查看: 5123|回復: 4
STM32F1 SD卡升級用戶代碼 bootloader_IAP
ID:320543 發表于 2018-5-2 16:12 | 顯示全部樓層 |閱讀模式
SD卡升級具體看代碼 , 以后還有U盤升級, 遠程升級等
bootloader_iap_sd
  1. /*************************************************************
  2. *************************************************************/
  3. #include "includes.h"
  4. extern pFunction Jump_To_Application;
  5. extern uint32_t JumpAddress;
  6. /* Private function prototypes -----------------------------------------------*/
  7. /* Private functions ---------------------------------------------------------*/
  8. /*******************************************************************************
  9. * @brief  Main program.
  10. * @param  None
  11. * @retval None
  12. *******************************************************************************/
  13. unsigned int key_flag = 0;
  14. int main(void)
  15. {
  16.         GPIO_InitTypeDef GPIO_InitStructure;
  17.   //Flash解鎖
  18.         FLASH_Unlock();
  19.   //Test if Key push-button on STM3210X-EVAL Board is pressed
  20.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);//
  21.         GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_5;//PA5
  22.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //
  23.         GPIO_Init(GPIOA, &GPIO_InitStructure);//
  24.
  25.         key_flag = GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_5);
  26.
  27.   /* 如果按鍵按下, 執行IAP驅動程序更新Flash程序 */
  28.   if (!key_flag)
  29.   {
  30.                 //串口初始化
  31.     BSP_Init();
  32.     SerialPutString("\r\n======================================================================");
  33.                 SerialPutString("\r\n                .\"\".    .\"\",");
  34.                 SerialPutString("\r\n                |  |   /  /");
  35.                 SerialPutString("\r\n                |  |  /  /");
  36.                 SerialPutString("\r\n                |  | /  /");
  37.                 SerialPutString("\r\n                |  |/  ;-._ ");
  38.                 SerialPutString("\r\n                }  ` _/  / ;");
  39.                 SerialPutString("\r\n                |  /` ) /  /");
  40.                 SerialPutString("\r\n                | /  /_/\\_/\\");
  41.                 SerialPutString("\r\n                |/  /      |");
  42.                 SerialPutString("\r\n                (  ' \\ '-  |");
  43.                 SerialPutString("\r\n                 \\    `.  /");
  44.                 SerialPutString("\r\n                  |      |");
  45.                 SerialPutString("\r\n                  |      |");
  46.                 SerialPutString("\r\n=                               Bootloader for STM32F10X  v1.0.1     =");
  47.                 SerialPutString("\r\n=                               COPYRIGHT@2012     Wanwei Tech       =");
  48.     SerialPutString("\r\n======================================================================");
  49.     SerialPutString("\r\n\r\n");
  50.     Main_Menu ();
  51.   }
  52.   else
  53.         {
  54.                 IAP_JumpToApplication();  /* 執行用戶程序 */
  55.         }
  56.
  57.   while (1)
  58.   {
  59.         }
  60. }
  61. #ifdef  USE_FULL_ASSERT
  62. /*******************************************************************************
  63. * @brief                Reports the name of the source file and the source line number
  64. *                                 where the CHECK_PARAM error has occurred.
  65. * @param[in]        file Pointer to the source file name
  66. * @param[in]    line assert_param error line source number
  67. * @return                None
  68. *******************************************************************************/
  69. void assert_failed(uint8_t* file, uint32_t line)
  70. {
  71.         printf("Wrong parameters value: file %s on line %d\r\n", file, line);
  72. //while(1);
  73. }
  74. #endif /* USE_FULL_ASSERT */
  75. /**
  76.   * @}
  77.   */
  78. /******************* (C) COPYRIGHT 2010 STMicroelectronics *****END OF FILE****/
bootloader_iap_sd.rar (1.16 MB, 下載次數: 183)
ID:445582 發表于 2019-2-27 15:42 | 顯示全部樓層
F1系列小容量和中容量貌似沒有SDIO接口啊
ID:130559 發表于 2019-4-9 16:33 | 顯示全部樓層
程序占用了19K的ROM啊,從3000開始跑APP程序會不會不夠啊
ID:297069 發表于 2020-5-2 14:43 | 顯示全部樓層
謝謝分享
ID:59363 發表于 2021-7-28 15:26 | 顯示全部樓層
試試好不好用
主站蜘蛛池模板: 日韩精品视频免费在线观看 | 成人高潮片免费网站 | 综合久久久 | 小镇姑娘国语版在线观看免费 | 亚洲 欧美 日韩 在线 | 日本黄色三级视频 | 久久久婷婷 | 天天看天天干 | 日韩免费高清视频 | 伊人久久艹| 天天爽天天 | 成人在线视频网 | 欧美在线观看一区二区 | 国产伊人久久 | 精品国产一区二区三区四区 | 久国产| 国产精品偷拍 | 久久免费国产 | 国产黄网 | 国产精品一品二区三区的使用体验 | 天天色天天爱 | 国产精品久久久久久无人区 | 一区二区三区视频 | 一区二区精品视频 | 亚洲精品一区二三区 | 一级a毛片 | 成人午夜在线 | 日韩怡红院 | 日本视频一区二区三区 | 91久久久久 | 一级片大全 | 免费一级大片 | 久久精品视频网 | 午夜精品国产精品大乳美女 | 美日韩一区二区三区 | 鲁鲁鲁鲁鲁鲁鲁777777 | 欧美精品第一页 | 黄色片视频在线观看 | 成人不卡 | 精品成人在线 | 国产美女在线播放 |
