查看: 10046|回復: 8
單片機心形流水燈制作PCB圖與電路原理圖及源碼
ID:257960 發表于 2018-5-5 21:03 | 顯示全部樓層 |閱讀模式
Altium Designer畫的心形流水燈原理圖和PCB圖如下:(51hei附件中可下載工程文件)
  1. #include <reg52.h>
  2. #include<intrins.h>                  //包含_crol_函數的頭文件
  4. #define uint   unsigned int
  5. uchar  aa,bb,cc,dd,ee;
  6. void  delayms(uint t);
  7. void  a();
  8. void  b();
  9. void  c();
  10. void  d();
  11. void  e();
  12. void  f();
  13. void  g();
  14. void  h();
  15. void k();
  16. void q();
  17. void p();
  18. void l();
  19. void x();
  20. void v();
  21. void z();
  22. void y();
  23. void w();
  24. void m();
  25. void r();
  26. void i();
  27. uchar code  LP0[]={0x01,0x03,0x07,0x0f,0x1f,0x3f,0x7f,0xff,
  28.                                    0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,//半個心向下
  29.                                    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  30.                                    0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe,0xff,//半心向上
  31.                                    0x01,0x03,0x07,0x0f,0x1f,0x3f,0x7f,0xff,
  32.                                    0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  33.                                    0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  34.                                    0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,//從右到左全心
  35.                                   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  36.                                   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  37.                                   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  38.                                   0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe,0xff//從左到全心
  39.
  40.                                    };
  41. uchar code  LP1[]={0x01,0x03,0x07,0x0f,0x1f,0x3f,0x7f,0xff,
  42.                                    0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,//
  43.                                         0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  44.                                         0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe,0xff,//
  45.                                    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  46.                                    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  47.                                    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  48.                                    0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe,0xff,//
  49.                                    0x01,0x03,0x07,0x0f,0x1f,0x3f,0x7f,0xff,
  50.                                    0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  51.                                    0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  52.                                    0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff
  53.
  54.                                    };
  55. uchar code  LP3[]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  56.                    0x01,0x03,0x07,0x0f,0x1f,0x3f,0x7f,0xff,//
  57.                                    0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe,0xff,
  58.                                    0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff ,//
  59.                                    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  60.                                    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  61.                                   0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe,0xff,
  62.                                   0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff ,//
  63.                                   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  64.                                   0x01,0x03,0x07,0x0f,0x1f,0x3f,0x7f,0xff,
  65.                                   0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff ,
  66.                                   0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff
  67.
  68.
  69.                                    };
  70. uchar code  LP2[]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  71.                                    0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe,0xff,//
  72.                                    0x01,0x03,0x07,0x0f,0x1f,0x3f,0x7f,0xff,
  73.                                    0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff ,//
  74.                                    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  75.                                    0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe,0xff,
  76.                                    0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  77.                                    0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,//
  78.                                    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  79.                                    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  80.                                    0x01,0x03,0x07,0x0f,0x1f,0x3f,0x7f,0xff,
  81.                                    0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  82.
  83.                                    };
  84. uchar code  LP01[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80//從0到7的一個一個亮
  85.
  86. };
  87. uchar code  LP02[]={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};//從7到0的一個一個亮
  88.
  89.
  90. uchar code  LP03[]={
  91.              0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe,0xff
  92.                                   };
  93. uchar code  LP04[]={
  94.              0xff,0x7f,0x3f,0x1f,0x0f,0x07,0x03,0x01,0x00
  95.                                   };//從7開始逐個滅
  96. uchar code  LP05[]={0xff,0xfe,0xfc,0xf8,0xf0,0xe0,0xc0,0x80,0x00
  97.                        };//從0開始到7逐個滅
  98.   uchar code  LP06[]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
  99.                     };
  100. uchar code  LP07[]={0x00,0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe,0xff
  101.              };//從7逐個亮
  102. uchar code  LP08[]={0x00,0x01,0x03,0x07,0x0f,0x1f,0x3f,0x7f,0xff
  103.                }; //從0開始逐個亮
  104.   void main()
  105. {
  106.           k();q();p();v();v();l();l();w();h();h();h();k();m();e();p();c();c();c();c();
  107.           r();d();d();h();h();l();p();d();
  108.           d();y();i();p();v();l();k();h();g();
  109.           f();d();k();p();h();h();z();x();c();v();b();m();
  110.           z();q();f();k();v();v();w();r(); d();d();x();y();i();l();k();h();
  111.          c();v();p();g();k();l();l();b();m();k(); g();        p();
  112.    v();e();y();p();i();p();p();k();g();f(); w();
  113.           z();l();x();c();c();c();c();c();k();p();e();q();v();v();r();b();m();h();
  114.          m();h();d();w();r();k();k();g();k();k();k();x();
  115.          k();d();d();y();l();z();k();j();g();
  116.           f();p();c();c();c();c();i();v();p();k();k();p();k();b(); a();q();
  117. }
  118. void a() //順時針一個流水
  119. {
  120. uint i,m=150;
  121. for(m;m>80;m=m-8)
  122.          {
  123.          for(i=0;i<8;i++)
  124.                 {
  125.                 P1=P2=P3=0X00;
  126.                  P0=LP01[i];
  127.                  delayms(m);
  128.                 }
  129.                 for(i=0;i<8;i++)
  130.                 {
  131.                 P0=P1=P3=0X00;
  132.                  P2=LP02[i];
  133.                  delayms(m);
  134.                 }
  135.
  136.             for(i=0;i<8;i++)
  137.                 {
  138.                 P1=P2=P0=0X00;
  139.                  P3=LP02[i]        ;
  140.                  delayms(m);
  141.                 }
  142.             for(i=0;i<8;i++)
  143.                 {
  144.                 P0=P2=P3=0X00;
  145.                  P1=LP02[i];
  146.           delayms(m);
  147.
  148.                 }
  149.                 }
  150.         }
  151.         void b()
  152.         {                uint i;
  153.                                      for(i=0;i<97;i++)
  154.                                                  {
  155.                                            uint m=150;
  156.                                                    P0=LP0[i];
  157.                                                    P1=LP1[i];
  158.                                                    P2=LP2[i];
  159.                                                    P3=LP3[i];
  160.                                                    delayms(m);
  161.                                                    }
  162.           }
  163.           void c() //一起閃滅
  164.    {
  165.            uint m=380;
  166.         for(m;m>30;m=m-50)
  167.         {P0=P1=P2=P3=0X00;
  168.         delayms(m);
  169.         P0=P1=P2=P3=0xff;
  170.     delayms(m);
  171.
  172.         }
  173.           }
  174. void d()          //8燈順時針行走
  175. {         uint m=140,j=0,i=0,k=0,q=0;
  176.            for(j;j<9;j++)         //從0到2過度
  177. {
  178. P0=LP05[j];
  179.         P2=LP07[j];
  180.         P1=P3=LP06[j];
  181.         delayms(m);
  182.       }
  183.
  184.
  185.
  186.                   for(i;i<9;i++) //從2到3過度
  187. {
  188. P0=P1=LP06[i];
  189.         P2=LP04[i];
  190.     P3=LP07[i];
  191.         delayms(m);
  192.       }
  193.                   for(k;j<9;k++)//從3到1過度
  194. {
  195. P0=P2=LP06[k];
  196.         P3=LP04[k];
  197. P1=LP07[k];
  198.         delayms(m);
  199.       }
  200.
  201.                   for(q;q<9;q++)//從3到0過度
  202. {
  203. P3=P2=LP06[q];
  204.         P1=LP04[q];
  205. P0=LP08[q];
  206.         delayms(m);
  207.       }
  208. }
  209.         void e() //單個從倆邊向中間
  210.         {   uint i,j,m=250;
  211.          for(i=0;i<8;i++)
  212.          {
  213.          P0=P1=LP01[i];
  214.         P2=P3=LP06[i];
  215.         delayms(m);
  216.         for(j=0;j<8;j++)
  217.          {
  218.          P3=LP01[j];
  219.          P2=LP02[j];
  220.         P0=P1=LP06[j];
  221.         delayms(m);
  222.          }
  223.         }
  224.         }
  225.         void f()//從中間一個向兩邊
  226.         { uint i,m=200;
  227.           for(i=0;i<8;i++)
  228.          {
  229.          P0=P2=P1=LP02[i];
  230.         P3=LP01[i];
  231.         delayms(m);
  232.         }
  233.
  234.
  235.         }
  236.         void g()//中間向倆邊亮著走向倆邊收回
  237. {  uint i,j,m=200;
  238.   for(i=0;i<8;i++)
  239.          {
  240.          P0=P2=P1=LP07[i];
  241.         P3=LP08[i];
  242.         delayms(m);
  243.         }
  244.         for(j=0;j<9;j++)
  245.          {
  246.          P0=P2=P1=LP04[j];
  247.         P3=LP05[j];
  248.         delayms(m);
  249.         }
  250. }
  251.         void h()//從中間亮再從下面回來
  252. {  uint i,j,m,n;
  253.   for(i=0;i<8;i++)
  254.          {m=200;
  255.          P0=P2=P1=LP07[i];
  256.         P3=LP08[i];
  257.         delayms(m);
  258.         }
  259.         for(n=0;n<5;n++)
  260.          {  m=200;
  261.           P0=P2=P1=P3=0xff;
  262.           delayms(m);
  263.         }
  264.         for(j=0;j<9;j++)
  265.          { m=200;
  266.          P0=P2=P1=LP08[j];
  267.         P3=LP07[j];
  268.         delayms(m);
  269.         }
  270.
  271.         for(n=0;n<5;n++)
  272.          {  m=200;
  273.           P0=P2=P1=P3=0xff;
  274.           delayms(m);
  275.         }
  276.
  277.         }
  278.                 void k() //亂花閃
  279.         {   uint i,m=100;
  280.          for(i=0;i<8;i++)
  281.          {
  282.          P0=P1=P2=P3=0xaa;
  283.          delayms(m);
  284.         P0=P1=P2=P3=0x55;
  285.         delayms(m);
  286.
  287.          }
  288.          }
  289.          void q() //逆時針一個流水
  290. {
  291. uint i,m=180;
  292. for(m;m>0;m=m-10)
  293.          {
  294.
  295.                 for(i=0;i<8;i++)
  296.                 {
  297.                 P0=P2=P3=0X00;
  298.                  P1=LP01[i];
  299.           delayms(m);
  300.
  301.                 }
  302.
  303.             for(i=0;i<8;i++)
  304.                 {
  305.                 P1=P2=P0=0X00;
  306.                 P3=LP01[i]
  307.                         ;
  308.                  delayms(m);
  309.                 }
  310.                         for(i=0;i<8;i++)
  311.                 {
  312.                 P0=P1=P3=0X00;
  313.                  P2=LP01[i];
  314.                  delayms(m);
  315.                 }
  316.
  317.
  318.                  for(i=0;i<8;i++)
  319.                 {
  320.                 P1=P2=P3=0X00;
  321.                  P0=LP02[i];
  322.                  delayms(m);
  323.                 }
  324.                 }
  325.         }
  326.          void p()//先左邊亮在右邊亮
  327. {
  328.    uint i,j,k,o,m=160;
  329.     for(i=0;i<8;i++)
  330.                 {
  331.                 P0=P2=P3=0X00;
  332.                  P1=LP08[i];
  333.                  delayms(m);
  334.                 }
  335.                 for(j=0;j<8;j++)
  336.                 {
  337.                 P0=P2=0X00;
  338.                  P3=LP08[j];
  339.                  delayms(m);
  340.                 }
  341.                 for(k=0;k<8;k++)
  342.                 {
  343.                 P1=P3=0Xff;
  344.                  P0=LP08[k];
  345.                  delayms(m);
  346.                 }
  347.                 for(o=0;o<8;o++)
  348.                 {
  349.                 P1=P3=P0=0Xff;
  350.                  P2=LP07[o];
  351.                  delayms(m);
  352.                 }
  353. }
  354.     void l() //先從左一半滅全滅完后在右邊
  355.         {
  356.          uint i,j,x,s,m=300;
  357.                 P1=P3=P0=0Xff;
  358.                 delayms(80);
  359.                 for(i=0;i<8;i++)
  360.                 {
  361.                 P1=P3=P0=0Xff;
  362.                  P2=LP05[i];
  363.                  delayms(m);
  364.                    }
  365.                 for(j=0;j<8;j++)
  366.                 {
  367.                 P1=P3=0Xff;
  368.                 P2=0x00;
  369.                  P0=LP04[j];
  370.                  delayms(m);
  371.                 }
  372.                         for(x=0;x<8;x++)
  373.                 {
  374.                 P0=P2=0x00;
  375.                 P1=0xff;
  376.                  P3=LP04[x];
  377.                  delayms(m);
  378.                 }
  379.
  380.                         for(s=0;s<8;s++)
  381.                 {
  382.                 P0=P2=P3=0x00;
  383.
  384.                  P1=LP04[s];
  385.                  delayms(m);
  386.                 }
  387.
  388.         }
  389.         void x()//逆時針流水
  390.         {
  391.          uint i,j,k,n;
  392.                  for(i=0;i<8;i++)
  393.                 {
  394.                 P0=P2=P3=0x00;
  395.
  396.                  P1=LP01[i];
  397.                  delayms(250);
  398.                 }
  399.                            for(j=0;j<8;j++)
  400.                 {
  401.                 P0=P2=P1=0x00;
  402.
  403.                  P3=LP01[j];
  404.                  delayms(200);
  405.                 }
  406.                         for(k=0;k<8;k++)
  407.                 {
  408.                 P0=P3=P1=0x00;
  409.
  410.                  P2=LP01[k];
  411.                  delayms(170);
  412.                 }
  413.                         for(n=0;n<8;n++)
  414.                 {
  415.                 P2=P3=P1=0x00;
  416.
  417.                  P0=LP02[n];
  418.                  delayms(130);
  419.                 }
  420.
  421.
  422.         }
  423.          void v()//中間向倆邊
  424.          {
  425.            uint i,j,k,n,p,m;
  426.     for(i=0;i<8;i++)
  427.                 { m=300;
  428.         P0=P2=P3=P1=0X00;
  429.                  P3=LP08[i];
  430.                  delayms(m);
  431.                 }
  432.                 for(j=0;j<8;j++)
  433.                 { m=300;
  434.                 P0=P1=0X00;
  435.                 P3=0xff;
  436.                  P2=LP07[j];
  437.                  delayms(m);
  438.                 }
  439.                    for(k=0;k<8;k++)
  440.                 {  m=300;
  441.                 P3=P2=0Xff;
  442.                 P0=0x00;
  443.                  P1=LP07[k];
  444.                  delayms(m);
  445.                 }
  446.                 for(n=0;n<8;n++)
  447.                 {  m=300;
  448.         P1=P3=P2=0Xff;
  449.         P0=0x00;
  450.                  P0=LP07[n];
  451.                  delayms(m);
  452.                 }
  453.                                 for(p=0;p<3;p++)
  454.                 {   m=80;
  455. P0=P1=P3=P2=0Xff;
  456.                  delayms(m);
  457.
  458.    }
  459.
  460.
  461.
  462.          }
  463.    void z()//對角開始亮
  464.    {
  465.             uint i,j,k,m;
  466.            for(i=0;i<8;i++)
  467.                 {
  468.                   m=200;
  469.                  P0=LP08[i];
  470.                  P3=LP07[i];
  471.                  P1=P2=0x00;
  472.                  delayms(m);
  473.                 }
  474.
  475.                         for(j=0;i<j;j++)
  476.                 {
  477.                     m=200;
  478.                  P2=P1=LP08[j];
  479.
  480.                  P3=P0=0xff;
  481.                  delayms(m);
  482.                 }
  483.                 for(k=0;k<3;k++)
  484.                 {   m=40;
  485. P0=P1=P3=P2=0Xff;
  486.                  delayms(m);
  487.
  488.    }
  489. }
  490. void y() //從左邊向倆邊滅
  491. {uint i,j,k,m;
  492. for(i=0;i<8;i++)
  493.                 {   m=200;
  494. P1=LP04[i];
  495. P3=        LP05[i];
  496. P0=P2=0xff;
  497.                  delayms(m);
  498.
  499.    }
  500. for(j=0;j<8;j++)
  501.                 {   m=200;
  502. P2=P0=LP05[j];
  503. P1=P3=0x00;
  504.                  delayms(m);
  505.
  506.    }
  507. for(k=0;k<3;k++)
  508.                 {   m=160;
  509. P0=P1=P3=P2=0Xff;
  510.                  delayms(m);
  511.
  512.    }
  513. }
  514.
  515.            void i()
  516.    {
  517.    uint n,j,m=200;
  518.   for(m=200;m>20;m=m-15)
  519.
  520.   {
  521.    for(n=0;n<8;n++)
  522.                 {
  523.   P0=LP08[n];
  524.      P3=LP07[n];
  525.     P1=P2=0x00;
  526.                  delayms(m);
  527.
  528.       }
  529.             for(j=0;j<8;j++)
  530.                 {
  531.      P1=P2=LP07[j];
  532.       P0=P3=0xff;
  533.          delayms(m);
  534.
  535.    }
  536.
  537.    }
  538. }
  539.      void w()//半個反向像一起
  540.    {
  541.    uint n,j,m=200;
  542.   for(m=200;m>20;m=m-15)
  543.
  544.   {
  545.    for(n=0;n<8;n++)
  546.                 {
  547.   P0=LP08[n];
  548.      P3=LP07[n];
  549.     P1=P2=0x00;
  550.                  delayms(m);
  551.
  552.       }
  553.             for(j=0;j<8;j++)
  554.                 {
  555.      P1=P2=LP07[j];
  556.       P0=P3=0xff;
  557.          delayms(m);
  558.              }
  559.    }
  560. }
  561.          void m() //一半反著走
  562.    {
  563.    uint i,n,j,m=200;
  564.   for(m=100;m>20;m=m-15)
  565.
  566.   {
  567.    for(n=0;n<8;n++)
  568.                 {
  569.   P1=P2=LP08[n];
  570.
  571.     P0=P3=0x00;
  572.                  delayms(m);
  573.
  574.       }
  575.             for(j=0;j<8;j++)
  576.                 {
  577.      P3=P0=LP08[j];
  578.          P0=LP07[j];
  579.       P1=P2=0xff;
  580.          delayms(m);
  581.              }
  582.
  583.    }
  584.    for(i=0;i<3;i++)
  585.                 {
  586.                  m=150;
  587.
  588.       P3=P0=P1=P2=0xff;
  589.          delayms(m);
  590.              }
  591. }
  592. void r()
  593.   {uint m;
  594.
  595.    for(m=400;m>10;m=m-10)
  596.
  597.           {
  598.       P3=P1=0xff;
  599.            P0=P2=0x00;
  600.                    delayms(m);
  601.           P3=P1=0x00;
  602.            P0=P2=0xff;
  603.              delayms(m);
  604.            }
  605.   }
  606.
  607.
  608.      void delayms(uint t)   //毫秒延時
  609. {
  610.          uint i,j;
  611.         for(i=t;i>0;i--)
  612.          for(j=110;j>0;j--);
  613. }
  614.
心形流水燈制作.rar (662.86 KB, 下載次數: 106)
ID:259987 發表于 2018-6-23 20:14 | 顯示全部樓層
做出來不對啊
ID:257960 發表于 2019-2-18 14:18 來自觸屏版 | 顯示全部樓層
泡泡1 發表于 2018-6-23 20:14
做出來不對啊
可以的
ID:450793 發表于 2019-3-7 20:06 | 顯示全部樓層
謝謝樓主  很有用呢
ID:450793 發表于 2019-3-7 20:28 | 顯示全部樓層
請問樓主電阻都是多少Ω的呢? 原理圖中D20和D21之間的那個LED燈是什么呢  多的嗎?
ID:257960 發表于 2019-3-9 14:48 | 顯示全部樓層
焱淼 發表于 2019-3-7 20:28
不好意哈,多了忘記刪
ID:257960 發表于 2019-3-9 14:49 | 顯示全部樓層
電阻我用1k
ID:339180 發表于 2019-3-11 16:22 | 顯示全部樓層
截圖里兩條線沒連
ID:605918 發表于 2019-8-31 21:14 來自觸屏版 | 顯示全部樓層
燈是不是多了
主站蜘蛛池模板: 欧美三级三级三级爽爽爽 | 久久久久久久网 | 中文字幕免费在线看线人动作大片 | 亚洲免费一区二区 | 最近中文字幕在线 | 日韩一区二区在线视频 | 久热精品视频在线观看 | 亚洲欧美日韩一区二区三区四区 | 精品在线免费观看 | 日韩中文视频 | 欧美亚洲在线 | 成人欧美一区二区三区黑人孕妇 | 一级真人毛片 | 久久久成人免费视频 | 最新av在线 | 成人毛片在线 | 五月天黄色网址 | 久草网站 | 精品久久久久久久久久久久久 | 日韩毛片视频 | 久久天天躁狠狠躁夜夜躁2014 | 国产精品久久久久久久久久久久久 | 日韩av一区二区三区四区 | 国产欧美精品 | 一区二区在线看 | 亚洲69视频| 91福利在线视频 | 在线观看国产小视频 | 日日爱视频 | 毛片网站在线观看 | 性色av浪潮av| 色婷婷影视 | 欧美日韩一区二区三区视频 | 午夜爽爽影院 | 欧美午夜精品一区二区三区 | 三上悠亚一区二区 | 亚洲精品综合 | 国产精品www | 亚洲国产一区在线观看 | 国产精品1区2区3区 国产乱码精品一区二区三 成人区精品一区二区婷婷 www.欧美日韩 | 在线天堂av|
