查看: 3641|回復: 2
DHT11溫濕度arduino程序
DHT11溫濕度檢測程序
arduino單片機源程序如下:
  1. #include "dht.h"
  2.
  3. #define TIMEOUT 10000
  4. #define pin     D2
  5. // return values:
  6. //  0 : OK
  7. // -1 : checksum error
  8. // -2 : timeout
  9. int dht::read11()
  10. {
  11.     // READ VALUES
  12.    int rv = read();
  13.     if (rv != 0) return rv;
  14.     // CONVERT AND STORE
  15.     humidity    = bits[0];  // bit[1] == 0;
  16.     temperature = bits[2];  // bits[3] == 0;
  17.
  18.     // TEST CHECKSUM
  19.    uint8_t sum = bits[0] + bits[2]; // bits[1] && bits[3] both 0
  20.     if (bits[4] != sum) return -1;
  21.     return 0;
  22. }
  23. // return values:
  24. //  0 : OK
  25. // -1 : checksum error
  26. // -2 : timeout
  27. int dht::read22()
  28. {
  29.     // READ VALUES
  30.     int rv = read();
  31.     if (rv != 0) return rv;
  32.
  33.     // CONVERT AND STORE
  34.     humidity    = word(bits[0], bits[1]) * 0.1;
  35.
  36.     int sign = 1;
  37.     if (bits[2] & 0x80) // negative temperature
  38.     {
  39.         bits[2] = bits[2] & 0x7F;
  40.         sign = -1;
  41.     }
  42.     temperature = sign * word(bits[2], bits[3]) * 0.1;
  43.
  44.   // TEST CHECKSUM
  45.     uint8_t sum = bits[0] + bits[1] + bits[2] + bits[3];
  46.     if (bits[4] != sum) return -1;
  47.     return 0;
  48. }
  49. // return values:
  50. //  0 : OK
  51. // -2 : timeout
  52. int dht::read()
  53. {
  54.     // INIT BUFFERVAR TO RECEIVE DATA
  55.     uint8_t cnt = 7;
  56.     uint8_t idx = 0;
  57.    // EMPTY BUFFER
  58.    for (int i=0; i< 5; i++) bits[i] = 0;
  59.
  60.     // REQUEST SAMPLE
  61.    pinMode(pin, OUTPUT);
  62.    digitalWrite(pin, LOW);
  63.    delay(20);
  64.    digitalWrite(pin, HIGH);
  65.    delayMicroseconds(40);
  66.    pinMode(pin, INPUT);
  67.
  68.    // GET ACKNOWLEDGE or TIMEOUT
  69.    unsigned int loopCnt = TIMEOUT;
  70.    while(digitalRead(pin) == LOW)
  71.       if (loopCnt-- == 0) return -2;
  72.
  73.     loopCnt = TIMEOUT;
  74.     while(digitalRead(pin) == HIGH)
  75.        if (loopCnt-- == 0) return -2;
  76.
  77.     // READ THE OUTPUT - 40 BITS => 5 BYTES
  78.     for (int i=0; i<40; i++)
  79.     {
  80.         loopCnt = TIMEOUT;
  81.         while(digitalRead(pin) == LOW)
  82.             if (loopCnt-- == 0) return -2;
  83.         unsigned long t = micros();
  84.
  85.         loopCnt = TIMEOUT;
  86.         while(digitalRead(pin) == HIGH)
  87. ……………………
  88. …………限于本文篇幅 余下代碼請從51黑下載附件…………
temperature.rar (1.77 KB, 下載次數: 24)
ID:234938 發表于 2018-4-12 15:41 | 只看該作者
看起來挺高大上的,過來學習一下。
ID:315637 發表于 2018-4-24 20:00 | 只看該作者
樓主能不能單獨發一份???thanks。
主站蜘蛛池模板: 久久免费国产 | 国产一区福利 | 中文字幕国产精品 | 亚洲精品乱码久久久久久动漫 | 91超碰在线播放 | 亚洲天天看 | 日韩中文字幕在线 | 日韩欧美中文 | 日韩在线| 中文字幕自拍 | 欧美日韩视频一区二区 | 精品国产欧美一区二区三区成人 | 国产黄色av网站 | 亚洲最大av网站 | 国精产品一区二区 | 五月婷婷丁香六月 | 中文字幕永久在线 | 国产精品一品二区三区的使用体验 | 国产视频一区二区在线 | 日本久久久久久久久 | 丁香激情网 | 欧美黑人性猛交 | 日日爽天天 | 国产免费视频 | 国产乱淫片视频 | 日韩免费在线 | 免费看黄色av | 日韩欧美在线观看视频 | 美日韩一区二区三区 | 97人人艹| 91午夜精品亚洲一区二区三区 | 久久精品视频国产 | 日韩国产精品一区二区 | 成人深夜福利 | 日韩在线高清 | 俺去俺来也在线www色官网 | 欧美精品网 | 国产aaaaaa| 在线观看av免费 | 午夜国产视频 | 成人在线视频免费 |
