查看: 2867|回復: 2
基于單片機的數字式電能表
ID:308098 發表于 2018-4-14 17:29 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<REG52.H>
#define uchar unsigned char
#define uint unsigned int
unsigned char code command[6][7]={
                                 0xB0,0xC0,0xA8,0x01,0x01,0x00,0x1A,//讀取電壓值
                                 0xB1,0xC0,0xA8,0x01,0x01,0x00,0x1B,//讀取電流值
                                 0xB3,0xC0,0xA8,0x01,0x01,0x00,0x1D,//讀取電量值
                                 0x7e,0x05,0x41,0x00,0x04,0x40,0xef,
                                 0x7e,0x05,0x41,0x00,0x05,0x41,0xef,
                                 0x7e,0x05,0x41,0x00,0x06,0x42,0xef
                                };//串口控制音樂指令
uchar shuju[8];
uchar jishu=0;
uchar CRC=0;
uchar j=0;
long  AA=0;
uint BB=0;
uint CC;
//******************LCD1602****************************//
sbit lcden=P1^2;
sbit lcdrw=P1^1;
sbit lcdrs=P1^0;
//////////////LCD1602///////////////////////////////////////
void delay1(uint z)
    uint x,y;
    for(x=z;x>0;x--)
        for(y=110;y>0;y--);
void write_com(uchar com)
    lcdrs=0;
    P0=com;
    delay1(5);
    lcden=1;
    delay1(5);
    lcden=0;
void write_data(uchar date)
    lcdrs=1;
    P0=date;
    delay1(5);
    lcden=1;
    delay1(5);
    lcden=0;
void init1602()
    lcden=0;
    write_com(0x38);
    write_com(0x0c);//    write_com(0x0e);
    write_com(0x06);
    write_com(0x01);
    write_com(0x80+2);
///////////////LCD1602
void SendASC(uchar d)    //串口發送字符
    SBUF=d;                //數據賦值到緩沖區
    while(!TI);            //發送完
    TI=0;                //清零
void deal(void)
  //電壓讀取
           jishu=0;
           for(j=0;j<7;j++)
            {    shuju[j]=0;
                  SendASC(command[0][j]);
            delay1(200);
            delay1(20);
            if(jishu>0)
              {      CRC=0;
                  for(j=0;j<6;j++)
                       CRC=CRC+shuju[j];
                  if((CRC==shuju[6])&&(shuju[0]==0xa0))
                          AA=shuju[1]*256+shuju[2];
                          write_com(0x80+0x40);
                          if(AA>=100)
                               write_data(AA/100+0x30);
                          else write_data(' ');
                          delay1(20);
                          write_data(AA%100/10+0x30);
                          delay1(20);
                          write_data(AA%10+0x30);
                          delay1(20);
                          write_data('.');
                          delay1(20);
                          write_data(shuju[3]+0x30);
                          delay1(20);
                          write_data('V');
                          delay1(20);
   //電流讀取
           jishu=0;
           for(j=0;j<7;j++)
            {    shuju[j]=0;
                  SendASC(command[1][j]);
            delay1(200);
            if(jishu>0)
              {      CRC=0;
                  for(j=0;j<6;j++)
                       CRC=CRC+shuju[j];
                  if((CRC==shuju[6])&&(shuju[0]==0xa1))
                          AA=shuju[2];
                          write_com(0x80+0x40+9);
                          if(AA>=100)
                          delay1(20);
                          delay1(20);
                          delay1(20);
                          write_data('.');
                          delay1(20);
                          write_data(shuju[3]/10+0x30);
                          delay1(20);
                          write_data(shuju[3]%10+0x30);
                          delay1(20);
                          write_data('A');
                          delay1(20);
    //電量讀取
           jishu=0;
           for(j=0;j<7;j++)
            {    shuju[j]=0;
                  SendASC(command[2][j]);
            delay1(200);
            if(jishu>0)
              {      CRC=0;
                  for(j=0;j<6;j++)
                       CRC=CRC+shuju[j];
                  if((CRC==shuju[6])&&(shuju[0]==0xa3))
                          AA=shuju[1];
                          AA=AA<<16;
                          AA=AA+shuju[2]*256;
                          AA=AA+shuju[3];
                          write_com(0x80);
                          if(AA>=1000000)
                               write_data(AA/1000000+0x30);
                          delay1(20);
                          if(AA>=100000)
                               write_data(AA%1000000/100000+0x30);
                          delay1(20);
                          if(AA>=10000)
                               write_data(AA%100000/10000+0x30);
                          delay1(20);
                          if(AA>=1000)
                               write_data(AA%10000/1000+0x30);
                          delay1(20);
                          if(AA>=100)
                               write_data(AA%1000/100+0x30);
                          delay1(20);
                          if(AA>=10)
                          delay1(20);
                          delay1(20);
                          write_data('W');
                          delay1(20);
                          write_data('H');
                          delay1(20);
void main(void)
  lcdrw=0;
  init1602();
  //串口通信
   TMOD=0x21;//?????0?????1
   TH1=0Xfd;
   TL1=0Xfd;        //9600波特率
   TR1=1;             // 定時器1啟動
   SM0=0;        // 設置串口的工作模式
   SM1=1;         //方式1
   REN=1;          // 允許串口接收數據
   ES=1;          // 串口中斷應許
   EA=1;
            deal();
void ser() interrupt 4
    if(RI)
        RI=0;
        shuju[jishu++]=SBUF;
        if(jishu>7)
            jishu=0;
ID:313732 發表于 2018-4-25 17:25 | 只看該作者
小白在做設計,有沒有仿真圖啊
ID:1115953 發表于 2024-4-10 14:05 | 只看該作者
靜凈 發表于 2018-4-25 17:25
小白在做設計,有沒有仿真圖啊
哥給看看仿真圖,我現在才做DIY小玩意,遇到難點了
主站蜘蛛池模板: 精品日韩一区二区三区 | 综合色播 | а天堂中文最新一区二区三区 | 伊人精品一区二区三区 | 亚洲福利一区二区 | 黄网免费 | 激情在线视频网站 | 日韩欧美综合在线视频 | 日本韩国欧美在线观看 | 成人av免费 | 国产精品久久国产精品 | 九色一区 | 伊人在线| 久草网址 | 欧美一a一片一级一片 | 日韩在线小视频 | 国产区精品 | 久草视频观看 | 国产精品麻 | 激情五月婷婷在线 | 亚洲精精品 | 九九99靖品| 午夜免费观看网站 | 日韩欧美亚洲 | 亚洲免费精品 | 久久亚洲精品久久国产一区二区 | 秋霞精品 | 成人免费一区二区三区视频网站 | 国产精品国产a | 成人欧美一区二区 | 亚洲国产精品久久 | 亚洲色欧美另类 | 日韩精品在线免费观看视频 | 欧美在线视频一区 | 在线观看亚洲一区二区 | 先锋资源站| 国产91精品久久久久久久网曝门 | 91精品国产综合久久婷婷香蕉 | 国产一区二区三区在线免费 | 免费国产一区二区视频 | 91视频大全|
