written into the Slave 4. If I2C_SLV4_RW
- * is set 1 (set to read), this register has no effect.
- * @param data New byte to write to Slave 4
- * @see MPU6050_RA_I2C_SLV4_DO
- void MPU6050::setSlave4OutputByte(uint8_t data) {
- I2Cdev::writeByte(devAddr, MPU6050_RA_I2C_SLV4_DO, data);
- /** Get the enabled value for the Slave 4.
- * When set to 1, this bit enables Slave 4 for data transfer operations. When
- * cleared to 0, this bit disables Slave 4 from data transfer operations.
- * @return Current enabled value for Slave 4
- * @see MPU6050_RA_I2C_SLV4_CTRL
- bool MPU6050::getSlave4Enabled() {
- I2Cdev::readBit(devAddr, MPU6050_RA_I2C_SLV4_CTRL, MPU6050_I2C_SLV4_EN_BIT, buffer);
- return buffer[0];
- /** Set the enabled value for Slave 4.
- * @param enabled New enabled value for Slave 4
- * @see getSlave4Enabled()
- void MPU6050::setSlave4Enabled(bool enabled) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_I2C_SLV4_CTRL, MPU6050_I2C_SLV4_EN_BIT, enabled);
- /** Get the enabled value for Slave 4 transaction interrupts.
- * When set to 1, this bit enables the generation of an interrupt signal upon
- * completion of a Slave 4 transaction. When cleared to 0, this bit disables the
- * generation of an interrupt signal upon completion of a Slave 4 transaction.
- * The interrupt status can be observed in Register 54.
- * @return Current enabled value for Slave 4 transaction interrupts.
- bool MPU6050::getSlave4InterruptEnabled() {
- I2Cdev::readBit(devAddr, MPU6050_RA_I2C_SLV4_CTRL, MPU6050_I2C_SLV4_INT_EN_BIT, buffer);
- return buffer[0];
- /** Set the enabled value for Slave 4 transaction interrupts.
- * @param enabled New enabled value for Slave 4 transaction interrupts.
- * @see getSlave4InterruptEnabled()
- void MPU6050::setSlave4InterruptEnabled(bool enabled) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_I2C_SLV4_CTRL, MPU6050_I2C_SLV4_INT_EN_BIT, enabled);
- /** Get write mode for Slave 4.
- * @return Current write mode for Slave 4 (0 = register address + data, 1 = data only)
- bool MPU6050::getSlave4WriteMode() {
- I2Cdev::readBit(devAddr, MPU6050_RA_I2C_SLV4_CTRL, MPU6050_I2C_SLV4_REG_DIS_BIT, buffer);
- return buffer[0];
- /** Set write mode for the Slave 4.
- * @param mode New write mode for Slave 4 (0 = register address + data, 1 = data only)
- * @see getSlave4WriteMode()
- void MPU6050::setSlave4WriteMode(bool mode) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_I2C_SLV4_CTRL, MPU6050_I2C_SLV4_REG_DIS_BIT, mode);
- /** Get Slave 4 master delay value.
- * This configures the reduced access rate of I2C slaves relative to the Sample
- * Rate. When a slave's access rate is decreased relative to the Sample Rate,
- * the slave is accessed every:
- * 1 / (1 + I2C_MST_DLY) samples
- * This base Sample Rate in turn is determined by SMPLRT_DIV (register 25) and
- * DLPF_CFG (register 26). Whether a slave's access rate is reduced relative to
- * the Sample Rate is determined by I2C_MST_DELAY_CTRL (register 103). For
- * further information regarding the Sample Rate, please refer to register 25.
- * @return Current Slave 4 master delay value
- uint8_t MPU6050::getSlave4MasterDelay() {
- I2Cdev::readBits(devAddr, MPU6050_RA_I2C_SLV4_CTRL, MPU6050_I2C_SLV4_MST_DLY_BIT, MPU6050_I2C_SLV4_MST_DLY_LENGTH, buffer);
- return buffer[0];
- /** Set Slave 4 master delay value.
- * @param delay New Slave 4 master delay value
- * @see getSlave4MasterDelay()
- void MPU6050::setSlave4MasterDelay(uint8_t delay) {
- I2Cdev::writeBits(devAddr, MPU6050_RA_I2C_SLV4_CTRL, MPU6050_I2C_SLV4_MST_DLY_BIT, MPU6050_I2C_SLV4_MST_DLY_LENGTH, delay);
- /** Get last available byte read from Slave 4.
- * This register stores the data read from Slave 4. This field is populated
- * after a read transaction.
- * @return Last available byte read from to Slave 4
- * @see MPU6050_RA_I2C_SLV4_DI
- uint8_t MPU6050::getSlate4InputByte() {
- I2Cdev::readByte(devAddr, MPU6050_RA_I2C_SLV4_DI, buffer);
- return buffer[0];
- // I2C_MST_STATUS register
- /** Get FSYNC interrupt status.
- * This bit reflects the status of the FSYNC interrupt from an external device
- * into the MPU-60X0. This is used as a way to pass an external interrupt
- * through the MPU-60X0 to the host application processor. When set to 1, this
- * bit will cause an interrupt if FSYNC_INT_EN is asserted in INT_PIN_CFG
- * (Register 55).
- * @return FSYNC interrupt status
- * @see MPU6050_RA_I2C_MST_STATUS
- bool MPU6050::getPassthroughStatus() {
- I2Cdev::readBit(devAddr, MPU6050_RA_I2C_MST_STATUS, MPU6050_MST_PASS_THROUGH_BIT, buffer);
- return buffer[0];
- /** Get Slave 4 transaction done status.
- * Automatically sets to 1 when a Slave 4 transaction has completed. This
- * triggers an interrupt if the I2C_MST_INT_EN bit in the INT_ENABLE register
- * (Register 56) is asserted and if the SLV_4_DONE_INT bit is asserted in the
- * I2C_SLV4_CTRL register (Register 52).
- * @return Slave 4 transaction done status
- bool MPU6050::getSlave4IsDone() {
- I2Cdev::readBit(devAddr, MPU6050_RA_I2C_MST_STATUS, MPU6050_MST_I2C_SLV4_DONE_BIT, buffer);
- return buffer[0];
- /** Get master arbitration lost status.
- * This bit automatically sets to 1 when the I2C Master has lost arbitration of
- * the auxiliary I2C bus (an error condition). This triggers an interrupt if the
- * I2C_MST_INT_EN bit in the INT_ENABLE register (Register 56) is asserted.
- * @return Master arbitration lost status
- bool MPU6050::getLostArbitration() {
- I2Cdev::readBit(devAddr, MPU6050_RA_I2C_MST_STATUS, MPU6050_MST_I2C_LOST_ARB_BIT, buffer);
- return buffer[0];
- /** Get Slave 4 NACK status.
- * This bit automatically sets to 1 when the I2C Master receives a NACK in a
- * transaction with Slave 4. This triggers an interrupt if the I2C_MST_INT_EN
- * bit in the INT_ENABLE register (Register 56) is asserted.
- * @return Slave 4 NACK interrupt status
- bool MPU6050::getSlave4Nack() {
- I2Cdev::readBit(devAddr, MPU6050_RA_I2C_MST_STATUS, MPU6050_MST_I2C_SLV4_NACK_BIT, buffer);
- return buffer[0];
- /** Get Slave 3 NACK status.
- * transaction with Slave 3. This triggers an interrupt if the I2C_MST_INT_EN
- * @return Slave 3 NACK interrupt status
- bool MPU6050::getSlave3Nack() {
- I2Cdev::readBit(devAddr, MPU6050_RA_I2C_MST_STATUS, MPU6050_MST_I2C_SLV3_NACK_BIT, buffer);
- return buffer[0];
- /** Get Slave 2 NACK status.
- * transaction with Slave 2. This triggers an interrupt if the I2C_MST_INT_EN
- * @return Slave 2 NACK interrupt status
- bool MPU6050::getSlave2Nack() {
- I2Cdev::readBit(devAddr, MPU6050_RA_I2C_MST_STATUS, MPU6050_MST_I2C_SLV2_NACK_BIT, buffer);
- return buffer[0];
- /** Get Slave 1 NACK status.
- * transaction with Slave 1. This triggers an interrupt if the I2C_MST_INT_EN
- * @return Slave 1 NACK interrupt status
- bool MPU6050::getSlave1Nack() {
- I2Cdev::readBit(devAddr, MPU6050_RA_I2C_MST_STATUS, MPU6050_MST_I2C_SLV1_NACK_BIT, buffer);
- return buffer[0];
- /** Get Slave 0 NACK status.
- * transaction with Slave 0. This triggers an interrupt if the I2C_MST_INT_EN
- * @return Slave 0 NACK interrupt status
- bool MPU6050::getSlave0Nack() {
- I2Cdev::readBit(devAddr, MPU6050_RA_I2C_MST_STATUS, MPU6050_MST_I2C_SLV0_NACK_BIT, buffer);
- return buffer[0];
- // INT_PIN_CFG register
- /** Get interrupt logic level mode.
- * Will be set 0 for active-high, 1 for active-low.
- * @return Current interrupt mode (0=active-high, 1=active-low)
- * @see MPU6050_RA_INT_PIN_CFG
- * @see MPU6050_INTCFG_INT_LEVEL_BIT
- bool MPU6050::getInterruptMode() {
- I2Cdev::readBit(devAddr, MPU6050_RA_INT_PIN_CFG, MPU6050_INTCFG_INT_LEVEL_BIT, buffer);
- return buffer[0];
- /** Set interrupt logic level mode.
- * @param mode New interrupt mode (0=active-high, 1=active-low)
- * @see getInterruptMode()
- void MPU6050::setInterruptMode(bool mode) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_INT_PIN_CFG, MPU6050_INTCFG_INT_LEVEL_BIT, mode);
- /** Get interrupt drive mode.
- * Will be set 0 for push-pull, 1 for open-drain.
- * @return Current interrupt drive mode (0=push-pull, 1=open-drain)
- * @see MPU6050_INTCFG_INT_OPEN_BIT
- bool MPU6050::getInterruptDrive() {
- I2Cdev::readBit(devAddr, MPU6050_RA_INT_PIN_CFG, MPU6050_INTCFG_INT_OPEN_BIT, buffer);
- return buffer[0];
- /** Set interrupt drive mode.
- * @param drive New interrupt drive mode (0=push-pull, 1=open-drain)
- * @see getInterruptDrive()
- void MPU6050::setInterruptDrive(bool drive) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_INT_PIN_CFG, MPU6050_INTCFG_INT_OPEN_BIT, drive);
- /** Get interrupt latch mode.
- * Will be set 0 for 50us-pulse, 1 for latch-until-int-cleared.
- * @return Current latch mode (0=50us-pulse, 1=latch-until-int-cleared)
- * @see MPU6050_INTCFG_LATCH_INT_EN_BIT
- bool MPU6050::getInterruptLatch() {
- I2Cdev::readBit(devAddr, MPU6050_RA_INT_PIN_CFG, MPU6050_INTCFG_LATCH_INT_EN_BIT, buffer);
- return buffer[0];
- /** Set interrupt latch mode.
- * @param latch New latch mode (0=50us-pulse, 1=latch-until-int-cleared)
- * @see getInterruptLatch()
- void MPU6050::setInterruptLatch(bool latch) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_INT_PIN_CFG, MPU6050_INTCFG_LATCH_INT_EN_BIT, latch);
- /** Get interrupt latch clear mode.
- * Will be set 0 for status-read-only, 1 for any-register-read.
- * @return Current latch clear mode (0=status-read-only, 1=any-register-read)
- * @see MPU6050_INTCFG_INT_RD_CLEAR_BIT
- bool MPU6050::getInterruptLatchClear() {
- I2Cdev::readBit(devAddr, MPU6050_RA_INT_PIN_CFG, MPU6050_INTCFG_INT_RD_CLEAR_BIT, buffer);
- return buffer[0];
- /** Set interrupt latch clear mode.
- * @param clear New latch clear mode (0=status-read-only, 1=any-register-read)
- * @see getInterruptLatchClear()
- void MPU6050::setInterruptLatchClear(bool clear) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_INT_PIN_CFG, MPU6050_INTCFG_INT_RD_CLEAR_BIT, clear);
- /** Get FSYNC interrupt logic level mode.
- * @return Current FSYNC interrupt mode (0=active-high, 1=active-low)
- * @see getFSyncInterruptMode()
- * @see MPU6050_INTCFG_FSYNC_INT_LEVEL_BIT
- bool MPU6050::getFSyncInterruptLevel() {
- I2Cdev::readBit(devAddr, MPU6050_RA_INT_PIN_CFG, MPU6050_INTCFG_FSYNC_INT_LEVEL_BIT, buffer);
- return buffer[0];
- /** Set FSYNC interrupt logic level mode.
- * @param mode New FSYNC interrupt mode (0=active-high, 1=active-low)
- void MPU6050::setFSyncInterruptLevel(bool level) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_INT_PIN_CFG, MPU6050_INTCFG_FSYNC_INT_LEVEL_BIT, level);
- /** Get FSYNC pin interrupt enabled setting.
- * Will be set 0 for disabled, 1 for enabled.
- * @return Current interrupt enabled setting
- * @see MPU6050_INTCFG_FSYNC_INT_EN_BIT
- bool MPU6050::getFSyncInterruptEnabled() {
- I2Cdev::readBit(devAddr, MPU6050_RA_INT_PIN_CFG, MPU6050_INTCFG_FSYNC_INT_EN_BIT, buffer);
- return buffer[0];
- /** Set FSYNC pin interrupt enabled setting.
- * @param enabled New FSYNC pin interrupt enabled setting
- * @see getFSyncInterruptEnabled()
- void MPU6050::setFSyncInterruptEnabled(bool enabled) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_INT_PIN_CFG, MPU6050_INTCFG_FSYNC_INT_EN_BIT, enabled);
- /** Get I2C bypass enabled status.
- * When this bit is equal to 1 and I2C_MST_EN (Register 106 bit[5]) is equal to
- * 0, the host application processor will be able to directly access the
- * auxiliary I2C bus of the MPU-60X0. When this bit is equal to 0, the host
- * application processor will not be able to directly access the auxiliary I2C
- * bus of the MPU-60X0 regardless of the state of I2C_MST_EN (Register 106
- * bit[5]).
- * @return Current I2C bypass enabled status
- * @see MPU6050_INTCFG_I2C_BYPASS_EN_BIT
- bool MPU6050::getI2CBypassEnabled() {
- I2Cdev::readBit(devAddr, MPU6050_RA_INT_PIN_CFG, MPU6050_INTCFG_I2C_BYPASS_EN_BIT, buffer);
- return buffer[0];
- /** Set I2C bypass enabled status.
- * bit[5]).
- * @param enabled New I2C bypass enabled status
- void MPU6050::setI2CBypassEnabled(bool enabled) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_INT_PIN_CFG, MPU6050_INTCFG_I2C_BYPASS_EN_BIT, enabled);
- /** Get reference clock output enabled status.
- * When this bit is equal to 1, a reference clock output is provided at the
- * CLKOUT pin. When this bit is equal to 0, the clock output is disabled. For
- * further information regarding CLKOUT, please refer to the MPU-60X0 Product
- * Specification document.
- * @return Current reference clock output enabled status
- * @see MPU6050_INTCFG_CLKOUT_EN_BIT
- bool MPU6050::getClockOutputEnabled() {
- I2Cdev::readBit(devAddr, MPU6050_RA_INT_PIN_CFG, MPU6050_INTCFG_CLKOUT_EN_BIT, buffer);
- return buffer[0];
- /** Set reference clock output enabled status.
- * @param enabled New reference clock output enabled status
- void MPU6050::setClockOutputEnabled(bool enabled) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_INT_PIN_CFG, MPU6050_INTCFG_CLKOUT_EN_BIT, enabled);
- // INT_ENABLE register
- /** Get Free Fall interrupt enabled status.
- * @return Current interrupt enabled status
- * @see MPU6050_RA_INT_ENABLE
- * @see MPU6050_INTERRUPT_FF_BIT
- bool MPU6050::getIntFreefallEnabled() {
- I2Cdev::readBit(devAddr, MPU6050_RA_INT_ENABLE, MPU6050_INTERRUPT_FF_BIT, buffer);
- return buffer[0];
- /** Set Free Fall interrupt enabled status.
- * @param enabled New interrupt enabled status
- * @see getIntFreefallEnabled()
- void MPU6050::setIntFreefallEnabled(bool enabled) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_INT_ENABLE, MPU6050_INTERRUPT_FF_BIT, enabled);
- /** Get Motion Detection interrupt enabled status.
- * @see MPU6050_INTERRUPT_MOT_BIT
- bool MPU6050::getIntMotionEnabled() {
- I2Cdev::readBit(devAddr, MPU6050_RA_INT_ENABLE, MPU6050_INTERRUPT_MOT_BIT, buffer);
- return buffer[0];
- /** Set Motion Detection interrupt enabled status.
- * @see getIntMotionEnabled()
- void MPU6050::setIntMotionEnabled(bool enabled) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_INT_ENABLE, MPU6050_INTERRUPT_MOT_BIT, enabled);
- /** Get Zero Motion Detection interrupt enabled status.
- * @see MPU6050_INTERRUPT_ZMOT_BIT
- bool MPU6050::getIntZeroMotionEnabled() {
- I2Cdev::readBit(devAddr, MPU6050_RA_INT_ENABLE, MPU6050_INTERRUPT_ZMOT_BIT, buffer);
- return buffer[0];
- /** Set Zero Motion Detection interrupt enabled status.
- * @see getIntZeroMotionEnabled()
- void MPU6050::setIntZeroMotionEnabled(bool enabled) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_INT_ENABLE, MPU6050_INTERRUPT_ZMOT_BIT, enabled);
- /** Get FIFO Buffer Overflow interrupt enabled status.
- * @see MPU6050_INTERRUPT_FIFO_OFLOW_BIT
- bool MPU6050::getIntFIFOBufferOverflowEnabled() {
- I2Cdev::readBit(devAddr, MPU6050_RA_INT_ENABLE, MPU6050_INTERRUPT_FIFO_OFLOW_BIT, buffer);
- return buffer[0];
- /** Set FIFO Buffer Overflow interrupt enabled status.
- * @see getIntFIFOBufferOverflowEnabled()
- void MPU6050::setIntFIFOBufferOverflowEnabled(bool enabled) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_INT_ENABLE, MPU6050_INTERRUPT_FIFO_OFLOW_BIT, enabled);
- /** Get I2C Master interrupt enabled status.
- * This enables any of the I2C Master interrupt sources to generate an
- * interrupt. Will be set 0 for disabled, 1 for enabled.
- * @see MPU6050_INTERRUPT_I2C_MST_INT_BIT
- bool MPU6050::getIntI2CMasterEnabled() {
- I2Cdev::readBit(devAddr, MPU6050_RA_INT_ENABLE, MPU6050_INTERRUPT_I2C_MST_INT_BIT, buffer);
- return buffer[0];
- /** Set I2C Master interrupt enabled status.
- * @see getIntI2CMasterEnabled()
- void MPU6050::setIntI2CMasterEnabled(bool enabled) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_INT_ENABLE, MPU6050_INTERRUPT_I2C_MST_INT_BIT, enabled);
- /** Get Data Ready interrupt enabled setting.
- * This event occurs each time a write operation to all of the sensor registers
- * has been completed. Will be set 0 for disabled, 1 for enabled.
- * @see MPU6050_INTERRUPT_DATA_RDY_BIT
- bool MPU6050::getIntDataReadyEnabled() {
- I2Cdev::readBit(devAddr, MPU6050_RA_INT_ENABLE, MPU6050_INTERRUPT_DATA_RDY_BIT, buffer);
- return buffer[0];
- /** Set Data Ready interrupt enabled status.
- * @see getIntDataReadyEnabled()
- * @see MPU6050_RA_INT_CFG
- void MPU6050::setIntDataReadyEnabled(bool enabled) {
- I2Cdev::writeBit(devAddr, MPU6050_RA_INT_ENABLE, MPU6050_INTERRUPT_DATA_RDY_BIT, enabled);
- // INT_STATUS register
- /** Get Free Fall interrupt status.
- * This bit automatically sets to 1 when a Free Fall interrupt has been
- * generated. The bit clears to 0 after the register has been read.
- * @return Current interrupt status
- * @see MPU6050_RA_INT_STATUS
- bool MPU6050::getIntFreefallStatus() {
- I2Cdev::readBit(devAddr, MPU6050_RA_INT_STATUS, MPU6050_INTERRUPT_FF_BIT, buffer);
- return buffer[0];
- /** Get Motion Detection interrupt status.
- * This bit automatically sets to 1 when a Motion Detection interrupt has been
- bool MPU6050::getIntMotionStatus() {
- I2Cdev::readBit(devAddr, MPU6050_RA_INT_STATUS, MPU6050_INTERRUPT_MOT_BIT, buffer);
- return buffer[0];
- /** Get Zero Motion Detection interrupt status.
- * This bit automatically sets to 1 when a Zero Motion Detection interrupt has
- * been generated. The bit clears to 0 after the register has been read.
- bool MPU6050::getIntZeroMotionStatus() {
- I2Cdev::readBit(devAddr, MPU6050_RA_INT_STATUS, MPU6050_INTERRUPT_ZMOT_BIT, buffer);
- return buffer[0];
- /** Get FIFO Buffer Overflow interrupt status.
- bool MPU6050::getIntFIFOBufferOverflowStatus() {
- I2Cdev::readBit(devAddr, MPU6050_RA_INT_STATUS, MPU6050_INTERRUPT_FIFO_OFLOW_BIT, buffer);
- return buffer[0];
- /** Get I2C Master interrupt status.
- * This bit automatically sets to 1 when an I2C Master interrupt has been
- * generated. For a list of I2C Master interrupts, please refer to Register 54.
- * The bit clears to 0 after the register has been read.
- bool MPU6050::getIntI2CMasterStatus() {
- I2Cdev::readBit(devAddr, MPU6050_RA_INT_STATUS, MPU6050_INTERRUPT_I2C_MST_INT_BIT, buffer);
- return buffer[0];
- /** Get Data Ready interrupt status.
- * This bit automatically sets to 1 when a Data Ready interrupt has been
- bool MPU6050::getIntDataReadyStatus() {
- I2Cdev::readBit(devAddr, MPU6050_RA_INT_STATUS, MPU6050_INTERRUPT_DATA_RDY_BIT, buffer);
- return buffer[0];
- // ACCEL_*OUT_* registers
- /** Get raw 9-axis motion sensor readings (accel/gyro/compass).
- * FUNCTION NOT FULLY IMPLEMENTED YET.
- * @param ax 16-bit signed integer container for accelerometer X-axis value
- * @param ay 16-bit signed integer container for accelerometer Y-axis value
- * @param az 16-bit signed integer container for accelerometer Z-axis value
- * @param gx 16-bit signed integer container for gyroscope X-axis value
- * @param gy 16-bit signed integer container for gyroscope Y-axis value
- * @param gz 16-bit signed integer container for gyroscope Z-axis value
- * @param mx 16-bit signed integer container for magnetometer X-axis value
- * @param my 16-bit signed integer container for magnetometer Y-axis value
- * @param mz 16-bit signed integer container for magnetometer Z-axis value
- * @see getMotion6()
- * @see getAcceleration()
- * @see getRotation()
- * @see MPU6050_RA_ACCEL_XOUT_H
- void MPU6050::getMotion9(int16_t* ax, int16_t* ay, int16_t* az, int16_t* gx, int16_t* gy, int16_t* gz, int16_t* mx, int16_t* my, int16_t* mz) {
- getMotion6(ax, ay, az, gx, gy, gz);
- // TODO: magnetometer integration
- /** Get raw 6-axis motion sensor readings (accel/gyro).
- * Retrieves all currently available motion sensor values.
- void MPU6050::getMotion6(int16_t* ax, int16_t* ay, int16_t* az, int16_t* gx, int16_t* gy, int16_t* gz) {
- I2Cdev::readBytes(devAddr, MPU6050_RA_ACCEL_XOUT_H, 14, buffer);
- *ax = (((int16_t)buffer[0]) << 8) | buffer[1];
- *ay = (((int16_t)buffer[2]) << 8) | buffer[3];
- *az = (((int16_t)buffer[4]) << 8) | buffer[5];
- *gx = (((int16_t)buffer[8]) << 8) | buffer[9];
- *gy = (((int16_t)buffer[10]) << 8) | buffer[11];
- *gz = (((int16_t)buffer[12]) << 8) | buffer[13];
- /** Get 3-axis accelerometer readings.
- * These registers store the most recent accelerometer measurements.
- * Accelerometer measurements are written to these registers at the Sample Rate
- * as defined in Register 25.
- * The accelerometer measurement registers, along with the temperature
- * measurement registers, gyroscope measurement registers, and external sensor
- * data registers, are composed of two sets of registers: an internal register
- * set and a user-facing read register set.
- * The data within the accelerometer sensors' internal register set is always
- * updated at the Sample Rate. Meanwhile, the user-facing read register set
- * duplicates the internal register set's data values whenever the serial
- * interface is idle. This guarantees that a burst read of sensor registers will
- * read measurements from the same sampling instant. Note that if burst reads
- * are not used, the user is responsible for ensuring a set of single byte reads
- * correspond to a single sampling instant by checking the Data Ready interrupt.
- * Each 16-bit accelerometer measurement has a full scale defined in ACCEL_FS
- * (Register 28). For each full scale setting, the accelerometers' sensitivity
- * per LSB in ACCEL_xOUT is shown in the table below:
- * <pre>
- * AFS_SEL | Full Scale Range | LSB Sensitivity
- * 0 | +/- 2g | 8192 LSB/mg
- * 1 | +/- 4g | 4096 LSB/mg
- * 2 | +/- 8g | 2048 LSB/mg
- * 3 | +/- 16g | 1024 LSB/mg
- * </pre>
- * @param x 16-bit signed integer container for X-axis acceleration
- * @param y 16-bit signed integer container for Y-axis acceleration
- * @param z 16-bit signed integer container for Z-axis acceleration
- * @see MPU6050_RA_GYRO_XOUT_H
- void MPU6050::getAcceleration(int16_t* x, int16_t* y, int16_t* z) {
- I2Cdev::readBytes(devAddr, MPU6050_RA_ACCEL_XOUT_H, 6, buffer);
- *x = (((int16_t)buffer[0]) << 8) | buffer[1];
- *y = (((int16_t)buffer[2]) << 8) | buffer[3];
- *z = (((int16_t)buffer[4]) << 8) | buffer[5];
- /** Get X-axis accelerometer reading.
- * @return X-axis acceleration measurement in 16-bit 2's complement format
- int16_t MPU6050::getAccelerationX() {
- I2Cdev::readBytes(devAddr, MPU6050_RA_ACCEL_XOUT_H, 2, buffer);
- return (((int16_t)buffer[0]) << 8) | buffer[1];
- /** Get Y-axis accelerometer reading.
- * @return Y-axis acceleration measurement in 16-bit 2's complement format
- * @see MPU6050_RA_ACCEL_YOUT_H
- int16_t MPU6050::getAccelerationY() {
- I2Cdev::readBytes(devAddr, MPU6050_RA_ACCEL_YOUT_H, 2, buffer);
- /** Get Z-axis accelerometer reading.
- * @return Z-axis acceleration measurement in 16-bit 2's complement format
- * @see MPU6050_RA_ACCEL_ZOUT_H
- int16_t MPU6050::getAccelerationZ() {
- I2Cdev::readBytes(devAddr, MPU6050_RA_ACCEL_ZOUT_H, 2, buffer);
- // TEMP_OUT_* registers
- /** Get current internal temperature.
- * @return Temperature reading in 16-bit 2's complement format
- * @see MPU6050_RA_TEMP_OUT_H
- int16_t MPU6050::getTemperature() {
- I2Cdev::readBytes(devAddr, MPU6050_RA_TEMP_OUT_H, 2, buffer);
- // GYRO_*OUT_* registers
- /** Get 3-axis gyroscope readings.
- * These gyroscope measurement registers, along with the accelerometer
- * measurement registers, temperature measurement registers, and external sensor
- * The data within the gyroscope sensors' internal register set is always
- * Each 16-bit gyroscope measurement has a full scale defined in FS_SEL
- * (Register 27). For each full scale setting, the gyroscopes' sensitivity per
- * LSB in GYRO_xOUT is shown in the table below:
- * <pre>
- * FS_SEL | Full Scale Range | LSB Sensitivity
- * 0 | +/- 250 degrees/s | 131 LSB/deg/s
- * 1 | +/- 500 degrees/s | 65.5 LSB/deg/s
- * 2 | +/- 1000 degrees/s | 32.8 LSB/deg/s
- * 3 | +/- 2000 degrees/s | 16.4 LSB/deg/s
- * </pre>
- * @param x 16-bit signed integer container for X-axis rotation
- * @param y 16-bit signed integer container for Y-axis rotation
- * @param z 16-bit signed integer container for Z-axis rotation
- void MPU6050::getRotation(int16_t* x, int16_t* y, int16_t* z) {
- I2Cdev::readBytes(devAddr, MPU6050_RA_GYRO_XOUT_H, 6, buffer);
- /** Get X-axis gyroscope reading.
- * @return X-axis rotation measurement in 16-bit 2's complement format
- int16_t MPU6050::getRotationX() {
- I2Cdev::readBytes(devAddr, MPU6050_RA_GYRO_XOUT_H, 2, buffer);
- /** Get Y-axis gyroscope reading.
- * @return Y-axis rotation measurement in 16-bit 2's complement format
- * @see MPU6050_RA_GYRO_YOUT_H
- int16_t MPU6050::getRotationY() {
- I2Cdev::readBytes(devAddr, MPU6050_RA_GYRO_YOUT_H, 2, buffer);
- /** Get Z-axis gyroscope reading.
- * @return Z-axis rotation measurement in 16-bit 2's complement format
- * @see MPU6050_RA_GYRO_ZOUT_H
- int16_t MPU6050::getRotationZ() {
- I2Cdev::readBytes(devAddr, MPU6050_RA_GYRO_ZOUT_H, 2, buffer);
- // EXT_SENS_DATA_* registers
- /** Read single byte from external sensor data register.
- * These registers store data read from external sensors by the Slave 0, 1, 2,
- * and 3 on the auxiliary I2C interface. Data read by Slave 4 is stored in
- * I2C_SLV4_DI (Register 53).
- * External sensor data is written to these registers at the Sample Rate as
- * defined in Register 25. This access rate can be reduced by using the Slave
- * Delay Enable registers (Register 103).
- * External sensor data registers, along with the gyroscope measurement
- * registers, accelerometer measurement registers, and temperature measurement
- * registers, are composed of two sets of registers: an internal register set
- * and a user-facing read register set.
- * The data within the external sensors' internal register set is always updated
- * at the Sample Rate (or the reduced access rate) whenever the serial interface
- * is idle. This guarantees that a burst read of sensor registers will read
- * measurements from the same sampling instant. Note that if burst reads are not
- * used, the user is responsible for ensuring a set of single byte reads
- * Data is placed in these external sensor data registers according to
- * I2C_SLV0_CTRL, I2C_SLV1_CTRL, I2C_SLV2_CTRL, and I2C_SLV3_CTRL (Registers 39,
- * 42, 45, and 48). When more than zero bytes are read (I2C_SLVx_LEN > 0) from
- * an enabled slave (I2C_SLVx_EN = 1), the slave is read at the Sample Rate (as
- * defined in Register 25) or delayed rate (if specified in Register 52 and
- * 103). During each Sample cycle, slave reads are performed in order of Slave
- * number. If all slaves are enabled with more than zero bytes to be read, the
- * order will be Slave 0, followed by Slave 1, Slave 2, and Slave 3.
- * Each enabled slave will have EXT_SENS_DATA registers associated with it by
- * number of bytes read (I2C_SLVx_LEN) in order of slave number, starting from
- * EXT_SENS_DATA_00. Note that this means enabling or disabling a slave may
- * change the higher numbered slaves' associated registers. Furthermore, if
- * fewer total bytes are being read from the external sensors as a result of
- * such a change, then the data remaining in the registers which no longer have
- * an associated slave device (i.e. high numbered registers) will remain in
- * these previously allocated registers unless reset.
- * If the sum of the read lengths of all SLVx transactions exceed the number of
- * available EXT_SENS_DATA registers, the excess bytes will be dropped. There
- * are 24 EXT_SENS_DATA registers and hence the total read lengths between all
- * the slaves cannot be greater than 24 or some bytes will be lost.
- * Note: Slave 4's behavior is distinct from that of Slaves 0-3. For further
- * information regarding the characteristics of Slave 4, please refer to
- * Registers 49 to 53.
- * EXAMPLE:
- * Suppose that Slave 0 is enabled with 4 bytes to be read (I2C_SLV0_EN = 1 and
- * I2C_SLV0_LEN = 4) while Slave 1 is enabled with 2 bytes to be read so that
- * I2C_SLV1_EN = 1 and I2C_SLV1_LEN = 2. In such a situation, EXT_SENS_DATA _00
- * through _03 will be associated with Slave 0, while EXT_SENS_DATA _04 and 05
- * will be associated with Slave 1. If Slave 2 is enabled as well, registers
- * starting from EXT_SENS_DATA_06 will be allocated to Slave 2.
- * If Slave 2 is disabled while Slave 3 is enabled in this same situation, then
- * registers starting from EXT_SENS_DATA_06 will be allocated to Slave 3
- * instead.
- * REGISTER ALLOCATION FOR DYNAMIC DISABLE VS. NORMAL DISABLE:
- * If a slave is disabled at any time, the space initially allocated to the
- * slave in the EXT_SENS_DATA register, will remain associated with that slave.
- * This is to avoid dynamic adjustment of the register allocation.
- * The allocation of the EXT_SENS_DATA registers is recomputed only when (1) all
- * slaves are disabled, or (2) the I2C_MST_RST bit is set (Register 106).
- * This above is also true if one of the slaves gets NACKed and stops
- * functioning.
- * @param position Starting position (0-23)
- * @return Byte read from register
- uint8_t MPU6050::getExternalSensorByte(int position) {
- I2Cdev::readByte(devAddr, MPU6050_RA_EXT_SENS_DATA_00 + position, buffer);
- return buffer[0];
- /** Read word (2 bytes) from external sensor data registers.
- * @param position Starting position (0-21)
- * @return Word read from register
- * @see getExternalSensorByte()
- uint16_t MPU6050::getExternalSensorWord(int position) {
- I2Cdev::readBytes(devAddr, MPU6050_RA_EXT_SENS_DATA_00 + position, 2, buffer);
- return (((uint16_t)buffer[0]) << 8) | buffer[1];
- /** Read double word (4 bytes) from external sensor data registers.
- * @param position Starting position (0-20)
- * @return Double word read from registers
- uint32_t MPU6050::getExternalSensorDWord(int position) {
- I2Cdev::readBytes(devAddr, MPU6050_RA_EXT_SENS_DATA_00 + position, 4, buffer);
- return (((uint32_t)buffer[0]) << 24) | (((uint32_t)buffer[1]) << 16) | (((uint16_t)buffer[2]) << 8) | buffer[3];
- // MOT_DETECT_STATUS register
- /** Get X-axis negative motion detection interrupt status.
- * @return Motion detection status
- * @see MPU6050_RA_MOT_DETECT_STATUS
- * @see MPU6050_MOTION_MOT_XNEG_BIT
- bool MPU6050::getXNegMotionDetected() {
- I2Cdev::readBit(devAddr, MPU6050_RA_MOT_DETECT_STATUS, MPU6050_MOTION_MOT_XNEG_BIT, buffer);
- return buffer[0];
- /** Get X-axis positive motion detection interrupt status.
- * @see MPU6050_MOTION_MOT_XPOS_BIT
- bool MPU6050::getXPosMotionDetected() {
- I2Cdev::readBit(devAddr, MPU6050_RA_MOT_DETECT_STATUS, MPU6050_MOTION_MOT_XPOS_BIT, buffer);
- return buffer[0];
- /** Get Y-axis negative motion detection interrupt status.
- * @see MPU6050_MOTION_MOT_YNEG_BIT
CZ521mpu-6050資料.rar
(2.86 MB, 下載次數(shù): 19)
2018-4-2 16:46 上傳
點(diǎn)擊文件名下載附件
