發個ds3231高精度時鐘模塊的庫文件及示例,用于Arduino開發版,精度不錯。
- DS3231.cpp: DS3231 Real-Time Clock library
- original code by
- Eric Ayars
- 4/1/11
- updated to Arduino 1.0
- John Hubert
- Feb 7, 2012
- Released into the public domain.
- #include <DS3231.h>
- #define CLOCK_ADDRESS 0x68
- // Constructor
- DS3231::DS3231() {
- // nothing to do for this constructor.
- Public Functions
- void DS3231::getTime(byte& year, byte& month, byte& date, byte& DoW, byte& hour, byte& minute, byte& second) {
- byte tempBuffer;
- bool PM;
- bool h12;
- Wire.beginTransmission(CLOCK_ADDRESS);
- Wire.write(uint8_t(0x00));
- Wire.endTransmission();
- Wire.requestFrom(CLOCK_ADDRESS, 7);
- second = bcdToDec(Wire.read());
- minute = bcdToDec(Wire.read());
- tempBuffer = bcdToDec(Wire.read());
- h12 = tempBuffer & 0b01000000;
- if (h12) {
- PM = tempBuffer & 0b00100000;
- hour = bcdToDec(tempBuffer & 0b00011111);
- } else {
- hour = bcdToDec(tempBuffer & 0b00111111);
- DoW = bcdToDec(Wire.read());
- date = bcdToDec(Wire.read());
- month = bcdToDec(Wire.read() & 0b01111111);
- year = bcdToDec(Wire.read());
- byte DS3231::getSecond() {
- Wire.requestFrom(CLOCK_ADDRESS, 1);
- return bcdToDec(Wire.read());
- byte DS3231::getMinute() {
- Wire.write(0x01);
- byte DS3231::getHour(bool& h12, bool& PM) {
- byte temp_buffer;
- byte hour;
- Wire.write(0x02);
- temp_buffer = Wire.read();
- h12 = temp_buffer & 0b01000000;
- if (h12) {
- PM = temp_buffer & 0b00100000;
- hour = bcdToDec(temp_buffer & 0b00011111);
- } else {
- hour = bcdToDec(temp_buffer & 0b00111111);
- return hour;
- byte DS3231::getDoW() {
- Wire.write(uint8_t(0x03));
- byte DS3231::getDate() {
- Wire.write(uint8_t(0x04));
- byte DS3231::getMonth(bool& Century) {
- byte temp_buffer;
- byte hour;
- Wire.write(uint8_t(0x05));
- Century = temp_buffer & 0b10000000;
- return (bcdToDec(temp_buffer & 0b01111111)) ;
- byte DS3231::getYear() {
- Wire.write(uint8_t(0x06));
- void DS3231::setSecond(byte Second) {
- // Sets the seconds
- // This function also resets the Oscillator Stop Flag, which is set
- // whenever power is interrupted.
- Wire.write(decToBcd(Second));
- // Clear OSF flag
- byte temp_buffer = readControlByte(1);
- writeControlByte((temp_buffer & 0b01111111), 1);
- void DS3231::setMinute(byte Minute) {
- // Sets the minutes
- Wire.write(uint8_t(0x01));
- Wire.write(decToBcd(Minute));
- void DS3231::setHour(byte Hour) {
- // Sets the hour, without changing 12/24h mode.
- // The hour must be in 24h format.
- bool h12;
- // Start by figuring out what the 12/24 mode is
- Wire.write(uint8_t(0x02));
- h12 = (Wire.read() & 0b01000000);
- // if h12 is true, it's 12h mode; false is 24h.
- if (h12) {
- // 12 hour
- if (Hour > 12) {
- Hour = decToBcd(Hour-12) | 0b01100000;
- } else {
- Hour = decToBcd(Hour) & 0b11011111;
- } else {
- // 24 hour
- Hour = decToBcd(Hour) & 0b10111111;
- Wire.write(Hour);
- void DS3231::setDoW(byte DoW) {
- // Sets the Day of Week
- Wire.write(decToBcd(DoW));
- void DS3231::setDate(byte Date) {
- // Sets the Date
- Wire.write(decToBcd(Date));
- void DS3231::setMonth(byte Month) {
- // Sets the month
- Wire.write(decToBcd(Month));
- void DS3231::setYear(byte Year) {
- // Sets the year
- Wire.write(decToBcd(Year));
- void DS3231::setClockMode(bool h12) {
- // sets the mode to 12-hour (true) or 24-hour (false).
- // One thing that bothers me about how I've written this is that
- // if the read and right happen at the right hourly millisecnd,
- // the clock will be set back an hour. Not sure how to do it better,
- // though, and as long as one doesn't set the mode frequently it's
- // a very minimal risk.
- // It's zero risk if you call this BEFORE setting the hour, since
- // the setHour() function doesn't change this mode.
- byte temp_buffer;
- // Start by reading byte 0x02.
- // Set the flag to the requested value:
- if (h12) {
- temp_buffer = temp_buffer | 0b01000000;
- } else {
- temp_buffer = temp_buffer & 0b10111111;
- // Write the byte
- Wire.write(temp_buffer);
- float DS3231::getTemperature() {
- // Checks the internal thermometer on the DS3231 and returns the
- // temperature as a floating-point value.
- byte temp;
- Wire.write(uint8_t(0x11));
- Wire.requestFrom(CLOCK_ADDRESS, 2);
- temp = Wire.read(); // Here's the MSB
- return float(temp) + 0.25*(Wire.read()>>6);
- void DS3231::getA1Time(byte& A1Day, byte& A1Hour, byte& A1Minute, byte& A1Second, byte& AlarmBits, bool& A1Dy, bool& A1h12, bool& A1PM) {
- byte temp_buffer;
- Wire.write(uint8_t(0x07));
- Wire.requestFrom(CLOCK_ADDRESS, 4);
- temp_buffer = Wire.read(); // Get A1M1 and A1 Seconds
- A1Second = bcdToDec(temp_buffer & 0b01111111);
- // put A1M1 bit in position 0 of DS3231_AlarmBits.
- AlarmBits = AlarmBits | (temp_buffer & 0b10000000)>>7;
- temp_buffer = Wire.read(); // Get A1M2 and A1 minutes
- A1Minute = bcdToDec(temp_buffer & 0b01111111);
- // put A1M2 bit in position 1 of DS3231_AlarmBits.
- AlarmBits = AlarmBits | (temp_buffer & 0b10000000)>>6;
- temp_buffer = Wire.read(); // Get A1M3 and A1 Hour
- // put A1M3 bit in position 2 of DS3231_AlarmBits.
- AlarmBits = AlarmBits | (temp_buffer & 0b10000000)>>5;
- // determine A1 12/24 mode
- A1h12 = temp_buffer & 0b01000000;
- if (A1h12) {
- A1PM = temp_buffer & 0b00100000; // determine am/pm
- A1Hour = bcdToDec(temp_buffer & 0b00011111); // 12-hour
- } else {
- A1Hour = bcdToDec(temp_buffer & 0b00111111); // 24-hour
- temp_buffer = Wire.read(); // Get A1M4 and A1 Day/Date
- // put A1M3 bit in position 3 of DS3231_AlarmBits.
- AlarmBits = AlarmBits | (temp_buffer & 0b10000000)>>4;
- // determine A1 day or date flag
- A1Dy = (temp_buffer & 0b01000000)>>6;
- if (A1Dy) {
- // alarm is by day of week, not date.
- A1Day = bcdToDec(temp_buffer & 0b00001111);
- } else {
- // alarm is by date, not day of week.
- A1Day = bcdToDec(temp_buffer & 0b00111111);
- void DS3231::getA2Time(byte& A2Day, byte& A2Hour, byte& A2Minute, byte& AlarmBits, bool& A2Dy, bool& A2h12, bool& A2PM) {
- byte temp_buffer;
- Wire.write(uint8_t(0x0b));
- Wire.requestFrom(CLOCK_ADDRESS, 3);
- temp_buffer = Wire.read(); // Get A2M2 and A2 Minutes
- A2Minute = bcdToDec(temp_buffer & 0b01111111);
- // put A2M2 bit in position 4 of DS3231_AlarmBits.
- AlarmBits = AlarmBits | (temp_buffer & 0b10000000)>>3;
- temp_buffer = Wire.read(); // Get A2M3 and A2 Hour
- // put A2M3 bit in position 5 of DS3231_AlarmBits.
- AlarmBits = AlarmBits | (temp_buffer & 0b10000000)>>2;
- // determine A2 12/24 mode
- A2h12 = temp_buffer & 0b01000000;
- if (A2h12) {
- A2PM = temp_buffer & 0b00100000; // determine am/pm
- A2Hour = bcdToDec(temp_buffer & 0b00011111); // 12-hour
- } else {
- A2Hour = bcdToDec(temp_buffer & 0b00111111); // 24-hour
- temp_buffer = Wire.read(); // Get A2M4 and A1 Day/Date
- // put A2M4 bit in position 6 of DS3231_AlarmBits.
- AlarmBits = AlarmBits | (temp_buffer & 0b10000000)>>1;
- // determine A2 day or date flag
- A2Dy = (temp_buffer & 0b01000000)>>6;
- if (A2Dy) {
- A2Day = bcdToDec(temp_buffer & 0b00001111);
- } else {
- A2Day = bcdToDec(temp_buffer & 0b00111111);
- void DS3231::setA1Time(byte A1Day, byte A1Hour, byte A1Minute, byte A1Second, byte AlarmBits, bool A1Dy, bool A1h12, bool A1PM) {
- // Sets the alarm-1 date and time on the DS3231, using A1* information
- byte temp_buffer;
- Wire.write(uint8_t(0x07)); // A1 starts at 07h
- // Send A1 second and A1M1
- Wire.write(decToBcd(A1Second) | ((AlarmBits & 0b00000001) << 7));
- // Send A1 Minute and A1M2
- Wire.write(decToBcd(A1Minute) | ((AlarmBits & 0b00000010) << 6));
- // Figure out A1 hour
- if (A1h12) {
- // Start by converting existing time to h12 if it was given in 24h.
- if (A1Hour > 12) {
- // well, then, this obviously isn't a h12 time, is it?
- A1Hour = A1Hour - 12;
- A1PM = true;
- if (A1PM) {
- // Afternoon
- // Convert the hour to BCD and add appropriate flags.
- temp_buffer = decToBcd(A1Hour) | 0b01100000;
- } else {
- // Morning
- temp_buffer = decToBcd(A1Hour) | 0b01000000;
- } else {
- // Now for 24h
- temp_buffer = decToBcd(A1Hour);
- temp_buffer = temp_buffer | ((AlarmBits & 0b00000100)<<5);
- // A1 hour is figured out, send it
- // Figure out A1 day/date and A1M4
- temp_buffer = ((AlarmBits & 0b00001000)<<4) | decToBcd(A1Day);
- if (A1Dy) {
- // Set A1 Day/Date flag (Otherwise it's zero)
- // All done!
- void DS3231::setA2Time(byte A2Day, byte A2Hour, byte A2Minute, byte AlarmBits, bool A2Dy, bool A2h12, bool A2PM) {
- // Sets the alarm-2 date and time on the DS3231, using A2* information
- byte temp_buffer;
- Wire.write(uint8_t(0x0b)); // A1 starts at 0bh
- // Send A2 Minute and A2M2
- Wire.write(decToBcd(A2Minute) | ((AlarmBits & 0b00010000) << 3));
- // Figure out A2 hour
- if (A2h12) {
- if (A2Hour > 12) {
- A2Hour = A2Hour - 12;
- A2PM = true;
- if (A2PM) {
- // Afternoon
- temp_buffer = decToBcd(A2Hour) | 0b01100000;
- } else {
- // Morning
- temp_buffer = decToBcd(A2Hour) | 0b01000000;
- } else {
- // Now for 24h
- temp_buffer = decToBcd(A2Hour);
- // add in A2M3 bit
- temp_buffer = temp_buffer | ((AlarmBits & 0b00100000)<<2);
- // A2 hour is figured out, send it
- // Figure out A2 day/date and A2M4
- temp_buffer = ((AlarmBits & 0b01000000)<<1) | decToBcd(A2Day);
- if (A2Dy) {
- // Set A2 Day/Date flag (Otherwise it's zero)
- // All done!
- void DS3231::turnOnAlarm(byte Alarm) {
- // turns on alarm number "Alarm". Defaults to 2 if Alarm is not 1.
- byte temp_buffer = readControlByte(0);
- // modify control byte
- if (Alarm == 1) {
- temp_buffer = temp_buffer | 0b00000101;
- } else {
- temp_buffer = temp_buffer | 0b00000110;
- writeControlByte(temp_buffer, 0);
- void DS3231::turnOffAlarm(byte Alarm) {
- // turns off alarm number "Alarm". Defaults to 2 if Alarm is not 1.
- // Leaves interrupt pin alone.
- if (Alarm == 1) {
- temp_buffer = temp_buffer & 0b11111110;
- } else {
- temp_buffer = temp_buffer & 0b11111101;
- bool DS3231::checkAlarmEnabled(byte Alarm) {
- // Checks whether the given alarm is enabled.
- byte result = 0x0;
- if (Alarm == 1) {
- result = temp_buffer & 0b00000001;
- } else {
- result = temp_buffer & 0b00000010;
- return result;
- bool DS3231::checkIfAlarm(byte Alarm) {
- // Checks whether alarm 1 or alarm 2 flag is on, returns T/F accordingly.
- // Turns flag off, also.
- // defaults to checking alarm 2, unless Alarm == 1.
- byte result;
- if (Alarm == 1) {
- // Did alarm 1 go off?
- // clear flag
- } else {
- // Did alarm 2 go off?
- // clear flag
- writeControlByte(temp_buffer, 1);
- return result;
- void DS3231::enableOscillator(bool TF, bool battery, byte frequency) {
- // turns oscillator on or off. True is on, false is off.
- // if battery is true, turns on even for battery-only operation,
- // otherwise turns off if Vcc is off.
- // frequency must be 0, 1, 2, or 3.
- // 0 = 1 Hz
- // 1 = 1.024 kHz
- // 2 = 4.096 kHz
- // 3 = 8.192 kHz (Default if frequency byte is out of range)
- if (frequency > 3) frequency = 3;
- // read control byte in, but zero out current state of RS2 and RS1.
- byte temp_buffer = readControlByte(0) & 0b11100111;
- if (battery) {
- // turn on BBSQW flag
- } else {
- // turn off BBSQW flag
- if (TF) {
- // set ~EOSC to 0 and INTCN to zero.
- temp_buffer = temp_buffer & 0b01111011;
- } else {
- // set ~EOSC to 1, leave INTCN as is.
- temp_buffer = temp_buffer | 0b10000000;
- // shift frequency into bits 3 and 4 and set.
- frequency = frequency << 3;
- temp_buffer = temp_buffer | frequency;
- // And write the control bits
- void DS3231::enable32kHz(bool TF) {
- // turn 32kHz pin on or off
- if (TF) {
- // turn on 32kHz pin
- temp_buffer = temp_buffer | 0b00001000;
- } else {
- // turn off 32kHz pin
- temp_buffer = temp_buffer & 0b11110111;
- bool DS3231::oscillatorCheck() {
- // Returns false if the oscillator has been off for some reason.
- // If this is the case, the time is probably not correct.
- bool result = true;
- if (temp_buffer & 0b10000000) {
- // Oscillator Stop Flag (OSF) is set, so return false.
- result = false;
- return result;
- Private Functions
- byte DS3231::decToBcd(byte val) {
- // Convert normal decimal numbers to binary coded decimal
- return ( (val/10*16) + (val%10) );
- byte DS3231::bcdToDec(byte val) {
- // Convert binary coded decimal to normal decimal numbers
- return ( (val/16*10) + (val%16) );
- byte DS3231::readControlByte(bool which) {
- // Read selected control byte
- // first byte (0) is 0x0e, second (1) is 0x0f
- if (which) {
- // second control byte
- Wire.write(uint8_t(0x0f));
- } else {
- // first control byte
- Wire.write(uint8_t(0x0e));
- return Wire.read();
- void DS3231::writeControlByte(byte control, bool which) {
- // Write the selected control byte.
- // which=false -> 0x0e, true->0x0f.
- if (which) {
- } else {
- Wire.write(control);
DS3231.rar
(498.21 KB, 下載次數: 164)
2018-4-2 23:51 上傳
點擊文件名下載附件
