查看: 42409|回復: 81
基于STM32驅動IIC0.96寸OLED屏 底層驅動+菜單程序源碼
本文針對IIC OLED屏底層驅動相關代碼
16X32,32X32,128X48等下面附帶相關實物圖
內置簡單的菜單程序,下面附帶實物圖
相關資料已經上傳
stm32單片機OLED菜單源程序如下:
  1. #define OLED_IIC_SCL  PBout(4) //SCL   串行時鐘
  2. #define OLED_IIC_SDA  PBout(3) //SDA  串行數據
  3. }
  4. void OLED_P16x32Ch(unsigned char x,unsigned char y,unsigned int N)
  5. {
  6.         unsigned char wm=0;
  7.         unsigned int adder=64*N;
  8.         OLED_Set_Pos(x , y);
  9.         for(wm = 0;wm < 16;wm++)
  10.         {
  11.                 OLED_WrDat(F16x32[adder]);
  12.                 adder += 1;
  13.         }
  14.         OLED_Set_Pos(x,y+1 );
  15.         for(wm = 0;wm <16;wm++)
  16.         {
  17.                 OLED_WrDat(F16x32[adder]);
  18.                 adder += 1;
  19.         }
  20. OLED_Set_Pos(x , y+2);
  21.         for(wm = 0;wm < 16;wm++)
  22.         {
  23.                 OLED_WrDat(F16x32[adder]);
  24.                 adder += 1;
  25.         }
  26.         OLED_Set_Pos(x,y+3 );
  27.         for(wm = 0;wm <16;wm++)
  28.         {
  29.                 OLED_WrDat(F16x32[adder]);
  30.                 adder += 1;
  31.         }
  32. }
  33. void OLED_P32x32Ch(unsigned char x,unsigned char y,unsigned int N)
  34. {
  35.         unsigned char wm=0;
  36.         unsigned int adder=128*N;
  37.         OLED_Set_Pos(x , y);
  38.         for(wm = 0;wm < 32;wm++)
  39.         {
  40.                 OLED_WrDat(F32x32[adder]);
  41.                 adder += 1;
  42.         }
  43.         OLED_Set_Pos(x,y+1 );
  44.         for(wm = 0;wm <32;wm++)
  45.         {
  46.                 OLED_WrDat(F32x32[adder]);
  47.                 adder += 1;
  48.         }
  49. OLED_Set_Pos(x , y+2);
  50.         for(wm = 0;wm < 32;wm++)
  51.         {
  52.                 OLED_WrDat(F32x32[adder]);
  53.                 adder += 1;
  54.         }
  55.         OLED_Set_Pos(x,y+3 );
  56.         for(wm = 0;wm <32;wm++)
  57.         {
  58.                 OLED_WrDat(F32x32[adder]);
  59.                 adder += 1;
  60.         }
  61. }
  62. void OLED_P128x48Ch(unsigned char x,unsigned char y,unsigned int N)
  63. {
  64.         unsigned char wm=0;
  65.         unsigned int adder=768*N;
  66.         OLED_Set_Pos(x , y);
  67.         for(wm = 0;wm < 128;wm++)
  68.         {
  69.                 OLED_WrDat(F128x48[adder]);
  70.                 adder += 1;
  71.         }
  72.         OLED_Set_Pos(x,y+1);
  73.         for(wm = 0;wm <128;wm++)
  74.         {
  75.                 OLED_WrDat(F128x48[adder]);
  76.                 adder += 1;
  77.         }
  78. OLED_Set_Pos(x , y+2);
  79.         for(wm = 0;wm < 128;wm++)
  80.         {
  81.                 OLED_WrDat(F128x48[adder]);
  82.                 adder += 1;
  83.         }
  84. OLED_Set_Pos(x,y+3 );
  85.         for(wm = 0;wm <128;wm++)
  86.         {
  87.                 OLED_WrDat(F128x48[adder]);
  88.                 adder += 1;
  89.         }
  90. OLED_Set_Pos(x,y+4 );
  91.         for(wm = 0;wm <128;wm++)
  92.         {
  93.                 OLED_WrDat(F128x48[adder]);
  94.                 adder += 1;
  95.         }
  96. OLED_Set_Pos(x,y+5 );
  97.         for(wm = 0;wm <128;wm++)
  98.         {
  99.                 OLED_WrDat(F128x48[adder]);
  100.                 adder += 1;
  101.         }
  102. }
  103. //  IIC協議    OLED屏 人機界面
  104. void lnterface(void)                          //人機界面
  105. {
  106.
  107.         Status_Bar();
  108.         switch(Page_Sgin)
  109.         {
  110.                 case 0:
  111.                              Main_Menu(); break;
  112.                 case 2:
  113.                              Menu_2(); break;
  114.                 case 3:
  115.                              Menu_3();break;
  116.
  117.
  118.                 default : break;
  119.         }
  120.
  121. }
  122. //主菜單
  123. void Main_Menu(void)
  124. {
  125.   WhenTheDisplay();                             //顯示時分秒
  126.         DayAndDayDisplay();                         //顯示年月日
  127.         OLED_P16x16Ch(0*16,6,11);                   //顯示 //菜
  128.         OLED_P16x16Ch(1*16,6,12);                   //顯示 //單
  129.         OLED_P16x16Ch(6*16,6,13);                   //顯示 //退
  130.         OLED_P16x16Ch(7*16,6,14);                   //顯示 //出
  131.         if(KEY_Scan(Key_Selectio)==Determine_Choice)//判斷是否按下確定按鍵
  132.         {
  133.                 Page_Sgin=2;                              //頁面選擇置2
  134.                 OLED_P128x48Ch(0,2,0);                    //清除內容欄
  135.         }
  136. }
  137. void Menu_2(void)
  138. {
  139.         if(Choice==2||Choice==4||Choice==6)
  140.         {
  141.                 OLED_P16x16Ch(0*16,Choice,44);              //選擇
  142.                 Display(2,0,0);
  143.
  144.
  145.                 switch(KEY_Scan(Key_Selectio))
  146.                 {
  147.                         case Superior_Choice:                     //上翻
  148.                                    OLED_P16x16Ch(0*16,Choice,37);
  149.                                    Choice-=2;
  150.                                    break;
  151.                         case Subordinate_Choice:                  //下翻
  152.                                    OLED_P16x16Ch(0*16,Choice,37);
  153.                                    Choice+=2;
  154.                                    break;
  155.                         case Determine_Choice:                    //確定
  156.                                    OLED_P128x48Ch(0,2,0);               //清除內容欄
  157.                              Page_Sgin=3;Choice=2;
  158.                                    break;
  159.                         case Return_Choice:                       //返回
  160.                                    OLED_P128x48Ch(0,2,0);
  161.                                    Page_Sgin=0;
  162.                              break;
  163.                         default :
  164.                                    break;
  165.                 }
  166.
  167.         }
  168.         else if(Choice>6)Choice=2;
  169.         else if(Choice<2)Choice=6;
  170.
  171.         OLED_ShowNum(6*16,6,Choice/2,1,12);
  172.         OLED_P6x8Str(6.5*16,7,"/");
  173.         OLED_P6x8Str(7*16,7,"10");
  174. }
  175. void Menu_3(void)
  176. {
  177.         if(Choice==2||Choice==4||Choice==6)
  178.         {
  179.                 OLED_P16x16Ch(0*16,Choice,44);              //選擇
  180.                 Display(2,0,0);
  181.
  182.                 switch(KEY_Scan(Key_Selectio))
  183.                 {
  184.                         case Superior_Choice:                     //上翻
  185.                                    OLED_P16x16Ch(0*16,Choice,37);
  186.                                    Choice-=2;
  187.                                    break;
  188.                         case Subordinate_Choice:                  //下翻
  189.                                    OLED_P16x16Ch(0*16,Choice,37);
  190.                                    Choice+=2;
  191.                                    break;
  192.                         case Determine_Choice:                    //確定
  193.                                    OLED_P128x48Ch(0,2,0);               //清除內容欄
  194.                              Page_Sgin=3;Choice=2;
  195.                                    break;
  196.                         case Return_Choice:                       //返回
  197.                                    OLED_P128x48Ch(0,2,0);
  198.                                    Page_Sgin=2;Choice=2;
  199.                              break;
  200.                         default :
  201.                                    break;
  202.                 }
  203.
  204.         }
  205.         else if(Choice>6)Choice=2;
  206.         else if(Choice<2)Choice=6;
  207.
  208.         OLED_ShowNum(6*16,6,Choice/2,1,12);
  209.         OLED_P6x8Str(6.5*16,7,"/");
  210.         OLED_P6x8Str(7*16,7,"10");
  211. }
  212.
PCtoLCD2002完美版.rar (702.05 KB, 下載次數: 480)
IIC驅動0.96寸OLED顯示實驗.rar (313.56 KB, 下載次數: 1607)
參與人數 2黑幣 +62 收起 理由
等風來, + 12
收藏收藏43 分享淘帖 頂3 踩
ID:297748 發表于 2018-4-22 21:01 | 只看該作者
非常不錯的程序,值得看看
ID:278170 發表于 2018-6-16 12:38 | 只看該作者
感謝摟主,學習學習
ID:357829 發表于 2018-6-24 16:31 | 只看該作者
你好,請問這個程序是stm32f103的嗎?
ID:360008 發表于 2018-6-27 10:07 | 只看該作者
很好的資料,正好學習需要
ID:278170 發表于 2018-7-21 13:51 | 只看該作者
很好的資料,感謝摟主
ID:374694 發表于 2018-7-23 07:52 | 只看該作者
學習學習
ID:392122 發表于 2018-8-31 20:23 | 只看該作者
找了好久!謝謝樓主的資源!
ID:375691 發表于 2018-9-8 19:03 | 只看該作者
66666感謝分享
ID:406408 發表于 2018-10-10 10:18 來自觸屏版 | 只看該作者
學習了,謝謝樓主!
ID:396406 發表于 2018-10-18 19:09 | 只看該作者
打開后程序首先有錯誤  其次主程序都被注釋掉了 就留了它qq 什么意思
ID:252603 發表于 2018-11-1 13:42 | 只看該作者
不能用
ID:262504 發表于 2018-11-6 17:05 | 只看該作者
剛好需要,謝謝分享
ID:374205 發表于 2018-11-6 21:52 | 只看該作者
謝謝樓主分享
ID:171746 發表于 2018-11-7 09:00 | 只看該作者
在stm32f429要改哪些地方?
ID:422206 發表于 2018-11-7 10:47 | 只看該作者
不錯,看看!
ID:422466 發表于 2018-11-7 16:55 | 只看該作者
寫得真的不錯!
ID:257841 發表于 2018-11-14 11:51 | 只看該作者
非常不錯的程序,值得看看
ID:140559 發表于 2018-11-14 23:19 | 只看該作者
好好學習學習,感謝您的分享
ID:427690 發表于 2018-11-16 13:55 | 只看該作者
謝謝分享呀,正好用上啦,棒棒棒!
ID:427910 發表于 2018-11-16 21:33 | 只看該作者
謝謝分享
ID:428508 發表于 2018-11-18 01:13 來自觸屏版 | 只看該作者
很好的資料
ID:371527 發表于 2018-12-12 20:09 | 只看該作者
感謝分享,測試一下,豎排陰反選菜單去掉顯示“確定”簡潔些
ID:385004 發表于 2018-12-13 19:44 | 只看該作者
很好的資源,下載看看
ID:81138 發表于 2018-12-13 22:29 | 只看該作者
我就是懶靜等成品
ID:137052 發表于 2018-12-16 22:17 | 只看該作者
謝謝樓主的分享啦。不過我怎么燒進去沒反應呢。。
ID:278145 發表于 2018-12-19 22:50 | 只看該作者
謝謝分享,值得學習
ID:450568 發表于 2018-12-20 10:50 | 只看該作者
謝謝樓主分享,我好好學習一下
ID:278145 發表于 2018-12-20 12:21 | 只看該作者
謝謝分享,不錯資料
ID:371527 發表于 2018-12-25 18:01 | 只看該作者
下載學習一下
ID:397008 發表于 2018-12-26 16:14 | 只看該作者
看著不錯;有需求會回來
ID:205091 發表于 2019-1-10 14:43 | 只看該作者
謝謝分享
ID:443931 發表于 2019-1-14 09:13 | 只看該作者
謝謝樓主分享
ID:337376 發表于 2019-2-10 09:19 | 只看該作者
謝謝樓主分享
ID:37147 發表于 2019-2-16 15:10 | 只看該作者
內容太棒了!非常的工整!謝謝!
ID:317383 發表于 2019-2-21 07:32 | 只看該作者
很好的資料,多給些資料
ID:478779 發表于 2019-2-21 10:46 | 只看該作者
不錯,學習學習
ID:101244 發表于 2019-2-23 11:31 | 只看該作者
不錯  我的下載上就是閃屏
ID:385466 發表于 2019-4-11 17:14 | 只看該作者
學習參考一下
ID:510870 發表于 2019-4-12 22:46 | 只看該作者
好好學習學習,感謝您的分享
主站蜘蛛池模板: 一级理论片 | 免费毛片在线 | 日韩特级毛片 | 人人干人人爱 | 久久久久久一区 | 色在线播放| 色综合天天综合网天天狠天天 | 免费一级黄色片 | 欧美成人激情视频 | 一边摸一边操 | 欧美日韩精品在线 | 久久精品欧美一区二区三区不卡 | 黄色福利视频 | 超碰在线观看免费 | 欧美不卡在线观看 | 午夜性视频| 欧美日韩国产一区二区三区 | 毛片一级片| 国产精品久久久久久无人区 | 国产一区二区三区四区 | 亚洲乱码在线 | 午夜成人在线视频 | 深夜福利网站 | av网站网址 | 97人人艹 | 久久国内精品 | 一道本av | 午夜影院在线 | 亚洲综合婷婷 | 91青青草 | 欧美在线免费观看 | 久久免费福利视频 | 午夜国产在线 | 中文字幕不卡在线观看 | 一级片免费在线观看 | 久久人体 | 久草超碰| 日韩国产在线播放 | 久久在线免费视频 | 亚洲一级大片 | 亚洲第十页 |
