查看: 3156|回復: 0
arduino_Uno_RevG-MU PCB板源文件
ID:326650 發表于 2018-5-10 11:09 | 顯示全部樓層 |閱讀模式
arduino PCB板
DesignSpark PCB Reference Design
Arduino UNO SMD (RS Part Number: 769-7409)
This  is a  reference design of Arduino UNO SMD. The Arduino UNO SMD was
converted  into  DesignSpark  PCB  format.  Download  link  of  the  project  files
and introduction of Arduino UNO SMD could be found in this datasheet.
The Arduino Uno  is a microcontroller board based on  the ATmega328.  It
contains  everything  needed  to  support  the  microcontroller;  simply
connect  it  to a computer with a USB cable or power  it with a AC-to-DC
adapter  or  battery  to  get  started.  The  Uno  differs  from  all  preceding
boards in that it does not use the FTDI USB-to-serial driver chip. Instead,
it  features  the  Atmega8U2  programmed  as  a  USB-to-serial  converter.
Two versions are available differing only  in  the MCU package style: DIP
or SMD. The Rev3 part has some minor pin changes.
  ATmega328 16MHz, 32KB Flash memory, 2KB
  SPI and IC bus support
  USB connector
  ICSP header
  Reset button
全部資料51hei下載地址:
1412855329103049.zip (790.38 KB, 下載次數: 11)
主站蜘蛛池模板: 日本少妇中文字幕 | 999在线视频 | 精品日韩在线 | 午夜伦理视频 | 日韩av专区 | 中文字幕在线看片 | 综合激情网站 | 国产福利在线 | 国产黄视频在线观看 | 久久久网| 久久精品一区二区三区四区 | 亚洲精品1| 亚洲欧美日韩国产 | 免费一区二区视频 | 欧美日韩一区二区在线观看 | 在线观看成人免费视频 | 精品久久久久久久久久久久久 | 欧美一级淫片免费视频魅影视频 | 日韩国产在线 | 天天干夜夜撸 | 免费毛片在线播放免费 | 一级片免费视频 | 一区二区欧美日韩 | 国产永久视频 | 亚洲视频一区在线观看 | 日韩专区中文字幕 | 久久99视频| 日韩精品在线看 | 黄色录像免费观看 | 天天插天天爽 | 日本在线视频一区 | 久久久久久国产 | 青青久久久 | 亚洲我射av | 福利在线看| 久久久久久久99 | 成人伊人网 | 一区在线观看 | 性生活网址 | 亚洲福利视频一区 | 黄色片网站免费 |
