查看: 4530|回復: 0
arduino溫濕度傳感器DHT11, 21, 22, 33 and 44庫文件 MEGA2560芯片
ID:312559 發(fā)表于 2018-4-20 17:22 | 顯示全部樓層 |閱讀模式
The DHT11, 21, 22, 33 and 44 are relative inexpensive sensors for measuring temperature and humidity.
This library can be used for reading both values from these DHT sensors.
The DHT11 only returns integers (e.g. 20) and does not support negative values.
The others are quite similar and provide one decimal digit (e.g. 20.2)
The hardware pins of the sensors and handshake are identical so ideal to combine in one lib.
The library (0.1.13 version) is confirmed to work on:
UNO (tested myself)
2009 (tested myself)
MEGA2560
DUE
attiny85 @8MHz
Digistump Digix @ 84 MHz
More information - http://playground.arduino.cc//Main/DHTLib -
Notes:
version 0.1.13 is the last stable version for both AVR and ARM
version 0.1.14 and up are not compatible anymore with pre 1.0 Arduino
version 0.1.14 and up have breaking changes wrt ARM based arduino's e.g DUE.
version 0.1.15 is stable version for AVR only
version 0.1.16 and 0.1.17 have breaking changes for DHT11
version 0.1.18 works again for DHT11 (avr only)
version 0.1.19 fixed masking bug DHT11 (avr only)
version 0.1.20 Reduce footprint (34 bytes) by using int8_t as error codes. (thanks to chaveiro)
  1. //
  2. //    FILE: dht.cpp
  3. //  AUTHOR: Rob Tillaart
  4. // VERSION: 0.1.20
  5. // PURPOSE: DHT Temperature & Humidity Sensor library for Arduino
  6. //     URL: http://arduino.cc/playground/Main/DHTLib
  7. //
  8. // HISTORY:
  9. // 0.1.20 Reduce footprint (34 bytes) by using int8_t as error codes.
  10. //        (thanks to chaveiro)
  11. // 0.1.19 masking error for DHT11 - FIXED (thanks Richard for noticing)
  12. // 0.1.18 version 1.16/17 broke the DHT11 - FIXED
  13. // 0.1.17 replaced micros() with adaptive loopcount
  14. //        removed DHTLIB_INVALID_VALUE
  15. //        added  DHTLIB_ERROR_CONNECT
  16. //        added  DHTLIB_ERROR_ACK_L  DHTLIB_ERROR_ACK_H
  17. // 0.1.16 masking unused bits (less errors); refactored bits[]
  18. // 0.1.15 reduced # micros calls 2->1 in inner loop.
  19. // 0.1.14 replace digital read with faster (~3x) code
  20. //        => more robust low MHz machines.
  21. //
  22. // 0.1.13 fix negative temperature
  23. // 0.1.12 support DHT33 and DHT44 initial version
  24. // 0.1.11 renamed DHTLIB_TIMEOUT
  25. // 0.1.10 optimized faster WAKEUP + TIMEOUT
  26. // 0.1.09 optimize size: timeout check + use of mask
  27. // 0.1.08 added formula for timeout based upon clockspeed
  28. // 0.1.07 added support for DHT21
  29. // 0.1.06 minimize footprint (2012-12-27)
  30. // 0.1.05 fixed negative temperature bug (thanks to Roseman)
  31. // 0.1.04 improved readability of code using DHTLIB_OK in code
  32. // 0.1.03 added error values for temp and humidity when read failed
  33. // 0.1.02 added error codes
  34. // 0.1.01 added support for Arduino 1.0, fixed typos (31/12/2011)
  35. // 0.1.00 by Rob Tillaart (01/04/2011)
  36. //
  37. // inspired by DHT11 library
  38. //
  39. // Released to the public domain
  40. //
  41. #include "dht.h"
  42. /////////////////////////////////////////////////////
  43. //
  44. // PUBLIC
  45. //
  46. int8_t dht::read11(uint8_t pin)
  47. {
  48.     // READ VALUES
  49.     int8_t result = _readSensor(pin, DHTLIB_DHT11_WAKEUP, DHTLIB_DHT11_LEADING_ZEROS);
  50.     // these bits are always zero, masking them reduces errors.
  51.     bits[0] &= 0x7F;
  52.     bits[2] &= 0x7F;
  53.     // CONVERT AND STORE
  54.     humidity    = bits[0];  // bits[1] == 0;
  55.     temperature = bits[2];  // bits[3] == 0;
  56.     // TEST CHECKSUM
  57.     // bits[1] && bits[3] both 0
  58.     uint8_t sum = bits[0] + bits[2];
  59.     if (bits[4] != sum)
  60.     {
  61.         return DHTLIB_ERROR_CHECKSUM;
  62.     }
  63.     return result;
  64. }
  65. int8_t dht::read(uint8_t pin)
  66. {
  67.     // READ VALUES
  68.     int8_t result = _readSensor(pin, DHTLIB_DHT_WAKEUP, DHTLIB_DHT_LEADING_ZEROS);
  69.     // these bits are always zero, masking them reduces errors.
  70.     bits[0] &= 0x03;
  71.     bits[2] &= 0x83;
  72.     // CONVERT AND STORE
  73.     humidity = word(bits[0], bits[1]) * 0.1;
  74.     temperature = word(bits[2] & 0x7F, bits[3]) * 0.1;
  75.     if (bits[2] & 0x80)  // negative temperature
  76.     {
  77.         temperature = -temperature;
  78.     }
  79.     // TEST CHECKSUM
  80.     uint8_t sum = bits[0] + bits[1] + bits[2] + bits[3];
  81.     if (bits[4] != sum)
  82.     {
  83.         return DHTLIB_ERROR_CHECKSUM;
  84.     }
  85.     return result;
  86. }
  87. /////////////////////////////////////////////////////
  88. //
  89. // PRIVATE
  90. //
  91. int8_t dht::_readSensor(uint8_t pin, uint8_t wakeupDelay, uint8_t leadingZeroBits)
  92. {
  93.     // INIT BUFFERVAR TO RECEIVE DATA
  94.     uint8_t mask = 128;
  95.     uint8_t idx = 0;
  96.     uint8_t data = 0;
  97.     uint8_t state = LOW;
  98.     uint8_t pstate = LOW;
  99.     uint16_t zeroLoop = DHTLIB_TIMEOUT;
  100.     uint16_t delta = 0;
  101.     leadingZeroBits = 40 - leadingZeroBits; // reverse counting...
  102.     // replace digitalRead() with Direct Port Reads.
  103.     // reduces footprint ~100 bytes => portability issue?
  104.     // direct port read is about 3x faster
  105.     uint8_t bit = digitalPinToBitMask(pin);
  106.     uint8_t port = digitalPinToPort(pin);
  107.     volatile uint8_t *PIR = portInputRegister(port);
  108.     // REQUEST SAMPLE
  109.     pinMode(pin, OUTPUT);
  110.     digitalWrite(pin, LOW); // T-be
  111.     delay(wakeupDelay);
  112.     digitalWrite(pin, HIGH); // T-go
  113.     pinMode(pin, INPUT);
  114.     uint16_t loopCount = DHTLIB_TIMEOUT * 2;  // 200uSec max
  115.     // while(digitalRead(pin) == HIGH)
  116.     while ((*PIR & bit) != LOW )
  117.     {
  118.         if (--loopCount == 0) return DHTLIB_ERROR_CONNECT;
  119.     }
  120.     // GET ACKNOWLEDGE or TIMEOUT
  121.     loopCount = DHTLIB_TIMEOUT;
  122.     // while(digitalRead(pin) == LOW)
  123.     while ((*PIR & bit) == LOW )  // T-rel
  124.     {
  125.         if (--loopCount == 0) return DHTLIB_ERROR_ACK_L;
  126.     }
  127.     loopCount = DHTLIB_TIMEOUT;
  128.     // while(digitalRead(pin) == HIGH)
  129.     while ((*PIR & bit) != LOW )  // T-reh
  130.     {
  131.         if (--loopCount == 0) return DHTLIB_ERROR_ACK_H;
  132.     }
  133.     loopCount = DHTLIB_TIMEOUT;
  134.     // READ THE OUTPUT - 40 BITS => 5 BYTES
  135.     for (uint8_t i = 40; i != 0; )
  136.     {
  137.         // WAIT FOR FALLING EDGE
  138.         state = (*PIR & bit);
  139.         if (state == LOW && pstate != LOW)
  140.         {
  141.             if (i > leadingZeroBits) // DHT22 first 6 bits are all zero !!   DHT11 only 1
  142.             {
  143.                 zeroLoop = min(zeroLoop, loopCount);
  144.                 delta = (DHTLIB_TIMEOUT - zeroLoop)/4;
  145.             }
  146.             else if ( loopCount <= (zeroLoop - delta) ) // long -> one
  147.             {
  148.                 data |= mask;
  149.             }
  150.             mask >>= 1;
  151.             if (mask == 0)   // next byte
  152.             {
  153.                 mask = 128;
  154.                 bits[idx] = data;
  155.                 idx++;
  156.                 data = 0;
  157.             }
  158.             // next bit
  159.             --i;
  160.             // reset timeout flag
  161.             loopCount = DHTLIB_TIMEOUT;
  162.         }
  163.         pstate = state;
  164.         // Check timeout
  165.         if (--loopCount == 0)
  166.         {
  167.             return DHTLIB_ERROR_TIMEOUT;
  168.         }
  169.     }
  170.     pinMode(pin, OUTPUT);
  171.     digitalWrite(pin, HIGH);
  172.     return DHTLIB_OK;
  173. }
  174. //
  175. // END OF FILE
  176. //
全部資料51hei下載地址:
DHT-lib.zip (10.73 KB, 下載次數: 31)
主站蜘蛛池模板: 免费成人黄色 | 精品网站999www | 日韩小视频 | 伊人久久影院 | 激情视频一区 | 97色综合 | 欧美日韩久久久 | www.操| 午夜视频免费看 | 欧美精品一二三区 | 亚洲区在线 | 日韩在线精品视频 | 国产精品爽爽爽 | 可以看的毛片 | 天堂在线观看av | 在线播放亚洲 | 国产一级免费观看 | 久久靖品 | 亚洲免费二区 | 亚洲精品乱码 | 网站av | 亚州av在线| 黄视频免费看网站 | 欧美成人精品 | 国产乱码精品一品二品 | 黄色一级大片在线免费看国产一 | 天天射天天操天天干 | 欧美视频一区 | 久久久久久久综合 | 国产精品日韩在线 | 成人免费黄色大片 | 波多野结衣视频在线播放 | 黄色av毛片 | 欧美性猛交99久久久久99按摩 | 国产尤物视频 | 深夜福利网站 | 超碰在线视屏 | 亚洲视频区 | 激情视频网址 | 免费黄色小视频 | 黄色录像大片 |
