查看: 4710|回復: 1
上傳一個顯示溫濕度的arduino代碼
ID:308464 發表于 2018-4-15 11:54 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
double Fahrenheit(double celsius)
       return 1.8 * celsius + 32;
}   //攝氏溫度度轉化為華氏溫度
double Kelvin(double celsius)
       return celsius + 273.15;
}    //攝氏溫度轉化為開氏溫度
// 露點(點在此溫度時,空氣飽和并產生露珠)
// 參考:wahiduddin點net/calc/density_algorithms.htm
double dewPoint(double celsius, doublehumidity)   //humidity是濕度,celsius是攝氏溫度
       double A0= 373.15/(273.15 + celsius);
       double SUM = -7.90298 * (A0-1);
       SUM += 5.02808 * log10(A0);
       SUM += -1.3816e-7 * (pow(10, (11.344*(1-1/A0)))-1) ;
       SUM += 8.1328e-3 * (pow(10,(-3.49149*(A0-1)))-1) ;
       SUM += log10(1013.246);
       double VP = pow(10, SUM-3) * humidity;
       double T = log(VP/0.61078);   //temp var
       return (241.88 * T) / (17.558-T);
// 快速計算露點,速度是5dewPoint()(上面函數的結果)
double dewPointFast(double celsius, doublehumidity)
       double a = 17.271;
       double b = 237.7;
       double temp = (a * celsius) / (b + celsius) + log(humidity/100);
       double Td = (b * temp) / (a - temp);
       return Td;
#include <dht11.h>
dht11 DHT11;
#define DHT11PIN 2
void setup()  //設置一些參數
Serial.begin(9600);
Serial.println("DHT11 TEST PROGRAM ");
Serial.print("LIBRARY VERSION: ");
Serial.println(DHT11LIB_VERSION);
Serial.println();
void loop()
Serial.println("\n"); //換行
  intchk = DHT11.read(DHT11PIN);
Serial.print("Read sensor: "); //讀取傳感器
switch (chk)
   case DHTLIB_OK:
                Serial.println("OK");
                break;
   case DHTLIB_ERROR_CHECKSUM:
                Serial.println("Checksumerror");
                break;
   case DHTLIB_ERROR_TIMEOUT:
                Serial.println("Time outerror");
                break;
   default:
                Serial.println("Unknownerror");
                break;
Serial.print("Humidity (%): ");
Serial.println((float)DHT11.humidity, 2);
Serial.print("Temperature (oC): ");
Serial.println((float)DHT11.temperature, 2);
Serial.print("Temperature (oF): ");
Serial.println(Fahrenheit(DHT11.temperature), 2);
Serial.print("Temperature (K): ");
Serial.println(Kelvin(DHT11.temperature), 2);
Serial.print("Dew Point (oC): ");
Serial.println(dewPoint(DHT11.temperature, DHT11.humidity));
Serial.print("Dew PointFast (oC): ");
Serial.println(dewPointFast(DHT11.temperature, DHT11.humidity));
delay(2000);
ID:656966 發表于 2019-12-5 18:33 | 只看該作者
我運行了一下   錯誤是說沒有dht11.h 這個文件 怎么解決 剛接觸arduino什么都不懂...求教
主站蜘蛛池模板: 亚洲精品国产精品国自产观看 | 中文字幕1区 | av免费观看网址 | 日韩精品免费 | 黄av在线| 国产伦精品一区二区免费 | h片在线观看 | 亚洲一区精品视频 | 成人a级片| 国产精品免费一区二区三区 | 中文字字幕 | 99一区二区 | 福利小视频在线观看 | 中文在线字幕免费观看 | 色综合五月 | 一区二区三区日韩 | 国产高清免费 | 欧美成人精品一区二区三区 | 日韩精品在线一区二区 | 蜜桃精品一区二区三区 | 国产成人精品一区 | 亚洲美女毛片 | 久久精品在线观看 | 亚洲三级黄色片 | www.狠狠操.com| 欧美日韩亚洲一区二区 | 国产精品免费一区二区三区 | 99国产精品99久久久久久 | 激情另类小说 | 狠狠干免费视频 | 国产免费无遮挡 | 六月丁香综合 | 狠狠操狠狠操 | 国产成人福利 | 欧美午夜精品一区二区三区 | 国产免费观看视频 | 老熟女毛片 | 一级黄色免费看 | 国产精品亚洲精品 | 精品在线免费观看 | 波多野结衣久久 |
